Mon, Feb 24, 2020 2:57 AM
Just because something can be and has been implemented in user space (more than once, apparently) doesn’t mean it should be. :-) Some algorithms are just rather slow and buggy to reimplement in user space.
-Revar
Perhaps add a set of functions to OpenSCAD with the same names as the
boolean ops that take geometry as lists and return new lists. That would
allow everything to be done in user land harnessing clipper.
-Revar
> Hasn't someone done that, OpenSCAD modules etc rewritten in user-land?
> Found it! https://github.com/thehans/FunctionalOpenSCAD
> Admin - email* me if you need anything, or if I've done something stupid...
> * click on my MichaelAtOz label, there is a link to email me.
> Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above.
Mon, Feb 24, 2020 3:14 AM
The referenced github project has asitsgoal the implementation of
everything in user space. The actual state of the project, however, is that
nothing nontrivial has been implemented. The boolean operations and offset
are both listed under the future work section, along with hull and
minkowski.
One major challenge of implementing these sorts of functions in user space
is that the efficient algorithms typically require data structures that are
not available in OpenSCAD, or whose implementation will be so inefficient
that it wouldn't deliver the intended speed-up.
-Revar
stupid...
- click on my MichaelAtOz label, there is a link to email me.
The referenced github project has *as*its*goal* the implementation of
minkowski.
> -Revar
> oz.at.michael@
>> stupid...
> Discuss@.openscad
> Discuss@.openscad
HJ
Hugo Jackson
Mon, Feb 24, 2020 3:43 AM
my enthusiasm for exteneded 2d boolean functions isn’t about efficiency but the flexibility of being able to manipulate point defined objects after they’ve been modified with 2d boolean functions. as it stands, as soon as you surrender a polygon of your own creation to the existing functions you no longer have access to the underlying point definition.
Maybe there are ways around that, but I confess I’m not a power user by any means, but the possibility of built-in 2d operations that return point lists seems very attractive. i wouldn’t care if they were efficient… just that they could actually do the operations.
minkowski.
-Revar
stupid...
> minkowski.
>> -Revar
>> oz.at.michael@
>>> stupid...
>> Discuss@.openscad
>> Discuss@.openscad
Mon, Feb 24, 2020 4:03 AM
So you're willing to wait 24 hours for them to run?
that
offset
minkowski.
space
are
(more
are
-Revar
would
stupid...
that
offset
minkowski.
space
are
(more
are
-Revar
would
stupid...
> avm4@
>> that
>> offset
>> minkowski.
>> space
>> are
>>> (more
>>> are
>>> -Revar
>>> oz.at.michael@
>>>>> would
>>>> stupid...
>>> Discuss@.openscad
>>> Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
> avm4@
>> that
>> offset
>> minkowski.
>> space
>> are
>>> (more
>>> are
>>> -Revar
>>> oz.at.michael@
>>>>> would
>>>> stupid...
>>> Discuss@.openscad
>>> Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
HJ
Hugo Jackson
Mon, Feb 24, 2020 4:17 AM
well there’s always a tradeoff of course… and if you’re stating that any built in 2d boolean operation will take 24 hours to execute, then yes, I spoke too soon. On the other hand if the computational time is relative to the complexity of the object and that is what is time dependent then it would depend on the application. I’m led to believe than in our current palette the most computationally expensive function is minkowski… and depending on what you want to combine it can take hours and hours to run. Notwithstanding, I presume there are lots of people who use minkowski regardless of it’s execution speed because it provides them with functionality they require.
The purpose of my post was simply to identify that my enthusiasm for a point based 2d boolean function suite was not with a goal of greater efficiency, and that there may be other users like me for whom speed of computation would be at best a secondary concern.
that
offset
minkowski.
space
are
(more
are
-Revar
would
that
offset
minkowski.
space
are
(more
are
-Revar
would
stupid...
Sent from: http://forum.openscad.org/ http://forum.openscad.org/
>> avm4@
>>> that
>>> offset
>>> minkowski.
>>> space
>>> are
>>>> (more
>>>> are
>>>> -Revar
>>>> oz.at.michael@
>>>>>> would
>>>>> Found it! https://github.com/thehans/FunctionalOpenSCAD <https://github.com/thehans/FunctionalOpenSCAD>
>>>>> stupid...
>>>>> Sent from: http://forum.openscad.org/ <http://forum.openscad.org/>
>>>> Discuss@.openscad
>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org>
>>>> Discuss@.openscad
>> Discuss@.openscad
>> Discuss@.openscad
>> avm4@
>>> that
>>> offset
>>> minkowski.
>>> space
>>> are
>>>> (more
>>>> are
>>>> -Revar
>>>> oz.at.michael@
>>>>>> would
>>>>> stupid...
>>>> Discuss@.openscad
>>>> Discuss@.openscad
>> Discuss@.openscad
>> Discuss@.openscad
Mon, Feb 24, 2020 5:16 AM
Obviously run times will be dependent on input size. My user space offset()
code is O(n^2). A good offset is more like O(n log n). That means if you
have a lot of points, it's going to be a lot slower than the built-in
options at some point. I just tested running offset on circles and with
$fn=1000 my code takes 8s and native OpenSCAD takes 0s. For 4000 points
native OpenSCAD still takes 0s and my code takes 2 minutes. Too slow? Who
can say. With 10k points OpenSCAD native still runs in 0s. My code failed
after 13 minutes---probably something having to do with the very small
segment size. But hard to debug something that takes 13 minutes to
manifest. One thing I do with my offset() is call it from offset_sweep()
which needs to run offset for every layer in the swept polyhedron. So if
offset() takes 2 minutes and you want 100 layers you're now approaching 3
hours.
I'd use minkowski more if it was faster. One reason I wrote offset() was to
avoid minkowski. At least for my applications, I don't need a lot of
points. But my point is that the run time of these user space
implementations is potentially really slow, like a thousand times slower
than native OpenSCAD. And my algorithm is not as robust as I would like.
point
just
that
offset
minkowski.
space
are
inefficient
(more
are
-Revar
would
user-land?
stupid...
point
just
that
offset
minkowski.
space
are
inefficient
(more
are
-Revar
would
user-land?
stupid...
hours.
> avm4@
>>> point
>>> just
>>> avm4@
>>>> that
>>>> offset
>>>> minkowski.
>>>> space
>>>> are
>>>> inefficient
>>>>> (more
>>>>> are
>>>>> -Revar
>>>>> oz.at.michael@
>>>>> > wrote:
>>>>>>> the
>>>>>>> would
>>>>>> user-land?
>>>>>> stupid...
>>>>> Discuss@.openscad
>>>>> Discuss@.openscad
>>> Discuss@.openscad
>>> Discuss@.openscad
>>> point
>>> just
>>> avm4@
>>>> that
>>>> offset
>>>> minkowski.
>>>> space
>>>> are
>>>> inefficient
>>>>> (more
>>>>> are
>>>>> -Revar
>>>>> oz.at.michael@
>>>>> > wrote:
>>>>>>> the
>>>>>>> would
>>>>>> user-land?
>>>>>> stupid...
>>>>> Discuss@.openscad
>>>>> Discuss@.openscad
>>> Discuss@.openscad
>>> Discuss@.openscad
> Discuss@.openscad
> Discuss@.openscad
DE
David Eccles (gringer)
Mon, Feb 24, 2020 10:54 AM
Or add a function that returns the points that would be encoded in
a rendered version of its children
<http://forum.openscad.org/User-Poll-What-do-you-want-to-see-from-OpenSCAD-development-tp27802p27851.html>
, so that the point list can be generated after the /existing/ OpenSCAD
operations are carried out.
Mon, Feb 24, 2020 11:56 AM
to
You name it. Personally I implement stuff in user land only, when I can't
avoid sweep() / skin() to finish a design in a decent way; and then I don't
care about robustness and run time in the first hand, mainly because I am
not able to affort to do it for time. To say it with Pareto, you spend 80%
of the time for the remaining 20% of a task or even more.
Our current dilemma is: Once you cross the border to profit from a native
operation like a Boolean op or something like offset(), there is no way back
... and since no sweep/skin is available there, the only way to proceed is
to implement those ops in user land. Therefore, having sweep() / skin() in
native OpenSCAD, things would get much easier for us.
But I also understand that the dev team doesn't want to include unsafe
operations into OpenSCAD that can (und will, if not used with care)
potentially produce invalid results - besides polyhedron() which is unsafe
by its very nature (and lets us do all our nasty things).
On the other hand, I think that once the door has be opened towards this
kind of functionality in native OpenSCAD, it should also be manageable to
implement it in a way so that it offers a protected mode testing each
polygon in the input feed for self-intersection and against all others for
mutual intersection. For most of us it would be fine to live with an
unsafe implementation of sweep()/skin() and big red use at you own risk
sign in the wiki paired with a best practice documentation, as it can be
found for polyhedron().
> to
But I also understand that the dev team doesn't want to include *unsafe*
implement it in a way so that it offers a *protected* mode testing each
*unsafe* implementation of sweep()/skin() and big red *use at you own risk*
Mon, Feb 24, 2020 2:32 PM
I agree that Boolean operations, offset e minkovski of objects defined by
points has its own interested. However, my point when I started this thread
was the inefficiency of the projection() operator. I consider brute force
to approach the projection by simply joining polygons by Boolean union.
Something better would be expected but it seems that is the way OpenSCAD
does projection as you can see by this small example:
$fn=400;
tw=180;
sc=0.01;
projection()
union(){
linear_extrude(20,twist=tw,scale=sc)
circle(30);
mirror([0,0,1])
circle(30);
It took more than 7 min. in my computer to find a circle with 400 vertices
at the end. Even with tw=0 and sc=0.8, it required 8 sec.
I think the union of polygons is one of the worst strategy to projection
despite its conceptual simplicity. The border of the projection of a
polyhedron is contained in the projection of its vertical silhouette edges
namely and loosely those edges whose adjacent faces are one facing upward
and the other, downward. Usually the set of silhouette edges is a small
fraction of the total number. After finding the silhouette edges and
projecting them a sweep algorithm may be used to connect the segments and
define a polygon. To those that may be interested, here is a reference:
https://pdfs.semanticscholar.org/cb59/7ff8889e379db66f05a23bc4b5f76c4f019f.pdf
It is not an easy task to implement in OpenSCAD language but it would be
far easier and faster than polygon union. Anyway, I am not interested here
in native language implementations of projection but to have a faster
built-in one.
$fn=400;
tw=180;
sc=0.01;
projection()
union(){
circle(30);
mirror([0,0,1])
circle(30);
built-in one.
CA
Mon, Feb 24, 2020 5:21 PM
by points has its own interested. However, my point when I started this
thread was the inefficiency of the projection() operator. I consider
brute force to approach the projection by simply joining polygons by
Boolean union. Something better would be expected but it seems that is
the way OpenSCAD does projection as you can see by this small example:
$fn=400;
tw=180;
sc=0.01;
projection()
union(){
circle(30);
mirror([0,0,1])
circle(30);
vertices at the end. Even with tw=0 and sc=0.8, it required 8 sec.
The problem here is mostly the 3d boolean, less so projection(). I
installed openscad-nightly 2020.01.25 under Kubuntu 18.04 (32 GB RAM)
and ran a couple of tests
body1.scad
$fn=400;
tw=180;
sc=0.01;
circle(30);
This took virtually no time, exported to body1.stl and body1.off
body2.scad
$fn=400;
tw=180;
sc=0.01;
mirror([0,0,1])
circle(30);
Again, this took virtually no time, exported to body2.stl and body2.off
Union_b1b2.scad
import("body1.stl");
import("body2.stl");
The imports took 4 seconds, but the union took 3min, using 5 GB of
RAM... If you don't have a lot of RAM I guess it will take much longer.
This was exported to Union_b1b2.stl and Union_b1b2.off
Union_b1b2_projection.scad
projection()
import("Union_b1b2.stl");
This took 54s so about ~50s for projection
Although the projection() took some time (~30% of boolean union), the 3d
boolean is the main problem.
Running your original code as written took 4min 25s consuming 5 GB RAM
on my machine.
For comparison, I read the same data into AngelCAD:
Union_b1b2_ac.as
shape@ main_shape()
return polyhedron("body1.off") + polyhedron("body2.off");
This took 16.6 sec (including export to STL and OFF) consuming at most
2.1GB RAM
Union_b1b2_projection_ac.as
shape@ main_shape()
return projection2d(polyhedron("Union_b1b2.off"));
This took 52 sec (including export to DXF) consuming ~1.8GB RAM
So clearly, the projection() code in OpenSCAD and AngelCAD takes about
the same time for this model (~50s on my machine). By running 2d
booleans in threads I guess it can be made to run faster, but I am not
sure it is worth the effort.
The big difference is in 3d booleans.
> $fn=400;
> tw=180;
> sc=0.01;
> projection()
> union(){
> circle(30);
> mirror([0,0,1])
> circle(30);
body1.scad
$fn=400;
tw=180;
sc=0.01;
circle(30);
body2.scad
$fn=400;
tw=180;
sc=0.01;
mirror([0,0,1])
circle(30);
Union_b1b2.scad
RAM... If you don't have a lot of RAM I guess it will take *much* longer.
projection()
on my machine.
Union_b1b2_ac.as
shape@ main_shape()
2.1GB RAM
shape@ main_shape()
