is color an actual operator module ?
Tue, Dec 9, 2025 11:09 PM
It looks to me like the shorter URL forwards to the longer one.  I think
maybe the shorter one was the original URL and then Revar reorganized
things.
On Tue, Dec 9, 2025 at 6:05 PM Jordan Brown via Discuss <
On 12/9/2025 6:44 AM, Peter Kriens wrote:
I do not think https://github.com/revarbat/BOSL2 is the right URL to the
BOSL2 repo? I think it should be https://github.com/BelfrySCAD/BOSL2/ or
git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's private repo
that might run behind the actual one.
Yeah, I think you're right.  I don't know where I got that.  I think it's
what my copy is currently cloned from, but I don't know why.
It looks to me like the shorter URL forwards to the longer one. I think maybe the shorter one was the original URL and then Revar reorganized things. On Tue, Dec 9, 2025 at 6:05 PM Jordan Brown via Discuss < discuss@lists.openscad.org> wrote: > On 12/9/2025 6:44 AM, Peter Kriens wrote: > > I do not think https://github.com/revarbat/BOSL2 is the right URL to the > BOSL2 repo? I think it should be https://github.com/BelfrySCAD/BOSL2/ or > git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's private repo > that might run behind the actual one. > > > Yeah, I think you're right. I don't know where I got that. I think it's > what my copy is currently cloned from, but I don't know why. > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
JJ
jon jonbondy.com
Wed, Dec 10, 2025 12:06 AM
That discussion puts versioning of major operating systems into perspective!
On 12/9/2025 5:58 PM, Jordan Brown wrote:
On 12/9/2025 5:28 AM, Jon Bondy via Discuss wrote:
It is interesting to me that, after decades, GitHub has not come up
with a way to calculate and display version information that actually
works.
Version identification in  a distributed source code control system is
... unobvious.
I pull a clone, and make some changes.  What version is it?
You pull a clone, and make some changes.  What version is it?
I pull from you, rebase my changes on top of yours, and make some more
Fred separately pulls my first set of changes (but not my second), and
your first set of changes, adds some of his own, and pushes that back
to the original repo.  What version is that?
Fred rebases all of those changes together, and force pushes it. What
version is that?
You could consider the commit time of the most recent changeset. But
what about branches?  There could be a brand new commit today against
last year's branch... it's the newest thing on that branch, but far
older than the main branch.  Maybe the branch plus the timestamp of
the last commit?  But then there's rebasing and forced pushes.
The changeset ID uniquely identifies the entire state of the
repository, but tells you nothing at all about the timing or history.
About all you can say is "these two repos are the same".
The only thing that's a true and complete identifier, and sort of
orderable, is the entire version history, but even that isn't really
enough when you consider the possibility of rewriting history.
That discussion puts versioning of major operating systems into perspective! On 12/9/2025 5:58 PM, Jordan Brown wrote: > On 12/9/2025 5:28 AM, Jon Bondy via Discuss wrote: >> It is interesting to me that, after decades, GitHub has not come up >> with a way to calculate and display version information that actually >> works. > > Version identification in  a distributed source code control system is > ... unobvious. > > I pull a clone, and make some changes.  What version is it? > You pull a clone, and make some changes.  What version is it? > I pull from you, rebase my changes on top of yours, and make some more > changes.  What version is it? > Fred separately pulls my first set of changes (but not my second), and > your first set of changes, adds some of his own, and pushes that back > to the original repo.  What version is that? > Fred rebases all of those changes together, and force pushes it. What > version is that? > > You could consider the commit time of the most recent changeset. But > what about branches?  There could be a brand new commit today against > last year's branch... it's the newest thing on that branch, but far > older than the main branch.  Maybe the branch plus the timestamp of > the last commit?  But then there's rebasing and forced pushes. > > The changeset ID uniquely identifies the entire state of the > repository, but tells you nothing at all about the timing or history.  > About all you can say is "these two repos are the same". > The only thing that's a true and complete identifier, and sort of > orderable, is the entire version history, but even that isn't really > enough when you consider the possibility of rewriting history. >
Wed, Dec 10, 2025 1:53 AM
Operating system versioning is hard, especially because it interacts
with marketing.  (Major versions are good because they show that you are
innovative and doing big stuff.  Major versions are bad because nobody
trusts compatibility across major versions and so it's hard to get
people to adopt them.)
But versioning a distributed project makes that look easy.  (And,
speaking as somebody in OS development... we have those problems too,
internally.  In my org, the major way we keep the versioning complexity
sort of under control is that, other than external releases, the only
thing that matters is the mainline build number.  Nothing that happens
in a developer's repo or a team's local repo has any sort of formal
versioning, other than a name and a timestamp.)
On 12/9/2025 4:06 PM, jon jonbondy.com wrote: > That discussion puts versioning of major operating systems into perspective! Operating system versioning is hard, especially because it interacts with marketing.  (Major versions are good because they show that you are innovative and doing big stuff.  Major versions are bad because nobody trusts compatibility across major versions and so it's hard to get people to adopt them.) But versioning a distributed project makes that look easy.  (And, speaking as somebody in OS development... we have those problems too, internally.  In my org, the major way we keep the versioning complexity sort of under control is that, other than external releases, the only thing that matters is the mainline build number.  Nothing that happens in a developer's repo or a team's local repo has any sort of formal versioning, other than a name and a timestamp.)
Wed, Dec 10, 2025 5:03 AM
On Tue, 2025-12-09 at 17:12 -0500, Adrian Mariano via Discuss wrote:
Not sure what you're seeing with Peter's code.  First of all, be
aware that the entire thing is one code block, so the diff() applies
to the entire block.  The "inside" in attach_part refers to the
inside part of the parent object.  The parent object is tube() and
tubes happen to have a part called "inside" which is the inside
surface of the tube.  In contrast, the "tube" description obtained by
tube=parent() refers to the outside of the tube, since it was created
before selecting the "inside" part.
OK... I wondered, because when I tried changing diff() to difference()
I got the ring and a rod that extended beyond the outer part of the
ring.
I'm not sure what you see since your text was incomplete and there is
no pic.  If I remove the second section starting with "restore(tube)"
then I get a ring with a solid cylinder running across the interior.
 The removed section is responsible for hollowing out the tube that
runs across the inside of the ring.
Ahh. I see it now. Thanks for your patience.
On Tue, Dec 9, 2025 at 3:05 PM larry via Discuss
On Tue, 2025-12-09 at 08:13 -0500, Adrian Mariano via Discuss
There is a way to query the BOSL2 version. Sadly it doesn’t
produce a
useful result. Revar tried to configure GitHub to automatically
increment a version variable when new code was merged but this
turned
out to create a bunch of problems and he eventually backed out
that
feature. The version variable still exists but it’s not being
incremented.
That's OK. I solved the problem by getting rid of the second BOSL2
in a
different library directory.
I mentioned that I have questions about Peter's code.
It looks like the code from diff) to the closing parenthesis after
filet=1, defines the solid tube, but if I comment out everything
after
that, I don't see a solid tube, but only a . As a test, I changed
diff() to difference(), and there it is. So far, I think I sort of
understand most of it, except for wondering what the "inside"
refers
to.
On Mon, Dec 8, 2025 at 22:57 larry via Discuss
On Mon, 2025-12-08 at 19:59 -0500, Adrian Mariano via Discuss
If you get unknown module for attach_part then your BOSL2 is
still
not updated.  You need to figure that out.  The code is
correct
and
produces the image Peter showed.
Is there a way to query the rev level of BOSL2?
On Mon, Dec 8, 2025 at 7:15 PM larry via Discuss
On Mon, 2025-12-08 at 16:37 -0500, Adrian Mariano via
Discuss
larry, sounds like you need to update your BOSL2.  The
attach_part()
feature is fairly new.
I did, but I put  it in the wrong place. It's there now,
but
Peter's
code still gives me the unknown module error for
attach_part.
I think there's more to it. The code really doesn't look
right.
I guess I'll try the attachment tutorial.
$fn= $preview ? 60 : 180;
diff()
 tube( id=50, h = 10, rounding=1, wall=2) // the ring
 let(tube=parent())
 attach_part("inside")
 prism_connector(      // the solid tube on the inside of
     circle(d=7),      // the ring
     parent(), LEFT,
     parent(), RIGHT,
     fillet=1
 restore(tube)
 tag("remove")
 prism_connector(       // the inside of the tubewith
     circle(d=5),       // exit on the outside of the ring
     parent(), LEFT,
     parent(), RIGHT,
     fillet=1
On Mon, Dec 8, 2025 at 11:06 AM larry via Discuss
On Thu, 2025-08-14 at 10:58 +0200, Peter Kriens via
Discuss
Maybe if you're purely data driven?
What I like about the attachment model is how you
never
have
to
figure out positions. Worst case a shift from a well
known
position
relative to another object. You can get highly
complex
components
and
easily change major parts without having to refactor
and
recalculate
a lot. Positions then quickly become complex to
calculate
when
objects are at angles. I learned that for injection
molding
everything is slightly angled to allow the release of
mold
but it
means there are never any easy modulo 90 degree
angles.
(The
rounded_prism() is my hero).
The absolute crown enabled by the attachment model is
however,
prism_connector ...
When I try this one, it doesn't understand
"attach_part()".
I
could
not
find it in BOSL2.
diff()
tube( id=50, h = 10, rounding=1, wall=2)// the ring
let(tube=parent())
tube
on
inside of
    parent(), LEFT,
    parent(), RIGHT,
    fillet=1
restore(tube)
tag("remove")
of
tube
with
outside
of
the ring
    parent(), LEFT,
    parent(), RIGHT,
    fillet=1
For me the attachment model of BOSL2 is the main
reason I
did
not
dive into Python. It is absolute stunning, it is now
hard
for
me
to
believe you can make complex modular components
without
them.
       Peter Kriens
On 13 Aug 2025, at 20:46, Leonard Martin Struttmann
via
Discuss
That's good, and very efficient for designs of that
type.
However, it's been years since I designed any
models of
that
type.
The vast majority of my designs (models of existing
printed
circuit
boards) consists of placing cubes and cylinders at
known
distances
from the origin.  And it's all table-driven. In my
workflow, I
never place a shape in reference to an existing
shape.
On Wed, Aug 13, 2025 at 11:40 AM Jordan Brown
On 8/13/2025 4:32 AM, Leonard Martin Struttmann
via
Discuss
However, I have yet to find a use-case in my
projects
where
attachments are easier than the native
translate()/rotate()
OpenSCAD primitives.
Quick:  build a cube with a cylinder sticking out
of
right
side.
cube(10) attach(RIGHT) cylinder(h=10, r=3);
Yes, you can do that with rotate and translate.
(Or
is
it
translate and rotate?)
How about if the cylinder is sticking out the
corner
of
cube?
cube(10) attach(RIGHT+FRONT+TOP) cylinder(h=10,
r=3);
Now put a sphere at the end of the cylinder, with
sphere
barely touching the cylinder:
cube(10)
    attach(TOP, BOTTOM) sphere(r=3);
Versus:
cubesz = 10;
cylh = 10;
spherer = 3;
cube(cubesz);
translate([cubesz, cubesz/2, cubesz/2])
rotate([0,90,0]) {
    cylinder(h=cylh, r=3);
    translate([0,0,cylh + spherer])
        sphere(r=spherer);
Note:  I didn't need the variables, but I did
if I
wanted
to
avoid duplicating the numbers.
On Tue, 2025-12-09 at 17:12 -0500, Adrian Mariano via Discuss wrote: > Not sure what you're seeing with Peter's code.  First of all, be > aware that the entire thing is one code block, so the diff() applies > to the entire block.  The "inside" in attach_part refers to the > inside part of the parent object.  The parent object is tube() and > tubes happen to have a part called "inside" which is the inside > surface of the tube.  In contrast, the "tube" description obtained by > tube=parent() refers to the outside of the tube, since it was created > before selecting the "inside" part.   OK... I wondered, because when I tried changing diff() to difference() I got the ring and a rod that extended beyond the outer part of the ring. > I'm not sure what you see since your text was incomplete and there is > no pic.  If I remove the second section starting with "restore(tube)" > then I get a ring with a solid cylinder running across the interior.  >  The removed section is responsible for hollowing out the tube that > runs across the inside of the ring.   Ahh. I see it now. Thanks for your patience. > On Tue, Dec 9, 2025 at 3:05 PM larry via Discuss > <discuss@lists.openscad.org> wrote: > > On Tue, 2025-12-09 at 08:13 -0500, Adrian Mariano via Discuss > > wrote: > > > There is a way to query the BOSL2 version. Sadly it doesn’t > > > produce a > > > useful result. Revar tried to configure GitHub to automatically > > > increment a version variable when new code was merged but this > > > turned > > > out to create a bunch of problems and he eventually backed out > > > that > > > feature. The version variable still exists but it’s not being > > > incremented.  > > > > That's OK. I solved the problem by getting rid of the second BOSL2 > > in a > > different library directory. > > > > I mentioned that I have questions about Peter's code. > > > > It looks like the code from diff) to the closing parenthesis after > > filet=1, defines the solid tube, but if I comment out everything > > after > > that, I don't see a solid tube, but only a . As a test, I changed > > diff() to difference(), and there it is. So far, I think I sort of > > understand most of it, except for wondering what the "inside" > > refers > > to. > > > > > On Mon, Dec 8, 2025 at 22:57 larry via Discuss > > > <discuss@lists.openscad.org> wrote: > > > > On Mon, 2025-12-08 at 19:59 -0500, Adrian Mariano via Discuss > > > > wrote: > > > > > If you get unknown module for attach_part then your BOSL2 is > > > > > still > > > > > not updated.  You need to figure that out.  The code is > > > > > correct > > > > > and > > > > > produces the image Peter showed.   > > > > > > > > Is there a way to query the rev level of BOSL2? > > > > > > > > > On Mon, Dec 8, 2025 at 7:15 PM larry via Discuss > > > > > <discuss@lists.openscad.org> wrote: > > > > > > On Mon, 2025-12-08 at 16:37 -0500, Adrian Mariano via > > > > > > Discuss > > > > > > wrote: > > > > > > > larry, sounds like you need to update your BOSL2.  The > > > > > > > attach_part() > > > > > > > feature is fairly new.   > > > > > > > > > > > > I did, but I put  it in the wrong place. It's there now, > > > > > > but > > > > > > Peter's > > > > > > code still gives me the unknown module error for > > > > > > attach_part. > > > > > > I think there's more to it. The code really doesn't look > > > > > > right. > > > > > > > > > > > > I guess I'll try the attachment tutorial. > > > > > > > > > > > > //---- > > > > > > include <BOSL2/std.scad> > > > > > > $fn= $preview ? 60 : 180; > > > > > > > > > > > > diff() > > > > > >  tube( id=50, h = 10, rounding=1, wall=2) // the ring > > > > > >  let(tube=parent()) > > > > > >  attach_part("inside") > > > > > >  prism_connector(      // the solid tube on the inside of > > > > > >      circle(d=7),      // the ring > > > > > >      parent(), LEFT, > > > > > >      parent(), RIGHT, > > > > > >      fillet=1 > > > > > >  ) > > > > > >  restore(tube) > > > > > >  tag("remove") > > > > > >  prism_connector(       // the inside of the tubewith > > > > > >      circle(d=5),       // exit on the outside of the ring > > > > > >      parent(), LEFT, > > > > > >      parent(), RIGHT, > > > > > >      fillet=1 > > > > > >  ); > > > > > > //---- > > > > > > > > > > > > > On Mon, Dec 8, 2025 at 11:06 AM larry via Discuss > > > > > > > <discuss@lists.openscad.org> wrote: > > > > > > > > On Thu, 2025-08-14 at 10:58 +0200, Peter Kriens via > > > > > > > > Discuss > > > > > > > > wrote: > > > > > > > > > Maybe if you're purely data driven?  > > > > > > > > > > > > > > > > > > What I like about the attachment model is how you > > > > > > > > > never > > > > > > > > > have > > > > > > > > > to > > > > > > > > > figure out positions. Worst case a shift from a well > > > > > > > > > known > > > > > > > > > position > > > > > > > > > relative to another object. You can get highly > > > > > > > > > complex > > > > > > > > > components > > > > > > > > > and > > > > > > > > > easily change major parts without having to refactor > > > > > > > > > and > > > > > > > > > recalculate > > > > > > > > > a lot. Positions then quickly become complex to > > > > > > > > > calculate > > > > > > > > > when > > > > > > > > > the > > > > > > > > > objects are at angles. I learned that for injection > > > > > > > > > molding > > > > > > > > > everything is slightly angled to allow the release of > > > > > > > > > the > > > > > > > > > mold > > > > > > > > > but it > > > > > > > > > means there are never any easy modulo 90 degree > > > > > > > > > angles. > > > > > > > > > (The > > > > > > > > > rounded_prism() is my hero). > > > > > > > > > > > > > > > > > > The absolute crown enabled by the attachment model is > > > > > > > > > however, > > > > > > > > > the > > > > > > > > > prism_connector ... > > > > > > > > > > > > > > > > > > PastedGraphic-3.png > > > > > > > > > > > > > > > > When I try this one, it doesn't understand > > > > > > > > "attach_part()". > > > > > > > > I > > > > > > > > could > > > > > > > > not > > > > > > > > find it in BOSL2. > > > > > > > > > > > > > > > > > > diff() > > > > > > > > > > tube( id=50, h = 10, rounding=1, wall=2)// the ring > > > > > > > > > > let(tube=parent())  > > > > > > > > > > attach_part("inside") > > > > > > > > > > prism_connector(                    // the solid > > > > > > > > > > tube > > > > > > > > > > on > > > > > > > > > > the > > > > > > > > > > inside of > > > > > > > > > >     circle(d=7),                    // the ring > > > > > > > > > >     parent(), LEFT, > > > > > > > > > >     parent(), RIGHT, > > > > > > > > > >     fillet=1 > > > > > > > > > > ) > > > > > > > > > > restore(tube) > > > > > > > > > > tag("remove") > > > > > > > > > > prism_connector(                    // the inside > > > > > > > > > > of > > > > > > > > > > the > > > > > > > > > > tube > > > > > > > > > > with  > > > > > > > > > >     circle(d=5),                    // exit on the > > > > > > > > > > outside > > > > > > > > > > of > > > > > > > > > > the ring > > > > > > > > > >     parent(), LEFT, > > > > > > > > > >     parent(), RIGHT, > > > > > > > > > >     fillet=1 > > > > > > > > > > ) > > > > > > > > > > ; > > > > > > > > > > > > > > > > > > > > > > > > > > > For me the attachment model of BOSL2 is the main > > > > > > > > > reason I > > > > > > > > > did > > > > > > > > > not > > > > > > > > > dive into Python. It is absolute stunning, it is now > > > > > > > > > hard > > > > > > > > > for > > > > > > > > > me > > > > > > > > > to > > > > > > > > > believe you can make complex modular components > > > > > > > > > without > > > > > > > > > them. > > > > > > > > > > > > > > > > > >        Peter Kriens > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > On 13 Aug 2025, at 20:46, Leonard Martin Struttmann > > > > > > > > > > via > > > > > > > > > > Discuss > > > > > > > > > > <discuss@lists.openscad.org> wrote: > > > > > > > > > > > > > > > > > > > > That's good, and very efficient for designs of that > > > > > > > > > > type. > > > > > > > > > > > > > > > > > > > > However, it's been years since I designed any > > > > > > > > > > models of > > > > > > > > > > that > > > > > > > > > > type.  > > > > > > > > > > The vast majority of my designs (models of existing > > > > > > > > > > printed > > > > > > > > > > circuit > > > > > > > > > > boards) consists of placing cubes and cylinders at > > > > > > > > > > known > > > > > > > > > > distances > > > > > > > > > > from the origin.  And it's all table-driven. In my > > > > > > > > > > workflow, I > > > > > > > > > > never place a shape in reference to an existing > > > > > > > > > > shape. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > On Wed, Aug 13, 2025 at 11:40 AM Jordan Brown > > > > > > > > > > <openscad@jordan.maileater.net> wrote: > > > > > > > > > > > On 8/13/2025 4:32 AM, Leonard Martin Struttmann > > > > > > > > > > > via > > > > > > > > > > > Discuss > > > > > > > > > > > wrote: > > > > > > > > > > >   > > > > > > > > > > > > However, I have yet to find a use-case in my > > > > > > > > > > > > projects > > > > > > > > > > > > where > > > > > > > > > > > > attachments are easier than the native > > > > > > > > > > > > translate()/rotate() > > > > > > > > > > > > OpenSCAD primitives. > > > > > > > > > > > > > > > > > > > > > > Quick:  build a cube with a cylinder sticking out > > > > > > > > > > > of > > > > > > > > > > > the > > > > > > > > > > > right > > > > > > > > > > > side. > > > > > > > > > > >   > > > > > > > > > > > > include <BOSL2/std.scad> > > > > > > > > > > > > > > > > > > > > > > > > cube(10) attach(RIGHT) cylinder(h=10, r=3); > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yes, you can do that with rotate and translate.  > > > > > > > > > > > (Or > > > > > > > > > > > is > > > > > > > > > > > it > > > > > > > > > > > translate and rotate?) > > > > > > > > > > > How about if the cylinder is sticking out the > > > > > > > > > > > corner > > > > > > > > > > > of > > > > > > > > > > > the > > > > > > > > > > > cube? > > > > > > > > > > >   > > > > > > > > > > > > include <BOSL2/std.scad> > > > > > > > > > > > > > > > > > > > > > > > > cube(10) attach(RIGHT+FRONT+TOP) cylinder(h=10, > > > > > > > > > > > > r=3); > > > > > > > > > > > > > > > > > > > > > > Now put a sphere at the end of the cylinder, with > > > > > > > > > > > the > > > > > > > > > > > sphere > > > > > > > > > > > barely touching the cylinder: > > > > > > > > > > >   > > > > > > > > > > > > include <BOSL2/std.scad> > > > > > > > > > > > > > > > > > > > > > > > > cube(10) > > > > > > > > > > > >     attach(RIGHT) cylinder(h=10, r=3) > > > > > > > > > > > >     attach(TOP, BOTTOM) sphere(r=3); > > > > > > > > > > > > > > > > > > > > > > Versus: > > > > > > > > > > >   > > > > > > > > > > > > cubesz = 10; > > > > > > > > > > > > cylh = 10; > > > > > > > > > > > > spherer = 3; > > > > > > > > > > > > cube(cubesz); > > > > > > > > > > > > translate([cubesz, cubesz/2, cubesz/2]) > > > > > > > > > > > > rotate([0,90,0]) { > > > > > > > > > > > >     cylinder(h=cylh, r=3); > > > > > > > > > > > >     translate([0,0,cylh + spherer]) > > > > > > > > > > > >         sphere(r=spherer); > > > > > > > > > > > > } > > > > > > > > > > > > > > > > > > > > > > Note:  I didn't *need* the variables, but I did > > > > > > > > > > > if I > > > > > > > > > > > wanted > > > > > > > > > > > to > > > > > > > > > > > avoid duplicating the numbers. > > > > > > > > > > >   > > > > > > > > > > > > > > > > > > > > > _______________________________________________ > > > > > > > > > > OpenSCAD mailing list > > > > > > > > > > To unsubscribe send an email to > > > > > > > > > > discuss-leave@lists.openscad.org > > > > > > > > > > > > > > > > > > _______________________________________________ > > > > > > > > > OpenSCAD mailing list > > > > > > > > > To unsubscribe send an email to > > > > > > > > > discuss-leave@lists.openscad.org > > > > > > > > _______________________________________________ > > > > > > > > OpenSCAD mailing list > > > > > > > > To unsubscribe send an email to > > > > > > > > discuss-leave@lists.openscad.org > > > > > > > _______________________________________________ > > > > > > > OpenSCAD mailing list > > > > > > > To unsubscribe send an email to > > > > > > > discuss-leave@lists.openscad.org > > > > > > _______________________________________________ > > > > > > OpenSCAD mailing list > > > > > > To unsubscribe send an email to > > > > > > discuss-leave@lists.openscad.org > > > > > _______________________________________________ > > > > > OpenSCAD mailing list > > > > > To unsubscribe send an email to > > > > > discuss-leave@lists.openscad.org > > > > _______________________________________________ > > > > OpenSCAD mailing list > > > > To unsubscribe send an email to > > > > discuss-leave@lists.openscad.org > > > _______________________________________________ > > > OpenSCAD mailing list > > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Dec 10, 2025 10:40 AM
NopScadLib uses semantic versioning and every push I do has a new version
tag. Obviously doesn't work with forks though but it does make it clear
what sort of changes have been made.
On Wed, 10 Dec 2025, 01:53 Jordan Brown via Discuss, <
to adopt them.)
and a timestamp.)
NopScadLib uses semantic versioning and every push I do has a new version tag. Obviously doesn't work with forks though but it does make it clear what sort of changes have been made. On Wed, 10 Dec 2025, 01:53 Jordan Brown via Discuss, < discuss@lists.openscad.org> wrote: > On 12/9/2025 4:06 PM, jon jonbondy.com wrote: > > That discussion puts versioning of major operating systems into perspective! > > > Operating system versioning is hard, especially because it interacts with > marketing. (Major versions are good because they show that you are > innovative and doing big stuff. Major versions are bad because nobody > trusts compatibility across major versions and so it's hard to get people > to adopt them.) > > But versioning a distributed project makes that look easy. (And, speaking > as somebody in OS development... we have those problems too, internally. > In my org, the major way we keep the versioning complexity sort of under > control is that, other than external releases, the only thing that matters > is the mainline build number. Nothing that happens in a developer's repo > or a team's local repo has any sort of formal versioning, other than a name > and a timestamp.) > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
PK
Peter Kriens
Wed, Dec 10, 2025 11:07 AM
On 9 Dec 2025, at 15:51, Jon Bondy jon@jonbondy.com wrote:
Peter:
Jordan's process appears to have worked for me.
That might be pure luck  :-)
The master repository is https://github.com/BelfrySCAD/BOSL2/
Revar is a very active developer so it is likely he often synchronizes with the master repository so they will most of the time be the same. However, this way it is easy to run a few days behind and when he is on vacation you might run behind weeks.
If in the future there is a similar problem, using the wrong URL now is bound to cost you a couple of hours then.
Peter
On 12/9/2025 9:44 AM, Peter Kriens via Discuss wrote:
I do not think https://github.com/revarbat/BOSL2 https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_revarbat_BOSL2&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=jGG7WzByI3vJ25Rak3r8Tza14ME7SQ7Q_zdOM0rYa8g&e= is the right URL to the BOSL2 repo? I think it should be https://github.com/BelfrySCAD/BOSL2/ https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_BelfrySCAD_BOSL2_&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=mVfm6DS8-FxMYoRIhpud6g2qvF9Ym4kYBQCjv-YkxtY&e= or git@github.com:BelfrySCAD/BOSL2.git mailto:git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's private repo that might run behind the actual one.
I actually make every project a Github repository and use dependencies like BOSL2 as a submodule. I too often experienced that if a library was updated it killed my code. Having a submodule for a project leeps the version the same as you worked on until you explicitly update it. And updates are completely independent on other projects.
Peter
On 9 Dec 2025, at 06:07, Jordan Brown via Discuss discuss@lists.openscad.org mailto:discuss@lists.openscad.org wrote:
I use "git" to manage my BOSL2 installation.
I went to the OpenSCAD/libraries directory, and I said "git clone https://github.com/revarbat/BOSL2 https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_revarbat_BOSL2&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=jGG7WzByI3vJ25Rak3r8Tza14ME7SQ7Q_zdOM0rYa8g&e=".  That gave me a BOSL2 installation.
Later, I go to that OpenSCAD/libraries/BOSL2 directory and say "git pull", and it updates my BOSL2 installation.
I think I got my git for Windows here: https://git-scm.com/install/windows https://urldefense.proofpoint.com/v2/url?u=https-3A__git-2Dscm.com_install_windows&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=Y3imy70E5DM25MqJETKAfOZlGET4K3rnigoCv1qttlc&e= but you could presumably use one of the GUIs similarly, assuming that it will let you put your worktree wherever you want to.
> On 9 Dec 2025, at 15:51, Jon Bondy <jon@jonbondy.com> wrote: > Peter: > > Jordan's process appears to have worked for me. > That might be pure luck :-) The master repository is https://github.com/BelfrySCAD/BOSL2/ Revar is a very active developer so it is likely he often synchronizes with the master repository so they will most of the time be the same. However, this way it is easy to run a few days behind and when he is on vacation you might run behind weeks. If in the future there is a similar problem, using the wrong URL now is bound to cost you a couple of hours then. Peter > Jon > > > > On 12/9/2025 9:44 AM, Peter Kriens via Discuss wrote: >> I do not think https://github.com/revarbat/BOSL2 <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_revarbat_BOSL2&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=jGG7WzByI3vJ25Rak3r8Tza14ME7SQ7Q_zdOM0rYa8g&e=> is the right URL to the BOSL2 repo? I think it should be https://github.com/BelfrySCAD/BOSL2/ <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_BelfrySCAD_BOSL2_&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=mVfm6DS8-FxMYoRIhpud6g2qvF9Ym4kYBQCjv-YkxtY&e=> or git@github.com:BelfrySCAD/BOSL2.git <mailto:git@github.com:BelfrySCAD/BOSL2.git> I think you use Revar's private repo that might run behind the actual one. >> >> I actually make every project a Github repository and use dependencies like BOSL2 as a submodule. I too often experienced that if a library was updated it killed my code. Having a submodule for a project leeps the version the same as you worked on until you explicitly update it. And updates are completely independent on other projects. >> >> Peter >> >> >>> On 9 Dec 2025, at 06:07, Jordan Brown via Discuss <discuss@lists.openscad.org> <mailto:discuss@lists.openscad.org> wrote: >>> >>> I use "git" to manage my BOSL2 installation. >>> >>> I went to the OpenSCAD/libraries directory, and I said "git clone https://github.com/revarbat/BOSL2 <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_revarbat_BOSL2&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=jGG7WzByI3vJ25Rak3r8Tza14ME7SQ7Q_zdOM0rYa8g&e=>". That gave me a BOSL2 installation. >>> >>> Later, I go to that OpenSCAD/libraries/BOSL2 directory and say "git pull", and it updates my BOSL2 installation. >>> >>> I think I got my git for Windows here: https://git-scm.com/install/windows <https://urldefense.proofpoint.com/v2/url?u=https-3A__git-2Dscm.com_install_windows&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=Y3imy70E5DM25MqJETKAfOZlGET4K3rnigoCv1qttlc&e=> but you could presumably use one of the GUIs similarly, assuming that it will let you put your worktree wherever you want to. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org <mailto:discuss-leave@lists.openscad.org> > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> Virus-free.www.avg.com <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> <x-msg://16/#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Wed, Dec 10, 2025 12:18 PM
In my web browser if I visit https://github.com/revarbat/BOSL2 it forwards
to https://github.com/BelfrySCAD/BOSL2 so I'm pretty sure the two things
are going to give the same result.
On Wed, Dec 10, 2025 at 6:07 AM Peter Kriens via Discuss <
Peter:
Peter
or git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's private
Peter
In my web browser if I visit https://github.com/revarbat/BOSL2 it forwards to https://github.com/BelfrySCAD/BOSL2 so I'm pretty sure the two things are going to give the same result. On Wed, Dec 10, 2025 at 6:07 AM Peter Kriens via Discuss < discuss@lists.openscad.org> wrote: > On 9 Dec 2025, at 15:51, Jon Bondy <jon@jonbondy.com> wrote: > > Peter: > > Jordan's process appears to have worked for me. > > That might be pure luck :-) > > The master repository is https://github.com/BelfrySCAD/BOSL2/ > > Revar is a very active developer so it is likely he often synchronizes > with the master repository so they will most of the time be the same. > However, this way it is easy to run a few days behind and when he is on > vacation you might run behind weeks. > > If in the future there is a similar problem, using the wrong URL now is > bound to cost you a couple of hours then. > > Peter > > Jon > > > On 12/9/2025 9:44 AM, Peter Kriens via Discuss wrote: > > I do not think https://github.com/revarbat/BOSL2 > <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_revarbat_BOSL2&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=jGG7WzByI3vJ25Rak3r8Tza14ME7SQ7Q_zdOM0rYa8g&e=> is > the right URL to the BOSL2 repo? I think it should be > https://github.com/BelfrySCAD/BOSL2/ > <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_BelfrySCAD_BOSL2_&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=mVfm6DS8-FxMYoRIhpud6g2qvF9Ym4kYBQCjv-YkxtY&e=> > or git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's private > repo that might run behind the actual one. > > I actually make every project a Github repository and use dependencies > like BOSL2 as a submodule. I too often experienced that if a library was > updated it killed my code. Having a submodule for a project leeps the > version the same as you worked on until you explicitly update it. And > updates are completely independent on other projects. > > Peter > > > On 9 Dec 2025, at 06:07, Jordan Brown via Discuss > <discuss@lists.openscad.org> <discuss@lists.openscad.org> wrote: > > I use "git" to manage my BOSL2 installation. > > I went to the OpenSCAD/libraries directory, and I said "git clone > https://github.com/revarbat/BOSL2 > <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_revarbat_BOSL2&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=jGG7WzByI3vJ25Rak3r8Tza14ME7SQ7Q_zdOM0rYa8g&e=>". > That gave me a BOSL2 installation. > > Later, I go to that OpenSCAD/libraries/BOSL2 directory and say "git pull", > and it updates my BOSL2 installation. > > I think I got my git for Windows here: https://git-scm.com/install/windows > <https://urldefense.proofpoint.com/v2/url?u=https-3A__git-2Dscm.com_install_windows&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=wSuymtCTYeYZuOULTBFKlna9lWEWQvheoG3oEd1kCXjGDHLhSdvzyAUdqGCNIm7x&s=Y3imy70E5DM25MqJETKAfOZlGET4K3rnigoCv1qttlc&e=> > but you could presumably use one of the GUIs similarly, assuming that it > will let you put your worktree wherever you want to. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > Virus-free.www.avg.com > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Dec 10, 2025 1:41 PM
Is there any downside to using a script running daily with cron, to
update BOSL2?
Peter:
Peter
Peter
clone https://github.com/revarbat/BOSL2".  That gave me a
BOSL2 installation.
https://git-scm.com/install/windows but you could presumably
On Wed, 2025-12-10 at 07:18 -0500, Adrian Mariano via Discuss wrote: > In my web browser if I visit https://github.com/revarbat/BOSL2 it > forwards to https://github.com/BelfrySCAD/BOSL2 so I'm pretty sure > the two things are going to give the same result.   Is there any downside to using a script running daily with cron, to update BOSL2? > On Wed, Dec 10, 2025 at 6:07 AM Peter Kriens via Discuss > <discuss@lists.openscad.org> wrote: > > > On 9 Dec 2025, at 15:51, Jon Bondy <jon@jonbondy.com> wrote: > > > Peter: > > > Jordan's process appears to have worked for me. > > That might be pure luck  :-) > > > > The master repository is https://github.com/BelfrySCAD/BOSL2/ > > > > Revar is a very active developer so it is likely he often > > synchronizes with the master repository so they will most of the > > time be the same. However, this way it is easy to run a few days > > behind and when he is on vacation you might run behind weeks. > > > > If in the future there is a similar problem, using the wrong URL > > now is bound to cost you a couple of hours then. > > > > Peter > > > Jon > > > > > > On 12/9/2025 9:44 AM, Peter Kriens via Discuss wrote: > > >   > > > >  I do not think https://github.com/revarbat/BOSL2 is the right > > > > URL to the BOSL2 repo? I think it should > > > > be https://github.com/BelfrySCAD/BOSL2/ or  > > > > git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's > > > > private repo that might run behind the actual one. > > > > > > > > I actually make every project a Github repository and use > > > > dependencies like BOSL2 as a submodule. I too often experienced > > > > that if a library was updated it killed my code. Having a > > > > submodule for a project leeps the version the same as you > > > > worked on until you explicitly update it. And updates are > > > > completely independent on other projects. > > > > > > > > Peter > > > > > > > > > > > >   > > > > > On 9 Dec 2025, at 06:07, Jordan Brown via Discuss > > > > > <discuss@lists.openscad.org> wrote: > > > > >   > > > > >  I use "git" to manage my BOSL2 installation. > > > > >   > > > > >  I went to the OpenSCAD/libraries directory, and I said "git > > > > > clone https://github.com/revarbat/BOSL2".  That gave me a > > > > > BOSL2 installation. > > > > >   > > > > >  Later, I go to that OpenSCAD/libraries/BOSL2 directory and > > > > > say "git pull", and it updates my BOSL2 installation. > > > > >   > > > > >  I think I got my git for Windows here: > > > > > https://git-scm.com/install/windows but you could presumably > > > > > use one of the GUIs similarly, assuming that it will let you > > > > > put your worktree wherever you want to. > > > > >  _______________________________________________ > > > > >  OpenSCAD mailing list > > > > >  To unsubscribe send an email to > > > > > discuss-leave@lists.openscad.org > > > >   > > > >   > > > >   > > > > _______________________________________________ > > > > OpenSCAD mailing list > > > > To unsubscribe send an email to > > > > discuss-leave@lists.openscad.org > > > > > > > > > Virus-free.www.avg.com > > > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Dec 10, 2025 2:13 PM
The main one I can see is that your code might stop working overnight,
since there are still sometimes (rarely) breaking changes.  At least if you
initiate an update you know that could be a possible cause of breakage.
If that is ok then the daily update seems ok to me.  I personally am
effectively working on a daily (hourly) update.
On Wed, Dec 10, 2025 at 08:42 larry via Discuss discuss@lists.openscad.org
update BOSL2?
Peter:
 Peter
     Peter
BOSL2 installation.
The main one I can see is that your code might stop working overnight, since there are still sometimes (rarely) breaking changes. At least if you initiate an update you know that could be a possible cause of breakage. If that is ok then the daily update seems ok to me. I personally am effectively working on a daily (hourly) update. On Wed, Dec 10, 2025 at 08:42 larry via Discuss <discuss@lists.openscad.org> wrote: > On Wed, 2025-12-10 at 07:18 -0500, Adrian Mariano via Discuss wrote: > > In my web browser if I visit https://github.com/revarbat/BOSL2 it > > forwards to https://github.com/BelfrySCAD/BOSL2 so I'm pretty sure > > the two things are going to give the same result. > > Is there any downside to using a script running daily with cron, to > update BOSL2? > > > On Wed, Dec 10, 2025 at 6:07 AM Peter Kriens via Discuss > > <discuss@lists.openscad.org> wrote: > > > > On 9 Dec 2025, at 15:51, Jon Bondy <jon@jonbondy.com> wrote: > > > > Peter: > > > > Jordan's process appears to have worked for me. > > > That might be pure luck :-) > > > > > > The master repository is https://github.com/BelfrySCAD/BOSL2/ > > > > > > Revar is a very active developer so it is likely he often > > > synchronizes with the master repository so they will most of the > > > time be the same. However, this way it is easy to run a few days > > > behind and when he is on vacation you might run behind weeks. > > > > > > If in the future there is a similar problem, using the wrong URL > > > now is bound to cost you a couple of hours then. > > > > > > Peter > > > > Jon > > > > > > > > On 12/9/2025 9:44 AM, Peter Kriens via Discuss wrote: > > > > > > > > > I do not think https://github.com/revarbat/BOSL2 is the right > > > > > URL to the BOSL2 repo? I think it should > > > > > be https://github.com/BelfrySCAD/BOSL2/ or > > > > > git@github.com:BelfrySCAD/BOSL2.git I think you use Revar's > > > > > private repo that might run behind the actual one. > > > > > > > > > > I actually make every project a Github repository and use > > > > > dependencies like BOSL2 as a submodule. I too often experienced > > > > > that if a library was updated it killed my code. Having a > > > > > submodule for a project leeps the version the same as you > > > > > worked on until you explicitly update it. And updates are > > > > > completely independent on other projects. > > > > > > > > > > Peter > > > > > > > > > > > > > > > > > > > > > On 9 Dec 2025, at 06:07, Jordan Brown via Discuss > > > > > > <discuss@lists.openscad.org> wrote: > > > > > > > > > > > > I use "git" to manage my BOSL2 installation. > > > > > > > > > > > > I went to the OpenSCAD/libraries directory, and I said "git > > > > > > clone https://github.com/revarbat/BOSL2". That gave me a > > > > > > BOSL2 installation. > > > > > > > > > > > > Later, I go to that OpenSCAD/libraries/BOSL2 directory and > > > > > > say "git pull", and it updates my BOSL2 installation. > > > > > > > > > > > > I think I got my git for Windows here: > > > > > > https://git-scm.com/install/windows but you could presumably > > > > > > use one of the GUIs similarly, assuming that it will let you > > > > > > put your worktree wherever you want to. > > > > > > _______________________________________________ > > > > > > OpenSCAD mailing list > > > > > > To unsubscribe send an email to > > > > > > discuss-leave@lists.openscad.org > > > > > > > > > > > > > > > > > > > > _______________________________________________ > > > > > OpenSCAD mailing list > > > > > To unsubscribe send an email to > > > > > discuss-leave@lists.openscad.org > > > > > > > > > > > > Virus-free.www.avg.com > > > > > > _______________________________________________ > > > OpenSCAD mailing list > > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Dec 10, 2025 3:33 PM
update BOSL2?
That depends on the programming-practises of the maintainer(s).
If they fork for any changes, and test those forks well before
merging, then staying on "master" and updating will get you the latest
and greatest asap.
If however they test directly in the master branch then you might on
occasion get a regression that makes the project you're working on
"not work". Worst case it's not directly evident that it's a BOSL2
regression and you spend time diagnosing a problem you didn't cause...
** KVK: 27239233    **
**  'a' for accelleration.
On Wed, Dec 10, 2025 at 07:41:54AM -0600, larry via Discuss wrote: > On Wed, 2025-12-10 at 07:18 -0500, Adrian Mariano via Discuss wrote: > > In my web browser if I visit https://github.com/revarbat/BOSL2 it > > forwards to https://github.com/BelfrySCAD/BOSL2 so I'm pretty sure > > the two things are going to give the same result.   > > Is there any downside to using a script running daily with cron, to > update BOSL2? That depends on the programming-practises of the maintainer(s). If they fork for any changes, and test those forks well before merging, then staying on "master" and updating will get you the latest and greatest asap. If however they test directly in the master branch then you might on occasion get a regression that makes the project you're working on "not work". Worst case it's not directly evident that it's a BOSL2 regression and you spend time diagnosing a problem you didn't cause... Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands. ** KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a** is going up. -- Chris Hadfield about flying up the space shuttle. ** 'a' for accelleration.
