On 12/10/25 16:33, Rogier Wolff via Discuss wrote:
Worst case it's not directly evident that it's a BOSL2
regression and you spend time diagnosing a problem you
didn't cause...
I would argue this is not true. If you automate updates
and those updates break your stuff, it's your fault
unless you got a written guaranty from whatever that
dependency is.
A guaranty of that type usually costs quite a bit of
money.
didn't cause...
dependency is.
money.
You're right. I worded it a bit wrong. I meant "... diagnosing a
problem that is not in the code you're working on".
I wanted to add, If you don't put in the auto-update, then you'll have
just typed "update bosl2" and it will be easier to find a problem that
the update caused.
** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands.
** KVK: 27239233 **
** 'a' for accelleration.
On 12/10/2025 5:41 AM, larry via Discuss wrote:
Is there any downside to using a script running daily with cron, to
update BOSL2?
There's a small risk that it will update while you're in the middle of a
run. If you set the update for the middle of the night, that risk
should be very low... and the worst thing that should happen is that the
run fails.
a run. If you set the update for the middle of the night, that risk
the run fails.
Well, maybe also (depending on implementation) a small risk that the
update fails because it tries to delete or write a file that's in use.
Probably not an issue on UNIX-ish systems, might be an issue on Windows.
didn't cause...
dependency is.
I agree, and I am going to try to see if I can deal with that easily.
I think I'll try something like this...
Copy current BOSL2 to b2.old
cd to BOSL2
git pull >b2.txt ;result to b2.txt
edt b2.txt ;loads output into my text editor
Then if the update doesn't work, I can have a script that deletes the
new one and renames the old one.
Thanks to you, Rogier, and Adrian for the advice.
I can see how to run OpenSCAD from a command line with a specified script and send its rendered output to a specified file.
What I’d really like to do is something on the order of:
openscad -i foobar.stl -o foobar_modified.stl modify_input.scad
where ‘modify_input.scad’ is some variation of:
<do stuff to child> import(INPUTFILE);
where “INPUTFILE” is the “-i” parameter…which of course does not exist.
Any easy/clean way to do this?
Ah, never mind, I’m having a “senior moment”…completely misread the explanation of that “-D” argument.
From: Lee DeRaud via Discuss discuss@lists.openscad.org
Sent: Wednesday, December 10, 2025 4:41 PM
To: 'OpenSCAD general discussion Mailing-list' discuss@lists.openscad.org
Cc: lee.deraud@roadrunner.com
Subject: [OpenSCAD] Input parameters to OpenSCAD in CLI
Oops, got a bit overconfident…
I’m using PowerShell on Windows and for the life of me, I cannot figure out the quoting/escapes
required to construct a command line when I’m passing in a string, specifically a filename.
Command line (typical; I’ve gotten different errors on other attempts):
PS A:\3D\Jaguar> openscad.com -D "IFILE=”"HoodBottom.stl"”" -o HoodBottom2.stl auto_hull.scad
Script (auto_hull.scad):
IFILE=”test.stl";
echo(IFILE);
hull() import(IFILE,center=false);
Result:
PS A:\3D\Jaguar> openscad.com -D "IFILE=""HoodBottom.stl""" -o HoodBottom2.stl auto_hull.scad
WARNING: Ignoring unknown variable "HoodBottom" in file auto_hull.scad, line 7
ECHO: undef
ERROR: Unsupported file format while trying to import file '""', import() at line 3
Current top level object is empty.
PS A:\3D\Jaguar>
Any help would be appreciated, because I am completely wrapped around the axle on this one.
Sent: Wednesday, December 10, 2025 4:50 PM
Subject: [OpenSCAD] Re: Input parameters to OpenSCAD in CLI
From: Lee DeRaud via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org >
To: 'OpenSCAD general discussion Mailing-list' <discuss@lists.openscad.org mailto:discuss@lists.openscad.org >
Cc: lee.deraud@roadrunner.com mailto:lee.deraud@roadrunner.com
Ask Copilot.
On Wed, Dec 10, 2025 at 10:12 PM Lee DeRaud via Discuss <
IFILE=”test.stl";
echo(IFILE);
Result:
line 7
ECHO: undef
at line 3
PS A:\3D\Jaguar>
axle on this one.
discuss@lists.openscad.org>
modify_input.scad
It may come to that. 😊At the moment Copilot is turned off on all of my machines, as was its predecessor, whose name I have purged from memory.
I was able to get it to work rather simply in CMD, but not in PowerShwll: I had not realized they use different escaping schemes.
Still can’t find a working combination in PS though.
From: Father Horton via Discuss discuss@lists.openscad.org
Sent: Wednesday, December 10, 2025 9:14 PM
Cc: Father Horton fatherhorton@gmail.com
Ask Copilot.
On Wed, Dec 10, 2025 at 10:12 PM Lee DeRaud via Discuss <discuss@lists.openscad.org mailto:discuss@lists.openscad.org > wrote:
PS A:\3D\Jaguar> openscad.com <http://openscad.com> -D "IFILE=”"HoodBottom.stl"”" -o HoodBottom2.stl auto_hull.scad
IFILE=”test.stl";
echo(IFILE);
Result:
PS A:\3D\Jaguar> openscad.com http://openscad.com -D "IFILE=""HoodBottom.stl""" -o HoodBottom2.stl auto_hull.scad
ECHO: undef
PS A:\3D\Jaguar>
