V
vulcan_ (at) mac.com
Mon, Jul 28, 2025 11:18 PM
ir is i just a low priority operator like echo and assert?
Mon, Jul 28, 2025 11:36 PM
Colors is an actual operator module.
There are only three of the "special" expression operators: let, echo,
assert.
They are similar to, but different from, the operator modules let, echo,
and assert.
And those are different from the list comprehension module let.
assert.
and assert.
V
Wed, Jul 30, 2025 7:38 PM
oi
so when i a statement do i need to be concerned that i dont know if (let echo assert) are operators or modules?
if i write
xxx= ( assert(true) 2 ) + 3 // i would think this assert is an operator in an expression so, as it is inside parens to force precedence right?
but
assert( true ) translate( [1,1,1] ) cube(); // here it is an operator module, yes?
are there any differences in operation between operator and module forms of (let echo assert) ?
are there any syntactic differences in how they are used in a script?
oi
if i write
but
assert( true ) translate( \[1,1,1\] ) cube(); // here it is an operator module, yes?
Wed, Jul 30, 2025 11:32 PM
The execution order is different between modules and expressions, because
expressions run first, before all modules.
If you write this
assert(x>0); // assert is a module
y=f(x); // function f requires that x>0
sphere(y);
then your code will fail if x<=0 when f() is evaluated and the assert will
never do anything. You have to rewrite it as:
dummy = assert(x>0); // assert is in an expression
y=f(x);
sphere(y);
in order for the assertion to prevent f() from being invoked incorrectly.
I was totally mystified the first time I encountered this behavior and I
could only fix it by moving the assert() into f(). I rarely put an assert
inside an expression that does something else. It seems less clear and
binds together two things that may not necessarily belong together. Also
it may not be obvious that you can chain them like dummy = assert(cond1)
assert(cond2) assert(cond3);
On Wed, Jul 30, 2025 at 3:38 PM vulcan_--- via Discuss <
oi
if i write
but
module, yes?
If you write this
sphere(y);
y=f(x);
sphere(y);
> oi
> if i write
> but
> module, yes?
Thu, Jul 31, 2025 7:55 AM
I would do:
y = assert(x>0) f(x);
That avoids the dummy variable and makes it clearer why the condition must
hold, i.e. to satisfy f().
On Thu, 31 Jul 2025 at 00:32, Adrian Mariano via Discuss <
If you write this
sphere(y);
y=f(x);
sphere(y);
oi
if i write
but
module, yes?
I would do:
> If you write this
> sphere(y);
> y=f(x);
> sphere(y);
> discuss@lists.openscad.org> wrote:
>> oi
>> if i write
>> but
>> module, yes?
Thu, Jul 31, 2025 10:36 AM
Real examples are not so simple, and it rarely makes sense, at least to
me, to try to attach the assertion to some specific calculation. There
may be 5 or 10 assertions checking the validity of input to a module. And
then there may be a dozen expressions, possibly with different conditions
based on the parameters. How do I decide which calculation to attach the
assertions to? Determining at which point invalid input causes a problem
may require effort, and I don't think it's going to increase clarity for
someone reading the code. In fact, I would argue that it's not trivial to
determine whether you can get away with the module form of assert. It
requires examining the code to figure out whether anything goes wrong
before the modules run.
Algorithmically the assertions are separate operations, not part of some
computation. Attaching ten assertions to a computation just makes the code
more confusing and harder to read by mixing assertion and calculation
together and putting a huge space between the variable and the calculation
for that variable. And if I were to somehow associate each assertion
with a different computation, that would be pretty confusing as well, since
now I have the same problem repeatedly. Also note that in real code, an
assertion doesn't look like "assert(x>0)", it's 80 characters with some
condition to check and a text error message to display. The calculation
also doesn't look like "f(x)" but may be a long calculation with
conditionals.
On Thu, Jul 31, 2025 at 3:55 AM nop head via Discuss <
I would do:
If you write this
sphere(y);
will never do anything. You have to rewrite it as:
y=f(x);
sphere(y);
incorrectly. I was totally mystified the first time I encountered this
behavior and I could only fix it by moving the assert() into f(). I
rarely put an assert inside an expression that does something else. It
seems less clear and binds together two things that may not necessarily
belong together. Also it may not be obvious that you can chain them like
dummy = assert(cond1) assert(cond2) assert(cond3);
oi
if i write
but
module, yes?
conditionals.
> I would do:
>> If you write this
>> sphere(y);
>> y=f(x);
>> sphere(y);
>>> oi
>>> if i write
>>> but
>>> module, yes?
V
Thu, Jul 31, 2025 3:07 PM
when assert() is a module, is it an operator module or an object module?
my testing:
RGB=[0,0,1];
color("red") assert( RGB == [0,0,1])
translate([0,3,0])
cube(3);
this works, the assert passes and the cube is drawn.
Or i change the test to [0,0,2 ] and the assert fails
color("red")
translate([0,3,0])
cube(3) assert( RGB == [0,0,01]);
emits this:
[WARNING: module cube() does not support child modules in file ., line 14](14,C:/Program Files/OpenSCAD (Nightly))
and draws the red cube
so .. in a limited sense assert() is an operator module
it can be placed so:
assert( RGB == [0,0,2]);
and then it is being an Object Model as it works even when it has no children, which an operator module cannot do.
and it can be a function returning a value and both types of module.
my testing:
`RGB=[0,0,1];`\
`color("red") assert( RGB == [0,0,1])`\
` translate([0,3,0])`\
` cube(3);`
this works, the assert passes and the cube is drawn.\
Or i change the test to \[0,0,2 \] and the assert fails
`color("red") `\
` cube(3) assert( RGB == [0,0,01]);`
emits this:
`assert( RGB == [0,0,2]);`
Thu, Jul 31, 2025 3:11 PM
There aren't any operator modules. Just modules used in statements and
functions used in expressions. Some are both like assert and echo.
On Thu, 31 Jul 2025, 16:08 vulcan_--- via Discuss, <
my testing:
RGB=[0,0,1];
translate([0,3,0])
cube(3);
color("red")
translate([0,3,0])
emits this:
> my testing:
> RGB=[0,0,1];
> translate([0,3,0])
> cube(3);
> color("red")
> translate([0,3,0])
> emits this:
Thu, Jul 31, 2025 4:53 PM
I think he is distinguishing between a module like cube which creates
geometry and does not accept children and a module like rotate which
operates on children and doesn’t produce any results itself. It does not
fail without children. It just does not produce a result.
So then cube is an “object” and rotate is an “operator”.
If you want to put the assert module into that framework it’s an operator.
It accepts children like rotate. It does not fail without children.
However the framework is not complete. A module can perfectly well produce
geometry and also process and operate on children. It just happens that no
built in modules do that.
I don’t think there is ever a reason to give children to assert even though
you can.
On Thu, Jul 31, 2025 at 11:12 nop head via Discuss <
my testing:
RGB=[0,0,1];
translate([0,3,0])
cube(3);
color("red")
translate([0,3,0])
emits this:
you can.
>> my testing:
>> RGB=[0,0,1];
>> translate([0,3,0])
>> cube(3);
>> color("red")
>> translate([0,3,0])
>> emits this:
V
Thu, Jul 31, 2025 11:02 PM
while the underlying implementation may be the same for Operator Modules and Object Modules in practice the differences are critical.
If one defines an Object Module it results in one or more shapes being drawn. An Operator Module must end with a call to children() and cannot itself draw shapes.
An operator at the end of a statement causes no error nor warning, but also does nothing. .. at least in the 2025.07.20 i am using
An object can only be at the end of a statement .. sort of
color("red")
cube(5)
translate([0,3,0])
this will run but emits a warning: WARNING: module cube() does not support child modules …
but it does draw the cube
This also draws the cube, with the warning, but does not draw the second object, the sphere()
color("red")
cube(5)
translate([0,3,0])
sphere(r=4);
So in real terms, there are
functions that return a value, can only be used in expressions, and cannot draw geometry
modules that draw geometry, must come last in a statement, and cannot call children()
modules that operate on objects can only call other operator modules and must call children() as their last statement
and i have documented all of this after quite a lot of experimentation to be sure i was writing true things about modules
If you folks can correct my understanding of modules where i might be in error i would appreciate it so i can update the docs
thanks
An object can *only* be at the end of a statement .. sort of
`color("red")`\
` cube(5)`\
`color("red")`\
` cube(5)`\
` sphere(r=4);`
1. functions that return a value, can only be used in expressions, and cannot draw geometry
2. modules that draw geometry, must come last in a statement, and cannot call children()
3. modules that operate on objects can only call other operator modules and must call children() as their last statement
thanks
