Although less important with the cheat sheet, this is my 1st pass at,
hopefully, a more logical order.
The biggest change is separating the language reference from the rest
Link on this trial page are not active.
Trial_Reorder
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Trial_Reorder
Please post your comments
View this message in context: http://forum.openscad.org/User-manual-order-tp14271.html
Overall, I think it is a big improvement to put the entire language
reference manual into a single node.
A small issue: the "Export as STL" command is in the GUI and CLI, it is not
part of the language, so shouldn't be in the language reference manual. See
section 8.5 of your reordered language reference manual.
Trial_Reorder
Was not sure about export and import.
Thanks for the feedback
View this message in context: http://forum.openscad.org/User-manual-order-tp14271p14273.html
Looks really good.
(How about rename Include to "Include and Use Statements")
View this message in context: http://forum.openscad.org/User-manual-order-tp14271p14274.html
Am Tue, 3 Nov 2015 04:13:38 -0700 (MST)
schrieb Neon22 mschafer@wireframe.biz:
Looks really good.
http://forum.openscad.org/User-manual-order-tp14271p14274.html Sent
from the OpenSCAD mailing list archive at Nabble.com.
"Include and Use Statements" sounds good.
In the headings there are no commands used, except "import_dxf" - why
not useing "DXF Import"
Mit freundlichen Grüßen
Kind Regards
Peter Ragosch
Dear All,
My first post! Hopefully many more will come.
I salute you for taking on this important and monumental task. The
current doc is just functional enough but far from professional
quality. I too have started making my own "book" with a faintest hope
of writing and publishing an actual book. When I use OpenSCAD, I like to
have a "dead-tree version" by my keyboard. And I can imagine a lot of
users would similarly desired a nicely-printed book.
But alas, I discipline myself NOT to spend time on my "book" because I
should put my time on more "important" things.
So perhaps my best hope to air my views (some might be considered
radical) and perhaps trick you into writing the book that I want to
have, but may not want to write :P
Firstly, I am mystified why there's such a thing as 2D subsystem. I
use both 2D and 3D primitives and transformations frequently and I find
no sense in talking about a subsystem. It makes no sense as the same as
talking about a vector subsystem or string subsystem. It is very
confusing because "offset" which operates on 2D isn't found in the 2D
subsystem chapter but in the Transformation chapter/section. Similarly
it's arbitrary to put projection in 3D and extrusions in 2D.
I propose merging all primitives in one chapter, first listing all the
solids: cube, sphere etc, then list the 2D shapes, square, circle and
polygon. A short section preceding the primitives should clearly
explain 2D and 3D objects and preview a few commands (to be covered
later) that transform between 2D and 3D objects.
Then after primitives, all transformations should be covered. Each
should be clearly labelled to work on 3D objects, 2D objects or both.
It is easy to create a module that operates on a mix of 2D and 3D
children. It makes no sense to divide projection, extrusions and
"common" transformation (e.g. rotate) into three different sections.
Now, for a radical idea: treat "for", "intersection_for", "if" as
transformations.
I have more radical ideas/views, but enough for today: just expunge
"subsystem" and treat "for" as a transformation.
Hope I am stirring the pot in a positive way.
Trial_Reorder
錢建庭 教授、教研办副主任
深圳大学 生物医学工程系
CHIN, Chien Ting, Professor, Vice Chairman (Education)
Department of Biomedical Engineering
Shenzhen University
Tel: +86-755-8667-1915
In addition to the reorder and Chien TIng's nice post.
I have been teaching openscad to some members of my Amateur Radio Club.
Most have not come from ANY programming type background, and are having
trouble.
I have retired from doing programming for 40+ years.
A lot of this is over their heads, but they want to learn.
In the first steps section, I would like to see a detailed tutorial on
building some simple part. The steps taken, and why, and what each little
step looks like when previewed.
Then you could maybe link out to some youtube, and other links that you
know of that are "tutorials" or how to's.
I am not sure that everyone coming to openscad has a programming
background. Having done scripting for years it is easy for me to KNOW that
for every ( you must have a corresponding ), and for every {, a }. But I
know there are some people that wonder why at just those simple things.
I would be willing to help in this regard, if asked. Being retired, I DO
have the time.
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
I
Anonymous
excellent code requires no comments at all!- Ken Thompson
On Tue, Nov 3, 2015 at 7:51 PM, CHIN, Chien Ting 钱建庭 c.t.chin@szu.edu.cn
Dear All,
current doc is just functional enough but far from professional quality. I
too have started making my own "book" with a faintest hope of writing and
publishing an actual book. When I use OpenSCAD, I like to have a "dead-tree
version" by my keyboard. And I can imagine a lot of users would similarly
So perhaps my best hope to air my views (some might be considered radical)
and perhaps trick you into writing the book that I want to have, but may
use both 2D and 3D primitives and transformations frequently and I find no
talking about a vector subsystem or string subsystem. It is very confusing
because "offset" which operates on 2D isn't found in the 2D subsystem
chapter but in the Transformation chapter/section. Similarly it's
polygon. A short section preceding the primitives should clearly explain
2D and 3D objects and preview a few commands (to be covered later) that
Then after primitives, all transformations should be covered. Each should
be clearly labelled to work on 3D objects, 2D objects or both. It is easy
to create a module that operates on a mix of 2D and 3D children. It makes
no sense to divide projection, extrusions and "common" transformation (e.g.
transformations.
Trial_Reorder
錢建庭 教授、教研办副主任
深圳大学 生物医学工程系
Shenzhen University
First of all, I am not rewriting the OpenSCAD manual. The existing manual
consists of many files, each of which describe a small portion of the total
picture. There is a list ( 3 actually ) of these files, which allow a user
to access these various portions.
The task, which I have assigned myself, is to reorder these lists in a more
logical fashion, hopefully making things easier to find. Reordering these
lists does not entail changing the contents of the the various files pointed
to in the list.
There have been some excellent suggestions about content. I would encourage
each of you, just as others have encouraged me, to dig in and make your
changes.
View this message in context: http://forum.openscad.org/User-manual-order-tp14271p14280.html
In my unwritten book, I open the introduction with the following paragraphs:
The official introduction page of OpenSCAD declares it is a software for
creating solid 3D CAD models.A better description is found in the
tagline: The Programmer’s Solid 3D CAD Modeller.Unlike most CAD
software, which have the designer working with data specifying a model,
in OpenSCAD, the designer write a program to create a model.This design
philosophy encourage designers to /engineer/ a parametric model instead
of /sculpting/ a work of creation.
Software like Google Sketch-up is the natural choice for designers who
are not trained in mathematics and programming and who need to create
organic or artistic designs.
Software like AutoCAD and Pro/Engineer are used by many enterprises and
professionals for mechanical or structure designs.They are loaded with
very advanced and powerful features which would be very challenging (and
likely too costly) for the amateur or occasional users.
OpenSCAD is the best choice for designers who needs mathematical
precision in the creation but cannot or would not dive into the deep
ocean of a full-brown professional CAD package.The instruction set is
quite small (and it’s fair to complain that it lacks powerful features),
but its simplicity is a great advantage for generalists, hobbyists and
professionals who possess a number of technical and artistic skills and
integrate them in his or her projects.
In another word, if you and your class come to OpenSCAD without at least
some exposure to computer programming then you ought to think a bit
harder if there's a easier way to build your projects. Have you looked
into Google SketchUp, AutoDesk 123D, TinkerCAD?
Of course it's not forbidden to learn OpenSCAD as your first programming
language, but there are a variety of choices for building a design (for
3D printing, I presume?). Blender (I presume to characterize it) is
attractive to artists, 123D might be good for mechanical engineers who
knew drafting, and OpenSCAD is attractive to programmers.
having trouble.
little step looks like when previewed.
you know of that are "tutorials" or how to's.
that for every ( you must have a corresponding ), and for every {, a
}. But I know there are some people that wonder why at just those
simple things.
DO have the time.
Jerry
/The most exciting phrase to hear in science - the one that heralds
new discoveries - is not "Eureka!" but "That's funny...".
/- Isaac. Asimov
/I//f you give someone a program, you will frustrate them for a day;
if you teach them how to program, you will frustrate them for a lifetime.
/- Anonymous
/If writing good code requires very little comments, then writing
really excellent code requires no comments at all!
/- Ken Thompson
<c.t.chin@szu.edu.cn mailto:c.t.chin@szu.edu.cn> wrote:
Dear All,
The current doc is just functional enough but far from
professional quality. I too have started making my own "book"
with a faintest hope of writing and publishing an actual book.
When I use OpenSCAD, I like to have a "dead-tree version" by my
because I should put my time on more "important" things.
to have, but may not want to write :P
__subsystem__. I use both 2D and 3D primitives and
transformations frequently and I find no sense in talking about a
subsystem. It makes no sense as the same as talking about a
vector subsystem or string subsystem. It is very confusing because
the solids: cube, sphere etc, then list the 2D shapes, square,
circle and polygon. A short section preceding the primitives
should clearly explain 2D and 3D objects and preview a few
commands (to be covered later) that transform between 2D and 3D
objects.
Each should be clearly labelled to work on 3D objects, 2D objects
or both. It is easy to create a module that operates on a mix of
2D and 3D children. It makes no sense to divide projection,
extrusions and "common" transformation (e.g. rotate) into three
different sections.
transformations.
expunge "subsystem" and treat "for" as a transformation.
pass at,
the rest
Trial_Reorder
<https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Trial_Reorder>
錢建庭 教授、教研办副主任
深圳大学 生物医学工程系
Shenzhen University
Tel: +86-755-8667-1915 <tel:%2B86-755-8667-1915>
錢建庭 教授、教研办副主任
深圳大学 生物医学工程系
Shenzhen University
I hear you, L. I had the same idea even before 2015-03 was released but ...
with due respect to the developers/writers who contributed so much already,
a pure re-ordering without adding and correcting the text would not be
satisfactory. For example:
Matrix multiplication:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Matrix_Multiplication
The text is completely inadequate. It is not reasonable to expect most
readers to understand "matrix multiplication", as many have never learned
linear algebra and most who have do not retain that knowledge. At least a
reference (e.g. Wikipedia) and an example is needed. The behavior of
ill-posed matrix multiplication () should be explained (result in undef).
The text for minkowski() is also inadequate, it is not an easy concept to
explain but at least an attempt should be made, and at least two examples
(2D and 3D) should be given.
There are more!
I've been wondering about the "source code" for the documentation,
especially with the "online" and "print" editions being somewhat different.
Where can I find the list(s) and the files themselves? Then I can actually
put in my (draft) edit for the community to consider instead of just whining
about it on the mailing list.
View this message in context: http://forum.openscad.org/User-manual-order-tp14271p14331.html
