I am hoping that L will put both the print and online editions into the
same order.
On Monday, 9 November 2015, ctchin c.t.chin@szu.edu.cn wrote:
I hear you, L. I had the same idea even before 2015-03 was released but
with due respect to the developers/writers who contributed so much already,
a pure re-ordering without adding and correcting the text would not be
satisfactory. For example:
Matrix multiplication:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Matrix_Multiplication
The text is completely inadequate. It is not reasonable to expect most
readers to understand "matrix multiplication", as many have never learned
linear algebra and most who have do not retain that knowledge. At least a
reference (e.g. Wikipedia) and an example is needed. The behavior of
ill-posed matrix multiplication () should be explained (result in undef).
The text for minkowski() is also inadequate, it is not an easy concept to
explain but at least an attempt should be made, and at least two examples
(2D and 3D) should be given.
There are more!
I've been wondering about the "source code" for the documentation,
especially with the "online" and "print" editions being somewhat different.
Where can I find the list(s) and the files themselves? Then I can actually
put in my (draft) edit for the community to consider instead of just
whining
about it on the mailing list.
View this message in context:
http://forum.openscad.org/User-manual-order-tp14271p14331.html
The main page contents list has been revised close to what I proposed. The
language reference is now logically separate from the rest of the user
manual. There are links on the main page to where you will find printable
version of the 2 manuals.
The printable versions are now in the same order as the main page. These are
not a second copy of the contents. Instead, when you visit the printable
page, the latest versions of the various components are assembled into a
single page.
Besides being printable as a unit, the manual can be viewed online. The
table of contents has active links just like the main page.
Yes, the contents can be improved. I encourage each of you to do something
about it. WikiBooks allows you to edit portions without rewriting the whole
book. Jerry, you should definitely work on the getting started chapter.
Hopefully the revised organization is helpful.
Larry
View this message in context: http://forum.openscad.org/User-manual-order-tp14271p14448.html
Thank you.
are
single page.
Larry
