I get these warnings, which are probably genuine errors, but without a
filename, very hard to find.
OpenSCAD 2018.11.29.ci630
WARNING: Ignoring unknown variable '$back', line 117.
WARNING: Ignoring unknown variable '$back', line 66.
WARNING: Ignoring unknown variable '$bom', line 25.
ARNING: Unable to convert translate([2.63, undef, 0]) parameter to a vec3
or vec2 of numbers, line 159
WARNING: Unable to convert translate([0, 0, undef]) parameter to a vec3 or
vec2 of numbers, line 56
WARNING: Unable to convert translate([undef, 4.63, 0]) parameter to a vec3
or vec2 of numbers, line 163
WARNING: Unable to convert translate([]) parameter to a vec3 or vec2 of
numbers, line 56
numbers, line 56
numbers, line 56
numbers, line 56
Are all warnings supposed to show the file now, or is that still work in
progress?
Another thing I noticed is the used file cache has way too many files. I
think files used with both absolute and relative file paths get two cache
entries. I don't know if this is a new bug, or has always been the case. It
happens with a library that uses some of its own files with a relative path
but the whole library is used with an absolute path (that comes from the
OPENSCADLIBS environment variable) in the project .
On Nov 29, 2018, at 10:32 AM, nop head nop.head@gmail.com wrote:
Are all warnings supposed to show the file now, or is that still work in progress?
At least some of that is an open PR: https://github.com/openscad/openscad/pull/2593
Another thing I noticed is the used file cache has way too many files. I think files used with both absolute and relative file paths get two cache entries.
I had a similar concern last night, see my comment here: https://github.com/openscad/openscad/pull/2593#discussion_r237359938
Not sure if we may need to backtrack through some of the warning stuff to figure this out..
Not sure why you would want to put the main file path into the cache key.
In MDI mode I expect the used files in my library to be cached once, not
once for each open window. Is there a reason why the cached files can't be
shared between different windows?
progress?
entries.
figure this out..
On Nov 29, 2018, at 12:09 PM, nop head nop.head@gmail.com wrote:
Not sure why you would want to put the main file path into the cache key. In MDI mode I expect the used files in my library to be cached once, not once for each open window. Is there a reason why the cached files can't be shared between different windows?
Exactly, that was the cause of my concern. If the compiled file is depending on the main file, this won’t fly, so we should probably find a way of decoupling that.
Let’s wait for Michael to comment and see where we can take it from there.
Was 'ARNING:' a cut & paste problem or in the console representing a code
typo?
Yes must have been an error on my part. WARNING is always spelt correctly.
typo?
Another issue is false is no longer converted to 0 when used in a vector
parameter to translate.
The undef is actually false. I thought true and false were converted to 1 ,
0 when a number was required, as C.
typo?
Admin - email* me if you need anything, or if I've done something
stupid...
BTW, it was actually a mistake that I was passing false but it is
misleading to say it is undef.
, 0 when a number was required, as C.
typo?
stupid...
On Nov 30, 2018, at 6:52 AM, nop head nop.head@gmail.com wrote:
Another issue is false is no longer converted to 0 when used in a vector parameter to translate.
WARNING: Unable to convert translate([0, 0, undef]) parameter to a vec3 or vec2 of numbers, line 56
The undef is actually false. I thought true and false were converted to 1 , 0 when a number was required, as C.
This is worthy of a github ticket.
Actually it is my fault again. The undef is generated by false * 15.
Passing an actual true or false gives a correct error message assuming true
and false are not valid as numbers.
echo(version());
echo(false * 5, true + 1);
translate([true, false, false * 15]);
ECHO: [2018, 11, 29]
ECHO: undef, undef
WARNING: Unable to convert translate([true, false, undef]) parameter to a
