Another thing I noticed is the used file cache has way too many files. I
think files used with both absolute and relative file paths get two cache
entries.
This again is my fault, or rather Bill Gate's. Under Windows paths are case
insensitive. When I used a relative path it picked up the actual name of a
directory that differed in case to the full paths I was using. When I
corrected the directory name I also had to not open the file from the
recent list as that was remembering the old name with the wrong case.
Case insensitive paths are a mess, not sure how this should be fixed. I
want my library to work on Linux as well as Windows so the paths have to be
the correct case. It is only this bug / feature that made me realise I had
some discrepancies left. I was previously alerted to some due to getting
lots of new warnings about variables defined twice due to same file being
reached by different case paths. I didn't report that as a bug because it
was useful.
One solution is to make all path comparisons case insensitive when running
on Windows to match the file system. But then if you want a library to work
on Linux you don't get any warnings when developing on Windows.
On Fri, 30 Nov 2018 at 15:09, nop head nop.head@gmail.com wrote:
Actually it is my fault again. The undef is generated by false * 15.
Passing an actual true or false gives a correct error message assuming true
and false are not valid as numbers.
echo(version());
echo(false * 5, true + 1);
translate([true, false, false * 15]);
ECHO: [2018, 11, 29]
ECHO: undef, undef
WARNING: Unable to convert translate([true, false, undef]) parameter to a
vec3 or vec2 of numbers, line 5
On Fri, 30 Nov 2018 at 13:49, Marius Kintel marius@kintel.net wrote:
On Nov 30, 2018, at 6:52 AM, nop head nop.head@gmail.com wrote:
Another issue is false is no longer converted to 0 when used in a
vector parameter to translate.
WARNING: Unable to convert translate([0, 0, undef]) parameter to a vec3
or vec2 of numbers, line 56
The undef is actually false. I thought true and false were converted to
1 , 0 when a number was required, as C.
This is worthy of a github ticket.
On 29.11.18 17:06, Marius Kintel wrote:
On Nov 29, 2018, at 10:32 AM, nop head nop.head@gmail.com wrote:
Are all warnings supposed to show the file now, or is that still work in progress?
At least some of that is an open PR: https://github.com/openscad/openscad/pull/2593
Now replaced with https://github.com/openscad/openscad/pull/2615
Another thing I noticed is the used file cache has way too many files. I think files used with both absolute and relative file paths get two cache entries.
I had a similar concern last night, see my comment here: https://github.com/openscad/openscad/pull/2593#discussion_r237359938
Not sure if we may need to backtrack through some of the warning stuff to figure this out..
It sound concerning to me that relatives paths are or might be used for
cache entries.
It is not unlikely that a user has an old copy of his project that uses
a different version of library via relative paths and he uses both and
old and new copy to debug something.
On the bright side: Making all cache entire paths absolute would resolve
both issues.
With kind regards,
Michael Frey
I think the cache entries probably are all absolute paths. The issue was in
converting from no path to absolute the current directory is used. That had
a different case to the absolute paths generated from OPENSCADLIBS, so got
a different cache entry even though it was the same file due to Windows
ignoring case. To debug it I generated a dependency file with the -d
option. All the paths were absolute but the ones in the root directory of
the project had a difference case for that directory.
in progress?
entries.
cache entries.
both issues.
With kind regards,
Michael Frey
