Oh, how stupid I didn't check this little detail :-( . My first approach was
to use a polygon with the same point sequence, but that didn't work, because
my sweep() currently also puts vertical walls along the kerfs. So if CGAL
would cooperate, one could easily implement sweep() to omit those walls.
http://forum.openscad.org/file/t887/sweepwithholes.png
use <Naca_sweep.scad>
a = circle(30, 0, 10, -1);
b = circle(6, 0, 100, 1);
q = prepsweep([a, each forN_(b, 17)]);
sweep([q, Tz_(10, q)]);
function prepsweep(P) = [each P[0], each for(p=[1:len(P)-1]) each [P[p],
[P[p][0]], [P[0][len(P[0])-1]]]];
function forN_(P, r=0, N=6) = [for(i=[0:N-1]) T_(rsin(360/Ni),
rcos(360/Ni), 0, P)];
function circle(r=10, z = 0, N=10, dir=1) = [for(i=[0:N-1])
[rcos(dir360/Ni), rsin(dir360/Ni), z]];
A multi-hole sweep can be also implemented straight forward and does not need
this hack. It has to provide its own triangulation of the first and last
faces with holes and just can't rely on CGAL to do it. CGAL gets slow
anyway, when it starts with "trying alternative construction". The rest is
just building the walls like a vectorized sweep.
The new call will be something like:
sweep(outerpolygon_sequence=a, listofholes_sequence=b)
As soon as I find time, I'm gonna try it.
You could just use clockwise-counterclockwise to identify holes.
I did write a triangulation thing for bending text, though there's probably
a better way.
https://gist.github.com/NateTG/b350378c56f436d3996a2107f7cba965
With a polyhedron counter-clockwise is already used to mean a face facing
the other way, which is different from a hole in a face. E.g. in runsun's
numbered example the bottom face is listed counter-clockwise looking from
the top because it is pointing downwards.
Perhaps the first polygon in the face could be assumed the outward facing
direction and any polygons in the same face that go the opposite direction
to be holes in it.
On Mon, 10 Dec 2018 at 18:17, NateTG nate-openscadforum@pedantic.org
a better way.
Thx for the check, nophead. Wondering how OpenSCAD allows it to render
correctly when it's stand-alone.
OpenCSG just draws all the triangles and if they cover all the pixels it
looks OK. CGAL on the other hand needs a mainfold mesh, not one with self
intersections in its planes.
I should add CGAL is avoided if there are no CSG ops.
A triangulation like earcut with holes will be cumbersome to implement in
OpenSCAD. However a fast and viable solution for implementing the multi-hole
sweep is to use a vectorized lazy union sweep for the holes and difference
the result from the sweep of the outer polygon. For export one will have to
use a Boolean operation to do a CGAL check anyway.
Just applied the union rendering check on the alternative face description
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Alternate_Face_Descriptions
described in the documentation and found it failed the same way.
nophead wrote
It's happy to preview but doesn't work with a union with a unit cube and
F6.
You are right: it doesn't work. I created that section based on the
examples of 2D polygons with holes. I had checked it then with F6 but had
not done a full check with a cube union. Sorry by that.
What is strange (or inconsistent) is that 2D polygons with holes render
fine even with a full check.
I have deleted the section from the manual. It can be retrieved from the
wiki history anyway.
Ronaldo
Em seg, 10 de dez de 2018 às 20:14, runsun runsun@gmail.com escreveu:
F6.
$ http://forum.openscad.org/mailing_list/MailingListOptions.jtp?forum=1 Runsun
Pan, PhD
$ libs: scadx https://bitbucket.org/runsun/scadx, doctest
https://github.com/runsun/openscad_doctest, faces
http://forum.openscad.org/A-faces-function-for-simple-polyhedrons-td12809.html
(git https://github.com/runsun/faces.scad), offline doc
http://forum.openscad.org/Use-openscad-offliner-for-offline-documentation-td13096.html
(git https://github.com/runsun/openscad_offliner), runscad.py
http://forum.openscad.org/Animating-gif-with-3D-rotation-tp14011p14029.html
(2 http://forum.openscad.org/Symmetrical-Rotation-tp14062p14075.html,git
https://gist.github.com/runsun/995250a8002386ab9abc), editor of choice:
CudaText
http://forum.openscad.org/Syntax-highlighting-tp23247p23258.html ( OpenSCAD
lexer http://www.thingiverse.com/thing:1237864); $ Tips
https://github.com/runsun/OpenSCAD_Tips; $ Snippets
https://github.com/runsun/OpenSCAD_Tips/blob/master/snippets.md
at Nabble.com.
