Hello, everyone.
I've just created a pull request for export() function - lt was strange for
me that a language has import() and doesn't have an export() operation,
although it's available from GUI. So, I've extended export.cc module to make
it support calls for export(file="test.dxf") ....;
Example:
export(file="testcube.dxf") projection(cut=true)
translate([0,0,-1])
cube([2,2,2]);
There is a pull request on github on this topic -
https://github.com/openscad/openscad/pull/1534
View this message in context: http://forum.openscad.org/export-function-tp15428.html
Hello,
I asked for such a functionality in a previous thread.
Now only a "function" to check for the existence of a file is missing.
Please note that the code I presented then did not intend to be exact, it
was only to express an idea.
And the idea was the capability of some automation from within the code to
achieve a fluid view and manipulation of complex multi-part objects.
Explaining briefly: rendering a multi-part complex object can make us loose
many minutes if not hours every time we start an editing session. When we
start assembling a multi-part object it happens frequently that some modules
are not at the right positions or that we forgot some details, so we need to
look to the object from several angles to understand better what to do. If
not rendered the set is almost impossible to move or rotate on the
view-port, the time lag is enormous.
My solution would be: the modules that are important for the assembly would
verify for a previously exported .stl file with the same name of the module.
If the file exist then that part is imported, else the code would be
compiled and exported as an .stl file. Since the code bellow is already
possible,
module ABC() {
import("ABC.stl");
ABC();
The only thing missing after having the export functionality working would
be a function returning a flag signaling the existence of a file.
I know it is possible to have a fluid view done from outside the script,
even to have a second instance of OpenSCAD open with all stls imported, but
it's not practical. It implies that the code is distributed into several
files and somehow the feel of unity of the object weakens.
Now with the OpenSCAD lexer presented by runsun (thank you runsun) for the
SinWrite editor, we have already the facility to better navigate in a more
"complex" code and we do not need to separate the code into several files
if we are not planning for code reuse, for that I would build a library.
I read this comment by doug.moen a few hours ago.
"An export command with a file name argument permits a malicious OpenSCAD
script to clobber any file in the file system for which it has write
permissions. OpenSCAD is intentionally designed so that it isn't a general
purpose language like Python, and it doesn't suffer from this kind of
security issue."
What if limiting the file name parameter to a couple of known pacific
extensions?
As I said in thread above I'm not a software guy nor an OpenSCAD expert and
I'm not a native english speaker either, so please understand that.
Happy new year
jpmendes
http://forum.openscad.org/How-to-check-if-a-file-exist-Why-not-export-from-code-td14982.html#a14995
View this message in context: http://forum.openscad.org/export-function-tp15428p15437.html
possible,
A persistent cache (I think there's already an issue on github for that)
could solve this specific issue too and in a way that does not need much
user interaction.
Having scad code to check for files and then automatically use those will
cause lots of headaches with outdated files that need to be updated
manually. If you open the the scad file in two instances of OpenSCAD,
funny things will happen and there might also be cross-platform issues.
How is the difference between preview and render mode handled with
export()? Will that always force the mesh generation and export the
file on F5? How will that interact with animation?
In essence, my totally personal opinion is that OpenSCAD itself should
focus on the model description part and not try to become a general
programming language. There's a huge amount of improvements possible
for making the model generation easier and more powerful.
Note that my view of model description includes (not yet available)
markup to define such things a multiple objects from one script that
could be exported in one step. But that would be a feature of the
GUI, not the description language.
In https://github.com/openscad/openscad/issues/1437 clothbot and I propose
to add a persistent caching option to 'render'. This can address both
jpmendes and Mihail's problem.
If we add export and a function for testing file existence, then openscad
starts to become a scripting language for automating file management
workflow. The security problem becomes worse because now you can determine
what operating system is running, by testing for the existence of system
files, and now you know which files to clobber using 'export', for maximum
damage.
On Sunday, 3 January 2016, jpmendes <jpmendes54@gmail.com
javascript:_e(%7B%7D,'cvml','jpmendes54@gmail.com');> wrote:
Hello,
modules
to
module.
possible,
module ABC() {
import("ABC.stl");
ABC();
security issue."
extensions?
Happy new year
jpmendes
Yes persistent caching gets my vote as there are no changes to the
language, it just gets faster.
To export multiple objects from my files I simply call them
something_stl(). I have a python script that finds them and invokes the
command line to export them. That would also get much faster with a
persistent cache.
propose to add a persistent caching option to 'render'. This can address
both jpmendes and Mihail's problem.
openscad starts to become a scripting language for automating file
management workflow. The security problem becomes worse because now you can
determine what operating system is running, by testing for the existence of
system files, and now you know which files to clobber using 'export', for
maximum damage.
On Sunday, 3 January 2016, jpmendes jpmendes54@gmail.com wrote:
Hello,
loose
modules
to
would
module.
possible,
module ABC() {
import("ABC.stl");
ABC();
would
but
security issue."
extensions?
and
Happy new year
jpmendes
May be it's safe enought to permit only files with names, derived from
original script name.
3 янв. 2016 г. 11:40 PM пользователь "nop head" nop.head@gmail.com
написал:
persistent cache.
maximum damage.
Hello,
to
loose
modules
need to
If
would
module.
possible,
module ABC() {
import("ABC.stl");
ABC();
would
but
more
files
general
security issue."
extensions?
and
Happy new year
jpmendes
Hello,
For me persistent cache is welcome as I seldom make complex multi-part
objects. For the guys tackling
several projects a time it can be very hard disk consuming.
However with the limitation of the names and extensions of the exports, and
placing the exported files inside the project directory, I cannot figure out
where could be risk for malware propagation.
For the guys not wanting to use the export functionality the language would
not be different.
And what if we had a GUI more like an IDE with a project tree, where the
files could be added from other project dirs and made available locally, and
all (except calls to libraries) would be kept under the project directory?
jpmendes
View this message in context: http://forum.openscad.org/export-function-tp15428p15448.html
On Sun, 3 Jan 2016 14:59:13 -0700 (MST)
Hello,
Its usually going to be smaller and easier to manage than having loads of
saved export files you have to keep remembering to clean up by hand. It's
a model that works well and has a very simple interface ("Size ?"). All
the web browsers use it for example.
Alan
I pray for the persistent cache location to be user defined. Please!!!
jpmendes
View this message in context: http://forum.openscad.org/export-function-tp15428p15455.html
One option would be the use of memcached, in that case OpenSCAD would
not specify a path for the actual storage.
