MV
Mihail Vasiliev
Mon, Jan 4, 2016 9:31 PM
On persistent cache - may be try using mmap-ed files? There is some mechanism
for it in boost
(http://www.boost.org/doc/libs/1_50_0/libs/iostreams/doc/classes/mapped_file.html),
but I have no experience with it.
On my original issue - what about reconsidering my patches and suggestions
on security enhancments?
View this message in context: http://forum.openscad.org/export-function-tp15428p15484.html
for it in boost
Mon, Jan 4, 2016 11:09 PM
Hi Mihail. Concerning your pull request for an export() command.
Torsten is a gatekeeper, I'm not. Torsten's response to your proposal was
more relevant and insightful than mine. The security problem is a side
issue, and the real problem is what Torsten said:
- OpenSCAD is not a procedural programming language. It is a purely
declarative language for describing geometry. This is the primary issue.
- You can't add a procedural, side effect causing 'export()' command to
the language because it doesn't make any sense to export a shape to a file
while the script is being evaluated: this would mess up preview
performance. Once again, this is a side issue, like security. It's a
technical issue which underlies the fundamental design decision that
OpenSCAD is a declarative language (see point 1 above).
Torsten asked a number of questions about "when does this side effect
occur", which are quite relevant, and which you didn't answer.
Then Torsten proposed a design which is consistent with the OpenSCAD
philosophy. Instead of an "export" function which has the semantics of
"write this shape to a file right now", there is a syntax for adding
metadata to a node of the CSG tree, which has the semantics: this branch of
the CSG tree should be exported to a separate file, at export time. It
could have the same syntax as your proposal.
This metadata is not interpreted until some GUI command is invoked. No
files are exported during preview, render or animation, which is as it
should be. For example, the GUI "Export" command can notice that there are
multiple exported subtrees tagged in the CSG tree. It could, for example,
ask you to specify a root directory, then write all of the exported files
relative to this directory. It should also be specified how to invoke
multiple export from the CLI.
Notice how the security problem goes away when the feature is properly
designed. We are no longer invisibly exporting files without the user's
knowledge, in the case of a downloaded SCAD file. Export only happens
explicitly.
This design addresses the goal of exporting multiple files from a single
*.scad file, but it doesn't address jpmendes' problem, because his goal is
for OpenSCAD to run faster, and he wants to achieve this by persistent
caching of specified subtrees. So we've proposed an extension to the
render() operator to solve his problem.
1. OpenSCAD is not a procedural programming language. It is a purely
2. You can't add a procedural, side effect causing 'export()' command to
"write this shape to a file *right now*", there is a syntax for adding
explicitly.
> mechanism
> for it in boost
MV
Mihail Vasiliev
Wed, Jan 6, 2016 7:57 PM
Hi, Doug, Torsten.
I'll try to answer Torsten's questions first.
- How is the difference between preview and render mode handled with
export()?
The very exact way another side-effecting operation - "echo" does.
It does it's dirty job on "instantiate" call to corresponding AbstractNode.
- Will that always force the mesh generation and export the
file on F5?
It's action is triggered at the same times as echo's.
As for now, it actually calls instantiateChildren on it's children nodes.
(I don't know, whether this function it use caches internally. I can dig
it, if it's necessary.)
Than it applies freshly-created GeometryEvaluator on the first of these
children and exports resulted geometry in supplied file, determining it's
type by it's name.
- How will that interact with animation?
Yes, I regenerates file on each frame, and can be used to create series of
exported files of each time step.
e.g. the code:
export(file=str("gg",$t,".stl")) rotate([$t*50,0,0]) cube([10,10,10]);
generates several stl files with different names, as expected.
Now on Doug's questions:
And why the way to output for this geometry is obligated to be declared in
command line, not in the language itself?
This technocal issue can be addressed by adding some extra argument to
export to make it skip it's operation in preview mode, for example. I can
do it, as well as security restrictions, regression tests and so on, if the
community is interested in the feature itself.
2016-01-05 2:09 GMT+03:00 doug moen doug@moens.org:
to the language because it doesn't make any sense to export a shape to a
file while the script is being evaluated: this would mess up preview
explicitly.
Hi, Doug, Torsten.
1. How is the difference between preview and render mode handled with
export()?
2. Will that always force the mesh generation and export the
file on F5?
type by it's name.
3. How will that interact with animation?
e.g. the code:
2016-01-05 2:09 GMT+03:00 doug moen <doug@moens.org>:
> explicitly.
>> mechanism
>> for it in boost
Fri, Jan 8, 2016 5:42 PM
export()?
So it would try to generate the full mesh (aka. F6) for this part
of the model for each preview and export the file. I don't think
this is a good way of handling it. See below for more details...
of exported files of each time step. e.g. the code:
Ok, that might be useful in some rare cases, but it looks a bit like
misusing the animation feature.
in command line, not in the language itself?
I would not say it's impossible to use some language feature to declare
what to export. The main issue is the immediate execution which the
code is compiled.
Trying to find the analogy to C++ here, we only have the compilation
step where you do "gcc -o program.exe file.c" and the analog part would
be "openscad -o model.stl file.scad".
So mapping the immediate execution of export() to gcc would be like
exporting another file while the compiler is running via #export file.out
or something similar.
Actually running as program does not really happen with OpenSCAD models,
as they are essentially a data structure that is evaluated by different
things.
Those things can be:
- F5 preview renderer in OpenSCAD GUI
- F6 mesh calculation in OpenSCAD GUI or command line
- various exports to different formats in OpenSCAD GUI or command line
- import into other programs, namely FreeCAD
Most notably here is the last point which highlights the interpretation
of SCAD (or it's simplified form CSG) files as data. What would FreeCAD
do with an export() node when reading the file?
It's true that echo() is also fitting into that problem area, it mainly
has the argument that there would be almost no debugging possibility
without it.
I think having some capabilities to markup/annotate parts of a model
to tell the OpenSCAD GUI what to do when interpreting the data could
cover both issues: a) leaving the scad script as a data description
while still b) allowing the user to export multiple parts at once.
All this without interfering with other programs that might want to
import the file or making the preview slow due to forced mesh generation.
Also annotations allow more control about export details, as for
instance the DXF export would benefit from defining model parts
as different layer while still exporting into a single file.
Maybe we can work together moving into that direction? The actual
feature for exporting multiple files / multiple layer would be
awesome to have and surely welcomed by a number of people.
> export()?
code is compiled.
Trying to find the analogy to C++ here, we _only_ have the compilation
things.
* F5 preview renderer in OpenSCAD GUI
* F6 mesh calculation in OpenSCAD GUI or command line
* various exports to different formats in OpenSCAD GUI or command line
* import into other programs, namely FreeCAD
without it.
Fri, Jan 8, 2016 6:57 PM
The animate feature doesn't create an output file for each frame unless
you select the "dump images" option. There's currently no option to export
each frame as stl. If we added such a feature, only then would it make
sense to export tagged subtrees as stl for each frame.
export()?
code is compiled.
things.
without it.
The animate feature doesn't create an output file for each frame *unless*
each frame as stl. *If* we added such a feature, only then would it make
> > export()?
> AbstractNode.
> code is compiled.
> things.
> without it.
> ciao,
> Torsten.
> Discuss@lists.openscad.org <javascript:;>
MV
Mihail Vasiliev
Fri, Jan 8, 2016 11:22 PM
May be it's better to leave this decision to end user, whether to use
export keyword or not?
On compatibility with other software-I'm not sure, how FreeCAD parses
unknown predicates, but if it behaves like OpenSCAD - just ignores
corresponding subtree, everythings should be fine - it will just show the
same - nothing.
8 янв. 2016 г. 9:58 PM пользователь "doug moen" doug@moens.org написал:
export()?
code is compiled.
things.
without it.
same - nothing.
8 янв. 2016 г. 9:58 PM пользователь "doug moen" <doug@moens.org> написал:
>> > export()?
>> AbstractNode.
>> code is compiled.
>> things.
>> without it.
>> ciao,
>> Torsten.
ER
Ezra Reynolds
Sat, Jan 9, 2016 2:59 AM
I wouldn't use FreeCAD as a barometer of compatibility, as it doesn't
support hull() or offset() as of the most current version (hull is split
into its components, offset throws nasty errors).
I have created many designs that have multiple subassemblies. They are
all inter-related pieces of the same design (e.g. top, bottom, middle,
with matching screw-holes, standoffs, etc.) Since they share variables,
it is logical for them to to share a .SCAD file. Yes, I know how to use
a batch file or script to do all this, but I would say it is more
I normally arrange the pieces in OpenSCAD for 3D printing (many discrete
volumes as a single STL). This works up to the point where I have a
single part, or several parts, fail during printing /
derafting/assembly. It is an error-prone thing to manually isolate each
part, render as an STL, save it with the correct name, rinse and repeat.
Not a problem with a three-part assembly, but could be a problem with
file that generates two dozen variations on a theme.
For my needs, an export("part1.stl") {subtree} approach would work,
where the subtree is rendered to screen/cache (exactly like render()),
but is also exported to disk as the last step of the process.
For example:
export("top.stl") top();
translate ([20, 0, 0]) export("middle.stl") middle ();
translate ([-20, 0, 0]) export("bottom.stl") bottom();
F5 Preview - no difference, objects are rendered and shown
F6 Render - objects are rendered, displayed on screen. Export subtrees
are written to disk, allowing user to still save whole render as .STL or
.AMF or whatever. This guarantees I have a current (top, middle,
bottom) and not a top from two revisions ago.
Or maybe have a "Super F6" (shift+F6?) that handles the export()
commands or whatever other metadata functions we need. I like
doug.moen's suggestion about handling this as metadata; you could
implement as a post-process function.
From my vantage point, export is still "Object Description" and not
"general programming"; it is describing the shape of the sub object, and
how it stored on the disk.
One potential problem that hasn't been mentioned is that if export()
triggers a render+write RIGHT NOW that can lead to a race condition; if
I export "X.stl" and use "X.stl" in other parts of the same file - does
it use the previous "X.stl" or the just-rendered version....
the same - nothing.
mailto:doug@moens.org> написал:
*unless* you select the "dump images" option. There's currently no
option to export each frame as stl. *If* we added such a feature,
only then would it make sense to export tagged subtrees as stl for
each frame.
export()?
declare
code is compiled.
compilation
part would
file.out
models,
different
things.
command line
interpretation
FreeCAD
mainly
without it.
generation.
For example:
> the same - nothing.
> <mailto:doug@moens.org>> написал:
> each frame.
> handled with
> > export()?
> does.
> AbstractNode.
> create series
> cube([10,10,10]);
> purely
> primary issue.
> be declared
> declare
> code is compiled.
> compilation
> part would
> file.out
> models,
> different
> things.
> command line
> interpretation
> FreeCAD
> mainly
> without it.
> generation.
> ciao,
> Torsten.
YA
Yona Appletree
Sat, Jan 9, 2016 3:10 AM
I have very much the same workflow, and really like the idea of being
able to tag a subtree as being a logically separate, named, object.
This would allow more than just exporting groups of objects at once
(which as mentioned would be much better than rendering each part
separately and manually entering filenames). It would be really neat if
the preview window had, for instance, a dropdown where you could either
view the entire generated tree or view each of the tagged subtrees on
their own. Effectively and after-the-fact application of the re-root (!)
operator.
In this same vein, having an export option that would automatically
create a new folder for the specific export instance that is timestamped
or versioned would be very awesome. Then, the current, many-step
workflow for rendering, examining, and exporting a new version of a
multipart model would be a click or two.
~ Yona
Ezra Reynolds mailto:shadowwynd@gmail.com
January 8, 2016 at 18:59
split into its components, offset throws nasty errors).
are all inter-related pieces of the same design (e.g. top, bottom,
middle, with matching screw-holes, standoffs, etc.) Since they share
variables, it is logical for them to to share a .SCAD file. Yes, I
know how to use a batch file or script to do all this, but I would say
it is more
discrete volumes as a single STL). This works up to the point where I
have a single part, or several parts, fail during printing /
each part, render as an STL, save it with the correct name, rinse and
repeat. Not a problem with a three-part assembly, but could be a
problem with file that generates two dozen variations on a theme.
For example:
subtrees are written to disk, allowing user to still save whole render
as .STL or .AMF or whatever. This guarantees I have a current (top,
middle, bottom) and not a top from two revisions ago.
and how it stored on the disk.
if I export "X.stl" and use "X.stl" in other parts of the same file -
does it use the previous "X.stl" or the just-rendered version....
Mihail Vasiliev mailto:mickvav@gmail.com
January 8, 2016 at 15:22
the same - nothing.
doug moen mailto:doug@moens.org
January 8, 2016 at 10:57
unless you select the "dump images" option. There's currently no
option to export each frame as stl. If we added such a feature, only
then would it make sense to export tagged subtrees as stl for each frame.
mailto:Torsten.Paul@gmx.de> wrote:
Torsten Paul mailto:Torsten.Paul@gmx.de
January 8, 2016 at 09:42
export()?
code is compiled.
things.
without it.
January 6, 2016 at 11:57
Hi, Doug, Torsten.
export()?
AbstractNode.
file on F5?
nodes. (I don't know, whether this function it use caches internally.
I can dig it, if it's necessary.)
these children and exports resulted geometry in supplied file,
determining it's type by it's name.
series of exported files of each time step.
e.g. the code:
declared in command line, not in the language itself?
a file while the script is being evaluated: this would mess up preview
can do it, as well as security restrictions, regression tests and so
on, if the community is interested in the feature itself.
operator.
~ Yona
> Ezra Reynolds <mailto:shadowwynd@gmail.com>
> it is more
> For example:
> Mihail Vasiliev <mailto:mickvav@gmail.com>
> the same - nothing.
> doug moen <mailto:doug@moens.org>
> option to export each frame as stl. *If* we added such a feature, only
> Torsten Paul <mailto:Torsten.Paul@gmx.de>
>> export()?
> code is compiled.
> things.
> without it.
> ciao,
> Torsten.
> Hi, Doug, Torsten.
> export()?
> AbstractNode.
> file on F5?
> e.g. the code:
MS
Mark Schafer
Sat, Jan 9, 2016 3:24 AM
would this be equivalent to allowing render() to have an export keyword ?
Sat, Jan 9, 2016 4:51 AM
We have had this discussion before
http://forum.openscad.org/Multi-material-support-was-Re-OpenSCAD-3000-td8613.html
, re multi-material support.
View this message in context: http://forum.openscad.org/export-function-tp15428p15583.html
<http://forum.openscad.org/Multi-material-support-was-Re-OpenSCAD-3000-td8613.html>
