Afternoon All
I'm after a bit of guidance and advice weather or not what i'm trying to do
is possible. The problem i have is i want to convert the following to a 3d
http://forum.openscad.org/file/n18425/sample.png
Basically the large round Circle (1200mm) is 20mm thick the lines on top
represents various inputs they all end up at 0deg but could start anywhere
from 90deg to 270deg and have various diameters from 100mm to 300mm for the
curved lines the radius will always be 400mm.
What i'm aiming for is to change a couple of references for the angles and
number of inputs and diameters and away it goes. If possible i would just
like a bit of guidance on where to start with it all
Many Thanks
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425.html
Your problem seems to be a geometric problem and not an OpenSCAD one. Anyway,
it was not clear to me. Is the issue to calculate the center of the circle
arcs for a given radius and input-output angle?
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18428.html
I think i didn't quite explain myself basically i would like to put a start
point of 0 deg and then another point on the circle (1200mm dia) lets say at
90 and then say i would like a cylinder at 150mmdia that meets the two end
points with a radius of 400 inbetween if that makes sense
Regards
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18429.html
Something like that?
http://forum.openscad.org/file/n18432/cyls.png
r=1200;
r1=400;
h= 200;
color("blue") cylinder(r=r, h=h);
translate([r1, -r1, h]) cylinder(r=r1, h=h);
line([0, -r, h], [0, -r1, h], thickness=30);
line([r1, 0, h], [r, 0, h], thickness=30);
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18432.html
Or if you want to do it the cheats way without any trigonometry (other than
making a wedge with the angle you want):
angle=50;
radius=40;
big_circle_radius=100;
intersection()
circle(r=big_circle_radius);
offset(r=radius)
offset(r=-radius)
scale(radius*10)
polygon(points=[[0,0],[0,-1],[cos(angle),sin(angle)]]);
r=1200;
r1=400;
h= 200;
tp18425p18432.html
You may try this:
ang = 30;
r = 90;
R = 100;
s = sign(90-ang);
// tangential circle center
c = rs[1, (sin(ang)-1)/cos(ang)];
// far away points for hull
c1 = c + 2R[cos(ang), sin(ang)];
c2 = 2sR*[1, -1];
c3 = [c[0], -2*R];
// comment this line to see what is going on
circle(R,$fa=2);
hull() {
translate(c) circle(r,$fa=2);
translate(c1)circle(r);
translate(c2)circle(r);
translate(c3)circle(r);
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18438.html
Thank you for your help but i'm looking for something more like below if
possible please
http://forum.openscad.org/file/n18439/download.jpg
or
http://forum.openscad.org/file/n18439/images.jpg
Many Thanks for your help
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18439.html
You will need rotate_extrude
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_the_2D_Subsystem#Rotate_Extrude
and some math to find angles and centers.
2016-09-20 4:31 GMT-03:00 dandare2020 dandare2020@gmail.com:
possible please
or
Dan
tp18425p18439.html
So you'd like to union (well, almost) two or more toroidal segments, yes?
Where the torii are hollow, aka tubes ???
If tubes, you want the passageways open ???
Like an tubular exhaust manifold for a combustion engine ???
Phil(f) in WI
On 9/19/2016 7:52 AM, dandare2020 wrote:
Afternoon All
Many Thanks
Dan
Now, with the pictures, your problem is clear. You asked if it is possible.
The answer is yes:
http://forum.openscad.org/file/n18445/Tube_junction.png
You asked for some guidance. Here you have:
a) you will need rotate_extrude, preferably with a OpenSCAD version 2016.xx;
this will give you the cylinder bendings; two standard cylinders will extend
it;
b) you will need to calculate the center of the torus arcs from the bending
angles; here is where some trigonometry is helpful;
c) to make the holes in the tubes, you will need to subtract (difference())
the inside bent cylinder model from the outside bent cylinder model;
d) to make the passages through the enclosure cylinder, you will need to
subtract (difference()) the inside bent cylinder models from the enclosure
model.
I think it is more convenient to measure the bending from the vertical
direction.
That is a good exercise of OpenSCAD modelling.
If you have additional questions, ask. If you want my code, just ask.
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18445.html
