dandare2020 wrote
Thank you for your help but i'm looking for something more like below if
possible please
or
Many Thanks for your help
Dan
I've seen that before.
Is this a course exercise?
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18446.html
Ah, in your original post
http://forum.openscad.org/Generating-Code-td18016.html .
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18447.html
Interesting use of industrial robot to carve foam for concrete moulds
http://hawkeyepedershaab.com/wp-content/uploads/2013/11/CPI-M-Con-article-Oct.20132.pdf
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18448.html
Ronaldo all i can say is thank you that is more or less what i'm looking for
minus the ring round the side and and small 20mm base on the bottom that
would be perfect. If you could post the code i will have a play
Thank you very much
Cheers
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18452.html
MichaelATOz
That is excatly what i'm trying to do I have the front end sorted in with a
nice user interface and just trying to sort out this bit. I got it to do
stright pipes at 180 and 90 etc but no curves and a such but it looks like
with the help of you guys i will get there
Many Thanks
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18453.html
And what you intend to do with this work?
2016-09-21 4:55 GMT-03:00 dandare2020 dandare2020@gmail.com:
MichaelATOz
Many Thanks
Dan
tp18425p18453.html
It's just something I'm playing with at work to see what is possible. we are
buying the smart Cast system but just fancied playing really and openscad
does seem to have potential in some applications so I thought I would see
what it can do. Long term I would like to learn it in depth but I've always
been one for looking at code and working out what it does and then playing I
seem to learn better this way for some reason
Cheers
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18460.html
Morning Ronaldo
Could you send me the code please so i can have a play. I have a few hours
spare today. Once i have everything connected together i have no issues
uploading all the files and code for the front end and the connection to the
openscad so others can play and use if wanted.
Regards
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18461.html
Hi, Dan. I needed one more day to organize the code mess and adapt it to
OpenSCAD customizer, a nice way to present and explore demos.
pipe_junction2.scad
http://forum.openscad.org/file/n18462/pipe_junction2.scad
Be careful with the resolution parameters; even the preview (which is a
really mess) requires a distressing time to process. Raise the resolution
only after the other parameters fulfill your requirements,.
Hope it helps.
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18462.html
That looks fantastic thank you. I'll have a play to see how close i can get
with removing the rings etc. It will give me somthing to do tonight i'm sure
my partner will be happy lol
Thank you
Dan
View this message in context: http://forum.openscad.org/Curved-Cylinders-tp18425p18463.html
