Apple M1 migtation
Sun, Jan 10, 2021 9:55 AM
I have always known that OpenCSG difference was a lot more expensive than
union. Union simply draws the objects on top of each other. Difference does
some tricks drawing negative objects.
With Bob's object the slow draw speed was because the arc section has a lot
of facets. It gets unioned with the rest and then the holes and text are
subtracted. That makes OpenSCG draw very slow. Shortening the arc so that
it doesn't intersect the screw holes means it can be unioned outside the
difference. It then draws very quickly, problem solved.
What puzzles me though is why does OpenCSG care how many facets there are?
We know it can draw the arc very fast in a union. Why do subsequent
differences slow down when it is simply drawing negative pixels over the
top? Why does it care what complexity the thing it is drawing over has when
it has already been drawn as pixels?
On Sun, 10 Jan 2021 at 05:02, MichaelAtOz oz.at.michael@gmail.com wrote:
oops...I keep forgetting I'm using S/W rendering on my VM.
Sent: Sun, 10 Jan 2021 14:29
Subject: Re: [OpenSCAD] Apple M1 migtation
I don't think it is restricted to Mac.
I've just compared my complex model in RC5 v's 2019.05.
In 2019.05 preview repaint is bad at ~5s, ie, click view/front icon, 5s
to repaint.
In RC5 it is unusable.
The repaint overwhelms the GUI handling.
I got to the point where I clicked the close X,
but as I had unsaved changes, I got the 'do you want to save'
dialogue, but as that overlayed the viewport, it went to
repaint, clicking 'cancel' typing Esc was ignored.
I pulled up another windows, then minimised it,
OpenSCAD repainted the editor & console (in ~3s), tries to
repaint the viewport, and never gets to repaint
the dialogue box.
I think this needs fixing before release.
I'll raise an Issue with further info.
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf
Of caggius
Sent: Sat, 9 Jan 2021 21:21
I am also having a love hate relationship with my new M1.
The primary purpose of buying a new computer was to reduce the long
CGAL
rendering (F6) times of some of my larger models (WW2 Spitfire Cockpit
Instruments) on my 2012 I7 Macbook.  Some can take 40+ minutes.
A lot of this could possibly be down to the way that I use OpenScad
and not
understanding any of the tuning options.
The M1 will F6 render faster than the i7 at around 175% so good news
there.
However the big problem that I have is that trying to change the
viewpoint
in preview mode on my more complex models has dropped from around 4 or
5fps
to around 2 seconds per frame making it totally unusable.
Any thoughts or suggestions ?
http://forum.openscad.org/file/t3083/Screenshot_2021-01-09_at_10.png
I have always known that OpenCSG difference was a lot more expensive than union. Union simply draws the objects on top of each other. Difference does some tricks drawing negative objects. With Bob's object the slow draw speed was because the arc section has a lot of facets. It gets unioned with the rest and then the holes and text are subtracted. That makes OpenSCG draw very slow. Shortening the arc so that it doesn't intersect the screw holes means it can be unioned outside the difference. It then draws very quickly, problem solved. What puzzles me though is why does OpenCSG care how many facets there are? We know it can draw the arc very fast in a union. Why do subsequent differences slow down when it is simply drawing negative pixels over the top? Why does it care what complexity the thing it is drawing over has when it has already been drawn as pixels? On Sun, 10 Jan 2021 at 05:02, MichaelAtOz <oz.at.michael@gmail.com> wrote: > oops...I keep forgetting I'm using S/W rendering on my VM. > > > -----Original Message----- > > From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of > MichaelAtOz > > Sent: Sun, 10 Jan 2021 14:29 > > To: 'OpenSCAD general discussion' > > Subject: Re: [OpenSCAD] Apple M1 migtation > > > > I don't think it is restricted to Mac. > > I've just compared my complex model in RC5 v's 2019.05. > > In 2019.05 preview repaint is bad at ~5s, ie, click view/front icon, 5s > to repaint. > > In RC5 it is unusable. > > > > The repaint overwhelms the GUI handling. > > I got to the point where I clicked the close X, > > but as I had unsaved changes, I got the 'do you want to save' > > dialogue, but as that overlayed the viewport, it went to > > repaint, clicking 'cancel' typing Esc was ignored. > > > > I pulled up another windows, then minimised it, > > OpenSCAD repainted the editor & console (in ~3s), tries to > > repaint the viewport, and never gets to repaint > > the dialogue box. > > > > I think this needs fixing before release. > > I'll raise an Issue with further info. > > > > > > > -----Original Message----- > > > From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf > Of caggius > > > Sent: Sat, 9 Jan 2021 21:21 > > > To: discuss@lists.openscad.org > > > Subject: Re: [OpenSCAD] Apple M1 migtation > > > > > > I am also having a love hate relationship with my new M1. > > > > > > The primary purpose of buying a new computer was to reduce the long > CGAL > > > rendering (F6) times of some of my larger models (WW2 Spitfire Cockpit > > > Instruments) on my 2012 I7 Macbook. Some can take 40+ minutes. > > > > > > A lot of this could possibly be down to the way that I use OpenScad > and not > > > understanding any of the tuning options. > > > > > > The M1 will F6 render faster than the i7 at around 175% so good news > there. > > > > > > However the big problem that I have is that trying to change the > viewpoint > > > in preview mode on my more complex models has dropped from around 4 or > 5fps > > > to around 2 seconds per frame making it totally unusable. > > > > > > Any thoughts or suggestions ? > > > <http://forum.openscad.org/file/t3083/Screenshot_2021-01-09_at_10.png> > > > > > > > > > > > > -- > > > Sent from: http://forum.openscad.org/ > > > > > > _______________________________________________ > > > OpenSCAD mailing list > > > Discuss@lists.openscad.org > > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > > > -- > > This email has been checked for viruses by AVG. > > https://www.avg.com > > > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > -- > This email has been checked for viruses by AVG. > https://www.avg.com > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Jan 13, 2021 11:59 AM
My 3D printer now has around 5000 entries in the CSG rendering chain. Most
of these are + and by adding some renders I can make them all +, so it's
just a list of Polysets to be drawn.
It now takes about 2s seconds to draw each frame and that makes panning
almost impossible due to a small mouse move making a big difference. I.e.
it is too sensitive. When the update rate is reasonable I can compensate
but when it lags two seconds it always overshoots massively. It would be
nice if the image panned the same distance the cursor moves instead of a
big multiple. Then I could just move the cursor the right amount and the
image would eventually catch up.
Who does it take 2 seconds for a reasonably modern laptop to draw 5000
polyhedra?
Yesterday I was looking at a VBO branch, by I think, thehans, but the
artefacts had timed out and today the branch seems to have gone. Is that
likely to speed up preview by an order of magnitude that I need?
Now that we have mouse click jumping to code location could the CSG
products dump use meaningful names instead of cube123, etc,? It would make
finding un render()ed differences and intersections easier. Although
OpenCSG unions are much faster than differences when you have thousands of
them the time adds up.
A lot of things in my model are not visible when assembled. For example a
PCB in an enclosure but it is still drawn with all its components and each
connector pin is a +hull object in the list. Is there anyway it can cull
these invisible polyhedra?
to repaint.
the dialogue box.
Of caggius
CGAL
and not
there.
viewpoint
or 5fps
My 3D printer now has around 5000 entries in the CSG rendering chain. Most of these are + and by adding some renders I can make them all +, so it's just a list of Polysets to be drawn. It now takes about 2s seconds to draw each frame and that makes panning almost impossible due to a small mouse move making a big difference. I.e. it is too sensitive. When the update rate is reasonable I can compensate but when it lags two seconds it always overshoots massively. It would be nice if the image panned the same distance the cursor moves instead of a big multiple. Then I could just move the cursor the right amount and the image would eventually catch up. Who does it take 2 seconds for a reasonably modern laptop to draw 5000 polyhedra? Yesterday I was looking at a VBO branch, by I think, thehans, but the artefacts had timed out and today the branch seems to have gone. Is that likely to speed up preview by an order of magnitude that I need? Now that we have mouse click jumping to code location could the CSG products dump use meaningful names instead of cube123, etc,? It would make finding un render()ed differences and intersections easier. Although OpenCSG unions are much faster than differences when you have thousands of them the time adds up. A lot of things in my model are not visible when assembled. For example a PCB in an enclosure but it is still drawn with all its components and each connector pin is a +hull object in the list. Is there anyway it can cull these invisible polyhedra? On Sun, 10 Jan 2021 at 09:55, nop head <nop.head@gmail.com> wrote: > I have always known that OpenCSG difference was a lot more expensive than > union. Union simply draws the objects on top of each other. Difference does > some tricks drawing negative objects. > > With Bob's object the slow draw speed was because the arc section has a > lot of facets. It gets unioned with the rest and then the holes and text > are subtracted. That makes OpenSCG draw very slow. Shortening the arc so > that it doesn't intersect the screw holes means it can be unioned outside > the difference. It then draws very quickly, problem solved. > > What puzzles me though is why does OpenCSG care how many facets there are? > We know it can draw the arc very fast in a union. Why do subsequent > differences slow down when it is simply drawing negative pixels over the > top? Why does it care what complexity the thing it is drawing over has when > it has already been drawn as pixels? > > > On Sun, 10 Jan 2021 at 05:02, MichaelAtOz <oz.at.michael@gmail.com> wrote: > >> oops...I keep forgetting I'm using S/W rendering on my VM. >> >> > -----Original Message----- >> > From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of >> MichaelAtOz >> > Sent: Sun, 10 Jan 2021 14:29 >> > To: 'OpenSCAD general discussion' >> > Subject: Re: [OpenSCAD] Apple M1 migtation >> > >> > I don't think it is restricted to Mac. >> > I've just compared my complex model in RC5 v's 2019.05. >> > In 2019.05 preview repaint is bad at ~5s, ie, click view/front icon, 5s >> to repaint. >> > In RC5 it is unusable. >> > >> > The repaint overwhelms the GUI handling. >> > I got to the point where I clicked the close X, >> > but as I had unsaved changes, I got the 'do you want to save' >> > dialogue, but as that overlayed the viewport, it went to >> > repaint, clicking 'cancel' typing Esc was ignored. >> > >> > I pulled up another windows, then minimised it, >> > OpenSCAD repainted the editor & console (in ~3s), tries to >> > repaint the viewport, and never gets to repaint >> > the dialogue box. >> > >> > I think this needs fixing before release. >> > I'll raise an Issue with further info. >> > >> > >> > > -----Original Message----- >> > > From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf >> Of caggius >> > > Sent: Sat, 9 Jan 2021 21:21 >> > > To: discuss@lists.openscad.org >> > > Subject: Re: [OpenSCAD] Apple M1 migtation >> > > >> > > I am also having a love hate relationship with my new M1. >> > > >> > > The primary purpose of buying a new computer was to reduce the long >> CGAL >> > > rendering (F6) times of some of my larger models (WW2 Spitfire Cockpit >> > > Instruments) on my 2012 I7 Macbook. Some can take 40+ minutes. >> > > >> > > A lot of this could possibly be down to the way that I use OpenScad >> and not >> > > understanding any of the tuning options. >> > > >> > > The M1 will F6 render faster than the i7 at around 175% so good news >> there. >> > > >> > > However the big problem that I have is that trying to change the >> viewpoint >> > > in preview mode on my more complex models has dropped from around 4 >> or 5fps >> > > to around 2 seconds per frame making it totally unusable. >> > > >> > > Any thoughts or suggestions ? >> > > <http://forum.openscad.org/file/t3083/Screenshot_2021-01-09_at_10.png >> > >> > > >> > > >> > > >> > > -- >> > > Sent from: http://forum.openscad.org/ >> > > >> > > _______________________________________________ >> > > OpenSCAD mailing list >> > > Discuss@lists.openscad.org >> > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >> > >> > -- >> > This email has been checked for viruses by AVG. >> > https://www.avg.com >> > >> > >> > _______________________________________________ >> > OpenSCAD mailing list >> > Discuss@lists.openscad.org >> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> -- >> This email has been checked for viruses by AVG. >> https://www.avg.com >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >
Wed, Jan 13, 2021 12:07 PM
On 13.01.21 12:59, nop head wrote: > Yesterday I was looking at a VBO branch, by I think, thehans, > but the artefacts had timed out and today the branch seems to > have gone. Is that likely to speed up preview by an order of > magnitude that I need? Latest updates are in: https://github.com/openscad/openscad/pull/1935 Last build: https://6490-1049088-gh.circle-artifacts.com/0/64-bit/OpenSCAD-2020.12.23.ci6490-x86-64_PR1935.zip ciao, Torsten.
Wed, Jan 13, 2021 12:57 PM
Thanks. It doesn't seem any different to OpenSCAD 2021.01.01.ci6570 playing
with them alongside each other.  Both somewhere between one and two seconds
per frame I think.
Thanks. It doesn't seem any different to OpenSCAD 2021.01.01.ci6570 playing with them alongside each other. Both somewhere between one and two seconds per frame I think. On Wed, 13 Jan 2021 at 12:08, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 13.01.21 12:59, nop head wrote: > > Yesterday I was looking at a VBO branch, by I think, thehans, > > but the artefacts had timed out and today the branch seems to > > have gone. Is that likely to speed up preview by an order of > > magnitude that I need? > > Latest updates are in: > https://github.com/openscad/openscad/pull/1935 > > Last build: > > https://6490-1049088-gh.circle-artifacts.com/0/64-bit/OpenSCAD-2020.12.23.ci6490-x86-64_PR1935.zip > > ciao, > Torsten. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
polyhedra?
This usually happens when an O(N) algorithm is used by a programmer
when he expects it to be "quick enough to be considered O(1)".
If you're not familiar with big-o-notation look it up at:
https://en.wikipedia.org/wiki/Big_O_notation
Of course this often happens at a library interface: if you write the
loop yourself you're likely to realize your mistake.
I observed this in "e2fsck". It opened a "simple database" to map
inodes to something. Now when you have a SHITLOAD of inodes, you
notice.... My big filesystems, extrapolated would have taken over a
month to fsck.
Turns out that the "simple database" designers meant it to be simple:
Not too many entries in a table. But, well designed: if you want many
that's possible too. Preferably you declare the expected number of
entries at creation time, but if not it will cope, albeit not
efficiently. Well e2fsck did not declare the expected number of
entries at creation time, so a low number like 139 was assumed. The
algorithm used is then O(N/139). For low N that (below 139) that's
O(1) as intended. But for large N like any reasonable number of inodes
that's O(N). For number-of-inodes below "a shitload", the problem is
manageable.
Anyway: "Expected finishing time: a month" is enough to debug, find,
and fix the problem. Then a restart of the still-running fsck results
in a fsck time of a couple of hours.
fsck expected iterating over all the inodes to be an O(N) operation:
repeating an O(1) operation (lookup that inode) N times is O(N). When
the underlying lookup becomes O(N), the whole loop becomes O(N^2)
which was unnecessary.
If you have a Linux system, my patch is included in there somewhere.
In the case at hand (openscad)... Someone with the right skillset
should look at it one day. And NOT stop at the library boundary:
"openCSG is just slow" but look into the actual problem.
You're saying that N=5000 is too slow. And you're saying that it
should be doable in O(N). Well with about 5G instructions available a
second, 1M instructions per object sounds like too much (improbable)
(*). Something in there is O(N^2) where it doesn't need to be. (like
in fsck described above).
(*) You can double check by halving the number of objects and measure
if you observe 1s redraw time (hint for O(N)), 0.5s (hint for N^2).
On Wed, Jan 13, 2021 at 11:59:44AM +0000, nop head wrote: > Who does it take 2 seconds for a reasonably modern laptop to draw 5000 > polyhedra? This usually happens when an O(N) algorithm is used by a programmer when he expects it to be "quick enough to be considered O(1)". If you're not familiar with big-o-notation look it up at: https://en.wikipedia.org/wiki/Big_O_notation Of course this often happens at a library interface: if you write the loop yourself you're likely to realize your mistake. I observed this in "e2fsck". It opened a "simple database" to map inodes to something. Now when you have a SHITLOAD of inodes, you notice.... My big filesystems, extrapolated would have taken over a month to fsck. Turns out that the "simple database" designers meant it to be simple: Not too many entries in a table. But, well designed: if you want many that's possible too. Preferably you declare the expected number of entries at creation time, but if not it will cope, albeit not efficiently. Well e2fsck did not declare the expected number of entries at creation time, so a low number like 139 was assumed. The algorithm used is then O(N/139). For low N that (below 139) that's O(1) as intended. But for large N like any reasonable number of inodes that's O(N). For number-of-inodes below "a shitload", the problem is manageable. Anyway: "Expected finishing time: a month" is enough to debug, find, and fix the problem. Then a restart of the still-running fsck results in a fsck time of a couple of hours. fsck expected iterating over all the inodes to be an O(N) operation: repeating an O(1) operation (lookup that inode) N times is O(N). When the underlying lookup becomes O(N), the whole loop becomes O(N^2) which was unnecessary. If you have a Linux system, my patch is included in there somewhere. In the case at hand (openscad)... Someone with the right skillset should look at it one day. And NOT stop at the library boundary: "openCSG is just slow" but look into the actual problem. You're saying that N=5000 is too slow. And you're saying that it should be doable in O(N). Well with about 5G instructions available a second, 1M instructions per object sounds like too much (improbable) (*). Something in there is O(N^2) where it doesn't need to be. (like in fsck described above). Roger. (*) You can double check by halving the number of objects and measure if you observe 1s redraw time (hint for O(N)), 0.5s (hint for N^2). -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Wed, Jan 13, 2021 1:02 PM
I wonder if there could be an optimisation when all the CGS terms are +
then simply draw them with OpenGL and not use OpenCSG at all.
polyhedra?
month to fsck.
manageable.
I wonder if there could be an optimisation when all the CGS terms are + then simply draw them with OpenGL and not use OpenCSG at all. On Wed, 13 Jan 2021 at 12:58, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Wed, Jan 13, 2021 at 11:59:44AM +0000, nop head wrote: > > Who does it take 2 seconds for a reasonably modern laptop to draw 5000 > > polyhedra? > > This usually happens when an O(N) algorithm is used by a programmer > when he expects it to be "quick enough to be considered O(1)". > > If you're not familiar with big-o-notation look it up at: > https://en.wikipedia.org/wiki/Big_O_notation > > Of course this often happens at a library interface: if you write the > loop yourself you're likely to realize your mistake. > > I observed this in "e2fsck". It opened a "simple database" to map > inodes to something. Now when you have a SHITLOAD of inodes, you > notice.... My big filesystems, extrapolated would have taken over a > month to fsck. > > Turns out that the "simple database" designers meant it to be simple: > Not too many entries in a table. But, well designed: if you want many > that's possible too. Preferably you declare the expected number of > entries at creation time, but if not it will cope, albeit not > efficiently. Well e2fsck did not declare the expected number of > entries at creation time, so a low number like 139 was assumed. The > algorithm used is then O(N/139). For low N that (below 139) that's > O(1) as intended. But for large N like any reasonable number of inodes > that's O(N). For number-of-inodes below "a shitload", the problem is > manageable. > > Anyway: "Expected finishing time: a month" is enough to debug, find, > and fix the problem. Then a restart of the still-running fsck results > in a fsck time of a couple of hours. > > fsck expected iterating over all the inodes to be an O(N) operation: > repeating an O(1) operation (lookup that inode) N times is O(N). When > the underlying lookup becomes O(N), the whole loop becomes O(N^2) > which was unnecessary. > > If you have a Linux system, my patch is included in there somewhere. > > In the case at hand (openscad)... Someone with the right skillset > should look at it one day. And NOT stop at the library boundary: > "openCSG is just slow" but look into the actual problem. > > You're saying that N=5000 is too slow. And you're saying that it > should be doable in O(N). Well with about 5G instructions available a > second, 1M instructions per object sounds like too much (improbable) > (*). Something in there is O(N^2) where it doesn't need to be. (like > in fsck described above). > > Roger. > > > (*) You can double check by halving the number of objects and measure > if you observe 1s redraw time (hint for O(N)), 0.5s (hint for N^2). > > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 > ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > f equals m times a. When your f is steady, and your m is going down > your a is going up. -- Chris Hadfield about flying up the space shuttle. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Wed, Jan 13, 2021 1:05 PM
Would it make sense for the UI to display the time it takes to perform
the current screen display?
2021.01.01.ci6570playing with them alongside each other.  Both
Would it make sense for the UI to display the time it takes to perform the current screen display? On 1/13/2021 7:57 AM, nop head wrote: > Thanks. It doesn't seem any different to OpenSCAD > 2021.01.01.ci6570playing with them alongside each other.  Both > somewhere between one and two seconds per frame I think. >
Wed, Jan 13, 2021 1:06 PM
Yes that would be nice, perhaps in the status bar?
per frame I think.
Yes that would be nice, perhaps in the status bar? On Wed, 13 Jan 2021 at 13:05, jon <jon@jonbondy.com> wrote: > Would it make sense for the UI to display the time it takes to perform the > current screen display? > On 1/13/2021 7:57 AM, nop head wrote: > > Thanks. It doesn't seem any different to OpenSCAD 2021.01.01.ci6570 playing > with them alongside each other. Both somewhere between one and two seconds > per frame I think. > >
Wed, Jan 13, 2021 1:14 PM
That's too simple. In your very simple case, that would help you and
only you.  But then adding a single non- + item, would cause a
fallback to the "other algorithm", and suddenly invoke other code and
also be slow. This is dangerous: You'll not realize that you're
not testing the other path.
For example when allocating a dynamic array:
init:
array = malloc (100);
space = 100;
curitems = 0;
use: add an item:
if (curitems == space) {
space = space * 2;
array = realloc (array, space);
array[curitems++] = newitem;
This is "nice", but now for "easy" test cases, you'll be adding all
items into the first 100 items allocated in the init routine. You'll
forget to test the realloc code!
Now if you initialize:
array = NULL
space = 0;
curitems = 0;
and use:
space = 1+ space * 2;
you'll test the "expand" code on every test. The "don't do the
complicated stuff in simple cases" programming trick is something to
be avoided when possible.
On Wed, Jan 13, 2021 at 01:02:27PM +0000, nop head wrote: > I wonder if there could be an optimisation when all the CGS terms are + > then simply draw them with OpenGL and not use OpenCSG at all. That's too simple. In your very simple case, that would help you and only you. But then adding a single non- + item, would cause a fallback to the "other algorithm", and suddenly invoke other code and also be slow. This is dangerous: You'll not realize that you're not testing the other path. For example when allocating a dynamic array: init: array = malloc (100); space = 100; curitems = 0; use: add an item: if (curitems == space) { space = space * 2; array = realloc (array, space); } array[curitems++] = newitem; This is "nice", but now for "easy" test cases, you'll be adding all items into the first 100 items allocated in the init routine. You'll forget to test the realloc code! Now if you initialize: array = NULL space = 0; curitems = 0; and use: if (curitems == space) { space = 1+ space * 2; array = realloc (array, space); } array[curitems++] = newitem; you'll test the "expand" code on every test. The "don't do the complicated stuff in simple cases" programming trick is something to be avoided when possible. Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Wed, Jan 13, 2021 1:26 PM
I think it would also help at least one other user of my library that also
uses it to design big machines with lots of parts.
I normally render all differences to avoid artefacts with negative objects
z-fighting and to get faster drawing. It would be easy to notice the slow
down and if the CGS dump used meaningful names easy to find the unrendered
difference and fix it.
I don't know any other way to make large models draw at a reasonable speed.
As can be seen from caggius' example it is easy to make OpeCSG crawl with
just a small assembly like his. By structuring my library to avoid 3D
difference as much as possible and render any that are necessary, I manage
to keep a balance between the preview taking too long and the frame rate
being too slow. Does anybody else make large assemblies with OpenSCAD
without using NopSCADlib or the techniques I describe?
init:
space = 100;
curitems = 0;
use: add an item:
space = space * 2;
array = NULL
space = 0;
curitems = 0;
and use:
> In your very simple case, that would help you and only you. But then adding a single non- + item, would cause a fallback to the "other algorithm" I think it would also help at least one other user of my library that also uses it to design big machines with lots of parts. I normally render all differences to avoid artefacts with negative objects z-fighting and to get faster drawing. It would be easy to notice the slow down and if the CGS dump used meaningful names easy to find the unrendered difference and fix it. I don't know any other way to make large models draw at a reasonable speed. As can be seen from caggius' example it is easy to make OpeCSG crawl with just a small assembly like his. By structuring my library to avoid 3D difference as much as possible and render any that are necessary, I manage to keep a balance between the preview taking too long and the frame rate being too slow. Does anybody else make large assemblies with OpenSCAD without using NopSCADlib or the techniques I describe? On Wed, 13 Jan 2021 at 13:15, Rogier Wolff <R.E.Wolff@bitwizard.nl> wrote: > On Wed, Jan 13, 2021 at 01:02:27PM +0000, nop head wrote: > > I wonder if there could be an optimisation when all the CGS terms are + > > then simply draw them with OpenGL and not use OpenCSG at all. > > That's too simple. In your very simple case, that would help you and > only you. But then adding a single non- + item, would cause a > fallback to the "other algorithm", and suddenly invoke other code and > also be slow. This is dangerous: You'll not realize that you're > not testing the other path. > > For example when allocating a dynamic array: > > init: > array = malloc (100); > space = 100; > curitems = 0; > > use: add an item: > if (curitems == space) { > space = space * 2; > array = realloc (array, space); > } > array[curitems++] = newitem; > > This is "nice", but now for "easy" test cases, you'll be adding all > items into the first 100 items allocated in the init routine. You'll > forget to test the realloc code! > > Now if you initialize: > array = NULL > space = 0; > curitems = 0; > > and use: > if (curitems == space) { > space = 1+ space * 2; > array = realloc (array, space); > } > array[curitems++] = newitem; > > you'll test the "expand" code on every test. The "don't do the > complicated stuff in simple cases" programming trick is something to > be avoided when possible. > > Roger. > > -- > ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 > ** > ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** > f equals m times a. When your f is steady, and your m is going down > your a is going up. -- Chris Hadfield about flying up the space shuttle. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
