@Marius. The following is nonsense from a semantical point of view, but it
shouldn't fail.
a = [each for(i=[1]) i];
shouldn't 'each' be always followed by a list ?
Yes, but OpenSCAD shouldn't crash on a syntax error.
@runsun in general the parser doesn't know what a for loop will return. Thus
it is not a syntax error
E.g. this is correct:
a = [each for(i=[1,2]) [i]];
Or this
a = [each [for(i=[1]) i]];
Rather than assert should it return undef or just return the scalar?
Thus
I would expect a run time error.
shouldn't fail.
This is covered by https://github.com/openscad/openscad/issues/1851
Why? What's the benefit of making it an error?
The proposal for each reads:
https://github.com/doug-moen/openscad2/blob/master/rfc/Generators.md
The each operator is new: it takes a sequence value
as argument, and adds each element to the list being
constructed. each x is equivalent to for(i=x)i.
So according to that, both lines should be identical:
echo([for(i=3) i]);
echo([each 3]);
The first one currently gives
ECHO: [3]
Torsten,
I wanted to say, I'd rather expect a runtime error instead of a failure! But
you are right, "each" can be implemented to not fail in this situation. Thus
a = [each for(i=[1:10]) i];
should be equivalent to
a = [for(i=[1:10]) i];
Why is this important? Because I want to write e.g.
a = [each for(i=[1:10]) myfunc(i)];
and there is no guarantee that e.g. myfunc() will return only list elements.
Yes, that's what I was thinking too.
echo([each for(i=1) i]);
echo([each for(i=[1,2]) i]);
echo([each for(i=[1,2,[3,4]]) i]);
echo([each for(i=[1,2,[3,4,[5,6]]]) i]);
echo([each each for(i=[1,2,[3,4,[5,6]]]) i]);
echo([each each for(i=[1,2,[3,4,[5,6,[7,8]]]]) i]);
echo([each each each for(i=[1,2,[3,4,[5,6,[7,8]]]]) i]);
ECHO: [1]
ECHO: [1, 2]
ECHO: [1, 2, 3, 4]
ECHO: [1, 2, 3, 4, [5, 6]]
ECHO: [1, 2, 3, 4, 5, 6]
ECHO: [1, 2, 3, 4, 5, 6, [7, 8]]
ECHO: [1, 2, 3, 4, 5, 6, 7, 8]
Any other cases I may have missed?
