each - Assertion failed on flat list
Sun, Apr 29, 2018 1:25 PM
It is a question of semantics.
The avoid-runtime-errors-rule would be (in pseudo code):
if (isscalar(value)) value;
else flatten(value);
and it would flatten down scalars and non-nested lists to the same level. Is
this desired?
Implementing the runtime-errors-rule would be more strict:
assert(!isscalar(value)) flatten(value);
It is a question of semantics. The avoid-runtime-errors-rule would be (in pseudo code): if (isscalar(value)) value; else flatten(value); and it would flatten down scalars and non-nested lists to the same level. Is this desired? Implementing the runtime-errors-rule would be more strict: assert(!isscalar(value)) flatten(value); -- Sent from: http://forum.openscad.org/
