Hello,
I have the following code which appears fine in F6 render (and makes a
manifold mesh afaics) but does not appear in the F5 preview.
I tried adding convexity=10 to each union/difference/hull which often
works for me, but made no difference here.
I realise I am abusing hull() to avoid making proper polyhedrons out
of laziness, but this code theoretically still should work shouldn't
it?
Jamie
$fn = 180;
e = 0.001;
f = 0.25;
module dual_bushing_holder() {
// body
cylinder(d=15,h=40);
translate([0,0,-1]) #cylinder(d=14,h=42);
// left middle tab
hull() {
translate([-14.5,-1,18.25]) cube([e,2,3.5]);
translate([-7.5+f,-1,8.5]) cube([e,2,23]);
// screw hole
translate([-11.25,-2,20]) rotate([-90,0,0]) cylinder(d=3.3,h=4);
// right upper tab
hull() {
translate([7.5-f,-1,25]) cube([e,2,15]);
translate([14.5,-1,32.25]) cube([e,2,7.75]);
// screw hole
translate([11.25,-2,35.25]) rotate([-90,0,0]) cylinder(d=3.3,h=4);
// right lower tab
hull() {
translate([7.5-f,-1,0]) cube([e,2,15]);
translate([14.5,-1,0]) cube([e,2,7.75]);
// screw hole
translate([11.25,-2,4.75]) rotate([-90,0,0]) cylinder(d=3.3,h=4);
dual_bushing_holder();
Previews fine for me with OpenSCAD version 2017.11.12 (git 7cb1e93) on Win7
64.
On 11 April 2018 at 12:39, Jamie Bainbridge jamie.bainbridge@gmail.com
Hello,
it?
Jamie
$fn = 180;
e = 0.001;
f = 0.25;
// body
// left middle tab
hull() {
// screw hole
// right upper tab
hull() {
// screw hole
// right lower tab
hull() {
// screw hole
Also fine in dev previews 2018.01.x and 2018.04.x for Windows 64
nice code, btw.
Is this the problem of the out of date graphics library that I asked about recently? I had the same "malfunction". I am away from my main computer so cannot look up previous posts. Someone with a better memory than me will be able to direct you to a snapshot that directly incorporates the later library to correct it. It certainly cured exactly that problem for me. (I am embarrassed I can't thank the person who helped me.)
Cheers, RobW
nice code, btw.
That happens to me now and then. I think the version I have is 2018
(something).
What seems to fix it is resizing the rendering window
Thanks all for the responses. I neglected to say I'm using Ubuntu
16.04 and the latest OpenSCAD nightly from t-paul's repo.
Exploring more, preview sometimes works but isn't 100% reliable for me.
For example I can save the file, quit OpenSCAD, open the file again,
and the preview works fine. However if I then press F6 to render then
F5 to preview, the shape disappears.
I'll experiment more with polyhedrons and in some Windows VMs I have.
Maybe it's a Linux-only problem.
Jamie
I think that Ubuntu still has opencsg < 1.4.2. You could verify
that in the Help->Library Info window.
Older versions of opencsg have an issue that could cause the
effects you describe.
Aha you are correct, I have OpenCSG 1.4.0
So no reproducing by others on Windows and a known library problem on
Linux, I think this one is solved. Thank you!
Looks like I have something to look forward to once Ubuntu 18.04 comes out.
Jamie
On 12 April 2018 at 15:35, Jamie Bainbridge jamie.bainbridge@gmail.com wrote:
To follow up on this, I fixed it with later libraries:
This has solved the problem, I cannot reproduce the disappear-on-F5 at all.
Thanks again Torsten!
Jamie
Thanks for following up. I've also been seeing this on Ubuntu 17.10.
On Fri, Apr 13, 2018 at 4:50 PM Jamie Bainbridge jamie.bainbridge@gmail.com
Jamie
