Object appears in F6 render but not F5 preview
Jamie Bainbridge
Sun, Apr 15, 2018 2:18 AM
17.10 also has OpenCSG 1.4.0: https://pkgs.org/download/opencsg
So the same cause, and the same solution should work for you too.
Jamie
On 15 April 2018 at 08:40, Don Garrett dgarrett@acm.org wrote:
Thanks for following up. I've also been seeing this on Ubuntu 17.10.
On Fri, Apr 13, 2018 at 4:50 PM Jamie Bainbridge
jamie.bainbridge@gmail.com wrote:
On 12 April 2018 at 15:35, Jamie Bainbridge jamie.bainbridge@gmail.com
On 12 April 2018 at 08:52, Torsten Paul Torsten.Paul@gmx.de wrote:
I think that Ubuntu still has opencsg < 1.4.2. You could verify
that in the Help->Library Info window.
Older versions of opencsg have an issue that could cause the
effects you describe.
Aha you are correct, I have OpenCSG 1.4.0
To follow up on this, I fixed it with later libraries:
  • Remove libopencsg1_1.4.0 from Ubuntu 16.04 (this removes
    openscad-nightly but that's okay)
  • Install libglew2 and openscg1_1.4.2 from Ubuntu unstable (soon to be
    18.04 LTS)
  • Install openscad-nightly again
This has solved the problem, I cannot reproduce the disappear-on-F5 at
all.
Thanks again Torsten!
Jamie
17.10 also has OpenCSG 1.4.0: https://pkgs.org/download/opencsg So the same cause, and the same solution should work for you too. Jamie On 15 April 2018 at 08:40, Don Garrett <dgarrett@acm.org> wrote: > Thanks for following up. I've also been seeing this on Ubuntu 17.10. > > On Fri, Apr 13, 2018 at 4:50 PM Jamie Bainbridge > <jamie.bainbridge@gmail.com> wrote: >> >> On 12 April 2018 at 15:35, Jamie Bainbridge <jamie.bainbridge@gmail.com> >> wrote: >> > On 12 April 2018 at 08:52, Torsten Paul <Torsten.Paul@gmx.de> wrote: >> >> I think that Ubuntu still has opencsg < 1.4.2. You could verify >> >> that in the Help->Library Info window. >> >> >> >> Older versions of opencsg have an issue that could cause the >> >> effects you describe. >> > >> > Aha you are correct, I have OpenCSG 1.4.0 >> >> To follow up on this, I fixed it with later libraries: >> >> * Remove libopencsg1_1.4.0 from Ubuntu 16.04 (this removes >> openscad-nightly but that's okay) >> * Install libglew2 and openscg1_1.4.2 from Ubuntu unstable (soon to be >> 18.04 LTS) >> * Install openscad-nightly again >> >> This has solved the problem, I cannot reproduce the disappear-on-F5 at >> all. >> >> Thanks again Torsten! >> >> Jamie >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Rob Ward
Sun, Apr 15, 2018 4:38 AM
Mmmh, that is annoying. The snapshot I am using works fine, over riding the resident library, but it is frustrating that a later version of Ubuntu does not fix the underlying problem mine now has. I was looking forward to cleaning that up with an upgrade. Grrrrr!
Cheers, RobW
On 15 April 2018 12:18:18 pm AEST, Jamie Bainbridge jamie.bainbridge@gmail.com wrote:
Jamie
be
18.04 LTS)
at
all.
Jamie
Mmmh, that is annoying. The snapshot I am using works fine, over riding the resident library, but it is frustrating that a later version of Ubuntu does not fix the underlying problem mine now has. I was looking forward to cleaning that up with an upgrade. Grrrrr! Cheers, RobW On 15 April 2018 12:18:18 pm AEST, Jamie Bainbridge <jamie.bainbridge@gmail.com> wrote: >17.10 also has OpenCSG 1.4.0: https://pkgs.org/download/opencsg > >So the same cause, and the same solution should work for you too. > >Jamie > >On 15 April 2018 at 08:40, Don Garrett <dgarrett@acm.org> wrote: >> Thanks for following up. I've also been seeing this on Ubuntu 17.10. >> >> On Fri, Apr 13, 2018 at 4:50 PM Jamie Bainbridge >> <jamie.bainbridge@gmail.com> wrote: >>> >>> On 12 April 2018 at 15:35, Jamie Bainbridge ><jamie.bainbridge@gmail.com> >>> wrote: >>> > On 12 April 2018 at 08:52, Torsten Paul <Torsten.Paul@gmx.de> >wrote: >>> >> I think that Ubuntu still has opencsg < 1.4.2. You could verify >>> >> that in the Help->Library Info window. >>> >> >>> >> Older versions of opencsg have an issue that could cause the >>> >> effects you describe. >>> > >>> > Aha you are correct, I have OpenCSG 1.4.0 >>> >>> To follow up on this, I fixed it with later libraries: >>> >>> * Remove libopencsg1_1.4.0 from Ubuntu 16.04 (this removes >>> openscad-nightly but that's okay) >>> * Install libglew2 and openscg1_1.4.2 from Ubuntu unstable (soon to >be >>> 18.04 LTS) >>> * Install openscad-nightly again >>> >>> This has solved the problem, I cannot reproduce the disappear-on-F5 >at >>> all. >>> >>> Thanks again Torsten! >>> >>> Jamie >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >_______________________________________________ >OpenSCAD mailing list >Discuss@lists.openscad.org >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
DG
Don Garrett
Sun, Apr 15, 2018 5:23 AM
The next LTS release should fix it, and due soon.
Cheers, RobW
Jamie
    18.04 LTS)
all.
Jamie
The next LTS release should fix it, and due soon. On Sat, Apr 14, 2018, 21:39 Rob Ward <rl.ward@bigpond.com> wrote: > Mmmh, that is annoying. The snapshot I am using works fine, over riding > the resident library, but it is frustrating that a later version of Ubuntu > does not fix the underlying problem mine now has. I was looking forward to > cleaning that up with an upgrade. Grrrrr! > > Cheers, RobW > > On 15 April 2018 12:18:18 pm AEST, Jamie Bainbridge < > jamie.bainbridge@gmail.com> wrote: > >> 17.10 also has OpenCSG 1.4.0: https://pkgs.org/download/opencsg >> >> So the same cause, and the same solution should work for you too. >> >> Jamie >> >> On 15 April 2018 at 08:40, Don Garrett <dgarrett@acm.org> wrote: >> >> Thanks for following up. I've also been seeing this on Ubuntu 17.10. >>> >>> On Fri, Apr 13, 2018 at 4:50 PM Jamie Bainbridge >>> <jamie.bainbridge@gmail.com> wrote: >>> >> >>>> On 12 April 2018 at 15:35, Jamie Bainbridge <jamie.bainbridge@gmail.com> >>>> wrote: >>>> >>>>> On 12 April 2018 at 08:52, Torsten Paul <Torsten.Paul@gmx.de> wrote: >>>>> >>>>>> I think that Ubuntu still has opencsg < 1.4.2. You could verify >>>>>> that in the Help->Library Info window. >>>>>> >>>>>> Older versions of opencsg have an issue that could cause the >>>>>> effects you describe. >>>>>> >>>>> >>>>> Aha you are correct, I have OpenCSG 1.4.0 >>>>> >>>> >>>> To follow up on this, I fixed it with later libraries: >>>> >>>> * Remove libopencsg1_1.4.0 from Ubuntu 16.04 (this removes >>>> openscad-nightly but that's okay) >>>> * Install libglew2 and openscg1_1.4.2 from Ubuntu unstable (soon to be >>>> 18.04 LTS) >>>> * Install openscad-nightly again >>>> >>>> This has solved the problem, I cannot reproduce the disappear-on-F5 at >>>> all. >>>> >>>> Thanks again Torsten! >>>> >>>> Jamie >>>> >>>> ------------------------------ >>>> >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> >>> >>> ------------------------------ >>> >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> >> >> ------------------------------ >> >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
