Sun, May 11, 2025 10:08 PM
On 5/11/25 15:31, Torsten Paul via Discuss wrote:
On 10.05.25 03:21, gene heskett via Discuss wrote:
Torsten: While I realize the market size is extremely out of balance
in favor of windows, please do not forget that OpenSCAD is also a
linux application.
Poking the wrong person here :-). I'm running Linux on my personal
systems since Debian 1.3 (bo, 1997), ignoring the even earlier
Slackware from 23 floppy disk dances. So I'm certainly not going to
forget Linux.
While I switched from amigados 3.1 to redhat 5.0 with a stack of
floppy's in late 1998.
But back to the topic of virtual environments. It would be useful
to hear from people who want to use OpenSCAD + Python. What's the
view on this?
I am not a python expert by any definition. I does seem to make a
bulletproof VPN, insulating AppImages from the sometimes ugly vagaries
of the arm64 crowd. And its heavily used for that here. But it it
upchucks, I'm lost.
Right now some official OpenSCAD nightly builds have basic
support for creating a virtual environment that can be used to
install external package for use in OpenSCAD.
(Menu: File -> Python -> Create Virtual Environment ; Select an
empty folder ; Wait for the "Success" popup ; Restart OpenSCAD)
Sounds pretty simple. But I'll likely object if it does not run w/o the
VPN at some point in the future.
Status:
- AppImage: Works for me :-), may have issues on some distros.
AppImages have been bulletproof on bananapi-m5's here, but OpenSCAD not
tested on the pi clones, not (generally) enough fast memory.
- Flatpak: should work wherever the flatpak itself works
I have problems with amd64 flatpaks here, prusaslicer for amd64
switched to flatpak about 6 months back, didn't work here on this 6 core
i5 with 32 GB of memory, and installed over 50,000 files in its home
directory. That is equ to a whole linux install. I deleted it all just
on general principles. Untried on arm64's due to slow u-sd card memory.
- Snap: nope, not working yet, all tries so far failed
FF Works fine on arm64 stuff as a snap. Armbian linux. Jammie or
nobel. Quite stable. Power failure to power failure.
- Distro Packages: untested, probably needs some minor changes
- Windows: nope, no Python yet
- MacOS: nope, no Python yet
Thank you for listening, Torsten. Appreciated.
Cheers, Gene Heskett, CET.
>> linux application.
> forget Linux.
> view on this?
upchucks, I'm lost.
> Right now *some* official OpenSCAD nightly builds have basic
> Status:
> - Flatpak: *should* work wherever the flatpak itself works
> ciao,
> Torsten.
- Louis D. Brandeis
CF
Carsten Fuchs
Mon, May 12, 2025 5:22 AM
Hello,
Am 09.05.25 um 22:02 schrieb Torsten Paul via Discuss:
As far as I'm aware it's the only way that allows people to
be flexible in regard to the python version.
If you use the AppImage, the Python version is fixed in that
build. So for people to use external libraries, those have
to match exactly the python version in the AppImage.
Virtual environments are one solution for that. There may
be others, I'm happy to hear about those. Or if people think
venvs are useless and it's just me thinking they are a must.
I'm with you on venvs. In my experience, venvs are a lightweight and straightforward way to isolate Python "installations" from each other and the OS.
The recently upcoming "uv" tool makes this even simpler (https://github.com/astral-sh/uv), but Python's built-in venv module might as well be sufficient. (I normally just use the version of Python that comes with the OS for python3 -m venv .venv, but if that is outdated, "uv" really saves the day.)
Best regards,
Carsten
Dipl.-Inf. Carsten Fuchs
Industriegebiet 3 ℅ Rofu
55768 Hoppstädten-Weiersbach
https://www.cafu.de
Hello,
The recently upcoming "uv" tool makes this even simpler (https://github.com/astral-sh/uv), but Python's built-in venv module might as well be sufficient. (I normally just use the version of Python that comes with the OS for `python3 -m venv .venv`, but if that is outdated, "uv" really saves the day.)
Best regards,
Carsten
https://www.cafu.de
John David
Mon, May 12, 2025 6:24 AM
I've broken out a little time to start playing with PythonSCAD. I'm having
some confusion with how it is discussed online if it is a separate effort,
or now in the most current versions of OpenSCAD. What is the best way to
install/build? In specific, I am still trying to solve the issue of
building colored SVGs, or any other input that is accepted by LaserGRBL or
LightBurn (which I am trying to move away from). @Guenther Sohler
guenther.sohler@gmail.com, last week you posted an image of PythonSCAD
that appears to be from the 2025.05.06 build. Would the same functionality
already be included in the 2025.04.24 code? I got that one already
installed. I tried running the code in your image (that started with "from
openscad import *"), and it failed on the first line. Is there some trick
to starting with python instead of a scad file?
On Mon, May 12, 2025 at 1:22 AM Carsten Fuchs via Discuss <
Hello,
the OS.
Best regards,
Carsten
https://www.cafu.de
<guenther.sohler@gmail.com>, last week you posted an image of PythonSCAD
> Hello,
> the OS.
> Best regards,
> Carsten
> https://www.cafu.de
KE
Karl Exler
Mon, May 12, 2025 7:07 AM
ähmm.. for all of us, who are not Prgrammers and who are happy to have
with OpenScad a fine modelling software..... has all this Phyton
"tamtam" any relevance for us ?
yours
Karl
Am 12.05.25 um 08:24 schrieb John David via Discuss:
having some confusion with how it is discussed online if it is a
separate effort, or now in the most current versions of OpenSCAD.
What is the best way to install/build? In specific, I am still trying
to solve the issue of building colored SVGs, or any other input that
is accepted by LaserGRBL or LightBurn (which I am trying to move away
from). @Guenther Sohler mailto:guenther.sohler@gmail.com, last week
you posted an image of PythonSCAD that appears to be from the
2025.05.06 build. Would the same functionality already be included in
the 2025.04.24 code? I got that one already installed. I tried
running the code in your image (that started with "from openscad
import *"), and it failed on the first line. Is there some trick to
Hello,
Best regards,
Carsten
https://www.cafu.de
yours
Karl
> from). @Guenther Sohler <mailto:guenther.sohler@gmail.com>, last week
> <discuss@lists.openscad.org> wrote:
> Hello,
> Best regards,
> Carsten
> https://www.cafu.de
Michael Möller
Mon, May 12, 2025 7:09 AM
with OpenScad a fine modelling software..... has all this Phyton "tamtam"
yours
Karl
having some confusion with how it is discussed online if it is a separate
effort, or now in the most current versions of OpenSCAD. What is the best
way to install/build? In specific, I am still trying to solve the issue of
Hello,
the OS.
Best regards,
Carsten
https://www.cafu.de
+1
man. 12. maj 2025 09.07 skrev Karl Exler via Discuss <
discuss@lists.openscad.org>:
> yours
> Karl
>> Hello,
>> the OS.
>> Best regards,
>> Carsten
>> https://www.cafu.de
Mon, May 12, 2025 8:03 AM
No, not at all.
From user side it's not much different from the huge number of
existing Python solutions generating OpenSCAD code.
This is just a much better integrated, but optional solution for
those cases.
William very much highlighted the point why I'm supporting this
even though I'm likely to continue using OpenSCAD scripts for my
own models:
Maybe bringing in some more ideas and development that hopefully
can benefit both OpenSCAD scripting and Python use.
No, not at all.
those cases.
own models:
John David
Mon, May 12, 2025 8:04 AM
I only have Linux machines. So the Win* install will not be so useful.
I do not have a "python" tab, and saving/running via a .py file is not
working. I'll look at compiling up a newer version. Is there a particular
branch or forked repository I need to work with?
EBo --
On Mon, May 12, 2025 at 3:09 AM Michael Möller via Discuss <
yours
Karl
Hello,
the OS.
Best regards,
Carsten
https://www.cafu.de
EBo --
> +1
>> yours
>> Karl
>>> Hello,
>>> the OS.
>>> Best regards,
>>> Carsten
>>> https://www.cafu.de
Mon, May 12, 2025 8:07 AM
particular branch or forked repository I need to work with?
For OpenSCAD master branch, you need to enable Python both on
compile time:
-DENABLE_PYTHON=ON
and on runtime:
CLI: --enable=python-engine --trust-python
GUI: Preferences->Features->Python-Engine
compile time:
-DENABLE_PYTHON=ON
and on runtime:
PK
Peter Kriens
Mon, May 12, 2025 8:29 AM
I am running the snapshot on MacOS:
I can neither see GUI: Preferences->Features->Python-Engine nor can I start the command line with the options CLI: --enable=python-engine --trust-python. I assume the CLI on Mac is in /Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD
Do I need to download another snapshot? I tried to find a landing page for getting started with Openscad python but I am a bit confused.
Kind regards,
Peter Kriens
On 12 May 2025, at 10:07, Torsten Paul via Discuss discuss@lists.openscad.org wrote:
I do not have a "python" tab, and saving/running via a .py file is not working. I'll look at compiling up a newer version. Is there a particular branch or forked repository I need to work with?
compile time:
-DENABLE_PYTHON=ON
and on runtime:
I can neither see `GUI: Preferences->Features->Python-Engine` nor can I start the command line with the options `CLI: --enable=python-engine --trust-python`. I assume the CLI on Mac is in `/Applications/OpenSCAD.app/Contents/MacOS/OpenSCAD`
Kind regards,
Peter Kriens
> On 12 May 2025, at 10:07, Torsten Paul via Discuss <discuss@lists.openscad.org> wrote:
> compile time:
> -DENABLE_PYTHON=ON
> and on runtime:
> ciao,
> Torsten.
Mon, May 12, 2025 8:36 AM
Quoting myself for the official OpenSCAD nightly build:
Status:
- AppImage: Works for me 🙂, may have issues on some distros
Sorry, I don't have the energy to explain the story again,
I'll leave that to Guenter.
I suppose there should be a web page explaining this, I
don't have enough spare time to do all that.
Status:
