Print version of OpenSCAD manual
Jerry Davis
Sun, Mar 20, 2016 9:58 PM
thanks, runsun.
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
- Isaac. Asimov
I
Anonymous
- Ken Thompson
On Sun, Mar 20, 2016 at 2:40 PM, runsun runsun@gmail.com wrote:
jdawgaz wrote
I found the github link in that thread, and downloaded and ran the
openscad_offliner.py script. got this:
I'll take a look.
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ),
runscad.py( 1 , 2 , git ), synwrite( 1 , 2 );  $ tips: hash( 1 , 2 ),
sweep( 1 , 2 ), var( 1 , 2 ), lerp , animGif , prodVid , precision( 1 , 2
), xl-control , type , rounded polygon
View this message in context:
http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16603.html
thanks, runsun. -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson On Sun, Mar 20, 2016 at 2:40 PM, runsun <runsun@gmail.com> wrote: > jdawgaz wrote > > I found the github link in that thread, and downloaded and ran the > > openscad_offliner.py script. got this: > > I'll take a look. > > > > ----- > > $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), > runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), > sweep( 1 , 2 ), var( 1 , 2 ), lerp , animGif , prodVid , precision( 1 , 2 > ), xl-control , type , rounded polygon > > > > > > -- > View this message in context: > http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16603.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Mar 20, 2016 10:08 PM
@Larry:
The table of contents for the language reference manual at
/OpenSCAD_User_Manual is different from the table of contents in
/OpenSCAD_User_Manual/The_OpenSCAD_Language.
That's to be expected, because the former has to be edited by hand, while
the latter is automatically updated each time somebody modifies the
language reference manual.
There are lots of sections missing from the manually edited table of
contents, that are present in the automatically generated one. For example,
section 1.6 (Getting Input), section 6.1.2 (intersection_for), sections
6.2.5 to 6.2.8 (vector and matrix operations), section 8.7 (parent_module).
I also noticed that the automatically generated TOC was missing a section
header for Use and Include, so I just added the missing header.
I did some research and I find there is no way to transclude the
automatically generated table of contents from The_OpenSCAD_Language into
OpenSCAD_User_Manual. I don't like the idea of having two TOCs that are out
of sync, so my proposal is to delete the one that is manually maintained,
and keep the automatically generated one.
On 20 March 2016 at 17:36, L Boyd lboyd@frontiernet.net wrote:
I disagree with the statement that the contents at
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual, is not maintained and
is
inaccurate/out of date. When was the last time you looked at it?
Larry
http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16601.html
@Larry: The table of contents for the language reference manual at /OpenSCAD_User_Manual is different from the table of contents in /OpenSCAD_User_Manual/The_OpenSCAD_Language. That's to be expected, because the former has to be edited by hand, while the latter is automatically updated each time somebody modifies the language reference manual. There are lots of sections missing from the manually edited table of contents, that are present in the automatically generated one. For example, section 1.6 (Getting Input), section 6.1.2 (intersection_for), sections 6.2.5 to 6.2.8 (vector and matrix operations), section 8.7 (parent_module). I also noticed that the automatically generated TOC was missing a section header for Use and Include, so I just added the missing header. I did some research and I find there is no way to transclude the automatically generated table of contents from The_OpenSCAD_Language into OpenSCAD_User_Manual. I don't like the idea of having two TOCs that are out of sync, so my proposal is to delete the one that is manually maintained, and keep the automatically generated one. On 20 March 2016 at 17:36, L Boyd <lboyd@frontiernet.net> wrote: > I disagree with the statement that the contents at > https://en.wikibooks.org/wiki/OpenSCAD_User_Manual, is not maintained and > is > inaccurate/out of date. When was the last time you looked at it? > > > > ----- > Larry > -- > View this message in context: > http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16601.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
LB
L Boyd
Mon, Mar 21, 2016 12:06 AM
/OpenSCAD_User_Manual was the same as the table of contents in
/OpenSCAD_User_Manual/The_OpenSCAD_Language until someone recently deleted
the copy from /OpenSCAD_User_Manual/The_OpenSCAD_Language.
Yes, the automatically generated one needs less work to maintain. The
problem is it reflects the lack of logical order to the contents.  When
coupled with the length of the generated TOC, it becomes very difficult to
use it for navigation.
In the long run, it would be desirable to reorganize the content of the
various files to reflect a more logical order, thus allowing the generated
TOC to be easier to navigate.
Larry
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16609.html
The table of contents for the language reference manual at /OpenSCAD_User_Manual was the same as the table of contents in /OpenSCAD_User_Manual/The_OpenSCAD_Language until someone recently deleted the copy from /OpenSCAD_User_Manual/The_OpenSCAD_Language. Yes, the automatically generated one needs less work to maintain. The problem is it reflects the lack of logical order to the contents. When coupled with the length of the generated TOC, it becomes very difficult to use it for navigation. In the long run, it would be desirable to reorganize the content of the various files to reflect a more logical order, thus allowing the generated TOC to be easier to navigate. ----- Larry -- View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16609.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Mar 21, 2016 12:50 AM
@Larry: I agree, I'd like to reorganize the material in the Language manual
into a more logical order, and make the automatically generated TOC easier
to navigate.
I've made a start at that with my recent changes, but that's just been
minor cleanup work, fixing obvious bugs. And currently, the automatically
generated TOC has basically the same structure as the manually edited one:
neither is ideal.
My bigger plan is to reorganize the contents based on data types and the
operations on those types, because I think this will give a more logical
and useful structure. It'll be something like this:
  1. General
  2. Constructing 3D Objects
  3. Constructing 2D Objects
  4. Geometric Operations
  5. Booleans
  6. Numbers
  7. Strings
  8. Lists
  9. Linear Algebra (Vectors and Matrices)
  10. Functions and Modules
  11. Scripts
  12. Other
One way to shorten the automatically generated TOC is to limit the depth to
2 or 3, which causes MediaWiki to ignore section headers deeper than this
(currently we have up to 4 levels of section headers).
Larry
@Larry: I agree, I'd like to reorganize the material in the Language manual into a more logical order, and make the automatically generated TOC easier to navigate. I've made a start at that with my recent changes, but that's just been minor cleanup work, fixing obvious bugs. And currently, the automatically generated TOC has basically the same structure as the manually edited one: neither is ideal. My bigger plan is to reorganize the contents based on data types and the operations on those types, because I think this will give a more logical and useful structure. It'll be something like this: 1. General 2. Constructing 3D Objects 3. Constructing 2D Objects 4. Geometric Operations 5. Booleans 6. Numbers 7. Strings 8. Lists 9. Linear Algebra (Vectors and Matrices) 10. Functions and Modules 11. Scripts 12. Other One way to shorten the automatically generated TOC is to limit the depth to 2 or 3, which causes MediaWiki to ignore section headers deeper than this (currently we have up to 4 levels of section headers). On 20 March 2016 at 20:06, L Boyd <lboyd@frontiernet.net> wrote: > The table of contents for the language reference manual at > /OpenSCAD_User_Manual was the same as the table of contents in > /OpenSCAD_User_Manual/The_OpenSCAD_Language until someone recently deleted > the copy from /OpenSCAD_User_Manual/The_OpenSCAD_Language. > > Yes, the automatically generated one needs less work to maintain. The > problem is it reflects the lack of logical order to the contents. When > coupled with the length of the generated TOC, it becomes very difficult to > use it for navigation. > > In the long run, it would be desirable to reorganize the content of the > various files to reflect a more logical order, thus allowing the generated > TOC to be easier to navigate. > > > > > > ----- > Larry > -- > View this message in context: > http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16609.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
runsun
Mon, Mar 21, 2016 1:09 AM
I've added some markups on both pages to transclude the table_of_content on
/OpenSCAD_User_Manual/The_OpenSCAD_Language to /OpenSCAD_User_Manual so we
don't need to edit it by hand any more. Not sure if it works 'cos it is
awaiting approval from Michael.
Ref:
https://en.wikipedia.org/wiki/Wikipedia:Transclusion#Selective_transclusion
https://en.wikipedia.org/wiki/Help:Labeled_section_transclusion
$  Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 );  $ tips: hash( 1 , 2 ), sweep( 1 , 2 ), var( 1 , 2 ), lerp , animGif , prodVid , precision( 1 , 2 ), xl-control , type , rounded polygon
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16612.html
doug.moen wrote > The table of contents for the language reference manual at > /OpenSCAD_User_Manual is different from the table of contents in > /OpenSCAD_User_Manual/The_OpenSCAD_Language. > > That's to be expected, because the former has to be edited by hand, while > the latter is automatically updated each time somebody modifies the > language reference manual. I've added some markups on both pages to transclude the table_of_content on /OpenSCAD_User_Manual/The_OpenSCAD_Language to /OpenSCAD_User_Manual so we don't need to edit it by hand any more. Not sure if it works 'cos it is awaiting approval from Michael. Ref: https://en.wikipedia.org/wiki/Wikipedia:Transclusion#Selective_transclusion https://en.wikipedia.org/wiki/Help:Labeled_section_transclusion ----- $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), sweep( 1 , 2 ), var( 1 , 2 ), lerp , animGif , prodVid , precision( 1 , 2 ), xl-control , type , rounded polygon -- View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16612.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Mar 21, 2016 1:31 AM
@runsun: I read the same documentation as you did, and tested something
similar. The problem was that when I transcluded the TOC tag into
OpenSCAD_User_Manual, the TOC was expanded into the user manual TOC,
not the language manual TOC. That said, if you can make it work, that will
be great. (I ran my test by publishing a change to The_OpenSCAD_Language,
and previewing a change to OpenSCAD_User_Manual. The transcluded TOC
was expanded incorrectly in the preview, and that's when I gave up.)
Ref:
@runsun: I read the same documentation as you did, and tested something similar. The problem was that when I transcluded the __TOC__ tag into OpenSCAD_User_Manual, the __TOC__ was expanded into the user manual TOC, not the language manual TOC. That said, if you can make it work, that will be great. (I ran my test by publishing a change to The_OpenSCAD_Language, and previewing a change to OpenSCAD_User_Manual. The transcluded __TOC__ was expanded incorrectly in the preview, and that's when I gave up.) On 20 March 2016 at 21:09, runsun <runsun@gmail.com> wrote: > doug.moen wrote > > The table of contents for the language reference manual at > > /OpenSCAD_User_Manual is different from the table of contents in > > /OpenSCAD_User_Manual/The_OpenSCAD_Language. > > > > That's to be expected, because the former has to be edited by hand, while > > the latter is automatically updated each time somebody modifies the > > language reference manual. > > I've added some markups on both pages to transclude the table_of_content on > /OpenSCAD_User_Manual/The_OpenSCAD_Language to /OpenSCAD_User_Manual so we > don't need to edit it by hand any more. Not sure if it works 'cos it is > awaiting approval from Michael. > > Ref: > https://en.wikipedia.org/wiki/Wikipedia:Transclusion#Selective_transclusion > https://en.wikipedia.org/wiki/Help:Labeled_section_transclusion > > > > ----- > > $ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), > runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), > sweep( 1 , 2 ), var( 1 , 2 ), lerp , animGif , prodVid , precision( 1 , 2 > ), xl-control , type , rounded polygon > > > > > > -- > View this message in context: > http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16612.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Mon, Mar 21, 2016 1:42 AM
doug.moen wrote
There is another table of contents for the Language Reference Manual at
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual, but it isn't not
automatically generated from the print version. It's not maintained, and
it's inaccurate/out of date. It should be deleted, or we should find some
way to transclude the correct TOC from the print version.
I have done much of the customisation of that TOC, in an endeavour to have
direct links to the individual keywords rather than just to the section as
per the automatically generated one. Also to keep it compact so you don't
need to scroll the TOC.
I do periodically update it, but haven't got to it for a while.
I have just taken a copy so if people want to do something else, I'll just
stick it as sandbox page and use it myself.
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16615.html
doug.moen wrote > There is another table of contents for the Language Reference Manual at > https://en.wikibooks.org/wiki/OpenSCAD_User_Manual, but it isn't not > automatically generated from the print version. It's not maintained, and > it's inaccurate/out of date. It should be deleted, or we should find some > way to transclude the correct TOC from the print version. I have done much of the customisation of that TOC, in an endeavour to have direct links to the individual keywords rather than just to the section as per the automatically generated one. Also to keep it compact so you don't need to scroll the TOC. I do periodically update it, but haven't got to it for a while. I have just taken a copy so if people want to do something else, I'll just stick it as sandbox page and use it myself. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16615.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Mar 21, 2016 2:24 AM
Ref:
Are you talking about:
{{#section:OpenSCAD User Manual/The OpenSCAD language|TableOfContent}}
It doesn't look any different in preview. I just rolled it back as it was
conflicting with my updates.
I'll retry it after I save my updates (the list Doug had above).
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16617.html
runsun wrote > > doug.moen wrote >> The table of contents for the language reference manual at >> /OpenSCAD_User_Manual is different from the table of contents in >> /OpenSCAD_User_Manual/The_OpenSCAD_Language. >> >> That's to be expected, because the former has to be edited by hand, while >> the latter is automatically updated each time somebody modifies the >> language reference manual. > I've added some markups on both pages to transclude the table_of_content > on /OpenSCAD_User_Manual/The_OpenSCAD_Language to /OpenSCAD_User_Manual so > we don't need to edit it by hand any more. Not sure if it works 'cos it is > awaiting approval from Michael. > > Ref: > https://en.wikipedia.org/wiki/Wikipedia:Transclusion#Selective_transclusion > https://en.wikipedia.org/wiki/Help:Labeled_section_transclusion Are you talking about: {{#section:OpenSCAD User Manual/The OpenSCAD language|TableOfContent}} It doesn't look any different in preview. I just rolled it back as it was conflicting with my updates. I'll retry it after I save my updates (the list Doug had above). ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16617.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Mar 21, 2016 2:41 AM
Ref:
They did nothing.
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16618.html
runsun wrote > I've added some markups on both pages to transclude the table_of_content > on /OpenSCAD_User_Manual/The_OpenSCAD_Language to /OpenSCAD_User_Manual so > we don't need to edit it by hand any more. Not sure if it works 'cos it is > awaiting approval from Michael. > > Ref: > https://en.wikipedia.org/wiki/Wikipedia:Transclusion#Selective_transclusion > https://en.wikipedia.org/wiki/Help:Labeled_section_transclusion They did nothing. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16618.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Mar 21, 2016 2:53 AM
Personally, I think the print versions are less useful, but as per Doug doing
searches on it that is obviously a usage style difference.
Before I re-jigged the non-print TOC it was generated and looked like:
http://forum.openscad.org/file/n16619/wikibook_original_toc.jpg
I do think the current version is a more usable TOC, even tho it needs
manual handling.
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16619.html
Personally, I think the print versions are less useful, but as per Doug doing searches on it that is obviously a usage style difference. Before I re-jigged the non-print TOC it was generated and looked like: <http://forum.openscad.org/file/n16619/wikibook_original_toc.jpg> I do think the current version is a more usable TOC, even tho it needs manual handling. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16619.html Sent from the OpenSCAD mailing list archive at Nabble.com.
