LB
L Boyd
Mon, Mar 21, 2016 11:29 AM
@Doug: I basically agree with you suggested order for the language portion of
the manual.
Why don't you post it in a new thread so we can discuss it separate from the
debate about how the TOC should look.
doug.moen wrote
@Larry: I agree, I'd like to reorganize the material in the Language
manual
into a more logical order, and make the automatically generated TOC easier
to navigate.
My bigger plan is to reorganize the contents based on data types and the
operations on those types, because I think this will give a more logical
and useful structure. It'll be something like this:
1. General
2. Constructing 3D Objects
3. Constructing 2D Objects
4. Geometric Operations
5. Booleans
6. Numbers
7. Strings
8. Lists
9. Linear Algebra (Vectors and Matrices)
10. Functions and Modules
11. Scripts
12. Other
the manual.
> manual
> to navigate.
> 1. General
> 5. Booleans
> 6. Numbers
> 7. Strings
> 8. Lists
> 11. Scripts
> 12. Other
Larry
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16624.html
LB
L Boyd
Mon, Mar 21, 2016 11:54 AM
@michael: Glad someone besides me finds the non-automatic TOC more useful
even if it does require manual maintenance.
Larry
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16626.html
Larry
runsun
Mon, Mar 21, 2016 2:21 PM
{{#section:OpenSCAD User Manual/The OpenSCAD language|TableOfContent}}
<--{{OpenSCAD User Manual/The OpenSCAD
Language|transcludesection=TableOfContent}}-->
It doesn't look any different in preview. I just rolled it back as it was
conflicting with my updates.
I'll retry it after I save my updates (the list Doug had above).
Yes, but also the markup in the source doc (OpenSCAD language), in which I
tried two different approaches:
<section begin=TableOfContent />
<onlyinclude>
{{#ifeq:{{{transcludesection|TableOfContent}}}|TableOfContent|
__TOC__
<p style="page-break-after:always;">
</p>
</onlyinclude>
<section end=TableOfContent />
I imagine that they have to be accepted for the transclusion-accepting doc
to work.
But I guess you guys know that, so I'll leave it here.
$ Runsun Pan, PhD $ libs: doctest , faces ( git ), offline doc ( git ), runscad.py( 1 , 2 , git ), synwrite( 1 , 2 ); $ tips: hash( 1 , 2 ), sweep( 1 , 2 ), var( 1 , 2 ), lerp , animGif , prodVid , precision( 1 , 2 ), xl-control , type , rounded polygon
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16630.html
MichaelAtOz wrote
> Are you talking about:
> <onlyinclude>
> __TOC__
> </p>
> </onlyinclude>
to work.
runsun
Mon, Mar 21, 2016 3:18 PM
@jdawgaz:
The bug in the openscad_offliner appears to be a cross-platform issue. The
original version was developed in Linux. I've got it to work in Windows now.
In fact, I took a step further to include a openscad_doc.zip. You should be
able to just extract that file and no need to run the script by yourself,
unless a most recent version is needed.
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16631.html
@jdawgaz:
Mon, Mar 21, 2016 5:01 PM
@runsun: The changes don't have to be accepted before you can test your
code. After all, the person doing the accepting has to be able to see what
he's accepting, right? I was able to test a similar approach (using
#section-h instead of #section), and got results, just not the results I
wanted. I reverted my changes already, so they never reached the acceptance
stage.
<onlyinclude>
__TOC__
</p>
</onlyinclude>
to work.
stage.
> > <onlyinclude>
> > __TOC__
> > </p>
> > </onlyinclude>
> to work.
runsun
Mon, Mar 21, 2016 5:44 PM
That's true --- if the change doesn't depend on other pages. But what I
tried was a markup on page-A depends on a markup on page-B. Only if the
markup on B is accepted, and thus an anchor is existing to be located, will
the markup on A be able to locate it and show effect. So to see if the
markup on A works, the markup on B has to be accepted.
Of course, if the wikibook is designed in such a way that a transclusion on
A is to link to a modification on B that is not yet accepted, then it'd be
another story.
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16636.html
another story.
Mon, Mar 21, 2016 6:56 PM
@runsun: Only if the
Yes, but for the third time, I already tested a version of your changes
without waiting for my changes to B to be accepted. All I needed to do was
publish my changes to B. One thing to note: I was logged in to Wikipedia
when I did this, and that might change the behaviour. Otherwise, I don't
know why the same procedure wouldn't work for you.
another story.
> what
> another story.
Mon, Mar 21, 2016 11:47 PM
I tried it with both, didn't do anything. But I'm no expert.
People are aware that the printed versions are basically transcluded from
the main manual?
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16643.html
the main manual?
Jerry Davis
Mon, Mar 21, 2016 11:53 PM
I looked up transclude in my dictionary and was not found, so what does
that mean?
that mean?
> the main manual?
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
Tue, Mar 22, 2016 12:14 AM
transclude https://www.mediawiki.org/wiki/Transclusion , copies sections
into another book.
View this message in context: http://forum.openscad.org/Print-version-of-OpenSCAD-manual-tp16593p16645.html
transclude <https://www.mediawiki.org/wiki/Transclusion> , copies sections
into another book.
