FH
Father Horton
Sat, Jan 29, 2022 5:39 PM
I have a project with three parts. They're all in the same file so that I
can be sure they fit properly. I defined a variable that's set to "ALL" if
all the parts are to be generated, or to the name of one part if only one
is to be generated. As far as I can tell, this is the most efficient way to
get three printable STLs.
But now I wonder ... is there a better way? This isn't awful, but I'd hate
to be missing something easy and obvious.
Sat, Jan 29, 2022 5:53 PM
I use a Python framework to generate STLs, DXFs and a bill of materials and
assembly instructions. Over the top if you have one project with three
parts but I use it for all my projects and some have thousands of parts.
See https://github.com/nophead/NopSCADlib. It is aimed at projects where
all the parts are modelled, not just the printable STLs.
Any parts that make STLs are made with a module with _stl suffix to its
name. They also call an stl module announcing their name. That adds them to
the BOM and then the framework can generate all the STLs on the BOM.
FH
Father Horton
Sat, Jan 29, 2022 6:19 PM
I will take a look. Thanks!
and assembly instructions. Over the top if you have one project with three
hate to be missing something easy and obvious.
KT
Kevin Toppenberg
Sat, Jan 29, 2022 9:05 PM
I usually use this pattern, similar to what you are doing....
show_top_part = 1;
show_front_part = 0;
show_base = 1;
I then set the relevant variable for which part I want to display.
Kevin
On Sat, Jan 29, 2022 at 12:39 PM Father Horton fatherhorton@gmail.com
show_top_part = 1;
show_base = 1;
Kevin
On Sat, Jan 29, 2022 at 12:39 PM Father Horton <fatherhorton@gmail.com>
Sat, Jan 29, 2022 9:28 PM
Similarly:
TopPart();
!FrontPart();
BasePart();
show_top_part = 1;
show_base = 1;
Kevin
that I can be sure they fit properly. I defined a variable that's
set to "ALL" if all the parts are to be generated, or to the name
of one part if only one is to be generated. As far as I can tell,
this is the most efficient way to get three printable STLs.
I'd hate to be missing something easy and obvious.
Similarly:
TopPart();
!FrontPart();
BasePart();
> show_top_part = 1;
> show_base = 1;
> Kevin
Sat, Jan 29, 2022 10:24 PM
I haven't done this yet, but with customizer you could have checkboxes to click which part you want, e.g.
part1=false;
part2=false;
if (part1) cube();
if (part2) sphere();
Sent: Sun, 30 Jan 2022 08:29
To: OpenSCAD general discussion; Kevin Toppenberg
Subject: [OpenSCAD] Re: Multiple objects in a file
Similarly:
TopPart();
!FrontPart();
BasePart();
show_top_part = 1;
show_base = 1;
Kevin
On Sat, Jan 29, 2022 at 12:39 PM Father Horton fatherhorton@gmail.com wrote:
I have a project with three parts. They're all in the same file so that I can be sure they fit properly. I defined a variable that's set to "ALL" if all the parts are to be generated, or to the name of one part if only one is to be generated. As far as I can tell, this is the most efficient way to get three printable STLs.
But now I wonder ... is there a better way? This isn't awful, but I'd hate to be missing something easy and obvious.
part1=false;
part2=false;
if (part1) cube();
_____
Similarly:
TopPart();
!FrontPart();
BasePart();
show_top_part = 1;
show_base = 1;
Kevin
On Sat, Jan 29, 2022 at 12:39 PM Father Horton <fatherhorton@gmail.com> wrote:
DS
David Schooley
By default, my parts are all in modules named draw_something, as in:
module draw_something(…) {..}
module draw_sub_part_of_something(…) {…}
At the end of the script, there is a call to draw_something(), with whatever parameters I want.
Depending on what I am doing, there might be small scripts that import the original script and do nothing more than call draw_something() or one of the draw_sub_part_of_something() modules with the correct parameters. This makes it easy to get the stl, 3mf, or svg files that I want.
This also works for assemblies. I only put one part for file, so a file for an assembly includes the individual part files and calls the correct draw_something modules while translating and/or rotating them to put everything together.
> On Jan 29, 2022, at 11:39 AM, Father Horton <fatherhorton@gmail.com> wrote:
Sat, Jan 29, 2022 10:29 PM
I set up a list of parts that I want to see:
parts = ["all"];
...or...
parts = ["base", "supports", "stepper"];
... and then put my calls to the appropriate modules within if clauses:
if (len(strSearch( [ "base", "all"], parts)) > 0)
base();
function strSearch( str, list ) =
let ( searchStrings = is_string(str)? [str]:str )
[ for (i=[0:len(list)-1], j=[0:len(searchStrings)-1])
if (searchStrings[j]==list[i]) i
parts = ["all"];
...or...
base();
Sun, Jan 30, 2022 4:27 PM
I have a mechanism that is more formal than many, though not as formal
as nophead's.
The top of a file will look something like so:
$content_selected = "all"; // [ all, chair1, chair2,
silverwarechest, table, table_frame, table_center, table_top,
table_leaves ]
contents() {
item("chair1") drchair();
item("chair2") drchair2();
item("silverwarechest", distance=120) silverwarechest();
item("table") drtable();
item("table_frame", png=false) drtable($part="frame");
item("table_center", png=false) drtable($part="center");
item("table_top", png=false) drtable($part="top");
item("table_leaves", png=false) drtable_leaves();
This gets used in two ways:
- From the Customizer, I can pick which component I want. "all" lays
them all out on a grid.
- From an external shell script (run under Cygwin on Windows), I can
list all of the components in the file and generate STLs and PNGs
for each of them, as modified by the options. "png=false" means
that a PNG doesn't get generated for that item. Similarly
"stl=false". There's a couple of camera-control options for the PNG
generation. Thus the block above generates eight STLs and four
PNGs. (The STL of the table isn't actually useful, except for 3D
visualization.)
At another layer, $part controls which part of an object gets generated.
I've enclosed the OpenSCAD components and the shell script.
as nophead's.
table_leaves ]
contents() {
* From the Customizer, I can pick which component I want. "all" lays
* From an external shell script (run under Cygwin on Windows), I can
visualization.)
Sun, Jan 30, 2022 4:29 PM
I keep thinking about multi-color / multi-material support. It seems
like such support will want to operate in a couple of modes, either
exporting to a multi-object format like 3MF or exporting multiple STLs
in one shot. Now if only I had the free time...
