On 31.08.26 20:33, maurice e heskett via Discuss wrote:
Which is NOT an arm64 cpu. Somebody bring me up to speed
on the N95 cpu this thing has, please.
Just a slightly older (~2023) Intel CPU targeting mobile
devices. Not the fasted, but not drawing a huge amount of
power. Should be fine for most normal stuff.
but this makes me want to ask if I'm trying to install
the wrong architecture for this cpu. I want the latest
weekly build.
Same process as my previous mail. That repo has both ARM64
and AMD64(x86_64) builds. Ubuntu should automatically pick
the correct one.
weekly build.
New computer, lost msg.
the correct one.
But it picks (and synaptic) both select the 5 yo version. Going to the
the openscad/downloads and scrolling down, which is the correct one please?
After the 2 steps of adding the repository from the
mail earlier, synaptic should show "openscad-nightly"
in addition to the old "openscad".
I don't know how to refresh the package list in
Synaptic. Maybe after the 2 steps from earlier
curl -fsSL
https://download.opensuse.org/repositories/home:/t-paul/xUbuntu_24.04/Release.key
| sudo gpg --dearmor -o /etc/apt/keyrings/obs-openscad.gpg
echo "deb [signed-by=/etc/apt/keyrings/obs-openscad.gpg]
/" | sudo tee /etc/apt/sources.list.d/obs-openscad.list
also do:
sudo apt-get update
I hope this 3rd step with the update is also picked
up by Synaptic.
following along, I get to here in a terminal after the "sudo apt update:"...
Reading package lists... Done
E: The repository 'http://archive.neon.kde.org noble Release' does not
have a Release file.
N: Updating from such a repository can't be done securely, and is
therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user
configuration details.
tryiing synaptic:, I get to this: but cannot copy-paste the error msg.
It looks like I might be able to install the 2101 version but not the
nightly.
Next?
Thanks Torsten Paul
Sounds like it's unhappy with http instead of https for accessing
the repo. I'm not sure if that would prevent other things from
installing.
While we are doing command line anyway, what's the result of
running
sudo apt install openscad-nightly
update:"...
nightly.
// I /lied. the oiriginal 21xx won't install, same error I think./
Next?
Thanks Torsten Paul
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libqscintilla2-qt6-15 : Depends: libqt6core6 (>= 6.4.0)
Depends: libqt6gui6 (>= 6.1.2)
Depends: libqt6printsupport6 (>= 6.1.2)
libqt6dbus6t64 : Depends: qt6-base-abi (= 6.4.2)
libqt6multimedia6 : Depends: libqt6network6t64 (>= 6.4.2+dfsg~) but it
is not installable
libqt6openglwidgets6t64 : Depends: libqt6opengl6t64 (>= 6.1.2) but it
is not installable
libqt6widgets6t64 : Depends: qt6-base-abi (= 6.4.2)
openscad-nightly : Depends: libqt6network6t64 (>= 6.1.2) but it is not
installable
E: Unable to correct problems, you have held broken packages.
And synaptics fix broken errors out too.
it is not installable> E: Unable to correct problems, you have held
broken packages.
That probably goes back to the other error where it did refuse
to access http://archive.neon.kde.org
A first step could be using synaptic to change this to https
instead. I would assume that shows up in Settings->Repositories
in synaptic.
not have a Release file.
installing.
running
Nvr mind, I just found it in the menu's, latest version and it appears
to run ok for its opening screen. Now if I can do the same with the
flashforge's version of OrcaSlicer, I'll be off and running. Thanks for
the quick responses, much appreaciated.(sp)
Cool, crossing fingers that it will work. A 3d printer without
the software driving it is a very sad thing.
