$vpx?
MS
mike Smith
Mon, Aug 31, 2026 8:50 PM
OFF TOPIC!
OFF TOPIC!
ME
maurice e heskett
Mon, Aug 31, 2026 11:40 PM
On 8/31/26 16:14, Torsten Paul via Discuss wrote:
On 31.08.26 21:56, maurice e heskett via Discuss wrote:
  openscad-nightly : Depends: libqt6network6t64 (>= 6.1.2) but
it is not installable> E: Unable to correct problems, you have held
broken packages.
That probably goes back to the other error where it did refuse
to access http://archive.neon.kde.org
A first step could be using synaptic to change this to https
instead. I would assume that shows up in Settings->Repositories
in synaptic.
I have now added the s to the http line in
/etc/apt/sources.list.d/kde(etc) but it made no diff. Used geany which
runs much like gedit but doesn't crash and scramble the files 10% of the
time.
Next?  Thank you Torsten
On 8/31/26 16:14, Torsten Paul via Discuss wrote: > On 31.08.26 21:56, maurice e heskett via Discuss wrote: > >>   openscad-nightly : Depends: libqt6network6t64 (>= 6.1.2) but > > it is not installable> E: Unable to correct problems, you have held > broken packages. > > That probably goes back to the other error where it did refuse > to access http://archive.neon.kde.org > > A first step could be using synaptic to change this to https > instead. I would assume that shows up in Settings->Repositories > in synaptic. > > ciao, >   Torsten. I have now added the s to the http line in /etc/apt/sources.list.d/kde(etc) but it made no diff. Used geany which runs much like gedit but doesn't crash and scramble the files 10% of the time. Next?  Thank you Torsten > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
ME
maurice e heskett
Tue, Sep 1, 2026 11:50 AM
On 8/31/26 16:50, mike Smith via Discuss wrote:
OFF TOPIC!
Maybe so Mike, but I bought this thing from false advertising.  So I
have nearly $400 in it.  I'd like to get some use out of it.   I found
in the night, after I'd added the s to http in the synaptic
source.list.d, that the weekly openscad was available and installable.
Now for Orcaslicer. Flashforge version. Thank you for your patience.
On 8/31/26 16:50, mike Smith via Discuss wrote: > > OFF TOPIC! > Maybe so Mike, but I bought this thing from false advertising.  So I have nearly $400 in it.  I'd like to get some use out of it.   I found in the night, after I'd added the s to http in the synaptic source.list.d, that the weekly openscad was available and installable.  Now for Orcaslicer. Flashforge version. Thank you for your patience. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Tue, Sep 1, 2026 11:58 AM
The OpenSCAD discussion is totally fine. I think what the shouting
is about is simply that this discussion started as reply to a
totally different topic (and mail subject).
When starting new topics, it's recommended to not just reply and
edit the mail subject, but go with a fresh mail, or maybe use
"Compose message to..." or whatever that's called in the various
mail applications.
On 01.09.26 13:50, maurice e heskett via Discuss wrote: > Maybe so Mike, but I bought this thing from false advertising.  So I > have nearly $400 in it.  I'd like to get some use out of it. The OpenSCAD discussion is totally fine. I think what the shouting is about is simply that this discussion started as reply to a totally different topic (and mail subject). When starting new topics, it's recommended to not just reply and edit the mail subject, but go with a fresh mail, or maybe use "Compose message to..." or whatever that's called in the various mail applications. ciao, Torsten.
MS
mike Smith
Tue, Sep 1, 2026 9:15 PM
I don’t see the connection.
It’s advisable to start a new thread for a new subject - it’s quite easy.
When I checked the thread to see what was new, I found, to my annoyance, that it had been killed off as far as the subject of interest to me was concerned.
Your own discussion is effectively hidden and if you ever want to refer back to it, it will be difficult to find.
maurice e heskett wrote: > Maybe so Mike, but I bought this thing from false advertising.  I don’t see the connection. It’s advisable to start a new thread for a new subject - it’s quite easy. When I checked the thread to see what was new, I found, to my annoyance, that it had been killed off as far as the subject of interest to me was concerned. Your own discussion is effectively hidden and if you ever want to refer back to it, it will be difficult to find.
ME
maurice e heskett
Wed, Sep 2, 2026 4:21 PM
No need, found apt's sources.d/ list, added an s to the http on line 2,
now it installs and runs fine from synaptic.
Thanks,  Gene
On 9/1/26 17:16, mike Smith via Discuss wrote: > > maurice e heskett wrote: > > Maybe so Mike, but I bought this thing from false advertising. > > I don’t see the connection. > > It’s advisable to start a new thread for a new subject - it’s quite easy. > > When I checked the thread to see what was new, I found, to my > annoyance, that it had been killed off as far as the subject of > interest to me was concerned. > > Your own discussion is effectively hidden and if you ever want to > refer back to it, it will be difficult to find. > No need, found apt's sources.d/ list, added an s to the http on line 2, now it installs and runs fine from synaptic. Thanks,  Gene > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
MS
mike Smith
Wed, Sep 2, 2026 11:04 PM
I’m thinking of all the people who lavished care and attention on you.
