azdle
Sun, Mar 3, 2024 2:42 AM
I'm trying to design a one-piece printable Stevenson Screen. It's
basically a cylinder with downward angled channels all around to
prevent any direct sunlight from getting at a temperature sensor. See
the attached overview image.
I'm struggling to get the geometry to all line up. I was trying to do
this by using BOSL2's cylindrical_extrude with a 45-degree rotated
square and then skewing the result down.
use <BOSL2/std.scad>
wall = 3;
cells_around = 16;
downward_angle = 50;
body_od = 150;
body_id = 75;
body_oc = PI * body_od;
cell_width = (body_oc / cells_around) * sin(45);
module cell() {
skew(szy = sin(downward_angle))
cylindrical_extrude(od = body_od, id=body_id, spin=360)
zrot(45)
difference () {
square([cell_width, cell_width], center = true);
square([cell_width - wall, cell_width - wall], center =
true);
zrot_copies(n = cells_around)
cell();
zrot(360/cells_around/2)
zcopies(cell_width/sin(45), 2)
cell();
However this doesn't work because the side points get skewed quite as
far as the center points. AFAIK that's because the side points are ever
so slightly closer to the Y-Z plane so they don't get skewed down quite
as far.
I think the thing that I want is a way to skew as a function of
distance from the Z-axis rather than the Y-Z plane. But, I can't figure
out any way to do that. Is that something that's possible? Or is there
a better way to go about this?
wall = 3;
cells_around = 16;
body_od = 150;
body_id = 75;
module cell() {
zrot(45)
difference () {
true);
cell();
cell();
as far.
Sun, Mar 3, 2024 8:58 AM
actual shape cannot remain square at both the ends, because as the radius
increases, height of the square section will remain same and the width will
increase.
maybe the shape will be something like this
check the attached file
On Sun, 3 Mar 2024 at 08:13, azdle via Discuss discuss@lists.openscad.org
wall = 3;
cells_around = 16;
body_od = 150;
body_id = 75;
module cell() {
zrot(45)
difference () {
true);
cell();
cell();
as far.
increase.
On Sun, 3 Mar 2024 at 08:13, azdle via Discuss <discuss@lists.openscad.org>
> wall = 3;
> cells_around = 16;
> body_od = 150;
> body_id = 75;
> module cell() {
> zrot(45)
> difference () {
> true);
> cell();
> cell();
> as far.
Sun, Mar 3, 2024 10:46 AM
forgot to give the slant
this one is better
also added a few functions in dependencies2.scad file to provide slices in
case you are interested.
On Sun, 3 Mar 2024 at 14:28, Sanjeev Prabhakar sprabhakar2006@gmail.com
increase.
wall = 3;
cells_around = 16;
body_od = 150;
body_id = 75;
module cell() {
zrot(45)
difference () {
true);
cell();
cell();
as far.
this one is better
On Sun, 3 Mar 2024 at 14:28, Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> increase.
> [image: image.png]
>> wall = 3;
>> cells_around = 16;
>> body_od = 150;
>> body_id = 75;
>> module cell() {
>> zrot(45)
>> difference () {
>> true);
>> cell();
>> cell();
>> as far.
azdle
Sun, Mar 3, 2024 3:27 PM
radius increases, height of the square section will remain same and
the width will increase.
That's not the issue I'm trying to solve.
If you comment out the skew in the scad snippet I posted, you'll see
that all 4 points of each the cells exactly line up with each of it's
neighbors. But, once skewed, the left & right points no longer line up
with the top & bottom points of the cells in the row above and below.
I'm perfectly fine with the inner parts of the cells no longer being
square.
this one is better
slices in case you are interested.
How are you generating the trial file? That isn't quite the shape that
I'm going for, but you may be on to something, I just don't know what
it is.
square.
> this one is better
it is.
Sun, Mar 3, 2024 3:50 PM
I tried running your file.
downloaded bosl2, but it was showing some errors, so tried to draw
something similar to the pictures you attached.
Anyway, maybe I could not understand the design intent here.
better luck next time
square.
this one is better
it is.
> square.
> > this one is better
> it is.
azdle
Sun, Mar 3, 2024 3:54 PM
Thanks for your help, hopefully someone else will know.
On Sun, Mar 3 2024 at 09:20:34 PM +0530, Sanjeev Prabhakar
Sun, Mar 3, 2024 4:08 PM
you want the outer cells to be square
azdle
Sun, Mar 3, 2024 4:31 PM
Yeah, I was going for square at the outside and diamond shaped at the
inside.
I also want to make it parametric. I've got a few designs I want to try
with different sizes, cell counts and wall thicknesses.
Also, I'm still curious what you're using to generate the giant list of
points in your scad file.
On Sun, Mar 3 2024 at 09:38:12 PM +0530, Sanjeev Prabhakar
inside.
Sun, Mar 3, 2024 4:44 PM
I do all the calculations in python and render results in openSCAD and use
native features of openSCAD like intersection, difference etc to draw
shapes.
and it is perfectly parametric in python
Is this the shape?
inside.
shapes.
Is this the shape?
> inside.
azdle
Sun, Mar 3, 2024 5:05 PM
Yeah! That looks like pretty much exactly what I'm going for.
Any chance you can share the scad file and the python too?
On Sun, Mar 3 2024 at 10:14:47 PM +0530, Sanjeev Prabhakar
and use native features of openSCAD like intersection, difference etc
to draw shapes.
Is this the shape?
> to draw shapes.
> Is this the shape?
