Tue, Feb 28, 2023 3:39 PM
I wrote some code to create a spiral of spheres around the surface of a
larger sphere. It works fine, but the spacing is too tight near the poles.
If I were writing in a "normal" language, I would calculate the position
of each possible new sphere, then calculate the distance from that
sphere to the most recently successfully placed sphere, and avoid
placing the new one if the distance was too small. But I am writing in
OpenSCAD, so that approach will not work; at least, I don't know how to
do this in OpenSCAD.
Any thoughts?
function x(r, theta, rho) = r * sin(theta) * cos(rho);
function y(r, theta, rho) = r * sin(theta) * sin(rho);
function z(r, theta, rho) = r * cos(theta);
sphereD = 5;
numRots = 7;
numSpheres = numRots * 360;
r = 100;
for (rho = [0:5:numSpheres])
let (theta = (180 * (rho / numSpheres)))
translate([x(r, theta, rho), y(r, theta, rho), z(r, theta, rho)])
sphere(d = sphereD);
Any thoughts?
sphereD = 5;
numRots = 7;
r = 100;
FH
Father Horton
Tue, Feb 28, 2023 3:42 PM
Can you give a pseudo-code example of the algorithm you want?
Any thoughts?
sphereD = 5;
numRots = 7;
r = 100;
> Any thoughts?
> sphereD = 5;
> numRots = 7;
> r = 100;
Tue, Feb 28, 2023 4:44 PM
Imagine a spiral line drawn on the surface of the large [invisible]
sphere, from pole to pole, twisting around the sphere "n" times. Then
put smaller spheres along that line so that they are more-or-less
equally spaced.
I suppose I could write that algorithm external to OpenSCAD and then
import the x/y/z list to create the STL, but I would prefer to keep it
in OpenSCAD if I can
of a
the poles.
position
writing in
how to
Any thoughts?
sphereD = 5;
numRots = 7;
r = 100;
theta, rho)])
equally spaced.
> of a
> the poles.
> position
> writing in
> how to
> Any thoughts?
> sphereD = 5;
> numRots = 7;
> r = 100;
> theta, rho)])
Tue, Feb 28, 2023 5:39 PM
If I were writing in a "normal" language, I would calculate the position of
each possible new sphere, then calculate the distance from that sphere to
the most recently successfully placed sphere, and avoid placing the new one
if the distance was too small. But I am writing in OpenSCAD, so that
approach will not work; at least, I don't know how to do this in OpenSCAD.
You can do this in openscad.
Just calculate x,y, z for the new point,
but also do this for the "last" point. (in openscad I'd just calculate
it AGAIN)
Then calculate the distance between the two
d = sqrt ((xold-x)(xold-x)+(yold-y)(yold-y)+(zold-z)*(zold-z));
and then put
if (d > mindist)
in front of the sphere.
If you want ONE spiral, I'd have just one variable theta run from 0 to
360 * number of loops around the sphere.
it AGAIN)
d = sqrt ((xold-x)*(xold-x)+(yold-y)*(yold-y)+(zold-z)*(zold-z));
and then put
if (d > mindist)
Tue, Feb 28, 2023 5:42 PM
You could write a list comprehension that produces a list of points on the
spiral at sufficient resolution and then calculate its total length with a
function like the path_length() function in NopSCADlib.
Then you could divide that by the number of spheres you want to the path
length between each sphere. Then, with another recursive function, you
could find how far along the list of points each sphere is and interpolate
between the nearest pair of points to get a fairly accurate position.
sphere, from pole to pole, twisting around the sphere "n" times. Then put
smaller spheres along that line so that they are more-or-less equally
spaced.
import the x/y/z list to create the STL, but I would prefer to keep it in
OpenSCAD if I can
poles.
Any thoughts?
sphereD = 5;
numRots = 7;
r = 100;
> spaced.
> OpenSCAD if I can
> Jon
>> poles.
>> Any thoughts?
>> sphereD = 5;
>> numRots = 7;
>> r = 100;
Tue, Feb 28, 2023 5:58 PM
Rogier:
Your algorithm is exactly what I had in mind. Can you code this in
OpenSCAD? Your description (and mine) seem too procedural, with various
variables (like r, rho, theta and oldR, oldRho, and oldTheta) assuming a
variety of values as the calculation proceeds, which is challenging in
OpenSCAD (where most "variables" are constants).
it AGAIN)
and then put
if (d > mindist)
Rogier:
> it AGAIN)
> and then put
> if (d > mindist)
> Roger.
Tue, Feb 28, 2023 6:59 PM
On Tue, Feb 28, 2023 at 12:58:24PM -0500, jon wrote:
Rogier:
In a procedural language, you'd optimize by keeping assigning oldrho =
rho; etc just before the loop goes to the next one.
in openscad you just calculate the old one based on <loopvariable-1> .
Oh.... My suggestion doesn't work if you need to skip more than one
sphere. :-(
it AGAIN)
and then put
if (d > mindist)
> Rogier:
sphere. :-(
> Jon
> > it AGAIN)
> > and then put
> > if (d > mindist)
> > Roger.
Tue, Feb 28, 2023 7:29 PM
I would think in terms of defining a function that describes the spiral
To my eye, Archimedean spirals start to degenerate during the center
loop, violating the constant-distance-between-loops behavior that you
see in the rest of the spiral. I would cope with that by either
skipping that loop, or by placing the dots there "by hand".
I think that what's going on in the center is that you're normally
looking at the distance from one loop to the next, 360° further
along the spiral, but in that innermost loop there *is* no loop
further in, and you're looking at the distance from one point to
another point that is closer than 360° away. Looking at the
Wikipedia page, the most extreme case looks like measuring from the
center point to the first time the spiral crosses the +Y axis.
That's only a quarter of a loop-to-loop distance, which looks really
small... and that's that because it's only 90° away, not 360°.
Now, I say that like I know how to do those things. I don't. I don't
know what an Archimedean spiral mapped onto a sphere really looks like.
I suspect that it is phi = a + b*theta, but I'd have to plot that out to
be sure. I have no idea how to measure the length of that path and no
idea how to find a particular point given a distance along the path.
(Well, other than iteratively, but that's just wrong.)
- probably based on an Archimedean spiral
<https://en.wikipedia.org/wiki/Archimedean_spiral> - and then dividing
that path into N equal segments and placing a dot at each of those points.
FH
Father Horton
Tue, Feb 28, 2023 8:19 PM
In general, when you would loop in an imperative (a.k.a. "normal")
language, you either use list comprehensions or recursion in a
functional-esque language like OpenSCAD.
I don't think this is quite right, but it should get you close:
spirals = 7;
d = 25;
r = 100;
numspheres = 700;
step = PI * r / numspheres;
function dist(p1, p2) = norm([p1.x - p2.x, p1.y - p2.y, p1.z - p2.z]);
function points(rho, sofar) =
let (theta = (180 * (rho / numspheres)),
x = r * sin(theta) * cos(rho),
y = r * sin(theta) * sin(rho),
z = r * cos(theta),
dummy = echo(x, y, z, sofar),
ds = dist([x, y, z], sofar[0]))
rho > numspheres ? [] :
points(rho + step, ds > d ? concat([[x, y, z]], sofar): sofar);
pts = points(0, [[0, 0, r]]);
On Tue, Feb 28, 2023 at 1:30 PM Jordan Brown openscad@jordan.maileater.net
I would think in terms of defining a function that describes the spiral -
https://en.wikipedia.org/wiki/Archimedean_spiral - and then dividing
To my eye, Archimedean spirals start to degenerate during the center loop,
violating the constant-distance-between-loops behavior that you see in the
rest of the spiral. I would cope with that by either skipping that loop,
I think that what's going on in the center is that you're normally looking
at the distance from one loop to the next, 360° further along the spiral,
but in that innermost loop there is no loop further in, and you're
looking at the distance from one point to another point that is closer than
360° away. Looking at the Wikipedia page, the most extreme case looks like
measuring from the center point to the first time the spiral crosses the +Y
axis. That's only a quarter of a loop-to-loop distance, which looks really
know what an Archimedean spiral mapped onto a sphere really looks like. I
suspect that it is phi = a + b*theta, but I'd have to plot that out to be
sure. I have no idea how to measure the length of that path and no idea
how to find a particular point given a distance along the path. (Well,
spirals = 7;
d = 25;
r = 100;
numspheres = 700;
z = r * cos(theta),
On Tue, Feb 28, 2023 at 1:30 PM Jordan Brown <openscad@jordan.maileater.net>
> but in that innermost loop there *is* no loop further in, and you're
FH
Father Horton
Tue, Feb 28, 2023 8:28 PM
Oops. Minor fix:
Should be
rho > numspheres ? sofar :
And you can take out the echo.
On Tue, Feb 28, 2023 at 2:19 PM Father Horton fatherhorton@gmail.com
spirals = 7;
d = 25;
r = 100;
numspheres = 700;
z = r * cos(theta),
loop, violating the constant-distance-between-loops behavior that you see
in the rest of the spiral. I would cope with that by either skipping that
looking at the distance from one loop to the next, 360° further along the
spiral, but in that innermost loop there is no loop further in, and
you're looking at the distance from one point to another point that is
closer than 360° away. Looking at the Wikipedia page, the most extreme
case looks like measuring from the center point to the first time the
spiral crosses the +Y axis. That's only a quarter of a loop-to-loop
distance, which looks really small... and that's that because it's only 90°
away, not 360°.
Oops. Minor fix:
Should be
On Tue, Feb 28, 2023 at 2:19 PM Father Horton <fatherhorton@gmail.com>
> spirals = 7;
> d = 25;
> r = 100;
> numspheres = 700;
> z = r * cos(theta),
>> spiral, but in that innermost loop there *is* no loop further in, and
>> away, not 360°.
