K
Ken
Thu, Jan 18, 2024 7:24 AM
Thanks Jordan, that will be greatly appreciated if you can find the time
for it.
On 2024-01-18 17:58, Jordan Brown via Discuss wrote:
On 1/17/2024 10:31 PM, Ken via Discuss wrote:
And the customiser would be a lot more usable for some of us if the
developer gave it customisable font size so we could actually see it!
I'll see if I can spend some time on that. No promises - prying time
free is tough - but since it's not a language change it shouldn't have
the slow going that most of my work does.
for it.
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Thu, Jan 18, 2024 11:11 AM
On Wed, Jan 17, 2024 at 07:51:33PM +0000, Jordan Brown wrote:
On 1/17/2024 5:02 AM, Rogier Wolff via Discuss wrote:
On Wed, Jan 17, 2024 at 04:19:22AM +0000, Jordan Brown via Discuss wrote:
- Have a click-y way to add any existing module, parameterized, to the
top level.
I think much more is possible.
[ ... what you might call click-assisted editing ... ]
Well, yeah... but were any of those clicks on the model in the view area?
If you reverse the projection of 3D => screen, you'll get a line.
If you keep a "default distance from the camera", then that is the
place to put new objects. The user is responsible for turning the
viewpoint and positioning the new objects to the correct 3D position.
A "rotate viewpoint 90 degrees left" and "rotate viewpoint 90 degrees
right" button would be very useful to prevent unwanted movement on the
line that was just correctly positioned.
But my impression is that that's not what people are talking about when
they talk about GUI interfaces to modeling.
Right, and my suggestion is.
Keep in mind that openscad is just being used as something to visualize the
textfile that is being edited by the gui.
I don't think that's what the people who occasional ask for this kind of
thing are thinking of. I think they'd rather hide the editor pane and
work only with the view pane. (But I'm not one of them, so maybe I
misread their desires.)
Yes. My inclusion of the openscad code was meant as the "reasonably
simple" actions that the editor-shell would need to do to the openscad
file to give the user the impresion that actions are being taken on
their clicks.
With some help from openscad, this could become even more
useful. People like to select (sub)modules by pointing and
clicking. So something that might need to be added to openscad is:
"What object caused the pixel at x,y to be colored the way it is?". I
think it would need to report the lowest level object that
satisfies. The user should then be able to click "up" enough times to
go up the hierarchy to find the proper
There is some of that today, with the ability to right-click on the
model in the view pane and get the stack and click on the desired
level. That will show you all of the "color" invocations that fed into
that pixel.
Oh Wow!
hmm. Rightclick is move viewpoint on mine. If that's changed in a more
recent version... that's a change that is not backward compatble with
my wet-ware.
> >> * Have a click-y way to add any existing module, parameterized, to the
> >> top level.
their clicks.
> that pixel.
Oh Wow!
my wet-ware.
Thu, Jan 18, 2024 11:22 AM
I'm now realizing that at first I was thinking: just put the object at
the origin. Now I'm thinking at the default distance from the current
view-point in the middle of the screen. That's implementation details
the implementer has to think about and implement whatever they think
is best.
is best.
Thu, Jan 18, 2024 11:52 AM
I think it is double right click to show the stack trace that produced the
pixel. It's a nightmare for me because my Microsoft mice have switch bounce
on the right button and on some PCs the stack trace makes the screen black
and I have to restart OpenSCAD.
On Thu, 18 Jan 2024 at 11:22, Rogier Wolff via Discuss <
is best.
> is best.
> Roger.
> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
> f equals m times a. When your f is steady, and your m is going down
GS
Guenther Sohler
Thu, Jan 18, 2024 11:53 AM
Exactly this, is key to be able to select existing points in the rendered
model.
Having this line last step is to find out, which points are nearby this
line with a few pixels tolerance.
Being able to select certain points, measuring stuff is just peanuts
model.
GS
Guenther Sohler
Thu, Jan 18, 2024 11:55 AM
Once somebody manages to read back the the depth value right below the
cursor position, we can easily select 3D locations within the rendered
model even in preview mode.
On Thu, Jan 18, 2024 at 12:52 PM nop head via Discuss <
is best.
>> is best.
>> Roger.
Thu, Jan 18, 2024 1:19 PM
I do not need to measure much within openscad. When I do I find
eyeballing is good enough. There was a thread back in September 2021,
where I explained what I ended up doing, which works good enough for me.
You can home in pretty quickly adjusting the values of p1 and p2.
I've simplified my eyeballing technique, distances can be measured
fairly quickly.
I start off by defining the tolerance I'm happy with.
I've made a module named tol() and set it to 0.5 for this example
module tol(t){
# sphere(t);
then I place a tolerance sphere at each of the two points I'm
measuring between
e.g. like
p1=([0,0,10]);
translate(p1)tol(); // first point
p2=([54.5,11.2,41.3]);
translate(p2)tol(); // second point
They are easy to position, one at a time, by positioning x,y from the
top or bottom view, adjusting the appropriate values in PI or P2, and
then position z from one of the other views. zooming or rotating the
view as required.
then the distance can be echoed by something like
module dist(p1,p2){
dx= p2.x-p1.x;
dy= p2.y-p1.y;
dz= p2.z-p2.y;
l= sqrt((dxdx) +(dydy) +(dz*dz));
echo(distance = l);
provided the points of interest lie within the tolerance spheres, I
get the distance between the points within my defined tolerance,. If I
want a more accurate result, I can reduce the tolerance and zoom in
closer when positioning the spheres. If the tolerance sphere is too
small, to see on the full size view, then I could easily place a few
rings around them, or similar.
On 18/01/2024 00:20, edmund ronald via Discuss wrote:
I don't know whether it helps, but I like working in the Edit pane
typing code. It's just that some things like finding the distance
between two points, or quickly adjusting a size is a pain. One
workaround would be to have cursors inside the viewing area, for
measurement -like on engineering scopes where one places a cursor eg.
to measure lag- and also be able to slave a parameter in the Edit pane
to a slider so that one can quickly adjust it while seeing the effect
in the wireframe. Last and not least there is the thing about the
extrusion poly lines, but that is truly point and click and a
different story, I agree.
Edmund
> fairly quickly.
> module tol(t){
> # sphere(t);
> measuring between
> e.g. like
> p1=([0,0,10]);
> view as required.
> module dist(p1,p2){
> dx= p2.x-p1.x;
> dy= p2.y-p1.y;
> dz= p2.z-p2.y;
> l= sqrt((dx*dx) +(dy*dy) +(dz*dz));
> echo(distance = l);
> Edmund
Thu, Jan 18, 2024 2:45 PM
I really like the approach described below (without attribution).
Thought provoking.
fairly quickly.
module tol(t){
# sphere(t);
measuring between
e.g. like
p1=([0,0,10]);
the view as required.
module dist(p1,p2){
dx= p2.x-p1.x;
dy= p2.y-p1.y;
dz= p2.z-p2.y;
echo(distance = l);
I want a more accurate result, I can reduce the tolerance and zoom in
Thought provoking.
>> fairly quickly.
>> module tol(t){
>> # sphere(t);
>> measuring between
>> e.g. like
>> p1=([0,0,10]);
>> module dist(p1,p2){
>> dx= p2.x-p1.x;
>> dy= p2.y-p1.y;
>> dz= p2.z-p2.y;
>> echo(distance = l);
SL
Steve Lelievre
Thu, Jan 18, 2024 6:35 PM
Yes, I like that trick. And, using the alt/arrow feature* makes it very
easy to position of the tolerance spheres exactly where you want them
based on what you see in the preview area.
In fact, come to think of it, perhaps alt/arrow already provides a
reasonable/adequate alternative to the click-and-dragging of vertices or
objects associated with a more interactive interface?
Steve
Thought provoking.
fairly quickly.
module tol(t){
# sphere(t);
measuring between
e.g. like
p1=([0,0,10]);
the top or bottom view, adjusting the appropriate values in PI or
P2, and then position z from one of the other views. zooming or
rotating the view as required.
module dist(p1,p2){
dx= p2.x-p1.x;
dy= p2.y-p1.y;
dz= p2.z-p2.y;
echo(distance = l);
in closer when positioning the spheres. If the tolerance sphere is
too small, to see on the full size view, then I could easily place
a few rings around them, or similar.
Steve
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_User_Interface#Interactive_modification_of_the_numerical_value
> Thought provoking.
>>> fairly quickly.
>>> module tol(t){
>>> # sphere(t);
>>> measuring between
>>> e.g. like
>>> p1=([0,0,10]);
>>> module dist(p1,p2){
>>> dx= p2.x-p1.x;
>>> dy= p2.y-p1.y;
>>> dz= p2.z-p2.y;
>>> echo(distance = l);
https://www.gnomoni.ca
https://www.youtube.com/@gnomonica
Thu, Jan 18, 2024 7:37 PM
is best.
But your example seemed to have it inserting the new object into the
right context in the program, which isn't the same thing as inserting it
at the origin (or at any point readily derivable from the view window).
> is best.
