Fri, Jan 19, 2024 10:36 AM
On Thu, Jan 18, 2024 at 07:37:03PM +0000, Jordan Brown wrote:
On 1/18/2024 3:22 AM, Rogier Wolff wrote:
On Thu, Jan 18, 2024 at 12:11:45PM +0100, Rogier Wolff via Discuss wrote:
If you keep a "default distance from the camera", then that is the
place to put new objects. The user is responsible for turning the
viewpoint and positioning the new objects to the correct 3D position.
A "rotate viewpoint 90 degrees left" and "rotate viewpoint 90 degrees
right" button would be very useful to prevent unwanted movement on the
line that was just correctly positioned.
I'm now realizing that at first I was thinking: just put the object at
the origin. Now I'm thinking at the default distance from the current
view-point in the middle of the screen. That's implementation details
the implementer has to think about and implement whatever they think
is best.
But your example seemed to have it inserting the new object into the
right context in the program, which isn't the same thing as
inserting it at the origin (or at any point readily derivable from
the view window).
Yeah. My suggestion is that if you just do something simple like
"insert into the currently-being-edited object" that is already
usable.
If you think about a fully generic "insert a cube", there is
translation (3 DOF), size (3 DOF), orientation (2DOF) and what object
(1 DOF). That is way too much to do in one go. So if you split that
apart, with the first DOF (what object) being determined by the users
first click ('add cube', 'add cylinder', 'add sphere' ... ) and then
separate out the others as operations on a selected object, you can
already do useful work.
Of course if we add a cube without translations into the current
submodule, then that would mean that in the final mainmodule the
translation of the submodule would apply.
That's implementation detail that I hadn't thought about. At
implementation time some reasonable choice needs to be made and
whichever way it would go, it is not a showstopper.
> > is best.
> the view window).
usable.
K
Ken
Tue, Jan 23, 2024 6:30 AM
Apologies Jordan, I just realised I had forgotten to thank you for your
offer of trying to find time for the modification to the customisercode.
I'm certain the more visually challenged of us will really appreciate
the work you will do on it.
While I am here, many thanks also to whoever it was that recently
pointed out the use of the alt-arrow key combinations for moving objects
around- that has already saved me a lot of time and frustration while
positioning things on my creations.
On 2024-01-18 17:58, Jordan Brown via Discuss wrote:
On 1/17/2024 10:31 PM, Ken via Discuss wrote:
And the customiser would be a lot more usable for some of us if the
developer gave it customisable font size so we could actually see it!
I'll see if I can spend some time on that. No promises - prying time
free is tough - but since it's not a language change it shouldn't have
the slow going that most of my work does.
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Tue, Jan 23, 2024 11:17 AM
I guess I missed this one: where do I find the thread, or the
documentation, please?
On 1/23/2024 1:30 AM, Ken via Discuss wrote:
Many thanks also to whoever it was that recently pointed out the use
of the alt-arrow key combinations for moving objects around- that has
already saved me a lot of time and frustration while positioning
GS
Guenther Sohler
Tue, Jan 23, 2024 11:21 AM
Many thanks also to whoever it was that recently pointed out the use of
the alt-arrow key combinations for moving objects around- that has already
saved me a lot of time and frustration while positioning things on my
creations.
you can find it here
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_User_Interface#Interactive_modification_of_the_numerical_value
On Tue, Jan 23, 2024 at 12:18 PM jon via Discuss <discuss@lists.openscad.org>
> creations.
K
Ken
Tue, Jan 23, 2024 11:22 AM
On this page Jon-
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Tue, Jan 23, 2024 11:25 AM
Thank you. It feels to me as if this belongs in the Cheat Sheet somewhere.
use of the alt-arrow key combinations for moving objects around-
Tue, Jan 23, 2024 11:28 AM
The existing thing called Cheat Sheet is language definition, so that
does not seem like a good place.
If someone would start a GUI Cheat Sheet (maybe with a better name)
that would be great though.
Tue, Jan 23, 2024 11:49 AM
Torsten:
Good point(s), but I see the Cheat Sheet as my one stop for reminders
about OpenSCAD, not just about the GUI. Perhaps the Cheat Sheet could
then link to this new GUI Cheat Sheet.
somewhere.
Torsten:
>> somewhere.
> ciao,
> Torsten.
WF
William F. Adams
Tue, Jan 23, 2024 12:47 PM
Or the GUI stuff could be integrated onto a second page? Folks could switch back and forth as needed then, and if need be print both sides separately.
On Tuesday, January 23, 2024 at 06:49:55 AM EST, jon via Discuss <discuss@lists.openscad.org> wrote:
Tue, Jan 23, 2024 1:47 PM
I agree. This is VERY useful and I never would have stumbled across it
since I assumed (incorrectly) that all of the keyboard shortcuts are listed
in the "Edit" drop-down menu in the editor.
Adding these to the Edit drop-down menu would be nice.
I also agree that a second Cheat Sheet page with a concise list of all of
the keyboard shortcuts would be quite useful.
Len
On Tue, Jan 23, 2024 at 6:48 AM William F. Adams via Discuss <
separately.
Len
> separately.
> William
