Fri, Jan 15, 2016 8:39 PM
Hi Torsten. In OpenSCAD2, because there is a single namespace (instead of
separate module/function namespaces), I need echo and echof to be separate
functions. They seem to require different interfaces, and I haven't found a
good way to unify them.
For OpenSCAD2, the syntax I designed for echof is:
echof(stuff, to, echo) result
The syntax is copied from module calls, and is convenient to use for the
same reasons.
For example,
echof("calling f(",x,")") f(x)
is syntactically similar to applying a transformation to some geometry, as
in
translate([10,0,0]) cube(10)
I just like the way that the debug output is visually separated from the
rest of the code in a function.
function sum(x, y) =
echof("sum(",x,",",y,")")
(x + y);
If you like this syntax, you'll need to add another production to the
expression grammar, which for now will only be used by echof. I can help,
since I've already got a working bison grammar for this.
On 15 January 2016 at 14:52, Torsten Paul Torsten.Paul@gmx.de wrote:
On 01/15/2016 08:40 PM, doug moen wrote:
Yes, I would like us to have echof.
Ok then, to make it easier to use, what about:
just call it echo() instead of echof()
have it declared like echo(result, ...)
where it returns the value that is either the first positional
argument or the argument named result (to match the argument
behavior of module instantiations).
all arguments are printed as with the module echo()
if the function echo() is called with no argument, it will
return undef.
same reasons.
For example,
in
(x + y);
> - just call it echo() instead of echof()
> - have it declared like echo(result, ...)
> - all arguments are printed as with the module echo()
> - if the function echo() is called with no argument, it will
> return undef.
> ciao,
> Torsten.
Fri, Jan 15, 2016 8:49 PM
(instead of separate module/function namespaces), I need echo
and echof to be separate functions. They seem to require
different interfaces, and I haven't found a good way to unify them.
Hmm, right, the result thingy would make it it harder to unify.
But we already have a case where the same name is used for both
cases: let().
So how about having it behave like let() (including the sequential
assignment) just with the additional side effect of printing the
values?
cases: let().
values?
Fri, Jan 15, 2016 8:56 PM
(x + y);
Nooooooooooo. (I think)
echof() needs to be able to be placed anywhere in an expression.
Consider a complex recursion, it could be going wrong in any number of
View this message in context: http://forum.openscad.org/debug-print-in-openscad-functions-tp15683p15715.html
> (x + y);
Fri, Jan 15, 2016 9:05 PM
return undef.
How about calling the parameter 'return' as in return code.
I was about to argue for just returning zero, as originally proposed, but
I can see echof(return=[],"msg") & echof(return="","msg") being handy in
non-numeric functions.
View this message in context: http://forum.openscad.org/debug-print-in-openscad-functions-tp15683p15716.html
> return undef.
Fri, Jan 15, 2016 9:07 PM
In OpenSCAD2, a call to echof is just an expression, and can therefore be
If you reduce it to the simplest case, then
echof(stuff,to,echo)(result)
is an expression with the same precedence as a function call, and can be
used in any context that a function call can be used. (There are also a
limited set of cases where the parentheses around (result) can be omitted,
but we can leave that out for now.)
Sorry to dump OpenSCAD2 syntax into this thread. My excuse is that Torsten
and Marius have previously expressed interest in integrating more of that
syntax into OpenSCAD.
(x + y);
> > (x + y);
> stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
Fri, Jan 15, 2016 9:09 PM
(x + y);
If it would behave as let(), you can place it where you want.
E.g. what I had first thought:
function f(x) = echo(x = x, result = x > 0 ? f(x - 1) * 2 : 1);
would become
function f(x) = echo(x = x) x > 0 ? f(x - 1) * 2 : 1;
and print the "x = ..." part first and after the values that
are coming from the assignment, it would print (and also return)
the expression behind.
Also: function f(x, y) = echo() x * echo() y;
or: function(x, y) = echo(x = x, y = y) x * y;
>> (x + y);
would become
Fri, Jan 15, 2016 10:25 PM
Are you suggesting the assignment actually works as per let()?
That changes it from a simple none side-effect (except console) debug
statement, to a functional part of the language.
View this message in context: http://forum.openscad.org/debug-print-in-openscad-functions-tp15683p15719.html
Fri, Jan 15, 2016 10:54 PM
I'd prefer something that makes it easier to move to the
OpenSCAD2 syntax later and does not have funny names like
echof().
If it's not possible to find a sensible way to have that
with echo(), it might even be something completely new for
both cases which leaves behind the current echo() eventually.
echof().
Sat, Jan 16, 2016 12:55 AM
Could consider plain dumb echof() or echo() [as a function] short term and
immediately deprecate it, while working on debug() [or whatever the grand
OpenSCAD2 solution will be].
Could call it _echo() or something if you don't like funny names...
View this message in context: http://forum.openscad.org/debug-print-in-openscad-functions-tp15683p15724.html
Sat, Jan 16, 2016 1:05 AM
In case a "temporary" solution is ok, then it can be just echo().
If that's fine with Marius, I'd have an updated pull request ready
based on the older existing echof() pull request...
