K
Ken
Wed, Apr 30, 2025 3:09 AM
Looking ahead to October and the end of Win10 free support- and at the risk of starting a war- is there any particular linux distro that is markedly better than others when it comes to openscad?
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Wed, Apr 30, 2025 10:17 AM
Not an easy question to answer, as there are always chances for
strange and special issues.
Without knowing your previous experience with Linux, my advice
would be:
In general, find and select a well maintained distribution you
feel at home overall (e.g. people you know use it and can help).
Or just go for one of the big players where it's easier to find
articles/videos/reports.
From official OpenSCAD builds there's a slight preference leaning
toward Debian/Ubuntu but we really try to provide options for as
many people as possible and most distros do the same on their own
too.
would be:
too.
MH
Matthieu Hendriks
Wed, Apr 30, 2025 10:31 AM
I've used Ubuntu, desktop and server side, for many years now, last 3
years with openscad, first as an appimage and then switched to a build
from sourcecode also the openscad-python variant.
Works like a charm :)
Greetings Matthieu
Torsten Paul via Discuss schreef op 2025-04-30 12:17:
would be:
too.
Greetings Matthieu
> would be:
> too.
> ciao,
> Torsten.
CK
Chun Kit LAM
Wed, Apr 30, 2025 10:34 AM
I don't think there is a distro difference for openscad. Maybe you will
want to use those fancy kernel builds, e.g. xanmod, for slightly better
performance. You may want to look at Phoronix for performance comparison.
But to be honest, this should not influence your distro choice. Choose
your distro based on your needs, e.g. rolling release vs more stable,
package support, whether you are willing to tinker with the settings, etc.
IMPORTANT: Don't take the openscad benchmark result in Phoronix into
account, it is the older stable version where performance
characteristics is very different from the manifold backend.
would be:
too.
> would be:
> too.
> ciao,
> Torsten.
K
Ken
Wed, Apr 30, 2025 11:53 AM
Thank you Gentlemen- based on your replies, I think I will go with ubuntu as I have a small familiarity with it, and there is a lot of on-line help available for neophytes like myself. Unfortunately, almost no help locally, pretty much everyone I know is firmly wedded to windows or mac- but hey, I'm only 76, plenty of time & brain cells left to learn aother o/s🙂
On 2025-04-30 20:34, Chun Kit LAM via Discuss wrote:
I don't think there is a distro difference for openscad. Maybe you will want to use those fancy kernel builds, e.g. xanmod, for slightly better performance. You may want to look at Phoronix for performance comparison.
But to be honest, this should not influence your distro choice. Choose your distro based on your needs, e.g. rolling release vs more stable, package support, whether you are willing to tinker with the settings, etc.
IMPORTANT: Don't take the openscad benchmark result in Phoronix into account, it is the older stable version where performance characteristics is very different from the manifold backend.
would be:
too.
>> would be:
>> too.
>> ciao,
>> Torsten.
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Wed, Apr 30, 2025 1:25 PM
My advice would be simplify the answer: There is no distribution
that's markedly better. Choose a distribution based on your needs. For
a "starter" with Linux, that would be a well-rounded distribution like
Ubuntu.
It comes with openscad available as an installable package... not the
most recent but usually: usable.
would be:
too.
** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands.
** KVK: 27239233 **
** 'a' for accelleration.
Ubuntu.
> > would be:
> > too.
> > ciao,
> > Torsten.
** KVK: 27239233 **
FH
Father Horton
Wed, Apr 30, 2025 5:56 PM
I’ve been running Mint for several years now. It’s stable and fairly
fussy-free. But, as others have said, nearly any distro will work.
John David
Wed, Apr 30, 2025 6:22 PM
I agree with Rogier. Most distros are based on a couple of primary paths
(like Debian, Slackware, etc.), and they are subtly different but mostly
the same. That said, there might be some reason to choose one over another
like support -- my current laptop was purchased from System-76, and runs
Linux native (Pop!_OS, an Ubuntu derivative). Before that I mostly ran
Gentoo for the previous 20 years, and before that I really liked SUSE
(great for its initial science support), and started with RH. If you want
to look around, take a look at DistroWatch <
https://distrowatch.com/search-mobile.php> - which will let you compare
various ones against your expertise level, use of systemd, supported
languages, and more.
While I love Gentoo, that is probably the only one I would suggest NOT
trying unless you are comfortable doing lots of low level systems
administration - Gentoo originated as a build-from-source distro, and once
you wrap your head around writing ebuilds (which explicitly define the
package/version requirements), you can explicitly control the entire
dependency graph. That is a godsend when developing and maintaining code.
The OS that came with my System-76 laptop is at the end of its LTS this
week, and I am seriously looking at upgrading not only Pop!_OS, but
installing Gentoo for dual boot. Not for the faint of heart, but it
typically works for me.
EBo --
On Wed, Apr 30, 2025 at 1:57 PM Father Horton via Discuss <
EBo --
WF
William F. Adams
Thu, May 1, 2025 11:40 AM
Is anyone running OpenSCAD in Windows using the Linux subsystem?
https://learn.microsoft.com/en-us/windows/wsl/tutorials/gui-apps
If so, how well does that work and are there any issues?
Considering it so as to make keeping up w/ OpenPythonSCAD easier.
https://designinto3d.com/
Fri, May 2, 2025 5:17 AM
No, but I run an MSYS2 build sometimes.
