On 2016-02-10 02:31, adamtimm1 wrote:
I am a photographer and an artist. I want to create 3D images from my
photos and from artwork so that the blind can touch an image and "see
it."
That is* all *I want to do. I did it once through another venue.
Hi, you may be interested in this
http://arnholm.org/a-reverse-3d-printing-experiment/
Where I convert a 2d image to a printable 3d object. The description is
fairly detailed. Observe that there are different forms of DXF.
Also, this relates to the same issue, but possibly closer to what you
want
http://arnholm.org/angelscript-csg-part-3/
Another option is to save the files as a small png image, then use ImageJ
to convert the image to a text image (File->Save As->Text Image). This will
convert greyscale values into numbers, which can be read in by openscad as a
height map. Things are improved by converting to greyscale (8-bit colour)
first, then applying a gaussian blur, but the example image you've provided
doesn't really work in its current form as a height/bump map:
http://forum.openscad.org/file/n16095/4EE5_bumpmap.png
I've had more success in doing this from light-field microscope images,
although it still takes a bit of work to get things working properly:
http://www.thingiverse.com/thing:897505
View this message in context: http://forum.openscad.org/converting-svg-files-from-Inkscape-to-scad-files-to-stl-files-tp16084p16095.html
Absolutely cool suggestion. I will check them out.
----- Original Message -----
From: David Eccles (gringer)mailto:bioinformatics@gringene.org
To: discuss@lists.openscad.orgmailto:discuss@lists.openscad.org
Sent: Wednesday, February 10, 2016 2:51 AM
Subject: Re: [OpenSCAD] converting svg files from Inkscape to scad files tostl files
Fabulous Carsten! Thank you!
From: arnholm@arnholm.orgmailto:arnholm@arnholm.org
To: OpenSCAD general discussionmailto:discuss@lists.openscad.org
Sent: Wednesday, February 10, 2016 2:46 AM
Subject: Re: [OpenSCAD] converting svg files from Inkscape to scad files to stl files
it."
want
And to you my friend!
Thank you so much for your detailed description. I am getting wonderful feedback.
I am on the FreeCad forum and one of their moderators ran a paragraph rant about how stupid my questions were/are. I responded that one cannot learn if they think their questions are too stupid to be asked.
I feel better.
Best,
Adam
Sent: Tuesday, February 09, 2016 11:39 PM
Subject: Re: [OpenSCAD] converting svg files from Inkscape to scad filestostl files
ok thanks for the detail. A couple of things first.
Regrettably changing a raster file to a vector file cannot be done by
just changing the file extension. That would be like changing a car to an
airplane by swapping the gas caps over. While they are both forms of
transport, they do different things. So there is no way it'll ever be that
simple. Sorry.
Your image is going to need to be in several layers. One for each of the
contour colors you can see in your image. Maybe 8 or more. Oh yes - as you
can see (way below), the image needs a bit of editing and tidying at the
borders before you begin to get a good result and no cruft at the edges.
So things to try:
You really should look at lithopanes. The author solved an interesting
problem and its worth considering if you can use it for what you want.
The live customiser online version cannot use really big files. But if you
download the scad then you can use much bigger images.
Try it:
I'm sorry for your troubles with Inkscape.
You need 0.91. You also need to download the extension (which what inkscape
calls plugins) and put it in the right directory. If you're on windows
that's %APPDATA% then go looking for the inkscape/extensions folder.
The instructable you reference is making a simple black and white one-layer
shape. Your image looks like its maybe > 8 layers.
When you split your image into 8 layers - using the Trace_Bitmap tool -
you'll need to have these settings:
But wait....
at the end of the file will be 8 (or whatever you chose) poly_path
statements.
You can toggle visibiility of these on and off using the // comment operator
to check each shape is there.
Anyway - if you translate each one away from the next one (by whatever
height you choose) then you'll end up with a stacked scan like this:
http://forum.openscad.org/file/n16093/profile_001316.png
The following numbers won't match yours at all but see what I'm doing with
the translates in Z... ?
// The shapes
poly_path4313(height, width);
translate([0,0,-height])
poly_path4319(height, width);
translate([0,0,-height2])
poly_path4311(height, width);
translate([0,0,-height3])
poly_path4315(height, width);
translate([0,0,-height4])
poly_path4321(height, width);
translate([0,0,-height5])
poly_path4317(height, width);
translate([0,0,-height6])
poly_path4309(height, width);
translate([0,0,-height7])
poly_path4307(height, width);
Try again
Cheers...
View this message in context: http://forum.openscad.org/converting-svg-files-from-Inkscape-to-scad-files-to-stl-files-tp16084p16093.html
Thank you Laura. As I said my goal is about making a textured topology of a 2D image. I want people to "feel" the lion when they cannot see.
Think of yourself as blind. How would anyone describe Van Gough's Starry Night to you? Maybe, if it could be touched. That is my goal.
Have you ever seen a Monet up close? I did at the Denver Art Museum. I got so close I was surprised that I did not end up in trouble with security. I could see the brush marks of Monet himself, (he uses check marks) because I have eyes. Who can touch such a masterpiece and how can you define what you really cannot see? ABS plastic can stand up to a lot of rough use and a new image can be printed again when needed.
Additionally I have sketches of feet of women I know. I want to print shoes that will exactly fit a womans foot-no more scrunching into a "cute" shoe that does not fit. No sending your foot to an Italian shoe maker. Taulman 3D has a new filament that would work with that. It's called PCPTE.
Sent: Tuesday, February 09, 2016 11:10 PM
Haha, no, not related to Taulman, but that is a neat coincidence.
Tinkercad is indeed only good for simple things, too bad that was not enough! My next-easiest quick-fix probably-too-simple suggestion is to try to use the Thingiverse Customizer for lithopanes: http://www.thingiverse.com/thing:74322http://www.thingiverse.com/thing:74322 (press "Open in Customizer"). It works well but it is limited in what it can do since it is for the specific purpose of making lithopanes. Might work for what you want to do, though. You can also select "View Source" when in the Customizer, and you'll see the OpenSCAD code that is used; maybe you can extend or modify it to suit your purposes.
On Tue, Feb 9, 2016 at 11:51 PM, Adam <adamtimm1@msn.commailto:adamtimm1@msn.com> wrote:
Thank you Laura. Are you related to Taulman filments?
I tried Tinkercad out and it only works with svg and stl files. It also did not give me the topography that I wanted rather just a bunch of dots all over the place and in 2D no matter how much I elevated. Messy! In short not powerful enough.
I use FreeCad but don't know how to get it to give me what I want. I printed this lion once and got some topography and want to do it again but better. I want people to be able to touch the image and get a sense of what it looks like.
Adam
Sent: Tuesday, February 09, 2016 9:23 PM
Maybe this is too simple a solution, but maybe not... If you really don't need openscad functionality beyond extruding a 2D image, then you could try using tinkercad instead. Here's instructions for how to do that: http://www.thingiverse.com/thing:1031735http://www.thingiverse.com/thing:1031735
Laura Taalman
educ.jmu.edu/~taalmalahttp://educ.jmu.edu/~taalmala
www.mathgrrl.comhttp://www.mathgrrl.com/
On Feb 9, 2016, at 8:31 PM, adamtimm1 <adamtimm1@msn.commailto:adamtimm1@msn.com> wrote:
I hope I do not offend anyone with this request or my stupidity. This was
supposed to be a simple "thing."
From an "instructable" and a "Thing" in Thingiverse (
http://www.instructables.com/id/Convert-any-2D-image-to-a-3D-object-using-OpenSCAD/http://www.instructables.com/id/Convert-any-2D-image-to-a-3D-object-using-OpenSCAD/
) the instructions said that I could import a 2D jpeg into Inkscape, covert
it into an svg file, click Path>Object to Path then click extensions
Paths2openscad. When I opened openscad I was supposed to be able to easily
convert the file to an extruded stl that I could print on my 3D printer.
REally?? I have been working on it for 2 days.
photos and from artwork so that the blind can touch an image and "see it."
I did drop a "dxf" file onto the command line but I haven't the foggiest how
to implement it. The first time I did it I got a message saying I had
dropped an invalid dxf file onto the command line.
I am told that I have to "correctly escape the string." How do I do that? I
am totally overwhelmed with things I have to do at the moment and I do not
want more. I am at a point where everything I do takes me further afield
from my goals. I know that there is a manual but for the little thing I am
attempting to do I only need a couple of instructions. I have no intention
of doing any greater things with SCAD. It is a task I will repeat many
times until something better/easier comes along.
Could someone please tell me how to import the dxf file I want, extrude it
then save it as an STL? I was thinking I would get an "import" button, but
noooo!
Can/would someone please walk me through this?
View this message in context: http://forum.openscad.org/converting-svg-files-from-Inkscape-to-scad-files-to-stl-files-tp16084.htmlhttp://forum.openscad.org/converting-svg-files-from-Inkscape-to-scad-files-to-stl-files-tp16084.html
Sent from the OpenSCAD mailing list archive at Nabble.comhttp://nabble.com/.
Discuss@lists.openscad.orgmailto:Discuss@lists.openscad.org
http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.orghttp://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Dr. Laura Taalman
www.mathgrrl.com/hacktastichttp://www.mathgrrl.com/hacktastic + educ.jmu.edu/~taalmalahttp://educ.jmu.edu/~taalmala + @mathgrrlhttp://www.twitter.com/mathgrrl
A few thoughts about 3d.
If U want to let them "see" a lion, than print the lion in 3d.
Start with black and white images, better even images that are only full
black and full white.
Think about what lightning U need.
One hard light from the side can through a hard shadow that defines a
shape.
Adam,
Did you get the Inkscape plug-in to work as per Neon22's suggestion
Where are you at?
Note for others. Adman just wants a black box, not an intro to how OpenSCAD
can be used.
View this message in context: http://forum.openscad.org/converting-svg-files-from-Inkscape-to-scad-files-to-stl-files-tp16084p16130.html
Thank you Peter,
Per the "Instructables" article I am trying to work from I had not thought about copying an image from a jpg into InkScape, saving the image as an svg or dxf file then importing from InkScape to OpenScad and once in OpenScad converting the image to an STL so that I can print it with my 3D printer.
Sorry, could not resist. I am getting posts from threads I did not subscribe to and they are flooding my email.
What I have found is that in InkScape the "Extensions" > "paths to OpenScad" does not work. I did not know how to use the OpenScad "import" function, which the author forgot to mention instructions for, but it is a moot point if I cannot export the file from InkScape .
I actually had one of my images converted by a "free" source and was able to print it the way I wanted to. While not perfect it was pretty cool and I am trying to learn how to do it so I have control over the results. I have attached the file from Instructables and please see below. I could use some help if you know how or are of a mind to be merciful.
"1. to transform a 2D raster image like a jpg you need to convert it to
vector form, then export it to .scad file
Note: To make a multilevel vectored version of your jpg artwork - check out
inkscape and trace bitmap online for help. basically the same but several
grouped layers.
Also the Lithopane idea mentioned by @fred_dot_u is very good one for many
layers but for touch you may need to scale the off-page axis quite a lot.
BTW do you still have the "raincoat?"
Adam
From: Peter Falkemailto:stempeldergeschichte@googlemail.com
Sent: Thursday, February 11, 2016 4:07 PM
Subject: Re: [OpenSCAD] converting svg files from Inkscape to scadfilestostl files
Start with black and white images, better even images that are only full black and full white.
One hard light from the side can through a hard shadow that defines a shape.
OpenSCAD can be used.
There's an older snapshot version for the potrace branch which would
remove the need to use inkscape and make the conversion from image
to 2D-vector to 3D as simple as:
height = 10;
linear_extrude(height) trace(file = "file.png", threshold = 0.5);
(must be non-transparent PNG image, no other formats supported yet)
http://files.openscad.org/snapshots/OpenSCAD-2015.05.17-x86-64_potrace.zip
http://files.openscad.org/snapshots/OpenSCAD-2015.05.17-x86-64_potrace-Installer.exe
However after the rude words in the last mail, my motivation to
check the state of that snapshot version or even build a newer
one is currently a bit limited.
