DG
Don Garrett
Wed, Aug 11, 2021 1:40 PM
I was asked to design some cookie cutters based on downloaded images,
and thought it would be easy, until I tried it. Now I'm looking for
advice on how to approach this.
I want to download an image (SVG or PNG), and create a cookie cutter
that outlines it. This means creating an outline of the original image
that is a fixed thickness (2mm?), extruding it vertically, then adding
a lip at the top that is thicker. Preferably, the lip is rounded.
Attached are a couple of sample images I'd like to use, but the goal
is to come up with different shapes quickly, not to use a specific
image, so I can be a bit picky about exactly how the images are
formatted.
Any thoughts about how to approach this?
Don
formatted.
Don
GC
Gareth Chen
Wed, Aug 11, 2021 2:06 PM
You can use the 2D subsystem and offset() to do something like this:
module cookie_cutter() {
linear_extrude(height=height) {
offset(r=2) children(0);
children(0);
translate([0,0,height-2])
linear_extrude (height=2) {
offset(r=7) children(0);
children(0);
cookie_cutter() {
import("shape.svg");
You could get a rounded edge using a minkowski() I think, but I wasn't sure
how to properly line up the sphere with the edge of the flange without
knowing what the shape looks like.
formatted.
Don
children(0);
children(0);
cookie_cutter() {
> formatted.
> Don
Wed, Aug 11, 2021 2:48 PM
Here's another example script, you can just plug in an SVG
file as additional shape():
https://cadhub.xyz/u/Torsten/cookie-cutter/ide
DG
Don Garrett
Wed, Aug 11, 2021 2:51 PM
Thank you both! I had somehow completely missed the existence of
"offset" which made this really hard to solve.
> ciao,
> Torsten.
Don
AR
Algot Runeman
Wed, Aug 11, 2021 3:08 PM
I was successful with a modified version of Gareth Chen's suggestion.
children(0);
translate([0,0,0]) // put the flat on the print plate
children(0);
height=30; // adjust depth of cutter to clear your cookie dough
cookie_cutter() {
import("emblem.svg");
But I did have trouble with the original emblem image which had a white
background.
I was able to solve that by using Inkscape to get only the actual emblem
saved as SVG.
For the mushroom, there is an added problem. The shape Don Garrett gave
as the example is just an "outline" which OpenSCAD converts to double
lines. To work with Gareth's code, you need a solid shape. It is also a
bit big, as is.
The final issue is making a (probably separate) hoop to attach on the
flat so the internal holes of both cutter shapes can be held in place.
You may need to create that by hand so it fits a given cookie cutter shape.
children(0);
children(0);
cookie_cutter() {
sure how to properly line up the sphere with the edge of the flange
without knowing what the shape looks like.
formatted.
Don
children(0);
children(0);
cookie_cutter() {
background.
saved as SVG.
bit big, as is.
> difference() {
> children(0);
> difference() {
> children(0);
> cookie_cutter() {
> formatted.
> Don
> <mailto:discuss-leave@lists.openscad.org>
Wed, Aug 11, 2021 3:37 PM
[ I see that others have responded, but I think I have some comments
that are a bit new and, besides, I had some fun writing the program. ]
The problem is hard enough for simple outlines, but the images that you
supply demonstrate larger problems.
In simple cases - an unfilled circle, say - it's obvious that the black
part is the cutter and the enclosed white part is the cookie. But in
the case of the Star Trek logo, presumably you want a cut line around
the outside of the black area, and another around the inside of the
black area, with the black area being the cookie and the enclosed white
area being discarded material.
The mushroom picture presents a different challenge. Interpreting the
black as cut lines is more or less straightforward, but would leave you
with three distinct cookies. You want some of the lines to be "full
depth", but you want other lines to only make an impression on the top
of the cookie, not cut all the way through it.
Here's a program that seems to work for straightforward closed shapes.
I haven't tried to fully understand how OpenSCAD imports SVGs, and so
I'm not sure exactly what shapes this will work for. It works for
squares, circles, closed polygons, and at least some combinations of
them (e.g. a square with another square subtracted from it). Simple
variations will let it work with native OpenSCAD 2D objects; see the
commented-out square. Note that it's Customizer-compatible, so you
don't have to edit it to play with parameters.
Figuring out how to print it, and figuring out how to connect
disconnected parts, left as an exercise for the reader.
// SVG file to process
svg = "cookie.svg";
// XY thickness of the lip
lip_w = 5;
// Z thickness of the lip
lip_h = 5;
// Radius of the lip corners
lip_r = 2;
// Cut height
cut_h = 10;
// Thickness of the blade
cut_t = 1;
// A very small number
epsilon = 0.01;
assert(lip_w >= lip_r2);
assert(lip_h >= lip_r2);
module cookie() {
translate([0,0,cut_h+lip_h/2]) lip() children();
linear_extrude(height=cut_h + lip_h/2) outline(cut_t) children();
module outline(w) {
offset(w/2) children();
offset(-w/2) children();
module lip() {
lip_base_h = max(epsilon, lip_h - lip_r2);
lip_base_w = max(epsilon, lip_w - lip_r2);
minkowski() {
linear_extrude(height=lip_base_h, center=true) {
outline(lip_base_w) children();
sphere(r=lip_r);
//cookie() square(20);
cookie() import(svg);
svg = "cookie.svg";
lip_w = 5;
lip_h = 5;
lip_r = 2;
// Cut height
cut_h = 10;
cut_t = 1;
epsilon = 0.01;
assert(lip_w >= lip_r*2);
assert(lip_h >= lip_r*2);
module cookie() {
module outline(w) {
module lip() {
lip_base_h = max(epsilon, lip_h - lip_r*2);
lip_base_w = max(epsilon, lip_w - lip_r*2);
minkowski() {
sphere(r=lip_r);
Douglas Miller
Thu, Aug 12, 2021 11:39 AM
Don, you have a different issue here that nobody has addressed so far --
don't /any/ of you guys bake?? -- even if you are successful in
3D-printing cookie cutters from these images, you will not be successful
in making cookies from them. The mushroom can be corrected, but the Star
Trek emblem simply isn't practical.
- The long, narrow, sharp point at the bottom right of the emblem
will burn, and burn badly. It simply isn't possible to bake the
rest of the cookie to doneness without burning that. And then the
burned part will break off when the cookie is removed from the
baking sheet.
- And that assumes that you can get the cookie dough out of the cutter
in the first place, without breaking the point off. It's too narrow
to work.
- There will probably be similar issues with the left point as well,
but those are merely likelihoods, as opposed to certainties.
- The point at the top of the emblem may not burn, but it certainly
will be much harder and darker than the main part of the cookie.
- The voids apparent in both shapes create another area that is likely
to burn; these will also make it difficult to transfer the cookies
from rolling board to baking sheet without deforming them.
Fortunately, there is a simple solution to /this/ problem, anyway:
add those parts of the design /after/ the cookies are baked, using
frosting.
Frosting is the solution to the emblem as well: create a shape with
well-rounded corners, /much/ wider than the points (e.g. offset() that
image with a radius of about 10), and use frosting to create the actual
emblem after baking.
formatted.
* The long, narrow, sharp point at the bottom right of the emblem
*will* burn, and burn badly. It simply isn't possible to bake the
baking sheet.
* And that assumes that you can get the cookie dough out of the cutter
to work.
* There will probably be similar issues with the left point as well,
* The point at the top of the emblem may not burn, but it certainly
* The voids apparent in both shapes create another area that is likely
frosting.
> formatted.
DS
Daniel Shriver
Thu, Aug 12, 2021 2:22 PM
You could address all those issues AND be able to make arbitrarily shaped
cookies (without any cookie cutters) if you adapt the printer!
You use cookie dough (no oatmeal, raisins. nuts. chocolate chips...)
instead of fillament, and adapt the printer head to bake the dough as it
comes out :)
don't any of you guys bake?? -- even if you are successful in
3D-printing cookie cutters from these images, you will not be successful in
making cookies from them. The mushroom can be corrected, but the Star Trek
*will* burn, and burn badly. It simply isn't possible to bake the rest
of the cookie to doneness without burning that. And then the burned part
will break off when the cookie is removed from the baking sheet.
in the first place, without breaking the point off. It's too narrow to work.
to burn; these will also make it difficult to transfer the cookies from
rolling board to baking sheet without deforming them. Fortunately, there is
a simple solution to *this* problem, anyway: add those parts of the
design *after* the cookies are baked, using frosting.
well-rounded corners, much wider than the points (e.g. offset() that
formatted.
comes out :)
> don't *any* of you guys bake?? -- even if you are successful in
> well-rounded corners, *much* wider than the points (e.g. offset() that
> formatted.
DG
Don Garrett
Thu, Aug 12, 2021 4:47 PM
LOL! Nice!
I've heard of chocolate printers, but never a cookie printer. I think
there is some potential in there somewhere.
On Thu, Aug 12, 2021 at 9:35 AM Daniel Shriver tabbydan@gmail.com wrote:
You could address all those issues AND be able to make arbitrarily shaped cookies (without any cookie cutters) if you adapt the printer!
You use cookie dough (no oatmeal, raisins. nuts. chocolate chips...) instead of fillament, and adapt the printer head to bake the dough as it comes out :)
Don, you have a different issue here that nobody has addressed so far -- don't any of you guys bake?? -- even if you are successful in 3D-printing cookie cutters from these images, you will not be successful in making cookies from them. The mushroom can be corrected, but the Star Trek emblem simply isn't practical.
The long, narrow, sharp point at the bottom right of the emblem will burn, and burn badly. It simply isn't possible to bake the rest of the cookie to doneness without burning that. And then the burned part will break off when the cookie is removed from the baking sheet.
And that assumes that you can get the cookie dough out of the cutter in the first place, without breaking the point off. It's too narrow to work.
There will probably be similar issues with the left point as well, but those are merely likelihoods, as opposed to certainties.
The point at the top of the emblem may not burn, but it certainly will be much harder and darker than the main part of the cookie.
The voids apparent in both shapes create another area that is likely to burn; these will also make it difficult to transfer the cookies from rolling board to baking sheet without deforming them. Fortunately, there is a simple solution to this problem, anyway: add those parts of the design after the cookies are baked, using frosting.
Frosting is the solution to the emblem as well: create a shape with well-rounded corners, much wider than the points (e.g. offset() that image with a radius of about 10), and use frosting to create the actual emblem after baking.
formatted.
LOL! Nice!
>> formatted.
Don
Thu, Aug 12, 2021 7:15 PM
3D pancake printing has been around for ages, and you could probably
adapt it to cookie dough (I wouldn't know. I cook, but do not bake).
Google "3D printed pancakes" (with quotes).
3D pancake printing has been around for ages, and you could _probably_
