Cookie Cutters
Ray West
Thu, Aug 12, 2021 8:54 PM
I guess you could 'emboss' a pattern easy enough, with the correct dough
mix, maybe a cutter for external shape, and a an inner one either lots
of pointy bits all the way through, or only part depth.
I guess you could 'emboss' a pattern easy enough, with the correct dough mix, maybe a cutter for external shape, and a an inner one either lots of pointy bits all the way through, or only part depth.
Thu, Aug 12, 2021 9:58 PM
On Wed, 2021-08-11 at 08:40 -0500, Don Garrett wrote:
Attached are a couple of sample images I'd like to use, but the goal
is to come up with different shapes quickly, not to use a specific
image, so I can be a bit picky about exactly how the images are
formatted.
Any thoughts about how to approach this?
There are several examples of cookie cutters on Thingiverse that are
what you might call 'multi-level', where part of it cuts the cookie,
and other parts create a design on it.
It would require you to split up the design, and linear_extrude the
various parts individually. This would be particularly useful for both
of your examples.
Here are a few examples:
https://www.thingiverse.com/thing:32431
https://www.thingiverse.com/thing:3194573
https://www.thingiverse.com/thing:891647
On Wed, 2021-08-11 at 08:40 -0500, Don Garrett wrote: > Attached are a couple of sample images I'd like to use, but the goal > is to come up with different shapes quickly, not to use a specific > image, so I can be a bit picky about exactly how the images are > formatted. > Any thoughts about how to approach this? There are several examples of cookie cutters on Thingiverse that are what you might call 'multi-level', where part of it cuts the cookie, and other parts create a design on it. It would require you to split up the design, and linear_extrude the various parts individually. This would be particularly useful for both of your examples. Here are a few examples: https://www.thingiverse.com/thing:32431 https://www.thingiverse.com/thing:3194573 https://www.thingiverse.com/thing:891647
