Fri, Jan 7, 2022 1:36 AM
I have not put your code into OpenSCAD, but there should be scales on
each axis, in mm. You should be able to see how large your model is.
You can use the "scale([x, y, z])" facility to change the scale. So, to
double the size, put "scale([2, 2, 2])" in front of all of your code.
Look in the Help menu and click on the Cheat Sheet and then you can get
more information about each of the intrinsic commands.
On 1/6/2022 8:30 PM, user user wrote:
Dear All,
Thank you for your comments. I can now convert to STL on commenting
the preview. I however now need properly scale the artefact. I am
actually wanting to insert this device -
https://www.aliexpress.com/item/1772142652.html - into it. The
transparent plastic guard that the touchscreen and PCB sit on will be
cut into two. The screen will now be inserted in a slanty form on my
print while the PCB will be sitting in a horizontal state.
The dimension I need is about 7.2inch for length. It is in accordance
with the touchscreen width. The keyboard (dimension 14.1” x 7.79” x
1.49) will sit just on top protuding out left and right. While I won't
worry about its length, I reckon the width of my artefact would be
roughly 12in and height being 7in too.
Kindly help me adjust the dimension in my source code to
7..2in(L)X12in(W)X7in(H)
On Fri, Jan 7, 2022 at 12:28 AM nop head nop.head@gmail.com wrote:
Line 60 is if($preview), so it only generates an assembly view
with F5 and nothing with F6.
Your main_assembly() has geometry in it, which is not how
NopSCADlib works. You put geometry in modules that make STLs and
include those modules in your assembly view. Then you normally
export the STLs using the Python framework but you could
add an else clause to the if($preview) to call one of your STL
making modules.
On Thu, 6 Jan 2022 at 15:19, <user35b@gmail.com> wrote:
Please help. I cannot convert the above Openscad code to STL.
On trying it, I received the above blank page with the
notice/warning below it.
I read somewhere that it might be owing to the % I used, yet I
don't know how to fix it. The keyboard dimension (top of
source code) is the actual length for the artefact.
Here is the code in editable form -
https://pastebin.mozilla.org/wjo2V2xj
Entire code and grahics can be downloaded from here -
https://file.pizza/download/gt0tfawi
Main code here:
[code]
//Comment line 52 to hide the PSU
//Keyboard dimension: 14.1” x 7.79” x 1.49”
//! Project description in Markdown format before the first
include.
$pp1_colour = "grey"; // Override any global defaults here if
required, see NopSCADlib/global_defs.scad.
include <NopSCADlib/lib.scad> // Includes all the vitamins and
utilities in NopSCADlib but not the printed parts.
include <NopSCADlib/vitamins/d_connector.scad>
include <NopSCADlib/vitamins/psus.scad>
//Custom files; may not be needed now
//include <bottom.scad>
//! Assembly instructions in Markdown format in front of each
module that makes an assembly.
module main_assembly()
assembly("main") {
linear_extrude(height = 15){
// translate([5,9,-2])
square(24, center = true);
square(23.5, center = true);
}//close of inner difference
}//close of linear extrude
translate([8, 0, 13])rotate([0, 90, 0])cube([11, 24, 18],
center = true);
// polygon(points=[[0,0],[10,0],[0,10],[1,1],[8,1],[1,8]],
paths=[[0,1,2],[3,4,5]],convexity=10);
// triangle_points =[[0,0],[10,0],[0,10],[1,1],[8,1],[1,8]];
// triangle_paths =[[0,1,2],[3,4,5]];
//translate([-10, 0, 7]) rotate([90, 0, 0])
linear_extrude(height = 24, center = true)
polygon(triangle_points,triangle_paths,1);
b = 10;
h = 10;
w = 24;
triangle_points = [[0,0],[h,0],[0,b]];
triangle_paths = [[0,1,2]];
//Start with an extruded triangle
translate([0, 0, 16]) rotate([90, 90,
180])linear_extrude(height = w, center = true, twist =
0)polygon(points = triangle_points, paths = triangle_paths,
convexity = 10);
}//close of difference
//scale([0.2,0.2,0.2])d_plug(DCONN9);
//Comment next line to hide the PSU
translate([-9, -7.7, 0]) rotate([0, 0,
90])scale([0.05,0.05,0.05])psu(PD_150_12);
}//close of assembly ("main")
if($preview){
main_assembly();
translate([0,0,-5])bottom();
intersection(){
translate([10,6,1]){scale(0.5,0.5,0.5){
// difference(){
// sphere(8);
// translate([0,10,0])sphere(8);
// translate([0,-10,0])sphere(8);
translate([0, 2, 0])rotate([90,0,0])cylinder(r = 1, h = 9,
center = true);
}//close of intersection
//updating via http-svn
translate([10,36,1]){
translate([0, -2, 0])rotate([90,0,0])cylinder(r = 1, h = 7,
center = true);
[/code]
Error image, desired output and code screenshots are attached.
Kindly assist.
Thanks in advance.
> Dear All,
> making modules.
> Main code here:
> [code]
> include.
> assembly("main") {
> difference(){
> difference(){
> center = true);
> b = 10;
> h = 10;
> w = 24;
> convexity = 10);
> if($preview){
> main_assembly();
> intersection(){
> // difference(){
> // sphere(8);
> center = true);
> center = true);
> [/code]
> Kindly assist.
> Thanks in advance.
UU
user user
Fri, Jan 7, 2022 1:48 AM
@Sanjeev: Another err on using 2021 ver. The err is ERROR: Parser error:
syntax error in file dependencies.scad, line 470
<470,/Users/others/Downloads/user35b/dependencies.scad>
Execution aborted
On Fri, Jan 7, 2022 at 9:16 AM Sanjeev Prabhakar sprabhakar2006@gmail.com
All right, I shall get the version 2021.
Thanks. I am wanting to learn from the resource you sent while putting
some final touches to mine.
On Fri, Jan 7, 2022 at 9:06 AM Sanjeev Prabhakar <
Which version of openscad you are working with?
It needs 2021 version which supports x^2 system for squaring otherwise
you need to replace the syntax with pow(x,2)
On Fri, 7 Jan 2022, 06:17 user user, user35b@gmail.com wrote:
Dear Sanjeev,
ou Tfor your assistance. Your attachment throws an error as shown
below:
dependencies.scad", line 107: syntax error
On Fri, Jan 7, 2022 at 12:34 AM Sanjeev Prabhakar <
Hi
There is another way to do this.
not clear what is psu
regards
On Thu, 6 Jan 2022 at 20:31, user35b@gmail.com wrote:
Please help. I cannot convert the above Openscad code to STL. On
trying it, I received the above blank page with the notice/warning below it.
I read somewhere that it might be owing to the % I used, yet I don't
know how to fix it. The keyboard dimension (top of source code) is the
Main code here:
[code]
//! Project description in Markdown format before the first include.
//! Assembly instructions in Markdown format in front of each module
assembly("main") {
translate([8, 0, 13])rotate([0, 90, 0])cube([11, 24, 18], center =
true);
//translate([-10, 0, 7]) rotate([90, 0, 0]) linear_extrude(height =
24, center = true) polygon(triangle_points,triangle_paths,1);
b = 10;
h = 10;
w = 24;
translate([0, 0, 16]) rotate([90, 90, 180])linear_extrude(height = w,
center = true, twist = 0)polygon(points = triangle_points, paths =
triangle_paths, convexity = 10);
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
translate([0, 2, 0])rotate([90,0,0])cylinder(r = 1, h = 9, center =
true);
translate([0, -2, 0])rotate([90,0,0])cylinder(r = 1, h = 7, center =
true);
[/code]
Kindly assist.
Thanks in advance.
Execution aborted
On Fri, Jan 7, 2022 at 9:16 AM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> Great thanks
>>> On Fri, 7 Jan 2022, 06:17 user user, <user35b@gmail.com> wrote:
>>>> Dear Sanjeev,
>>>> below:
>>>>> Hi
>>>>> regards
>>>>>> Main code here:
>>>>>> [code]
>>>>>> assembly("main") {
>>>>>> difference(){
>>>>>> difference(){
>>>>>> true);
>>>>>> b = 10;
>>>>>> h = 10;
>>>>>> w = 24;
>>>>>> if($preview){
>>>>>> main_assembly();
>>>>>> intersection(){
>>>>>> // difference(){
>>>>>> // sphere(8);
>>>>>> true);
>>>>>> true);
>>>>>> [/code]
>>>>>> Kindly assist.
>>>>>> Thanks in advance.
>>>>>> _______________________________________________
>>>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org
Fri, Jan 7, 2022 2:34 AM
I don't have my laptop with me as I am traveling
Can you please paste the line no 470 here so that I can comment
Dear Sanjeev,
below:
Hi
regards
Main code here:
[code]
assembly("main") {
true);
b = 10;
h = 10;
w = 24;
w, center = true, twist = 0)polygon(points = triangle_points, paths =
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
true);
true);
[/code]
Kindly assist.
Thanks in advance.
> <http://470,/Users/others/Downloads/user35b/dependencies.scad>
> Execution aborted
> wrote:
>> Great thanks
>>>>> Dear Sanjeev,
>>>>> below:
>>>>>> Hi
>>>>>> regards
>>>>>>> Main code here:
>>>>>>> [code]
>>>>>>> assembly("main") {
>>>>>>> difference(){
>>>>>>> difference(){
>>>>>>> true);
>>>>>>> b = 10;
>>>>>>> h = 10;
>>>>>>> w = 24;
>>>>>>> if($preview){
>>>>>>> main_assembly();
>>>>>>> intersection(){
>>>>>>> // difference(){
>>>>>>> // sphere(8);
>>>>>>> true);
>>>>>>> true);
>>>>>>> [/code]
>>>>>>> Kindly assist.
>>>>>>> Thanks in advance.
Fri, Jan 7, 2022 3:48 AM
I just checked
Function 2df is used in another function cr (short form of corner radius).
You cannot use it independently.
Once I am back will send an example for function cr. This is a very useful
function
On Fri, 7 Jan 2022, 08:04 Sanjeev Prabhakar, sprabhakar2006@gmail.com
Dear Sanjeev,
below:
Hi
regards
don't know how to fix it. The keyboard dimension (top of source code) is
Main code here:
[code]
assembly("main") {
true);
b = 10;
h = 10;
w = 24;
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
true);
= true);
[/code]
Kindly assist.
Thanks in advance.
I just checked
function
On Fri, 7 Jan 2022, 08:04 Sanjeev Prabhakar, <sprabhakar2006@gmail.com>
>> Execution aborted
>>> Great thanks
>>>>>> Dear Sanjeev,
>>>>>> below:
>>>>>>> Hi
>>>>>>> regards
>>>>>>>> Main code here:
>>>>>>>> [code]
>>>>>>>> assembly("main") {
>>>>>>>> difference(){
>>>>>>>> difference(){
>>>>>>>> true);
>>>>>>>> b = 10;
>>>>>>>> h = 10;
>>>>>>>> w = 24;
>>>>>>>> if($preview){
>>>>>>>> main_assembly();
>>>>>>>> intersection(){
>>>>>>>> // difference(){
>>>>>>>> // sphere(8);
>>>>>>>> true);
>>>>>>>> = true);
>>>>>>>> [/code]
>>>>>>>> Kindly assist.
>>>>>>>> Thanks in advance.
UU
user user
Fri, Jan 7, 2022 3:50 AM
I shall directly mail you about it. If you don't mind. I am afraid I don't
want my request for assistance with setting the dimensions overlooked. If
you could assist with that (too), it would be greatly appreciated.
On Fri, Jan 7, 2022, 10:35 Sanjeev Prabhakar sprabhakar2006@gmail.com
Dear Sanjeev,
below:
Hi
regards
Main code here:
[code]
assembly("main") {
true);
b = 10;
h = 10;
w = 24;
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
true);
= true);
[/code]
Kindly assist.
Thanks in advance.
On Fri, Jan 7, 2022, 10:35 Sanjeev Prabhakar <sprabhakar2006@gmail.com>
>> Execution aborted
>>> Great thanks
>>>>>> Dear Sanjeev,
>>>>>> below:
>>>>>>> Hi
>>>>>>> regards
>>>>>>>> Main code here:
>>>>>>>> [code]
>>>>>>>> assembly("main") {
>>>>>>>> difference(){
>>>>>>>> difference(){
>>>>>>>> true);
>>>>>>>> b = 10;
>>>>>>>> h = 10;
>>>>>>>> w = 24;
>>>>>>>> if($preview){
>>>>>>>> main_assembly();
>>>>>>>> intersection(){
>>>>>>>> // difference(){
>>>>>>>> // sphere(8);
>>>>>>>> true);
>>>>>>>> = true);
>>>>>>>> [/code]
>>>>>>>> Kindly assist.
>>>>>>>> Thanks in advance.
Fri, Jan 7, 2022 3:52 AM
otherwise you need to replace the syntax with pow(x,2)
Dear Sanjeev,
below:
Hi
regards
Main code here:
[code]
include.
assembly("main") {
true);
= 24, center = true) polygon(triangle_points,triangle_paths,1);
b = 10;
h = 10;
w = 24;
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
= true);
= true);
[/code]
Kindly assist.
Thanks in advance.
Sure it's ok
>>> error: syntax error in file dependencies.scad, line 470
>>> Execution aborted
>>>> Great thanks
>>>>>>> Dear Sanjeev,
>>>>>>> below:
>>>>>>>> Hi
>>>>>>>> regards
>>>>>>>>> Main code here:
>>>>>>>>> [code]
>>>>>>>>> include.
>>>>>>>>> assembly("main") {
>>>>>>>>> difference(){
>>>>>>>>> difference(){
>>>>>>>>> true);
>>>>>>>>> b = 10;
>>>>>>>>> h = 10;
>>>>>>>>> w = 24;
>>>>>>>>> if($preview){
>>>>>>>>> main_assembly();
>>>>>>>>> intersection(){
>>>>>>>>> // difference(){
>>>>>>>>> // sphere(8);
>>>>>>>>> = true);
>>>>>>>>> = true);
>>>>>>>>> [/code]
>>>>>>>>> Kindly assist.
>>>>>>>>> Thanks in advance.
UU
user user
Fri, Jan 7, 2022 3:56 AM
I look forward to hearing from you on setting the dimensions. Scale() would
perfectly help as earlier suggested by another guru.
On Fri, Jan 7, 2022, 11:53 Sanjeev Prabhakar sprabhakar2006@gmail.com
don't want my request for assistance with setting the dimensions
overlooked. If you could assist with that (too), it would be greatly
appreciated.
putting some final touches to mine.
Dear Sanjeev,
below:
Hi
regards
Main code here:
[code]
include.
assembly("main") {
= true);
b = 10;
h = 10;
w = 24;
= w, center = true, twist = 0)polygon(points = triangle_points, paths =
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
= true);
center = true);
[/code]
Kindly assist.
Thanks in advance.
On Fri, Jan 7, 2022, 11:53 Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> Sure it's ok
>> appreciated.
>>>> Execution aborted
>>>>> Great thanks
>>>>>>>> Dear Sanjeev,
>>>>>>>> below:
>>>>>>>>> Hi
>>>>>>>>> regards
>>>>>>>>>> Main code here:
>>>>>>>>>> [code]
>>>>>>>>>> include.
>>>>>>>>>> assembly("main") {
>>>>>>>>>> difference(){
>>>>>>>>>> difference(){
>>>>>>>>>> = true);
>>>>>>>>>> b = 10;
>>>>>>>>>> h = 10;
>>>>>>>>>> w = 24;
>>>>>>>>>> if($preview){
>>>>>>>>>> main_assembly();
>>>>>>>>>> intersection(){
>>>>>>>>>> // difference(){
>>>>>>>>>> // sphere(8);
>>>>>>>>>> = true);
>>>>>>>>>> center = true);
>>>>>>>>>> [/code]
>>>>>>>>>> Kindly assist.
>>>>>>>>>> Thanks in advance.
Fri, Jan 7, 2022 4:08 AM
Resize would be better for exact dimensions
You can write and Check following command
swp(rsz3d(cub([30,20,20]),[10,10,10]));
would perfectly help as earlier suggested by another guru.
appreciated.
Dear Sanjeev,
below:
Hi
regards
Main code here:
[code]
include.
assembly("main") {
= true);
b = 10;
h = 10;
w = 24;
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
center = true);
center = true);
[/code]
Kindly assist.
Thanks in advance.
> wrote:
>> Sure it's ok
>>> appreciated.
>>>>> Execution aborted
>>>>>> Great thanks
>>>>>>>>> Dear Sanjeev,
>>>>>>>>> below:
>>>>>>>>>> Hi
>>>>>>>>>> regards
>>>>>>>>>>> Main code here:
>>>>>>>>>>> [code]
>>>>>>>>>>> include.
>>>>>>>>>>> assembly("main") {
>>>>>>>>>>> difference(){
>>>>>>>>>>> difference(){
>>>>>>>>>>> = true);
>>>>>>>>>>> b = 10;
>>>>>>>>>>> h = 10;
>>>>>>>>>>> w = 24;
>>>>>>>>>>> if($preview){
>>>>>>>>>>> main_assembly();
>>>>>>>>>>> intersection(){
>>>>>>>>>>> // difference(){
>>>>>>>>>>> // sphere(8);
>>>>>>>>>>> center = true);
>>>>>>>>>>> center = true);
>>>>>>>>>>> [/code]
>>>>>>>>>>> Kindly assist.
>>>>>>>>>>> Thanks in advance.
UU
user user
Fri, Jan 7, 2022 4:29 AM
I'm looking over and over again where to insert your command -
swp(rsz3d(cub([30,20,20]),[10,10,10])); please advise what line.
On Fri, Jan 7, 2022 at 12:08 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
appreciated.
Dear Sanjeev,
shown below:
Hi
regards
On trying it, I received the above blank page with the notice/warning below
it.
Main code here:
[code]
include.
assembly("main") {
center = true);
b = 10;
h = 10;
w = 24;
180])linear_extrude(height = w, center = true, twist = 0)polygon(points =
triangle_points, paths = triangle_paths, convexity = 10);
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
center = true);
center = true);
[/code]
Kindly assist.
Thanks in advance.
On Fri, Jan 7, 2022 at 12:08 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
>> wrote:
>>> Sure it's ok
>>>> appreciated.
>>>>>> Execution aborted
>>>>>>> Great thanks
>>>>>>>>>> Dear Sanjeev,
>>>>>>>>>> shown below:
>>>>>>>>>>> Hi
>>>>>>>>>>> regards
>>>>>>>>>>>> it.
>>>>>>>>>>>> Main code here:
>>>>>>>>>>>> [code]
>>>>>>>>>>>> include.
>>>>>>>>>>>> assembly("main") {
>>>>>>>>>>>> difference(){
>>>>>>>>>>>> difference(){
>>>>>>>>>>>> center = true);
>>>>>>>>>>>> b = 10;
>>>>>>>>>>>> h = 10;
>>>>>>>>>>>> w = 24;
>>>>>>>>>>>> if($preview){
>>>>>>>>>>>> main_assembly();
>>>>>>>>>>>> intersection(){
>>>>>>>>>>>> // difference(){
>>>>>>>>>>>> // sphere(8);
>>>>>>>>>>>> center = true);
>>>>>>>>>>>> center = true);
>>>>>>>>>>>> [/code]
>>>>>>>>>>>> Kindly assist.
>>>>>>>>>>>> Thanks in advance.
Fri, Jan 7, 2022 4:40 AM
I am sorry
This is just an example
I need to check your code and it will take time as I am not at home
You can check resize command in the cheatsheet for standard application.
appreciated.
Dear Sanjeev,
shown below:
Hi
regards
it.
Main code here:
[code]
include.
assembly("main") {
center = true);
b = 10;
h = 10;
w = 24;
if($preview){
main_assembly();
intersection(){
// difference(){
// sphere(8);
center = true);
center = true);
[/code]
Kindly assist.
Thanks in advance.
I am sorry
>>> wrote:
>>>> Sure it's ok
>>>>> appreciated.
>>>>>>> Execution aborted
>>>>>>>> Great thanks
>>>>>>>>>>> Dear Sanjeev,
>>>>>>>>>>> shown below:
>>>>>>>>>>>> Hi
>>>>>>>>>>>> regards
>>>>>>>>>>>>> it.
>>>>>>>>>>>>> Main code here:
>>>>>>>>>>>>> [code]
>>>>>>>>>>>>> include.
>>>>>>>>>>>>> assembly("main") {
>>>>>>>>>>>>> difference(){
>>>>>>>>>>>>> difference(){
>>>>>>>>>>>>> center = true);
>>>>>>>>>>>>> b = 10;
>>>>>>>>>>>>> h = 10;
>>>>>>>>>>>>> w = 24;
>>>>>>>>>>>>> if($preview){
>>>>>>>>>>>>> main_assembly();
>>>>>>>>>>>>> intersection(){
>>>>>>>>>>>>> // difference(){
>>>>>>>>>>>>> // sphere(8);
>>>>>>>>>>>>> center = true);
>>>>>>>>>>>>> center = true);
>>>>>>>>>>>>> [/code]
>>>>>>>>>>>>> Kindly assist.
>>>>>>>>>>>>> Thanks in advance.
