Can I share this code with the OpenSCAD group? Or do you wish to?
OpenSCAD general discussion discuss@lists.openscad.org
I think you have to join and until then your questions get flagged in
some way. Might be easier for me to do.
OpenSCAD is not a programming language. It is a language to define
geometry. And the geometry is static. So all named values are in fact
constants, not variables. Thus your confusion about summation. EVERY
OpenSCAD user goes through this moment of WTF.
You are correct, of course, about using hull(). I think there is a way
to use various sweep libraries to create the shape you need. As I
recall the sweep libraries call a function to generate a cross section
and another function to generate a path through space. Does the
attached demo help at all?
On 6/8/2017 12:30 AM, Alexey Finkel wrote:
Blade shape is somewhat more complicated than may at first appear. If
you comment out the rotor generation, and uncomment "blade_prim();" at
the end, you will see how it is supposed to curve more clearly. The
generic design I sent you uses a fairly narrow sliver of the whole
shape, but does require that it curve in multiple directions. That is
not something that hull() does well, as I learned during my last
venture into SCAD. For one, it makes a straight line on the back of
the cord, filling in the concavity. It will also not give a different
angle of attack at the top vs. the bottom of the rotor unless I build
it out of straight-line segments like before, which would again be
computationally intensive and also prevent me from using "backsweep"
(and backsweep is supposed to be good for both flow stability and
compressor efficiency, I am told).
Attached is a version of the design with thicker, more visibly tapered
(but still not buttressed) blades.
The 3Dsweep library that you suggested a while ago may be able to
handle it, but I do not know how to generate the NACA airfoil profiles
that it uses, or even if those can be adopted to centrifugal blade
profiles. Reading the code, I also could not see right away how to set
the curve between the beginning and ending profiles. Still, may be
worth another look.
By the way, I had a moment of profound bewilderment when I realized
that the only way OpenSCDA can do summation is through recursive
functions. What sort of a respectable language would do that?!
My search for diffuser guidelines is not proving fruitful, so I am
going to forge ahead with what I hope is a relatively safe, if not the
most effective design. If I aim my efforts towards a test rig, then we
will soon need to do some scheming to figure out how the driver
turbine with its plumbing, the compressor with its, and the
throttleable instrumentation pipe can all be made to "coexist
peacefully together". Speaking of which: did any information on
possible compressor options come to light?
On Wed, Jun 7, 2017 at 9:35 PM, jon <jon@jonbondy.com
mailto:jon@jonbondy.com> wrote:
You use linear_extrude() to make the blade. What if you created a
profile for the top of the blade and one for the bottom,
separately, and then used hull() to connect them. Then the base
could be broader than the top. In fact, the base could be the top
just scaled by 2.
On 6/7/2017 5:12 PM, Alexey Finkel wrote:
The blades actually taper veeery slightly toward the outer edge,
but indeed do not include any real buttressing. Because of the
complicated shape of the hub, I am really not sure how to even go
about putting something like that in place. I could mess with the
arc that generates the blade surface to make the taper more
pronounced, but that's not quite the same thing, of course.
Excel does not, as far as I know, come with an animation package,
so I think I would lose out on the visual appeal part of the
market for the calculators.
On Wed, Jun 7, 2017 at 10:09 AM, jon <jon@jonbondy.com
<mailto:jon@jonbondy.com>> wrote:
Preview rendered instantly here, although trying to
manipulate the view screen in any way causes OpenSCAD to hang
(which may be what you meant). I worry that the blades are
of uniform thickness, which means their attachment point at
the base is fairly narrow. My intuition says that they will
snap off without some broadening at the base
I wrote some Stirling Engine simulators which were very
naive, but I included animations. It was to help my
intuition. I had quite a few requests for them, even though
they were ... stupid.
On 6/7/2017 8:08 AM, Alexey Finkel wrote:
I will ponder on the question of the Discussion group until
Sunday, but as my comment on the meetup page suggests, I
think putting the whole thing on hold while it is not
working so great for you has a substantial risk associated
with it.
Without knowing much of anything about how to use a DSP
unit, I will nevertheless venture a guess that "stunning"
difference may live in a very small and remote corner of
available parameter space; a corner that is difficult to
find unless one has either much insight knowledge, or
preternatural intuitive talent. But that's just a guess.
Of course real engineers have much, *much* more complete and
sophisticated software packages for turbomachinery design.
My spreadsheets are naive child's drivel by comparison.
Their primary purpose is really to give me the illusion of
knowing that I knew what I was doing when choosing some
basic design parameters. It may be an intermediate stage
between completely seat-of-the-pants design and real-life
engineering work, but I have to wonder how big a market
there is for such a beast. At any rate, if we ever built
something based on those calculators, and it worked in any
sense of the word, I would probably make the calculators
available online for free.
It looks like I sent you the wrong version of the new blade
design. This may be for the best, because I developed it
into a proof-of-concept compressor rotor design by now. The
result is attached. Be sure to disable preview before
opening it though! The thing is very high-polygon, and
pretty much kills my SCAD dead if it tries to preview it.
The rotor has a radius of 50 mm, so if you wished, you could
use it as a test. However, I recall you mentioned that the
resin is not cheap, so I wonder if a scaled-down version
would be a more practical way to go. Or, you could cut out a
cylinder or a cone from the rotor hub, at least if
unsolidified resin can be recovered and reused. Also, I used
lower values of $fn that I might for a "final" version to
save computation time. If you were interested to see how
smooth we can get the surfaces, maybe increasing $fn to 100
or even 200 everywhere would help put the printer through
its paces.
On Tue, Jun 6, 2017 at 8:36 AM, jon <jon@jonbondy.com
The new/larger resin printer is assembled, but not
tested, so the timing is good (I hope).
Your spreadsheets are interesting. I wonder if they
could become a commercial product (or, better yet, they
could be re-coded to produce a commercial product). I
know that the Big Guys would not want/need them, but DIY
folks might.
The new 5' tall speakers are interesting. The sound is
OK but not stunning in the frequency-response sense, but
the "sound field" that I had assumed was just BS turns
out to be palpable. You can walk behind the speakers
without losing much of the sound. It seems to just fill
the room. So, from the perspective of wanting to
experience something new, it is a success. The $700 DSP
unit produces detectable differences in system response,
but not stunning differences.
I seem to have run out of steam for the Discussion
group. In the past, topics just leapt to mind, but now
my mind heads in other directions. I'm not sure what to
do about that.
On 6/6/2017 6:36 AM, Alexey Finkel wrote:
It seems I haven't said anything on the subject in a
while, but the last couple of weeks have been a
relatively productive time on the turbine front, so
I thought I'd give a bit of an update on the state
of things.
Both the compressor and turbine calculators are
coming along. Both pass the basic sanity checks I've
put into them and give believable results. However,
I keep adding bits to them, and finding other bits
that can be done better, so I would not risk saying
that they are "done" just yet (or ever, really). One
conclusion is that going from 30-mm radius to 50-mm
rotors makes a huge difference in power, as well as
a significant, but less dramatic one in compressor
pressure. Kilowatt-level output seems feasible with
50-mm rotors without going to ludicrous rpm.
I think this means that we could tentatively answer
one question from the long list as follows: if the
100-mm resin printer is going to be available, we
should be able to print high-precision and smooth
moulds, and cast a ceramic rotor (or rotors).
Whether this works in practice, and whether a stator
made from a plastic printer cast can be made usable
remain open questions, of course.
I've also tried to match a compressor to one
possible version cold-air turbine, and found that it
is sort of possible even with the very low flow rate
available, if a number of adaptations and
concessions are made. Still, as I think I mentioned
,if we can get higher flow rate even at the cost of
pressure, it would be a lot better.
However, I have not tried to assemble a full
compressor-diffuser-combustor-turbine calculator yet
because my rudimentary combustor calculator is
giving me unrealistically high combustion
temperatures, and because useful data on even the
simplest kind of radial-flow diffusers is proving
tricky to track down.
On the other hand, I came up with a new way of
generating blade geometries in SCAD. It uses linear
extrudes with twists instead of hull, thus getting
around the convexity issues I had before. A sample
is attached, but be warned: it also uses differences
of high-polygon objects, so it *really* doesn't like
to run in preview mode. On the plus side, it seems
to compile and render pretty quickly for me.
Proceeding with diffuser design may be slow for a
while, as it looks like I am going to have to do
some more serious reading, but I will try to keep
myself entertained by modeling other parts and
pondering how to fit them together.
How are your projects going by the way? Do you have
more speaker cabinets than you know what to do with
yet? Or did you see the light and opt for the
magical "blue diamond" sound-improver?
Alexey
