OPenSCAD exits immediately after start
B
Bojan
Tue, Nov 27, 2018 9:19 PM
I have a problem - OpenSCAD presents the splash screen, I click on something
(new design or open recent) and programs simply exits. I can see
openscad.exe process for second in Task Manager, then it dissapears.
If I click on existing design file, nothing is shown, nothing happens.
I updated display drivers, but no change.
Please help!
Bojan
Hi, I have a problem - OpenSCAD presents the splash screen, I click on something (new design or open recent) and programs simply exits. I can see openscad.exe process for second in Task Manager, then it dissapears. If I click on existing design file, nothing is shown, nothing happens. I updated display drivers, but no change. Please help! Bojan -- Sent from: http://forum.openscad.org/
KT
Kevin Toppenberg
Tue, Nov 27, 2018 9:21 PM
Has this worked before, but now just stopped working?  What OS are
you using?
Kevin
something
Please help!
Bojan
Has this worked before, but now just stopped working? What OS are you using? Kevin On Tue, Nov 27, 2018 at 4:20 PM Bojan <bstajcar@iinet.net.au> wrote: > Hi, > I have a problem - OpenSCAD presents the splash screen, I click on > something > (new design or open recent) and programs simply exits. I can see > openscad.exe process for second in Task Manager, then it dissapears. > If I click on existing design file, nothing is shown, nothing happens. > > I updated display drivers, but no change. > Please help! > Bojan > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
B
Bojan
Tue, Nov 27, 2018 11:15 PM
Yes, it worked before (W'7 pro), and it works on my other machine at home.
Interesting thing is, recently Repetier host also stopped working (it shows
similar symptoms, this happened quite some time AFTER OpenSCAD stopped),
Yes, it worked before (W'7 pro), and it works on my other machine at home. Interesting thing is, recently Repetier host also stopped working (it shows similar symptoms, this happened quite some time AFTER OpenSCAD stopped), -- Sent from: http://forum.openscad.org/
Troberg
Wed, Nov 28, 2018 7:21 AM
Sounds like time for a virus scan.
Sounds like time for a virus scan. -- Sent from: http://forum.openscad.org/
B
Bojan
Wed, Nov 28, 2018 9:39 PM
Not likely...
Computer in question has Sophos Endpoint engine installed regularly, so I
ampretty confident there are no viruses.
However.. could this (or any other) antivirus software be the cause of that
strange behaviour?
Not likely... Computer in question has Sophos Endpoint engine installed regularly, so I ampretty confident there are no viruses. However.. could this (or any other) antivirus software be the cause of that strange behaviour? -- Sent from: http://forum.openscad.org/
KT
Kevin Toppenberg
Thu, Nov 29, 2018 2:46 PM
Your trust that your virus engine can stop every virus might be a bit
optimistic.  However, I would suspect it would be more like some new
graphics driver is not working with the engine.
Are you using the standard release OpenSCAD, or the beta / early versions?
Which every you have, I wonder if you could download the other and see if
you have the same problem.  Also, you aren't autoloading an OpenSCAD file,
right?  Just trying to open the application by itself.  If you were opening
a design that caused a crash (I have had such a file recently), then it
might be the design file that is the problem, not the engine itself.
Kevin
On Wed, Nov 28, 2018 at 4:39 PM Bojan bstajcar@iinet.net.au wrote:
Not likely...
strange behaviour?
Your trust that your virus engine can stop every virus might be a bit optimistic. However, I would suspect it would be more like some new graphics driver is not working with the engine. Are you using the standard release OpenSCAD, or the beta / early versions? Which every you have, I wonder if you could download the other and see if you have the same problem. Also, you aren't autoloading an OpenSCAD file, right? Just trying to open the application by itself. If you were opening a design that caused a crash (I have had such a file recently), then it might be the design file that is the problem, not the engine itself. Kevin On Wed, Nov 28, 2018 at 4:39 PM Bojan <bstajcar@iinet.net.au> wrote: > Not likely... > Computer in question has Sophos Endpoint engine installed regularly, so I > ampretty confident there are no viruses. > However.. could this (or any other) antivirus software be the cause of that > strange behaviour? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
B
Bojan
Thu, Nov 29, 2018 10:34 PM
Hi Kevin,
I am using standard version (2015.03), 64-bit, w'7 Pro.
Hi Kevin, I am using standard version (2015.03), 64-bit, w'7 Pro. -- Sent from: http://forum.openscad.org/
Sun, Dec 2, 2018 2:22 AM
See if anything shows in Eventlog?
See if anything shows in Eventlog? ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
KT
Kevin Toppenberg
Mon, Dec 3, 2018 2:53 AM
I have not viewed the event log before.  How would I do that?  I.e. where
is the file stored?  I'm on OSX
Thanks
Kevin
I have not viewed the event log before. How would I do that? I.e. where is the file stored? I'm on OSX Thanks Kevin On Sat, Dec 1, 2018 at 9:22 PM MichaelAtOz <oz.at.michael@gmail.com> wrote: > See if anything shows in Eventlog? > > > > > > ----- > Admin - email* me if you need anything, or if I've done something stupid... > > * click on my MichaelAtOz label, there is a link to email me. > > Unless specifically shown otherwise above, my contribution is in the > Public Domain; to the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. Obviously > inclusion of works of previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ time is running out! > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Dec 3, 2018 3:24 AM
This thread is about Bojan's Windows 7 issue. Are you having startup issue on OS X as well?
> On Dec 2, 2018, at 9:53 PM, Kevin Toppenberg <kdtop3@gmail.com> wrote: > > I have not viewed the event log before. How would I do that? I.e. where is the file stored? I'm on OSX > This thread is about Bojan's Windows 7 issue. Are you having startup issue on OS X as well? -Marius
