OPenSCAD exits immediately after start
B
Bojan
Mon, Dec 3, 2018 4:31 AM
Event log is below:
Faulting application name: openscad.exe, version: 0.0.0.0, time stamp:
0x564d2b59
Faulting module name: atig6txx.dll, version: 8.14.1.6463, time stamp:
0x56569fdb
Exception code: 0xc0000005
Fault offset: 0x0000000000016def
Faulting process id: 0x318c
Faulting application start time: 0x01d48ababc497b45
Faulting application path: C:\Program Files\OpenSCAD\openscad.exe
Faulting module path: C:\windows\system32\atig6txx.dll
Report Id: 180788a5-f6ae-11e8-a103-a0481ca3e182
Event log is below: Faulting application name: openscad.exe, version: 0.0.0.0, time stamp: 0x564d2b59 Faulting module name: atig6txx.dll, version: 8.14.1.6463, time stamp: 0x56569fdb Exception code: 0xc0000005 Fault offset: 0x0000000000016def Faulting process id: 0x318c Faulting application start time: 0x01d48ababc497b45 Faulting application path: C:\Program Files\OpenSCAD\openscad.exe Faulting module path: C:\windows\system32\atig6txx.dll Report Id: 180788a5-f6ae-11e8-a103-a0481ca3e182 -- Sent from: http://forum.openscad.org/
B
Bojan
Mon, Dec 3, 2018 4:36 AM
Repetier Hos has much more events went wrong:
Application: RepetierHost.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at OpenTK.Platform.Windows.Wgl+Arb.ChoosePixelFormat(IntPtr, Int32[],
Single[], Int32, Int32[], Int32 ByRef)
at OpenTK.Platform.Windows.WinGraphicsMode.ChoosePixelFormatARB(IntPtr,
OpenTK.Graphics.GraphicsMode)
at
OpenTK.Platform.Windows.WinGraphicsMode.SelectGraphicsMode(OpenTK.Graphics.ColorFormat,
Int32, Int32, Int32, OpenTK.Graphics.ColorFormat, Int32, Boolean)
at
OpenTK.Platform.Windows.WinGLContext.SetGraphicsModePFD(OpenTK.Platform.Windows.WinGraphicsMode,
OpenTK.Graphics.GraphicsMode, OpenTK.Platform.Windows.WinWindowInfo)
at
OpenTK.Platform.Windows.WinGLContext..ctor(OpenTK.Graphics.GraphicsMode,
OpenTK.Platform.Windows.WinWindowInfo, OpenTK.Graphics.IGraphicsContext,
Int32, Int32, OpenTK.Graphics.GraphicsContextFlags)
at
OpenTK.Platform.Windows.WinFactory.CreateGLContext(OpenTK.Graphics.GraphicsMode,
OpenTK.Platform.IWindowInfo, OpenTK.Graphics.IGraphicsContext, Boolean,
at OpenTK.Graphics.GraphicsContext..ctor(OpenTK.Graphics.GraphicsMode,
OpenTK.Platform.IWindowInfo, Int32, Int32,
at OpenTK.WinGLControl.CreateContext(Int32, Int32,
at OpenTK.GLControl.OnHandleCreated(System.EventArgs)
at System.Windows.Forms.Control.WmCreate(System.Windows.Forms.Message
ByRef)
at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message
ByRef)
at System.Windows.Forms.UserControl.WndProc(System.Windows.Forms.Message
ByRef)
at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr,
IntPtr)
Faulting application name: RepetierHost.exe, version: 2.1.3.0, time stamp:
0x5b474e94
0x56569fdb
Faulting process id: 0x6410
Faulting application start time: 0x01d48ac1258a01cd
Faulting application path: C:\Program Files\Repetier-Host\RepetierHost.exe
Report Id: 6a3cdbdd-f6b4-11e8-a103-a0481ca3e182
0x5b474e94
0x56569fdb
Exception code: 0xc000041d
Report Id: 6e601fbd-f6b4-11e8-a103-a0481ca3e182
Repetier Hos has much more events went wrong: Application: RepetierHost.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException at OpenTK.Platform.Windows.Wgl+Arb.ChoosePixelFormat(IntPtr, Int32[], Single[], Int32, Int32[], Int32 ByRef) at OpenTK.Platform.Windows.WinGraphicsMode.ChoosePixelFormatARB(IntPtr, OpenTK.Graphics.GraphicsMode) at OpenTK.Platform.Windows.WinGraphicsMode.SelectGraphicsMode(OpenTK.Graphics.ColorFormat, Int32, Int32, Int32, OpenTK.Graphics.ColorFormat, Int32, Boolean) at OpenTK.Platform.Windows.WinGLContext.SetGraphicsModePFD(OpenTK.Platform.Windows.WinGraphicsMode, OpenTK.Graphics.GraphicsMode, OpenTK.Platform.Windows.WinWindowInfo) at OpenTK.Platform.Windows.WinGLContext..ctor(OpenTK.Graphics.GraphicsMode, OpenTK.Platform.Windows.WinWindowInfo, OpenTK.Graphics.IGraphicsContext, Int32, Int32, OpenTK.Graphics.GraphicsContextFlags) at OpenTK.Platform.Windows.WinFactory.CreateGLContext(OpenTK.Graphics.GraphicsMode, OpenTK.Platform.IWindowInfo, OpenTK.Graphics.IGraphicsContext, Boolean, Int32, Int32, OpenTK.Graphics.GraphicsContextFlags) at OpenTK.Graphics.GraphicsContext..ctor(OpenTK.Graphics.GraphicsMode, OpenTK.Platform.IWindowInfo, Int32, Int32, OpenTK.Graphics.GraphicsContextFlags) at OpenTK.WinGLControl.CreateContext(Int32, Int32, OpenTK.Graphics.GraphicsContextFlags) at OpenTK.GLControl.OnHandleCreated(System.EventArgs) at System.Windows.Forms.Control.WmCreate(System.Windows.Forms.Message ByRef) at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef) at System.Windows.Forms.UserControl.WndProc(System.Windows.Forms.Message ByRef) at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr) Faulting application name: RepetierHost.exe, version: 2.1.3.0, time stamp: 0x5b474e94 Faulting module name: atig6txx.dll, version: 8.14.1.6463, time stamp: 0x56569fdb Exception code: 0xc0000005 Fault offset: 0x0000000000016def Faulting process id: 0x6410 Faulting application start time: 0x01d48ac1258a01cd Faulting application path: C:\Program Files\Repetier-Host\RepetierHost.exe Faulting module path: C:\windows\system32\atig6txx.dll Report Id: 6a3cdbdd-f6b4-11e8-a103-a0481ca3e182 Faulting application name: RepetierHost.exe, version: 2.1.3.0, time stamp: 0x5b474e94 Faulting module name: atig6txx.dll, version: 8.14.1.6463, time stamp: 0x56569fdb Exception code: 0xc000041d Fault offset: 0x0000000000016def Faulting process id: 0x6410 Faulting application start time: 0x01d48ac1258a01cd Faulting application path: C:\Program Files\Repetier-Host\RepetierHost.exe Faulting module path: C:\windows\system32\atig6txx.dll Report Id: 6e601fbd-f6b4-11e8-a103-a0481ca3e182 -- Sent from: http://forum.openscad.org/
Looks like your ATI GPU drivers crashed.
I would recommend looking for a driver update. GPU drivers should never crash.
This is a similar issue: https://github.com/openscad/openscad/issues/2388
On Dec 2, 2018, at 11:31 PM, Bojan bstajcar@iinet.net.au wrote:
Event log is below:
0x564d2b59
0x56569fdb
Looks like your ATI GPU drivers crashed. I would recommend looking for a driver update. GPU drivers should never crash. This is a similar issue: https://github.com/openscad/openscad/issues/2388 -Marius > On Dec 2, 2018, at 11:31 PM, Bojan <bstajcar@iinet.net.au> wrote: > > Event log is below: > > Faulting application name: openscad.exe, version: 0.0.0.0, time stamp: > 0x564d2b59 > Faulting module name: atig6txx.dll, version: 8.14.1.6463, time stamp: > 0x56569fdb > Exception code: 0xc0000005 > Fault offset: 0x0000000000016def > Faulting process id: 0x318c > Faulting application start time: 0x01d48ababc497b45 > Faulting application path: C:\Program Files\OpenSCAD\openscad.exe > Faulting module path: C:\windows\system32\atig6txx.dll > Report Id: 180788a5-f6ae-11e8-a103-a0481ca3e182 > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
B
Bojan
Mon, Dec 3, 2018 4:53 AM
I found th eprevious version of previously mentioned  atig6txx.dll file..
When I restored it, nox the eror is elsewhere:
0x564d2b59
Faulting module name: atio6axx.dll, version: 6.14.10.13411, time stamp:
0x5656a648
Fault offset: 0x0000000001083565
Faulting process id: 0x4f18
Faulting application start time: 0x01d48ac38d5fc005
Faulting module path: C:\windows\system32\atio6axx.dll
Report Id: cc82cde5-f6b6-11e8-a103-a0481ca3e182
Obviously, OpenSCAD doesn't liike newer system files (from 2016 onwards?)
I found th eprevious version of previously mentioned atig6txx.dll file.. When I restored it, nox the eror is elsewhere: Faulting application name: openscad.exe, version: 0.0.0.0, time stamp: 0x564d2b59 Faulting module name: atio6axx.dll, version: 6.14.10.13411, time stamp: 0x5656a648 Exception code: 0xc0000005 Fault offset: 0x0000000001083565 Faulting process id: 0x4f18 Faulting application start time: 0x01d48ac38d5fc005 Faulting application path: C:\Program Files\OpenSCAD\openscad.exe Faulting module path: C:\windows\system32\atio6axx.dll Report Id: cc82cde5-f6b6-11e8-a103-a0481ca3e182 Obviously, OpenSCAD doesn't liike newer system files (from 2016 onwards?) -- Sent from: http://forum.openscad.org/
Mon, Dec 3, 2018 5:34 AM
It’s still the ATI drivers that crashes.
> On Dec 2, 2018, at 11:53 PM, Bojan <bstajcar@iinet.net.au> wrote: > > I found th eprevious version of previously mentioned atig6txx.dll file.. > When I restored it, nox the eror is elsewhere: [...] > Faulting module path: C:\windows\system32\atio6axx.dll It’s still the ATI drivers that crashes. -Marius
KT
Kevin Toppenberg
Mon, Dec 3, 2018 1:23 PM
I'm not having problems, but I would like to know where the event log is on
OS X for future reference.
Thanks
On Sun, Dec 2, 2018 at 10:25 PM Marius Kintel marius@kintel.net wrote:
On Dec 2, 2018, at 9:53 PM, Kevin Toppenberg kdtop3@gmail.com wrote:
I have not viewed the event log before.  How would I do that?  I.e.
where is the file stored?  I'm on OSX
This thread is about Bojan's Windows 7 issue. Are you having startup issue
on OS X as well?
I'm not having problems, but I would like to know where the event log is on OS X for future reference. Thanks On Sun, Dec 2, 2018 at 10:25 PM Marius Kintel <marius@kintel.net> wrote: > > > On Dec 2, 2018, at 9:53 PM, Kevin Toppenberg <kdtop3@gmail.com> wrote: > > > > I have not viewed the event log before. How would I do that? I.e. > where is the file stored? I'm on OSX > > > This thread is about Bojan's Windows 7 issue. Are you having startup issue > on OS X as well? > > -Marius > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
B
Bojan
Mon, Dec 3, 2018 9:09 PM
I updated both ATI and Intel graphic drivers, but no joy, both applications
still crash.
Forgot to mention, system doesn't find any webcam either (not a big problem
for me, though)
I updated both ATI and Intel graphic drivers, but no joy, both applications still crash. Forgot to mention, system doesn't find any webcam either (not a big problem for me, though) -- Sent from: http://forum.openscad.org/
