DV
david vanhorn
Mon, Mar 22, 2021 3:37 PM
I'm doing a complex design with multiple parts.
I need to be able to render and export each sub part independently.
I also need to see a cross section with all parts assembled.
I created an overview, using a boolean variable called CrossSection, and in
the sub parts, I would like to have them sectioned only if CrossSection is
true, but of course without the main file, CrossSection is undefined.
In other languages I would do something like "If undef CrossSection then
CrossSection = false"
How can I implement this in OpenScad?
K1FZY (WA4TPW) SK 9/29/37-4/13/15
Mon, Mar 22, 2021 3:39 PM
if(is_undef(CrossSection) ? false : CrossSection) ...;
in the sub parts, I would like to have them sectioned only if CrossSection
is true, but of course without the main file, CrossSection is undefined.
DV
david vanhorn
Mon, Mar 22, 2021 3:52 PM
I'm not quite seeing it.
How would I apply it here:
module HandleFront(){
render()
HandleFrontFull();
// I'd like to turn this element on or off based on CrossSection
HalfClip(); //
}// end of difference
}// end of module
So I assume that earlier in this file, I should use the if Is_undef to set
CrossSection to false, but I'm not understanding how.
render()
HandleFrontFull();
HalfClip(); //
}// end of module
DV
david vanhorn
Mon, Mar 22, 2021 4:31 PM
Ok, I think I have it now.
Not quite the same, but it's working for me
CrossSection = !is_undef(CrossSection);
if (false == CrossSection){
echo("Printable part generation of CH_Part_Lock");
} else {
echo("Generating cross section of CH_Part_Lock");
Then at the bottom of the file:
// Show the part alone if we're only running this file
echo("Showing part");
TwistLockF(); // This could be printed separately
render()
HandleFrontFull();
HalfClip(); //
}// end of module
then CrossSection = false"
} else {
> render()
> difference(){
> HandleFrontFull();
> HalfClip(); //
> }// end of module
DV
david vanhorn
Mon, Mar 22, 2021 5:10 PM
Well.. I thought I understood it..
// If we're running this file without calling it from the top level file,
then CrossSection is undefined.
if (is_undef(CrossSection)){
CrossSection = false; // So set it to false
// Now use echos to check that CrossSection has been set
echo("CrossSection is undefined");
echo("CrossSection is false");
if (true==CrossSection){
echo("CrossSection is true");
Output:
ECHO:"CrossSection is undefined"
} else {
render()
HandleFrontFull();
HalfClip(); //
}// end of module
set CrossSection to false, but I'm not understanding how.
and in the sub parts, I would like to have them sectioned only if
CrossSection is true, but of course without the main file, CrossSection is
undefined.
Output:
> } else {
>> render()
>> difference(){
>> HandleFrontFull();
>> HalfClip(); //
>> }// end of module
>>>> undefined.
AC
A. Craig West
Mon, Mar 22, 2021 5:21 PM
The general consensus amongst programmers is that using global variables is
rarely a good idea, the easiest and most understandable way to do this is
by adding CrossSection as an argument to the module...
Output:
} else {
render()
HandleFrontFull();
HalfClip(); //
}// end of module
undefined.
> Output:
>> } else {
>>> render()
>>> difference(){
>>> HandleFrontFull();
>>> HalfClip(); //
>>> }// end of module
>>>>> undefined.
Mon, Mar 22, 2021 5:23 PM
You can't change variables in OpenSCAD.
Simply creates a new variable: CrossSection, that only exists between the
braces.
You can create a new variable. Like this.
DoSection = !is_undef(CrossSection) && CrossSection;
Or you could use a function.
function CrossSection() = !is_undef(CrossSection) && CrossSection;
Then do:
if(CrossSection()) {
Output:
} else {
render()
HandleFrontFull();
HalfClip(); //
}// end of module
undefined.
braces.
Then do:
> Output:
>> } else {
>>> render()
>>> difference(){
>>> HandleFrontFull();
>>> HalfClip(); //
>>> }// end of module
>>>>> undefined.
DV
david vanhorn
Mon, Mar 22, 2021 5:26 PM
I knew you couldn't change variables, but I didn't think that assigning one
which was undefined was "changing" it.
braces.
Then do:
Output:
} else {
render()
HandleFrontFull();
HalfClip(); //
}// end of module
undefined.
> braces.
> Then do:
>> Output:
>>> } else {
>>>> render()
>>>> difference(){
>>>> HandleFrontFull();
>>>> HalfClip(); //
>>>> }// end of module
>>>>>> undefined.
Mon, Mar 22, 2021 5:51 PM
It isn't changing it, it defines a new one, but if you do it with if() it
only lasts for the scope of the if construct.
one which was undefined was "changing" it.
braces.
Then do:
file, then CrossSection is undefined.
Output:
} else {
render()
HandleFrontFull();
HalfClip(); //
}// end of module
undefined.
>> braces.
>> Then do:
>>> Output:
>>>> } else {
>>>>> render()
>>>>> difference(){
>>>>> HandleFrontFull();
>>>>> HalfClip(); //
>>>>> }// end of module
>>>>>>> undefined.
Mon, Mar 22, 2021 5:52 PM
No, that would only set CrossSection for that one block.
Once a name has a value defined in a particular block, you can't change
that value - and the top level is a block. At one particular block
level, there is no variation that will let you optionally set a name to
a value at point A, and then later at point B set it to a default value
if it wasn't set at A. Can't be done.
Here's a few variations that work. (Spoiler: I wouldn't use any of
these; see below.)
A) Test for undef at time of use.
module part1() {
if (!is_undef(CrossSection) && CrossSection) {
... whatever ...
B) Define a function, and call it when you need the answer.
function shouldCrossSection( ) = is_undef(CrossSection) ? false : CrossSection;
module part1() {
if (shouldCrossSection()) {
... whatever ...
C) Define a second name at the top level, or inside a block for use in
that block.
shouldCrossSection = is_undef(CrossSection) ? false : CrossSection;
if (shouldCrossSection) {
... whatever ...
D) Define a new variable with the same name, inside a block, for use in
that block.
module part1() {
if (CrossSection) {
... whatever ...
Note that this is not *changing* the value of the variable; it is
creating a new variable inside this block.
But none of those is what I would do. They all use a global variable,
lexically scoped. It's not quite correct to say that you're stuck with
it across your entire model, but it's close. Also, they don't work
across "use <foo.scad>"; they only work across "include <foo.scad>", and
for a lot of purposes "use" is better because it hides the details of
one file from the other.
I would use a $ variable, so that it's dynamically scoped. I'd still
use a function to test it. The result would be sort of like
function shouldCrossSection() = is_undef($CrossSection) ? false : $CrossSection;
module part1() {
... do whatever ...
module part2() {
... do whatever ...
module part3() {
... do whatever ...
and then you could do
$CrossSection = true;
part1();
part2();
part3();
and all three parts would be cross-sectioned, or you could do
part1($CrossSection=true);
part2($CrossSection=false);
part3();
and only part1 would be cross-sectioned. Since false is the default,
part3() doesn't get cross-sectioned.
these; see below.)
module part1() {
... whatever ...
module part1() {
... whatever ...
that block.
... whatever ...
that block.
module part1() {
if (CrossSection) {
... whatever ...
module part1() {
... do whatever ...
module part2() {
... do whatever ...
module part3() {
... do whatever ...
part1();
part2();
part3();
part3();
