MP
Marijan Pollak
Wed, May 10, 2017 5:40 PM
I have found out that when renaming File to an existing name,
file is replaced but date of file remain same old date.
Next of late some programs cause SCAD to turn white screen
and whatever I do it is "Not Responding" all day long.
Is it W10 or my program?
I downloaded Newest Version of OPEN SCAD, but things turned from BAD to
WORSE.
Program Attached!
Thanks in Advance, Marijan Pollak
WORSE.
Program Attached!
Regards from Croatia, the Homeland of one of greatest inventors from 19th
and 20th Centuries, Engineer Nikola Tesla!
WORSE.
Program Attached!
> WORSE.
> Program Attached!
TangTurbineRoundBottomShortNewJetZI.scad (10K) <http://forum.openscad.org/attachment/21425/0/TangTurbineRoundBottomShortNewJetZI.scad>
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425.html
Wed, May 10, 2017 9:20 PM
Confirmed this causes OpenSCAD to go into a CPU loop after preview results
show in console, presumable then when painting the page.
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21426.html
Wed, May 10, 2017 9:26 PM
I believe it's because of all the vertices lining up in the center.
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21427.html
Wed, May 10, 2017 9:34 PM
If you get rid of the difference here
// rotate([0, 270, 0]) {
difference (){
union(){
//difference() // <---------
// Cutting 120 Degrees of Circle, Screw Holes from
it solves the immediate problem.
I think this has been seen before.
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21428.html
difference (){
union(){
Wed, May 10, 2017 10:03 PM
While OpenSCAD should not go rouge when this happens, the problem is that all
the objects in the two unions have coincident faces at [0,0], the tangent
faces of the various circular objects (possibly elsewhere), so in preview
CSG, the difference can't tell whether particular faces should be there or
not.
F6 Render works, the results are non-manifold, which also points to other
coincident faces and possibly other issues. This is the result, those are
holes you can see inside what should be solid.
http://forum.openscad.org/file/n21429/coincident.png
This is netfabb, those yellow lines are holes, so there are problems there
too.
http://forum.openscad.org/file/n21429/coincident_holes_netfabb.png
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21429.html
not.
<http://forum.openscad.org/file/n21429/coincident.png>
too.
<http://forum.openscad.org/file/n21429/coincident_holes_netfabb.png>
Wed, May 10, 2017 11:45 PM
I think I’m missing some info. If anyone feels like opening a github issue that would be helpful!
Thu, May 11, 2017 3:39 AM
Ahh, I knew I'd seen this before
https://github.com/openscad/openscad/issues/1988 .
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21432.html
<https://github.com/openscad/openscad/issues/1988> .
Thu, May 11, 2017 3:42 AM
Well, similar, but not the same...
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21433.html
Thu, May 11, 2017 3:53 AM
Do you mean, using OpenSCAD to save a file named the same as an existing
file, ie replacing the old file by Save?
WORSE.
What was the version originally, and which new version?
Could you also post the Help/Library info data.
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21434.html
> WORSE.
Thu, May 11, 2017 4:54 AM
Note that it is not hung, OpenCSG just takes a very very long time to repaint
the window.
If you hover the mouse over the View menu, when it is done, the menu (ie the
:View:) is highlighted, you can then press Alt-V, then one of the different
view, it then takes a very very long time again.
View this message in context: http://forum.openscad.org/Re-Help-with-two-problems-with-SCAD-tp21425p21435.html
the window.
