Thu, Mar 23, 2023 2:44 AM
I would propose if a module can be developed to rotate an object around an
axis.
e.g. for any sequence of rotations an equivalent axis and angle can be
found from the functions written below
function cvar(a)=
let(
text=a[0],
b=search("-",a)!=[]&&search(".",a)!=[]?[for(i=[2:len(a)-1])if(a[i]!=".")a[i]]:
search("-",a)!=[]&&search(".",a)==[]?[for(i=[2:len(a)-1])a[i]]:
search("-",a)==[]&&search(".",a)!=[]?[for(i=[1:len(a)-1])if(a[i]!=".")a[i]]:[for(i=[1:len(a)-1])a[i]],
n=[["0"],["1"],["2"],["3"],["4"],["5"],["6"],["7"],["8"],["9"]],
l=len(b),
c=[for(i=[0:l-1])each search(b[i],n)],
d=[for(i=[0:len(c)-1])10^(l-i-1)],
e=cd,
f=search(".",a)!=[]&&search("-",a)!=[]?e10^-(l-(search(".",a)[0]-2)):search(".",a)!=[]&&search("-",a)==[]?e10^-(l-(search(".",a)[0]-1)):e,
g=search("-",a)!=[]?f-1:f
)[text,g];
//function to rotate a point around a vector(axis) with angle theta
function q(vector=[1,0,0],point=[0,5,0],theta=0)=
let(t=theta,
v=vector/norm(vector),
p=[cos(t/2),vsin(t/2)],
p1=[p.x,-p.y],
q=[0,len(point)==2?[point.x,point.y,0]:point],
pq=[p.xq.x-p.yq.y,p.xq.y+p.yq.x+cross(p.y,q.y)],
pqp1=[pq.xp1.x-pq.yp1.y,pq.xp1.y+pq.y*p1.x+cross(pq.y,p1.y)],
transformation=pqp1.y
transformation
// function is input to another function q_rot
function qmr1(s,r,pl,n=0)= n==len(s)?pl:
qmr1(s,r,
let(
v1=s[n]=="x"?[1,0,0]:s[n]=="y"?[0,1,0]:[0,0,1],
r1=r[n]==undef?0:r[n])
[for(p=pl)q(v1,p,r1)],n+1);
//function is input to another function q_rot
function qmr2(s,r,pl,n=0)= n==len(s)?pl:qmr2(s,r,let(
[for(i=[0:len(pl)-1])[for(p=pl[i])q(v1,p,r1)]],n+1);
//function to rotate a group of points "pl" around a series of axis with
defined angles e.g q_rot(s=["z20","x40","y80"],pl=[[2,0],[10,2]])=> will
rotate the line first around z axis by 20 deg then around x axis by 40
degrees and then around y axis by 80 degrees.
function q_rot(s,pl)=
is_num(pl[0][0])?qmr1([for(p=s)cvar(p)[0]],[for(p=s)cvar(p)[1]],pl):qmr2([for(p=s)cvar(p)[0]],[for(p=s)cvar(p)[1]],pl);
// sequence of rotation defined by r1
r1=["x30","y40","z100"];
vz=[0,0,1];
v1=q_rot(r1,[vz])[0];
v2=cross(vz,v1);
theta=acos(vz*v1/norm(v1));
// equivalent rotation axis and angle of rotation w.r.t vector vz
echo(v2,theta);
axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
f=search(".",a)!=[]&&search("-",a)!=[]?e*10^-(l-(search(".",a)[0]-2)):search(".",a)!=[]&&search("-",a)==[]?e*10^-(l-(search(".",a)[0]-1)):e,
g=search("-",a)!=[]?f*-1:f
)[text,g];
let(t=theta,
p=[cos(t/2),v*sin(t/2)],
p1=[p.x,-p.y],
pq=[p.x*q.x-p.y*q.y,p.x*q.y+p.y*q.x+cross(p.y,q.y)],
pqp1=[pq.x*p1.x-pq.y*p1.y,pq.x*p1.y+pq.y*p1.x+cross(pq.y,p1.y)],
transformation
qmr1(s,r,
let(
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
KT
Kevin Toppenberg
Fri, Mar 24, 2023 9:23 PM
The math is too dense for me to pick apart, but it seems that when I worked
on this in a different engine, that the math involves quaternions.
Does this solution use quaternions?
Kevin
On Wed, Mar 22, 2023 at 10:45 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
)[text,g];
let(t=theta,
p1=[p.x,-p.y],
transformation
qmr1(s,r,
let(
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
Kevin
On Wed, Mar 22, 2023 at 10:45 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> axis.
> function cvar(a)=
> let(
> text=a[0],
> l=len(b),
> e=c*d,
> )[text,g];
> let(t=theta,
> p1=[p.x,-p.y],
> transformation
> qmr1(s,r,
> let(
> vz=[0,0,1];
> v2=cross(vz,v1);
> echo(v2,theta);
Fri, Mar 24, 2023 9:31 PM
Of course a module can be developed to rotate around an arbitrary axis: the
native rotate in fact already does this with the v= argument.
axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
)[text,g];
let(t=theta,
p1=[p.x,-p.y],
transformation
qmr1(s,r,
let(
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
> axis.
> function cvar(a)=
> let(
> text=a[0],
> l=len(b),
> e=c*d,
> )[text,g];
> let(t=theta,
> p1=[p.x,-p.y],
> transformation
> qmr1(s,r,
> let(
> vz=[0,0,1];
> v2=cross(vz,v1);
> echo(v2,theta);
Fri, Mar 24, 2023 11:38 PM
Yes the function q() is quaternion rotation
Rest of it is mainly to rotate a vector to a sequence.
You can give any length of sequence in any order e.g.
"x30","z90","y73","z50","x43" etc.
worked on this in a different engine, that the math involves quaternions.
Kevin
an axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
)[text,g];
let(t=theta,
p1=[p.x,-p.y],
transformation
qmr1(s,r,
let(
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
> Kevin
>> an axis.
>> function cvar(a)=
>> let(
>> text=a[0],
>> l=len(b),
>> e=c*d,
>> )[text,g];
>> let(t=theta,
>> p1=[p.x,-p.y],
>> transformation
>> qmr1(s,r,
>> let(
>> vz=[0,0,1];
>> v2=cross(vz,v1);
>> echo(v2,theta);
Fri, Mar 24, 2023 11:46 PM
I mean for 3d models without the points list.
This can make the rotations easier to write in my opinion and would request
openscad developers to make a module which rotates the object around an
arbitrary axis, rather than only x,y and z
For the models which I develop with the points list, I have written a
function which does this.
the native rotate in fact already does this with the v= argument.
an axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
)[text,g];
let(t=theta,
p1=[p.x,-p.y],
transformation
qmr1(s,r,
let(
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
>> an axis.
>> function cvar(a)=
>> let(
>> text=a[0],
>> l=len(b),
>> e=c*d,
>> )[text,g];
>> let(t=theta,
>> p1=[p.x,-p.y],
>> transformation
>> qmr1(s,r,
>> let(
>> vz=[0,0,1];
>> v2=cross(vz,v1);
>> echo(v2,theta);
Sat, Mar 25, 2023 12:01 AM
Yes, for 3d geometry, not point lists, the already existing OpenSCAD
rotate() module will rotate angle a around an arbitrary axis v. I don't
find this to be a particularly useful operation in general, though. Must
more useful is rotating one vector onto another. We asked at one point for
them to add rotation that maps vector v onto vector w and they said this
was not suitable to be native and should be done in user space. Of course,
BOSL2 can produce rotation matrices or apply rotations to point lists.
On Fri, Mar 24, 2023 at 7:48 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
request openscad developers to make a module which rotates the object
around an arbitrary axis, rather than only x,y and z
an axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
)[text,g];
let(t=theta,
p1=[p.x,-p.y],
transformation
qmr1(s,r,
let(
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
On Fri, Mar 24, 2023 at 7:48 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
>>> an axis.
>>> function cvar(a)=
>>> let(
>>> text=a[0],
>>> l=len(b),
>>> e=c*d,
>>> )[text,g];
>>> let(t=theta,
>>> p1=[p.x,-p.y],
>>> transformation
>>> qmr1(s,r,
>>> let(
>>> vz=[0,0,1];
>>> v2=cross(vz,v1);
>>> echo(v2,theta);
Sat, Mar 25, 2023 12:15 AM
For a function like that, I'd recommend pairs of operation and value - [
"x", 30, "z", 90, "y", 73, "x", 43 ].
That's both a lot easier to process - no parsing strings to extract
numbers - and more easily allows for the values being variables.
Sat, Mar 25, 2023 12:21 AM
Oh, I didn't know this
Will check once I have access to my computer
Thanks
an axis.
function cvar(a)=
let(
text=a[0],
l=len(b),
e=c*d,
)[text,g];
let(t=theta,
p1=[p.x,-p.y],
transformation
qmr1(s,r,
let(
with defined angles e.g q_rot(s=["z20","x40","y80"],pl=[[2,0],[10,2]])=>
will rotate the line first around z axis by 20 deg then around x axis by 40
vz=[0,0,1];
v2=cross(vz,v1);
echo(v2,theta);
Thanks
>>>> an axis.
>>>> function cvar(a)=
>>>> let(
>>>> text=a[0],
>>>> l=len(b),
>>>> e=c*d,
>>>> )[text,g];
>>>> let(t=theta,
>>>> p1=[p.x,-p.y],
>>>> transformation
>>>> qmr1(s,r,
>>>> let(
>>>> vz=[0,0,1];
>>>> v2=cross(vz,v1);
>>>> echo(v2,theta);
Sat, Mar 25, 2023 12:23 AM
You are right
It is easier but you need to write a little extra
On Sat, 25 Mar 2023, 05:46 Jordan Brown, <openscad@jordan.maileater.net>
Sat, Mar 25, 2023 1:46 AM
//rotated cylinder
color("magenta")
rotate([0,45,0])
rotate([70,0,0])
rotate([0,10,0])
rotate([30,40,100])
cylinder(r=1,h=50,$fn=30);
//reverse rotation based on equivalent axis of rotation and angle
theta=78.09373872704292;
v=[0.33215577139188024, 0.9203587619795575, -0.0];
color("green")
rotate(-theta,v)
rotate(theta,v)
On Sat, 25 Mar 2023, 05:53 Sanjeev Prabhakar, sprabhakar2006@gmail.com
//rotated cylinder
color("magenta")
rotate([0,45,0])
rotate([70,0,0])
rotate([0,10,0])
rotate([30,40,100])
color("green")
rotate(-theta,v)
rotate(theta,v)
On Sat, 25 Mar 2023, 05:53 Sanjeev Prabhakar, <sprabhakar2006@gmail.com>
> You are right
