HL
Hans L
Mon, Jan 28, 2019 10:29 AM
Are you using a somewhat recent dev snapshot? The CSG Tree generation and
key storing got reworked significantly in the past year.
With the example you gave I get 7s preview and "Geometries in cache: 1". I
see that yours is showing 395 geometries so either your posted example
simplified away the cause of the issue, or something different between with
the build you are running.
On Mon, Jan 28, 2019 at 2:59 AM nop head nop.head@gmail.com wrote:
Here is a boiled down version:
https://gist.github.com/nophead/fd4ca58b5f6b19dc25bb98f7edbae90f
I captured the points and face lists generated by sweep and hard coded
them to remove all of my library. Each spring is 4576 points, 9122 faces
but they are all the same polyhedron repeated 100 times. Given that it
doesn't cache polyhedra it has to process the same lists to a Polyset 100
times. Taking about 1/4 second to process 9000 faces seems very slow to me
on a 64 bit 2.5GHz core I7 with 8 GB memory.
On Mon, 28 Jan 2019 at 02:23, Hans L thehans@gmail.com wrote:
Hi nophead,
Could you post a sample script for others to reproduce the slowness you
experience?
Thanks,
Hans
On Sun, Jan 27, 2019 at 4:59 PM nop head nop.head@gmail.com wrote:
It spends most of the 22 seconds stuck at Compiling design (CSG Tree
generation)...
After that it does all the rest in about 1 second, including a very fast
progress bar.
Geometries in cache: 395
Geometry cache size in bytes: 20331104
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Normalized CSG tree has 100 elements
Compile and preview finished.
Total rendering time: 0 hours, 0 minutes, 22 seconds
It would be a problem if I was designing a mattress with PLA springs but
fortunately only a battery box with four, but it would be nice if
polyhedrons were cached like other geometry seems to be. I clearly don't
fully understand OpenSCADs caching system.
On Sun, 27 Jan 2019 at 22:33, Parkinbot rudolf@digitaldocument.de
Is it perhaps that the lists are stored as strings when the
instantiated and then parsed to vectors every time the geometry is
created.
> On Mon, 28 Jan 2019 at 02:23, Hans L <thehans@gmail.com> wrote:
>> Hi nophead,
>> experience?
>> Thanks,
>> Hans
>>> generation)...
>>> progress bar.
>>> Compiling design (CSG Products generation)...
>>> Compiling design (CSG Products normalization)...
>>> On Sun, 27 Jan 2019 at 22:33, Parkinbot <rudolf@digitaldocument.de>
>>> wrote:
>>>> polyhedron is
>>>> > created.
>>>> I doubt that. But you are right, the code really looks like nothing very
>>>> time consuming is happening.
>>>> Is the triangulation of the faces done by Open GL? What happens after
>>>> the
>>>> geometry has been created?
>>>> Sent from: http://forum.openscad.org/
>>>> _______________________________________________
>>>> OpenSCAD mailing list
>>>> Discuss@lists.openscad.org
>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Jan 28, 2019 10:52 AM
I am using a snapshot from yesterday.
I only get one geometry if that is the only file loaded. I had more MDI
windows open when I posted yesterday.
You might have a machine that is three times faster than this laptop but
even so 7 seconds seems slow to me. It has to read about 1 million faces
from a list and convert them into Polysets which are just vectors of
vectors of vertices. Perhaps I have just lost touch with how inefficient
modern software is.
OpenSCAD 2019.01.27.ci1306
https://www.openscad.org/
Copyright (C) 2009-2019 The OpenSCAD Developers
This program is free software; you can redistribute it and/or modify it
under the terms of the GNU General Public License as published by the Free
Software Foundation; either version 2 of the License, or (at your option)
any later version.
Loaded design 'C:/Users/ChrisP/Documents/springs.csg'.
Geometry cache size in bytes: 657560
Total rendering time: 0 hours, 0 minutes, 21 seconds
I see that yours is showing 395 geometries so either your posted example
Hi nophead,
experience?
Thanks,
Hans
generation)...
fast progress bar.
but fortunately only a battery box with four, but it would be nice if
created.
modern software is.
any later version.
>>> Hi nophead,
>>> experience?
>>> Thanks,
>>> Hans
>>>> generation)...
>>>> fast progress bar.
>>>> wrote:
>>>>> polyhedron is
>>>>> > created.
>>>>> very
>>>>> the
Mon, Jan 28, 2019 2:38 PM
I tried some older snaps with 100 copies of a sweep object, each containing
19002 facets and no buffering of the points and faces: one from 2016
(1'36"), one from 2017 (1'16"), one from 2018 (1'00") and a recent 2019
(1':00"). So there was some progress.
With buffering of points and faces the 2019 version needed 0'42".
As compiling an own fork of OpenSCAD is not recommended on Windows (too much
effort to set it up), I don't know the code well enough to be able to follow
what is happening in an F5 context. But I am curious.
Can anybody provide a sketch of how the execution goes on after
createGeometry()?
(1':00"). So there was *some* progress.
createGeometry()?
Mon, Jan 28, 2019 4:59 PM
I think the majority of the time is taken in createGeometry, not after it
it.
100 spheres with $fn set to 150, which gives 11250 vertices each, only
takes 1 second, presumably because it is cached, or it is 20 times quicker
to calculate vertices with trig than it is to read them from a list.
much
follow
createGeometry()?
it.
On Mon, 28 Jan 2019 at 14:40, Parkinbot <rudolf@digitaldocument.de> wrote:
> and
> much
> follow
> createGeometry()?
HL
Hans L
Mon, Jan 28, 2019 6:06 PM
Well for reference my cpu is: Intel(R) Core(TM) i7-6820HQ CPU @ 2.70GHz, I
wouldn't expect it to be 3x faster than a 2.5GHz core i7..
I am testing on Linux, not Windows, so maybe that is the main difference. I
wonder if Windows snapshots are not getting the same -O2 compiler
optimizations?
But anyways, the main thing about caching is that it doesn't simply cache a
call to a module. OpenSCAD first converts the entire script into csg
format which is just a static representation of primitives, multmatrix
transformations and boolean operations, so it has to evaluate all lists
comprehensions, control structures etc, creating scope for each node etc;
essentially building up the entire output that you see in .csg export, in
memory (about 31.6MB of text for nopheads example, although in memory it
should be a bit less due to whitespace/indentation stripping). Then it
caches Polysets for matching subtrees (substrings basically of any node and
its children) from this .csg representation.
Compare the 31.6MB to the size of the .csg output of your sphere example,
that's gonna be like a couple kb of text processing.
it.
containing
much
follow
createGeometry()?
optimizations?
*call* to a module. OpenSCAD first converts the entire script into csg
should be a bit less due to whitespace/indentation stripping). *Then* it
> it.
>> and
>> containing
>> much
>> follow
>> createGeometry()?
Mon, Jan 28, 2019 6:40 PM
It is only 31.6MB in the csg because the lists are text and are repeated
over and over again. But at runtime there should only be one copy of the
lists in binary. Does it really generate a textual csg representation in
memory or is that just when you dump it? And does it actually make 100
copies of the lists by value? That might explain why it is so slow.
I wouldn't expect it to be 3x faster than a 2.5GHz core i7..
I wonder if Windows snapshots are not getting the same -O2 compiler
optimizations?
a call to a module. OpenSCAD first converts the entire script into csg
it.
containing
much
follow
createGeometry()?
> optimizations?
> a *call* to a module. OpenSCAD first converts the entire script into csg
>> it.
>> wrote:
>>> and
>>> containing
>>> much
>>> follow
>>> createGeometry()?
HL
Hans L
Mon, Jan 28, 2019 6:47 PM
Yes it really does. The csg text representation of a node is its cache
key. And the csg format doesn't really do individual variable (list)
caching.
optimizations?
it it.
containing
much
follow
createGeometry()?
Yes it really does. The csg text representation of a node *is* its cache
caching.
>> optimizations?
>>> it it.
>>> wrote:
>>>> generation and
>>>> containing
>>>> much
>>>> follow
>>>> createGeometry()?
HL
Hans L
Mon, Jan 28, 2019 8:17 PM
I did some profiling and found that its spending much of its time in
PolysetUtils::tessellate_faces, because its re-tessellating each geometry
after pulling from geometry cache. Ideally it should tesselate only once
before putting into the cache. Pull request incoming. :)
caching.
difference. I wonder if Windows snapshots are not getting the same -O2
compiler optimizations?
cache a call to a module. OpenSCAD first converts the entire script into
csg format which is just a static representation of primitives, multmatrix
example, that's gonna be like a couple kb of text processing.
it it.
only takes 1 second, presumably because it is cached, or it is 20 times
quicker to calculate vertices with trig than it is to read them from a list.
containing
(too much
follow
createGeometry()?
*before* putting into the cache. Pull request incoming. :)
> caching.
>>> cache a *call* to a module. OpenSCAD first converts the entire script into
>>>> it it.
>>>> wrote:
>>>>> generation and
>>>>> containing
>>>>> (too much
>>>>> follow
>>>>> createGeometry()?
Mon, Jan 28, 2019 9:28 PM
Ah I see. Thanks for your information. That explains a lot and it looks like
values are indeed parsed from string representation as nophead had supposed.
Mon, Jan 28, 2019 10:20 PM
I am totally confused because in the source code it is just passed as a
variable that happens to be a list. Where does it get converted to back a
string again and parsed? Or are OpenSCAD lists just vectors of strings?
And as for re-tessellating. How long does it take to tessellate something
that is already mostly triangles? Should I manually tessellate the end caps
with a triangle fan? The other 9000+ facets are already triangles.
> like
> supposed.
