Module caching
HL
Hans L
Mon, Jan 28, 2019 10:45 PM
The code is in:  Tree::getIdString, which calls to NodeDumper class to dump
the whole tree into a string.
On Mon, Jan 28, 2019 at 4:21 PM nop head nop.head@gmail.com wrote:
I am totally confused because in the source code it is just passed as a
variable that happens to be a list. Where does it get converted to back a
string again and parsed? Or are OpenSCAD lists just vectors of strings?
And as for re-tessellating. How long does it take to tessellate something
that is already mostly triangles? Should I manually tessellate the end caps
with a triangle fan? The other 9000+ facets are already triangles.
On Mon, 28 Jan 2019 at 21:30, Parkinbot rudolf@digitaldocument.de wrote:
Ah I see. Thanks for your information. That explains a lot and it looks
like
values are indeed parsed from string representation as nophead had
supposed.
The code is in: Tree::getIdString, which calls to NodeDumper class to dump the whole tree into a string. On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: > I am totally confused because in the source code it is just passed as a > variable that happens to be a list. Where does it get converted to back a > string again and parsed? Or are OpenSCAD lists just vectors of strings? > > And as for re-tessellating. How long does it take to tessellate something > that is already mostly triangles? Should I manually tessellate the end caps > with a triangle fan? The other 9000+ facets are already triangles. > > On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> wrote: > >> Ah I see. Thanks for your information. That explains a lot and it looks >> like >> values are indeed parsed from string representation as nophead had >> supposed. >> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Jan 28, 2019 11:43 PM
Sort of makes sense for scalar arguments but to dump list contents of list
arguments is bonkers. Perhaps the memory address of the list, since it is
the same list used 100 times?
like
supposed.
Sort of makes sense for scalar arguments but to dump list contents of list arguments is bonkers. Perhaps the memory address of the list, since it is the same list used 100 times? On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: > The code is in: Tree::getIdString, which calls to NodeDumper class to > dump the whole tree into a string. > > On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: > >> I am totally confused because in the source code it is just passed as a >> variable that happens to be a list. Where does it get converted to back a >> string again and parsed? Or are OpenSCAD lists just vectors of strings? >> >> And as for re-tessellating. How long does it take to tessellate something >> that is already mostly triangles? Should I manually tessellate the end caps >> with a triangle fan? The other 9000+ facets are already triangles. >> >> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >> wrote: >> >>> Ah I see. Thanks for your information. That explains a lot and it looks >>> like >>> values are indeed parsed from string representation as nophead had >>> supposed. >>> >>> >>> >>> >>> -- >>> Sent from: http://forum.openscad.org/ >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
HL
Hans L
Tue, Jan 29, 2019 2:00 AM
OK, I finished up working out the bugs and made my pull request re:
tessellation: https://github.com/openscad/openscad/pull/2738
Between that and the progress bar changes (
https://github.com/openscad/openscad/pull/2735 ) I had to bump up the
spring count to get some more precision from the rendering time.  It's gone
from 26s to 16s, for a 20x20 grid of your springs.
Yeah there is probably still some performance to be gained from optimizing
the cache id strings in some way, i'm not sure referencing memory addresses
would be the most reliable approach, but I'll look into where its spending
cycles on that front.
something that is already mostly triangles? Should I manually tessellate
the end caps with a triangle fan? The other 9000+ facets are already
triangles.
like
supposed.
OK, I finished up working out the bugs and made my pull request re: tessellation: https://github.com/openscad/openscad/pull/2738 Between that and the progress bar changes ( https://github.com/openscad/openscad/pull/2735 ) I had to bump up the spring count to get some more precision from the rendering time. It's gone from 26s to 16s, for a 20x20 grid of your springs. Yeah there is probably still some performance to be gained from optimizing the cache id strings in some way, i'm not sure referencing memory addresses would be the most reliable approach, but I'll look into where its spending cycles on that front. On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: > Sort of makes sense for scalar arguments but to dump list contents of list > arguments is bonkers. Perhaps the memory address of the list, since it is > the same list used 100 times? > > On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: > >> The code is in: Tree::getIdString, which calls to NodeDumper class to >> dump the whole tree into a string. >> >> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: >> >>> I am totally confused because in the source code it is just passed as a >>> variable that happens to be a list. Where does it get converted to back a >>> string again and parsed? Or are OpenSCAD lists just vectors of strings? >>> >>> And as for re-tessellating. How long does it take to tessellate >>> something that is already mostly triangles? Should I manually tessellate >>> the end caps with a triangle fan? The other 9000+ facets are already >>> triangles. >>> >>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>> wrote: >>> >>>> Ah I see. Thanks for your information. That explains a lot and it looks >>>> like >>>> values are indeed parsed from string representation as nophead had >>>> supposed. >>>> >>>> >>>> >>>> >>>> -- >>>> Sent from: http://forum.openscad.org/ >>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
HL
Hans L
Tue, Jan 29, 2019 6:11 AM
I've updated my PR with another optimization related to how strings are
generated for long lists, and I've now got it down to 9s for 20x20 grid of
springs.
triangles.
looks like
supposed.
I've updated my PR with another optimization related to how strings are generated for long lists, and I've now got it down to 9s for 20x20 grid of springs. On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: > OK, I finished up working out the bugs and made my pull request re: > tessellation: https://github.com/openscad/openscad/pull/2738 > > Between that and the progress bar changes ( > https://github.com/openscad/openscad/pull/2735 ) I had to bump up the > spring count to get some more precision from the rendering time. It's gone > from 26s to 16s, for a 20x20 grid of your springs. > > Yeah there is probably still some performance to be gained from optimizing > the cache id strings in some way, i'm not sure referencing memory addresses > would be the most reliable approach, but I'll look into where its spending > cycles on that front. > > > > On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: > >> Sort of makes sense for scalar arguments but to dump list contents of >> list arguments is bonkers. Perhaps the memory address of the list, since it >> is the same list used 100 times? >> >> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >> >>> The code is in: Tree::getIdString, which calls to NodeDumper class to >>> dump the whole tree into a string. >>> >>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: >>> >>>> I am totally confused because in the source code it is just passed as a >>>> variable that happens to be a list. Where does it get converted to back a >>>> string again and parsed? Or are OpenSCAD lists just vectors of strings? >>>> >>>> And as for re-tessellating. How long does it take to tessellate >>>> something that is already mostly triangles? Should I manually tessellate >>>> the end caps with a triangle fan? The other 9000+ facets are already >>>> triangles. >>>> >>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>>> wrote: >>>> >>>>> Ah I see. Thanks for your information. That explains a lot and it >>>>> looks like >>>>> values are indeed parsed from string representation as nophead had >>>>> supposed. >>>>> >>>>> >>>>> >>>>> >>>>> -- >>>>> Sent from: http://forum.openscad.org/ >>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >
Tue, Jan 29, 2019 10:10 AM
Great although it only went from 22 to 17 seconds for me for 100 springs.
400 takes 70 seconds. I used the 64 bit MXE version here:
https://circleci.com/gh/openscad/openscad/1350#artifacts
I was willing to believe you had a machine three times faster, due to
faster memory / bus, etc but 8 times faster is a bit extreme. I do notice
that the test suite runs a lot faster on the server than it does on my
desktop at home. I assumed that cloud servers are somewhat more powerful. I
wonder of the Linux version is faster for some reason.
springs.
a variable that happens to be a list. Where does it get converted to back a
triangles.
looks like
supposed.
Great although it only went from 22 to 17 seconds for me for 100 springs. 400 takes 70 seconds. I used the 64 bit MXE version here: https://circleci.com/gh/openscad/openscad/1350#artifacts I was willing to believe you had a machine three times faster, due to faster memory / bus, etc but 8 times faster is a bit extreme. I do notice that the test suite runs a lot faster on the server than it does on my desktop at home. I assumed that cloud servers are somewhat more powerful. I wonder of the Linux version is faster for some reason. On Tue, 29 Jan 2019 at 06:12, Hans L <thehans@gmail.com> wrote: > I've updated my PR with another optimization related to how strings are > generated for long lists, and I've now got it down to 9s for 20x20 grid of > springs. > > On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: > >> OK, I finished up working out the bugs and made my pull request re: >> tessellation: https://github.com/openscad/openscad/pull/2738 >> >> Between that and the progress bar changes ( >> https://github.com/openscad/openscad/pull/2735 ) I had to bump up the >> spring count to get some more precision from the rendering time. It's gone >> from 26s to 16s, for a 20x20 grid of your springs. >> >> Yeah there is probably still some performance to be gained from >> optimizing the cache id strings in some way, i'm not sure referencing >> memory addresses would be the most reliable approach, but I'll look into >> where its spending cycles on that front. >> >> >> >> On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: >> >>> Sort of makes sense for scalar arguments but to dump list contents of >>> list arguments is bonkers. Perhaps the memory address of the list, since it >>> is the same list used 100 times? >>> >>> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >>> >>>> The code is in: Tree::getIdString, which calls to NodeDumper class to >>>> dump the whole tree into a string. >>>> >>>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: >>>> >>>>> I am totally confused because in the source code it is just passed as >>>>> a variable that happens to be a list. Where does it get converted to back a >>>>> string again and parsed? Or are OpenSCAD lists just vectors of strings? >>>>> >>>>> And as for re-tessellating. How long does it take to tessellate >>>>> something that is already mostly triangles? Should I manually tessellate >>>>> the end caps with a triangle fan? The other 9000+ facets are already >>>>> triangles. >>>>> >>>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>>>> wrote: >>>>> >>>>>> Ah I see. Thanks for your information. That explains a lot and it >>>>>> looks like >>>>>> values are indeed parsed from string representation as nophead had >>>>>> supposed. >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> -- >>>>>> Sent from: http://forum.openscad.org/ >>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
HL
Hans L
Wed, Jan 30, 2019 3:56 AM
Hmm, it appears so.  I finally dual booted into Windows 10 on my same
computer that I tested the linux builds on.
The circle-ci build gives me 18s for 100, and 73s for 400 springs, so
pretty much the same results you are getting.
I was looking into what profiling tools are available for windows, and it
looks like Windows Performance Analyzer (WPA) would be able to do what I
want.  I particularly like viewing flame graphs; that is what I've used to
analyze Linux performance, and those are available through WPA.
Unfortunately I hadn't booted into windows on this machine for what looks
like 22 months and its been running updates for the past 8 hours.  It won't
let me install WPA until I've updated to a more recent version, so I'm just
waiting...
springs.
triangles.
looks like
supposed.
Hmm, it appears so. I finally dual booted into Windows 10 on my same computer that I tested the linux builds on. The circle-ci build gives me 18s for 100, and 73s for 400 springs, so pretty much the same results you are getting. I was looking into what profiling tools are available for windows, and it looks like Windows Performance Analyzer (WPA) would be able to do what I want. I particularly like viewing flame graphs; that is what I've used to analyze Linux performance, and those are available through WPA. Unfortunately I hadn't booted into windows on this machine for what looks like 22 months and its been running updates for the past 8 hours. It won't let me install WPA until I've updated to a more recent version, so I'm just waiting... On Tue, Jan 29, 2019 at 4:11 AM nop head <nop.head@gmail.com> wrote: > Great although it only went from 22 to 17 seconds for me for 100 springs. > 400 takes 70 seconds. I used the 64 bit MXE version here: > https://circleci.com/gh/openscad/openscad/1350#artifacts > > I was willing to believe you had a machine three times faster, due to > faster memory / bus, etc but 8 times faster is a bit extreme. I do notice > that the test suite runs a lot faster on the server than it does on my > desktop at home. I assumed that cloud servers are somewhat more powerful. I > wonder of the Linux version is faster for some reason. > > On Tue, 29 Jan 2019 at 06:12, Hans L <thehans@gmail.com> wrote: > >> I've updated my PR with another optimization related to how strings are >> generated for long lists, and I've now got it down to 9s for 20x20 grid of >> springs. >> >> On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: >> >>> OK, I finished up working out the bugs and made my pull request re: >>> tessellation: https://github.com/openscad/openscad/pull/2738 >>> >>> Between that and the progress bar changes ( >>> https://github.com/openscad/openscad/pull/2735 ) I had to bump up the >>> spring count to get some more precision from the rendering time. It's gone >>> from 26s to 16s, for a 20x20 grid of your springs. >>> >>> Yeah there is probably still some performance to be gained from >>> optimizing the cache id strings in some way, i'm not sure referencing >>> memory addresses would be the most reliable approach, but I'll look into >>> where its spending cycles on that front. >>> >>> >>> >>> On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: >>> >>>> Sort of makes sense for scalar arguments but to dump list contents of >>>> list arguments is bonkers. Perhaps the memory address of the list, since it >>>> is the same list used 100 times? >>>> >>>> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >>>> >>>>> The code is in: Tree::getIdString, which calls to NodeDumper class to >>>>> dump the whole tree into a string. >>>>> >>>>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: >>>>> >>>>>> I am totally confused because in the source code it is just passed as >>>>>> a variable that happens to be a list. Where does it get converted to back a >>>>>> string again and parsed? Or are OpenSCAD lists just vectors of strings? >>>>>> >>>>>> And as for re-tessellating. How long does it take to tessellate >>>>>> something that is already mostly triangles? Should I manually tessellate >>>>>> the end caps with a triangle fan? The other 9000+ facets are already >>>>>> triangles. >>>>>> >>>>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>>>>> wrote: >>>>>> >>>>>>> Ah I see. Thanks for your information. That explains a lot and it >>>>>>> looks like >>>>>>> values are indeed parsed from string representation as nophead had >>>>>>> supposed. >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> -- >>>>>>> Sent from: http://forum.openscad.org/ >>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
HL
Hans L
Wed, Jan 30, 2019 9:00 PM
OK I've had a hell of a time getting the updates to install and just given
up on using Windows on that machine for now.  It would have been nice to
compare on the same hardware, but I've just decided to do some more testing
on my main windows machine that is already properly updated.
I got WPR and WPA installed, but don't have debug symbols in the circle-ci
builds so the flame graph stack listings are useless to me at the moment.
I'm not sure how to create a debug windows build yet, I'll look into that.
I was able to test the AppImage to under windows, by more or less following
these instructions:
https://discourse.appimage.org/t/run-appimage-on-windows/177
I used Debian linux from Microsoft Store, and also had to install a couple
more packages:
sudo apt install xcb libgtk2.0-0 libgl1-mesa-glx
It does 100 springs in 2s and 400 in 10s, which is basically the same
results I was seeing from native linux.
waiting...
springs.
as a variable that happens to be a list. Where does it get converted to
back a string again and parsed? Or are OpenSCAD lists just vectors of
strings?
triangles.
looks like
supposed.
OK I've had a hell of a time getting the updates to install and just given up on using Windows on that machine for now. It would have been nice to compare on the same hardware, but I've just decided to do some more testing on my main windows machine that is already properly updated. I got WPR and WPA installed, but don't have debug symbols in the circle-ci builds so the flame graph stack listings are useless to me at the moment. I'm not sure how to create a debug windows build yet, I'll look into that. I was able to test the AppImage to under windows, by more or less following these instructions: https://discourse.appimage.org/t/run-appimage-on-windows/177 I used Debian linux from Microsoft Store, and also had to install a couple more packages: sudo apt install xcb libgtk2.0-0 libgl1-mesa-glx It does 100 springs in 2s and 400 in 10s, which is basically the same results I was seeing from native linux. On Tue, Jan 29, 2019 at 9:56 PM Hans L <thehans@gmail.com> wrote: > Hmm, it appears so. I finally dual booted into Windows 10 on my same > computer that I tested the linux builds on. > > The circle-ci build gives me 18s for 100, and 73s for 400 springs, so > pretty much the same results you are getting. > > I was looking into what profiling tools are available for windows, and it > looks like Windows Performance Analyzer (WPA) would be able to do what I > want. I particularly like viewing flame graphs; that is what I've used to > analyze Linux performance, and those are available through WPA. > Unfortunately I hadn't booted into windows on this machine for what looks > like 22 months and its been running updates for the past 8 hours. It won't > let me install WPA until I've updated to a more recent version, so I'm just > waiting... > > > On Tue, Jan 29, 2019 at 4:11 AM nop head <nop.head@gmail.com> wrote: > >> Great although it only went from 22 to 17 seconds for me for 100 springs. >> 400 takes 70 seconds. I used the 64 bit MXE version here: >> https://circleci.com/gh/openscad/openscad/1350#artifacts >> >> I was willing to believe you had a machine three times faster, due to >> faster memory / bus, etc but 8 times faster is a bit extreme. I do notice >> that the test suite runs a lot faster on the server than it does on my >> desktop at home. I assumed that cloud servers are somewhat more powerful. I >> wonder of the Linux version is faster for some reason. >> >> On Tue, 29 Jan 2019 at 06:12, Hans L <thehans@gmail.com> wrote: >> >>> I've updated my PR with another optimization related to how strings are >>> generated for long lists, and I've now got it down to 9s for 20x20 grid of >>> springs. >>> >>> On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: >>> >>>> OK, I finished up working out the bugs and made my pull request re: >>>> tessellation: https://github.com/openscad/openscad/pull/2738 >>>> >>>> Between that and the progress bar changes ( >>>> https://github.com/openscad/openscad/pull/2735 ) I had to bump up the >>>> spring count to get some more precision from the rendering time. It's gone >>>> from 26s to 16s, for a 20x20 grid of your springs. >>>> >>>> Yeah there is probably still some performance to be gained from >>>> optimizing the cache id strings in some way, i'm not sure referencing >>>> memory addresses would be the most reliable approach, but I'll look into >>>> where its spending cycles on that front. >>>> >>>> >>>> >>>> On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: >>>> >>>>> Sort of makes sense for scalar arguments but to dump list contents of >>>>> list arguments is bonkers. Perhaps the memory address of the list, since it >>>>> is the same list used 100 times? >>>>> >>>>> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >>>>> >>>>>> The code is in: Tree::getIdString, which calls to NodeDumper class >>>>>> to dump the whole tree into a string. >>>>>> >>>>>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: >>>>>> >>>>>>> I am totally confused because in the source code it is just passed >>>>>>> as a variable that happens to be a list. Where does it get converted to >>>>>>> back a string again and parsed? Or are OpenSCAD lists just vectors of >>>>>>> strings? >>>>>>> >>>>>>> And as for re-tessellating. How long does it take to tessellate >>>>>>> something that is already mostly triangles? Should I manually tessellate >>>>>>> the end caps with a triangle fan? The other 9000+ facets are already >>>>>>> triangles. >>>>>>> >>>>>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>>>>>> wrote: >>>>>>> >>>>>>>> Ah I see. Thanks for your information. That explains a lot and it >>>>>>>> looks like >>>>>>>> values are indeed parsed from string representation as nophead had >>>>>>>> supposed. >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> -- >>>>>>>> Sent from: http://forum.openscad.org/ >>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >
HL
Hans L
Wed, Jan 30, 2019 11:26 PM
Progress!
I managed to figure out that most of the process time is spent in
msvcrt.dll!setlocale
https://imgur.com/AXNRrfd
Still don't have OpenSCAD symbols to show what part of OpenSCAD is invoking
this so much, but I found that going into OpenSCAD Preferences -> Advanced,
and disabling "Enabled user interface localization" (then restart OpenSCAD)
makes it fast again!
more packages:
waiting...
springs.
strings?
triangles.
looks like
supposed.
Progress! I managed to figure out that most of the process time is spent in msvcrt.dll!setlocale https://imgur.com/AXNRrfd Still don't have OpenSCAD symbols to show what part of OpenSCAD is invoking this so much, but I found that going into OpenSCAD Preferences -> Advanced, and disabling "Enabled user interface localization" (then restart OpenSCAD) makes it fast again! On Wed, Jan 30, 2019 at 3:00 PM Hans L <thehans@gmail.com> wrote: > OK I've had a hell of a time getting the updates to install and just given > up on using Windows on that machine for now. It would have been nice to > compare on the same hardware, but I've just decided to do some more testing > on my main windows machine that is already properly updated. > I got WPR and WPA installed, but don't have debug symbols in the circle-ci > builds so the flame graph stack listings are useless to me at the moment. > I'm not sure how to create a debug windows build yet, I'll look into that. > > I was able to test the AppImage to under windows, by more or less > following these instructions: > https://discourse.appimage.org/t/run-appimage-on-windows/177 > I used Debian linux from Microsoft Store, and also had to install a couple > more packages: > sudo apt install xcb libgtk2.0-0 libgl1-mesa-glx > > It does 100 springs in 2s and 400 in 10s, which is basically the same > results I was seeing from native linux. > > > On Tue, Jan 29, 2019 at 9:56 PM Hans L <thehans@gmail.com> wrote: > >> Hmm, it appears so. I finally dual booted into Windows 10 on my same >> computer that I tested the linux builds on. >> >> The circle-ci build gives me 18s for 100, and 73s for 400 springs, so >> pretty much the same results you are getting. >> >> I was looking into what profiling tools are available for windows, and it >> looks like Windows Performance Analyzer (WPA) would be able to do what I >> want. I particularly like viewing flame graphs; that is what I've used to >> analyze Linux performance, and those are available through WPA. >> Unfortunately I hadn't booted into windows on this machine for what looks >> like 22 months and its been running updates for the past 8 hours. It won't >> let me install WPA until I've updated to a more recent version, so I'm just >> waiting... >> >> >> On Tue, Jan 29, 2019 at 4:11 AM nop head <nop.head@gmail.com> wrote: >> >>> Great although it only went from 22 to 17 seconds for me for 100 >>> springs. 400 takes 70 seconds. I used the 64 bit MXE version here: >>> https://circleci.com/gh/openscad/openscad/1350#artifacts >>> >>> I was willing to believe you had a machine three times faster, due to >>> faster memory / bus, etc but 8 times faster is a bit extreme. I do notice >>> that the test suite runs a lot faster on the server than it does on my >>> desktop at home. I assumed that cloud servers are somewhat more powerful. I >>> wonder of the Linux version is faster for some reason. >>> >>> On Tue, 29 Jan 2019 at 06:12, Hans L <thehans@gmail.com> wrote: >>> >>>> I've updated my PR with another optimization related to how strings are >>>> generated for long lists, and I've now got it down to 9s for 20x20 grid of >>>> springs. >>>> >>>> On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: >>>> >>>>> OK, I finished up working out the bugs and made my pull request re: >>>>> tessellation: https://github.com/openscad/openscad/pull/2738 >>>>> >>>>> Between that and the progress bar changes ( >>>>> https://github.com/openscad/openscad/pull/2735 ) I had to bump up the >>>>> spring count to get some more precision from the rendering time. It's gone >>>>> from 26s to 16s, for a 20x20 grid of your springs. >>>>> >>>>> Yeah there is probably still some performance to be gained from >>>>> optimizing the cache id strings in some way, i'm not sure referencing >>>>> memory addresses would be the most reliable approach, but I'll look into >>>>> where its spending cycles on that front. >>>>> >>>>> >>>>> >>>>> On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: >>>>> >>>>>> Sort of makes sense for scalar arguments but to dump list contents of >>>>>> list arguments is bonkers. Perhaps the memory address of the list, since it >>>>>> is the same list used 100 times? >>>>>> >>>>>> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >>>>>> >>>>>>> The code is in: Tree::getIdString, which calls to NodeDumper class >>>>>>> to dump the whole tree into a string. >>>>>>> >>>>>>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> wrote: >>>>>>> >>>>>>>> I am totally confused because in the source code it is just passed >>>>>>>> as a variable that happens to be a list. Where does it get converted to >>>>>>>> back a string again and parsed? Or are OpenSCAD lists just vectors of >>>>>>>> strings? >>>>>>>> >>>>>>>> And as for re-tessellating. How long does it take to tessellate >>>>>>>> something that is already mostly triangles? Should I manually tessellate >>>>>>>> the end caps with a triangle fan? The other 9000+ facets are already >>>>>>>> triangles. >>>>>>>> >>>>>>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>>>>>>> wrote: >>>>>>>> >>>>>>>>> Ah I see. Thanks for your information. That explains a lot and it >>>>>>>>> looks like >>>>>>>>> values are indeed parsed from string representation as nophead had >>>>>>>>> supposed. >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> -- >>>>>>>>> Sent from: http://forum.openscad.org/ >>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>> >>
Thu, Jan 31, 2019 12:04 AM
Amazing. I turned that off and goes about 3 times faster, so 7 seconds
before your mod and 5 seconds after it. 18 seconds for 400
On Wed, 30 Jan 2019 at 23:28, Hans L thehans@gmail.com wrote:
Progress!
into that.
waiting...
of springs.
strings?
triangles.
looks like
had supposed.
Amazing. I turned that off and goes about 3 times faster, so 7 seconds before your mod and 5 seconds after it. 18 seconds for 400 On Wed, 30 Jan 2019 at 23:28, Hans L <thehans@gmail.com> wrote: > Progress! > > I managed to figure out that most of the process time is spent in > msvcrt.dll!setlocale > https://imgur.com/AXNRrfd > Still don't have OpenSCAD symbols to show what part of OpenSCAD is > invoking this so much, but I found that going into OpenSCAD Preferences -> > Advanced, and disabling "Enabled user interface localization" (then restart > OpenSCAD) makes it fast again! > > > On Wed, Jan 30, 2019 at 3:00 PM Hans L <thehans@gmail.com> wrote: > >> OK I've had a hell of a time getting the updates to install and just >> given up on using Windows on that machine for now. It would have been nice >> to compare on the same hardware, but I've just decided to do some more >> testing on my main windows machine that is already properly updated. >> I got WPR and WPA installed, but don't have debug symbols in the >> circle-ci builds so the flame graph stack listings are useless to me at the >> moment. I'm not sure how to create a debug windows build yet, I'll look >> into that. >> >> I was able to test the AppImage to under windows, by more or less >> following these instructions: >> https://discourse.appimage.org/t/run-appimage-on-windows/177 >> I used Debian linux from Microsoft Store, and also had to install a >> couple more packages: >> sudo apt install xcb libgtk2.0-0 libgl1-mesa-glx >> >> It does 100 springs in 2s and 400 in 10s, which is basically the same >> results I was seeing from native linux. >> >> >> On Tue, Jan 29, 2019 at 9:56 PM Hans L <thehans@gmail.com> wrote: >> >>> Hmm, it appears so. I finally dual booted into Windows 10 on my same >>> computer that I tested the linux builds on. >>> >>> The circle-ci build gives me 18s for 100, and 73s for 400 springs, so >>> pretty much the same results you are getting. >>> >>> I was looking into what profiling tools are available for windows, and >>> it looks like Windows Performance Analyzer (WPA) would be able to do what I >>> want. I particularly like viewing flame graphs; that is what I've used to >>> analyze Linux performance, and those are available through WPA. >>> Unfortunately I hadn't booted into windows on this machine for what looks >>> like 22 months and its been running updates for the past 8 hours. It won't >>> let me install WPA until I've updated to a more recent version, so I'm just >>> waiting... >>> >>> >>> On Tue, Jan 29, 2019 at 4:11 AM nop head <nop.head@gmail.com> wrote: >>> >>>> Great although it only went from 22 to 17 seconds for me for 100 >>>> springs. 400 takes 70 seconds. I used the 64 bit MXE version here: >>>> https://circleci.com/gh/openscad/openscad/1350#artifacts >>>> >>>> I was willing to believe you had a machine three times faster, due to >>>> faster memory / bus, etc but 8 times faster is a bit extreme. I do notice >>>> that the test suite runs a lot faster on the server than it does on my >>>> desktop at home. I assumed that cloud servers are somewhat more powerful. I >>>> wonder of the Linux version is faster for some reason. >>>> >>>> On Tue, 29 Jan 2019 at 06:12, Hans L <thehans@gmail.com> wrote: >>>> >>>>> I've updated my PR with another optimization related to how strings >>>>> are generated for long lists, and I've now got it down to 9s for 20x20 grid >>>>> of springs. >>>>> >>>>> On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: >>>>> >>>>>> OK, I finished up working out the bugs and made my pull request re: >>>>>> tessellation: https://github.com/openscad/openscad/pull/2738 >>>>>> >>>>>> Between that and the progress bar changes ( >>>>>> https://github.com/openscad/openscad/pull/2735 ) I had to bump up >>>>>> the spring count to get some more precision from the rendering time. It's >>>>>> gone from 26s to 16s, for a 20x20 grid of your springs. >>>>>> >>>>>> Yeah there is probably still some performance to be gained from >>>>>> optimizing the cache id strings in some way, i'm not sure referencing >>>>>> memory addresses would be the most reliable approach, but I'll look into >>>>>> where its spending cycles on that front. >>>>>> >>>>>> >>>>>> >>>>>> On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: >>>>>> >>>>>>> Sort of makes sense for scalar arguments but to dump list contents >>>>>>> of list arguments is bonkers. Perhaps the memory address of the list, since >>>>>>> it is the same list used 100 times? >>>>>>> >>>>>>> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >>>>>>> >>>>>>>> The code is in: Tree::getIdString, which calls to NodeDumper class >>>>>>>> to dump the whole tree into a string. >>>>>>>> >>>>>>>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> >>>>>>>> wrote: >>>>>>>> >>>>>>>>> I am totally confused because in the source code it is just passed >>>>>>>>> as a variable that happens to be a list. Where does it get converted to >>>>>>>>> back a string again and parsed? Or are OpenSCAD lists just vectors of >>>>>>>>> strings? >>>>>>>>> >>>>>>>>> And as for re-tessellating. How long does it take to tessellate >>>>>>>>> something that is already mostly triangles? Should I manually tessellate >>>>>>>>> the end caps with a triangle fan? The other 9000+ facets are already >>>>>>>>> triangles. >>>>>>>>> >>>>>>>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot <rudolf@digitaldocument.de> >>>>>>>>> wrote: >>>>>>>>> >>>>>>>>>> Ah I see. Thanks for your information. That explains a lot and it >>>>>>>>>> looks like >>>>>>>>>> values are indeed parsed from string representation as nophead >>>>>>>>>> had supposed. >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> >>>>>>>>>> -- >>>>>>>>>> Sent from: http://forum.openscad.org/ >>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>>>> OpenSCAD mailing list >>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>> >>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>> _______________________________________________ >>>>>>> OpenSCAD mailing list >>>>>>> Discuss@lists.openscad.org >>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>> >>>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> Discuss@lists.openscad.org >>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>> >>> _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Feb 5, 2019 12:32 AM
Now down to 2 seconds for 100 and 8 seconds for 400 with your latest double
optimisation. So altogether a 50 times speed improvement, very impressive,
thanks.
Progress!
into that.
waiting...
of springs.
passed as a variable that happens to be a list. Where does it get converted
to back a string again and parsed? Or are OpenSCAD lists just vectors of
strings?
triangles.
it looks like
had supposed.
Now down to 2 seconds for 100 and 8 seconds for 400 with your latest double optimisation. So altogether a 50 times speed improvement, very impressive, thanks. On Thu, 31 Jan 2019 at 00:04, nop head <nop.head@gmail.com> wrote: > Amazing. I turned that off and goes about 3 times faster, so 7 seconds > before your mod and 5 seconds after it. 18 seconds for 400 > > On Wed, 30 Jan 2019 at 23:28, Hans L <thehans@gmail.com> wrote: > >> Progress! >> >> I managed to figure out that most of the process time is spent in >> msvcrt.dll!setlocale >> https://imgur.com/AXNRrfd >> Still don't have OpenSCAD symbols to show what part of OpenSCAD is >> invoking this so much, but I found that going into OpenSCAD Preferences -> >> Advanced, and disabling "Enabled user interface localization" (then restart >> OpenSCAD) makes it fast again! >> >> >> On Wed, Jan 30, 2019 at 3:00 PM Hans L <thehans@gmail.com> wrote: >> >>> OK I've had a hell of a time getting the updates to install and just >>> given up on using Windows on that machine for now. It would have been nice >>> to compare on the same hardware, but I've just decided to do some more >>> testing on my main windows machine that is already properly updated. >>> I got WPR and WPA installed, but don't have debug symbols in the >>> circle-ci builds so the flame graph stack listings are useless to me at the >>> moment. I'm not sure how to create a debug windows build yet, I'll look >>> into that. >>> >>> I was able to test the AppImage to under windows, by more or less >>> following these instructions: >>> https://discourse.appimage.org/t/run-appimage-on-windows/177 >>> I used Debian linux from Microsoft Store, and also had to install a >>> couple more packages: >>> sudo apt install xcb libgtk2.0-0 libgl1-mesa-glx >>> >>> It does 100 springs in 2s and 400 in 10s, which is basically the same >>> results I was seeing from native linux. >>> >>> >>> On Tue, Jan 29, 2019 at 9:56 PM Hans L <thehans@gmail.com> wrote: >>> >>>> Hmm, it appears so. I finally dual booted into Windows 10 on my same >>>> computer that I tested the linux builds on. >>>> >>>> The circle-ci build gives me 18s for 100, and 73s for 400 springs, so >>>> pretty much the same results you are getting. >>>> >>>> I was looking into what profiling tools are available for windows, and >>>> it looks like Windows Performance Analyzer (WPA) would be able to do what I >>>> want. I particularly like viewing flame graphs; that is what I've used to >>>> analyze Linux performance, and those are available through WPA. >>>> Unfortunately I hadn't booted into windows on this machine for what looks >>>> like 22 months and its been running updates for the past 8 hours. It won't >>>> let me install WPA until I've updated to a more recent version, so I'm just >>>> waiting... >>>> >>>> >>>> On Tue, Jan 29, 2019 at 4:11 AM nop head <nop.head@gmail.com> wrote: >>>> >>>>> Great although it only went from 22 to 17 seconds for me for 100 >>>>> springs. 400 takes 70 seconds. I used the 64 bit MXE version here: >>>>> https://circleci.com/gh/openscad/openscad/1350#artifacts >>>>> >>>>> I was willing to believe you had a machine three times faster, due to >>>>> faster memory / bus, etc but 8 times faster is a bit extreme. I do notice >>>>> that the test suite runs a lot faster on the server than it does on my >>>>> desktop at home. I assumed that cloud servers are somewhat more powerful. I >>>>> wonder of the Linux version is faster for some reason. >>>>> >>>>> On Tue, 29 Jan 2019 at 06:12, Hans L <thehans@gmail.com> wrote: >>>>> >>>>>> I've updated my PR with another optimization related to how strings >>>>>> are generated for long lists, and I've now got it down to 9s for 20x20 grid >>>>>> of springs. >>>>>> >>>>>> On Mon, Jan 28, 2019 at 8:00 PM Hans L <thehans@gmail.com> wrote: >>>>>> >>>>>>> OK, I finished up working out the bugs and made my pull request re: >>>>>>> tessellation: https://github.com/openscad/openscad/pull/2738 >>>>>>> >>>>>>> Between that and the progress bar changes ( >>>>>>> https://github.com/openscad/openscad/pull/2735 ) I had to bump up >>>>>>> the spring count to get some more precision from the rendering time. It's >>>>>>> gone from 26s to 16s, for a 20x20 grid of your springs. >>>>>>> >>>>>>> Yeah there is probably still some performance to be gained from >>>>>>> optimizing the cache id strings in some way, i'm not sure referencing >>>>>>> memory addresses would be the most reliable approach, but I'll look into >>>>>>> where its spending cycles on that front. >>>>>>> >>>>>>> >>>>>>> >>>>>>> On Mon, Jan 28, 2019 at 5:44 PM nop head <nop.head@gmail.com> wrote: >>>>>>> >>>>>>>> Sort of makes sense for scalar arguments but to dump list contents >>>>>>>> of list arguments is bonkers. Perhaps the memory address of the list, since >>>>>>>> it is the same list used 100 times? >>>>>>>> >>>>>>>> On Mon, 28 Jan 2019 at 22:46, Hans L <thehans@gmail.com> wrote: >>>>>>>> >>>>>>>>> The code is in: Tree::getIdString, which calls to NodeDumper >>>>>>>>> class to dump the whole tree into a string. >>>>>>>>> >>>>>>>>> On Mon, Jan 28, 2019 at 4:21 PM nop head <nop.head@gmail.com> >>>>>>>>> wrote: >>>>>>>>> >>>>>>>>>> I am totally confused because in the source code it is just >>>>>>>>>> passed as a variable that happens to be a list. Where does it get converted >>>>>>>>>> to back a string again and parsed? Or are OpenSCAD lists just vectors of >>>>>>>>>> strings? >>>>>>>>>> >>>>>>>>>> And as for re-tessellating. How long does it take to tessellate >>>>>>>>>> something that is already mostly triangles? Should I manually tessellate >>>>>>>>>> the end caps with a triangle fan? The other 9000+ facets are already >>>>>>>>>> triangles. >>>>>>>>>> >>>>>>>>>> On Mon, 28 Jan 2019 at 21:30, Parkinbot < >>>>>>>>>> rudolf@digitaldocument.de> wrote: >>>>>>>>>> >>>>>>>>>>> Ah I see. Thanks for your information. That explains a lot and >>>>>>>>>>> it looks like >>>>>>>>>>> values are indeed parsed from string representation as nophead >>>>>>>>>>> had supposed. >>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>>> >>>>>>>>>>> -- >>>>>>>>>>> Sent from: http://forum.openscad.org/ >>>>>>>>>>> >>>>>>>>>>> _______________________________________________ >>>>>>>>>>> OpenSCAD mailing list >>>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>>> >>>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>>> >>>>>>>>>> _______________________________________________ >>>>>>>>>> OpenSCAD mailing list >>>>>>>>>> Discuss@lists.openscad.org >>>>>>>>>> >>>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>>> >>>>>>>>> _______________________________________________ >>>>>>>>> OpenSCAD mailing list >>>>>>>>> Discuss@lists.openscad.org >>>>>>>>> >>>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>>> >>>>>>>> _______________________________________________ >>>>>>>> OpenSCAD mailing list >>>>>>>> Discuss@lists.openscad.org >>>>>>>> >>>>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>>>> >>>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> Discuss@lists.openscad.org >>>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> Discuss@lists.openscad.org >>>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >>>>> >>>> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >
