BS
Ben Suter
Wed, Jun 1, 2016 11:30 AM
Is it possible to save an STL file without going through the full render step?
It frustrates me that I can see the surface model using "preview",
but apparently can not simply save this as an STL file?
Background: I am using OpenSCAD to generate surface models of neurons,
because the ability to programmatically define 3D surfaces from a set
of tapered cylinders closely matches the way in which neuronal
geometry is represented when derived from experimental measurements.
My goal is to make an STL file that I can use for 3D printing - I
don't care about lighting, viewpoints, textures, colors. Just the pure
surface model.
Currently the render takes 2.5 hours per neuron, severely limiting my
ability to process many neurons and making me doubt whether it's
feasible for me to assemble a single scene with ~50 neurons (as I had
hoped).
In any case, I'm very happy to have found OpenSCAD and have to say
it's been a great pleasure using it in my processing pipeline. Thank
you, and please keep up the great work!
PS: Currently my scene consists of a few thousand individual cylinders
and spheres, each with its own translation and rotation relative to
the origin. However, each of these segments naturally falls into a
geometrical hierarchy - so alternatively I could represent the scene
as a hierarchy of rotations and translations of each child segment
relative to its parent. Is there reason to believe that the
hierarchical representation (with few root nodes) would render faster?
PPS: Here's the console output after my latest render - note this is
on a 16-core Xeon / Windows 7 64-bit / 72 GB RAM / SSD / GTX 970
machine. Are there any OpenSCAD settings I should modify to make
better use of these resources?
Geometries in cache: 6514
Geometry cache size in bytes: 60051248
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Total rendering time: 2 hours, 19 minutes, 58 seconds
Simple: yes
Vertices: 490328
Halfedges: 1703918
Edges: 851959
Halffacets: 730078
Facets: 365039
Volumes: 3
Rendering finished.
It frustrates me that I can *see* the surface model using "preview",
surface model.
hoped).
Simple: yes
Vertices: 490328
Halfedges: 1703918
Edges: 851959
Halffacets: 730078
Facets: 365039
Volumes: 3
Rendering finished.
Wed, Jun 1, 2016 11:36 AM
No you can only save an image from the preview. The geometry hasn't been
calculated at the point, just a picture of it using graphic rendering
tricks.
step?
surface model.
hoped).
Simple: yes
Vertices: 490328
Halfedges: 1703918
Edges: 851959
Halffacets: 730078
Facets: 365039
Volumes: 3
Rendering finished.
tricks.
> step?
> surface model.
> hoped).
> Top level object is a 3D object:
> Simple: yes
> Vertices: 490328
> Halfedges: 1703918
> Edges: 851959
> Halffacets: 730078
> Facets: 365039
> Volumes: 3
> Rendering finished.
Rob Ward
Wed, Jun 1, 2016 12:29 PM
I like the idea of modeling cellular activity or constructions. OpenSCAD
lends itself really well to visualizing these things, but
computationally we are still limited compared to the biological
capacity. I think a previous thread discussing narrowing bifurcating
cylinders with smooth transitions, similar to what we could expect going
from arteries to capillaries and back to veins, was running into a
similar exponential growth in the computational challenge. It reminded
me though that as every cell reproduces, it essentially spawns another
two computational units in the nucleus of those new cells (The answer to
the N squared problem?). The programs in the DNA are applying their
rules in the new environment for each new cell. I can't see us
surpassing this system too quickly with our silicon models, but I admire
the efforts of people such as Ben who are investigating these areas.
Rob
surface model.
hoped).
Simple: yes
Vertices: 490328
Halfedges: 1703918
Edges: 851959
Halffacets: 730078
Facets: 365039
Volumes: 3
Rendering finished.
Rob
> surface model.
> hoped).
> Simple: yes
> Vertices: 490328
> Halfedges: 1703918
> Edges: 851959
> Halffacets: 730078
> Facets: 365039
> Volumes: 3
> Rendering finished.
B
bsuter
Wed, Jun 1, 2016 1:27 PM
Thank you both for your feedback and input!
tricks.
Aha, so the GPU did all the hard work of tessellating, etc. but we can't
"recapture" that? Interesting how fast the GPU preview works (< 1 sec)
compared to how long the render takes (2.3 hours).
Three questions:
Are there any other tools like OpenSCAD that I could try, that also allow
declarative description of 3D surfaces using cylinder and sphere primitives
together with geometric transformations? Maybe tools that use the GPU or
multiple cores for the "render" step?
I'd very much appreciate any tips or suggestions for alternatives: I
don't need lighting, color, textures or such, I just want to describe the
geometry using tapered cylinders and spheres, and then have the software
convert this to a surface model (e.g. tessellate) suitable for 3D printing
(e.g. STL, OBJ, VRML).
Sticking with OpenSCAD, is it better to have a "flat" or "hierarchical"
scene graph?
> tricks.
Three questions:
1. Are there any other tools like OpenSCAD that I could try, that also allow
2. I'd very much appreciate any tips or suggestions for alternatives: I
3. Sticking with OpenSCAD, is it better to have a "flat" or "hierarchical"
scene graph?
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17506.html
BS
Ben Suter
Wed, Jun 1, 2016 1:30 PM
<quote author="nophead">
tricks.
</quote>
can't "recapture" that? Interesting how fast the GPU preview works (<
1 sec) compared to how long the render takes (2.3 hours).
Four questions:
allow declarative description of 3D surfaces using cylinder and sphere
primitives together with geometric transformations? Maybe tools that
use the GPU or multiple cores for the "render" step?
I don't need lighting, color, textures or such, I just want to
describe the geometry using tapered cylinders and spheres, and then
have the software convert this to a surface model (e.g. tessellate)
suitable for 3D printing (e.g. STL, OBJ, VRML).
"hierarchical" scene graph?
<quote author="bsuter">
</quote>
- I subscribed to this email list, but am not getting replies to this
thread in my inbox. On the web interface (Nabble) I can see replies,
but when I post a reply there myself, I get a message indicating that
my reply "was not yet accepted to the mailing list". Any advice on how
to improve this?
surface model.
hoped).
Simple: yes
Vertices: 490328
Halfedges: 1703918
Edges: 851959
Halffacets: 730078
Facets: 365039
Volumes: 3
Rendering finished.
tricks.
</quote>
Four questions:
</quote>
4. I subscribed to this email list, but am not getting replies to this
to improve this?
> surface model.
> hoped).
> Simple: yes
> Vertices: 490328
> Halfedges: 1703918
> Edges: 851959
> Halffacets: 730078
> Facets: 365039
> Volumes: 3
> Rendering finished.
Wed, Jun 1, 2016 2:04 PM
I am seeing all your messages twice on the mailing list so they are getting
there. When you post on the forum it always says it has not been accepted
to start with.
The preview works by rendering the primitive objects into the Z buffer and
using that to work out which bits are visible. For example when you union
two objects it just draws them both separately. It never actually works out
a 3D representation of the union, just a 2D picture of what it looks like
from one angle.
When you do F6 CGAL is used to calculate the 3D solids very accurately and
is very slow because it uses rational numbers instead of floating point.
Others maybe able to suggest faster alternatives. It is fast enough for the
designs I do so I haven't looked elsewhere.
tricks.
</quote>
Four questions:
</quote>
to improve this?
surface model.
hoped).
Simple: yes
Vertices: 490328
Halfedges: 1703918
Edges: 851959
Halffacets: 730078
Facets: 365039
Volumes: 3
Rendering finished.
to start with.
from one angle.
> tricks.
> </quote>
> Four questions:
> </quote>
> to improve this?
> step?
> > surface model.
> > hoped).
> > Simple: yes
> > Vertices: 490328
> > Halfedges: 1703918
> > Edges: 851959
> > Halffacets: 730078
> > Facets: 365039
> > Volumes: 3
> > Rendering finished.
Wed, Jun 1, 2016 5:22 PM
Can you share some image that shows your model in detail?
In OpenSCAD there are fast and slow alternatives to produce a design. If you
stack too many primitives on top of each other, use boolean operations over
too much detail (number of vertices) or special high-level operators like
minkowski() and hull(), rendering gets slow. And it gets even slower, when
you try to clone complex shapes into more complex structures like grids.
There are also ways to create complex shapes by doing most of triagulation
work on your own. So it depends much on the programming approach you use and
of course on the complexity of the design itself.
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17510.html
CA
Wed, Jun 1, 2016 7:16 PM
On 01. juni 2016 15:30, Ben Suter wrote:
- Are there any other tools like OpenSCAD that I could try, that also
You could try http://arnholm.org/angelscript-csg-ide/
Be warned that the current public version relies on OpenSCAD to do the
booleans, so you don't gain anything in speed that way.
I do have an unreleased test version that does not use OpenSCAD for
booleans and that is much faster. But it isn't released at this time.
B
bsuter
Thu, Jun 2, 2016 10:15 AM
you stack too many primitives on top of each other, use boolean operations
over too much detail (number of vertices) or special high-level operators
like minkowski() and hull(), rendering gets slow. And it gets even slower,
when you try to clone complex shapes into more complex structures like
grids.
My model currently consists of a single sphere at the origin, and then about
1600 instances of a (tapered) cylinder with a sphere at the end (I add these
spheres where two non-parallel cylinders come together, to "fill out" the
join between them). I naively implemented each of these cylinder-sphere
pairs like this:
translate([-2.918, -7.452, 0.698])
rotate(93.4419, [0.800474,-0.596353,0])
cylinder($fn=20, 0.499704, 0.8, 0.5);
translate([-3.216, -7.852, 0.668])
sphere($fn=20, 0.5);
So the above 5 lines repeat roughly 1600 times, of course with different
values. The $fn values I chose basically to balance speed and beauty ...
As you can see in the image, this model is a naturally branched structure -
so for many of these cylinder-sphere segments, their translation and
rotation could naturally be defined as relative to their parent segment,
rather than using a flat structure with each segment oriented relative to
the origin (as I do now). Would you expect one of these approaches to be
faster?
and of course on the complexity of the design itself.
Interesting. Could you point me to some more info on the pre-triangulated
approach? I think I can maybe use Matlab (where I am analyzing the geometry
and generating the .scad now) to generate tessellated coordinates for each
cylinder, or at least the vertices.
Thank you very much!
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17523.html
Sure, I'm attaching a view here.
<http://forum.openscad.org/file/n17523/CA3pyr-Amaral-c11571.png>
> grids.
pairs like this:
faster?
Thu, Jun 2, 2016 11:24 AM
How lovely! Nice to see, what people do with OpenSCAD.
A similar problem, doing a union() of a large number of cylinder and sphere
primitives is currently discussed here.
http://www.thingiverse.com/groups/openscad/topic:6515#comment-900694
CGAL rendering is not very efficient when (very) large numbers of shapes
come into play.
I've implemented some Matlab class to generically describe arteries with an
interpolation scheme. The output is a winding 'wire' in 3D with free radius
a each point in STL-format. In lack of an own union or furcation operator
capable to do the intersection triangulation we currently use OpenSCAD and
Blender to compose porperly placed wires into tree structures which we again
cut into puzzle pieces for 3D print.
You might be interested for inspiration or even build on at least part of
the code (in a non-commercial way), e.g. to implement this 'little' details
on your own. Send me a PM to get in further touch.
I imagine some tree class, allowing for a (recursive) generic description of
path points with radii that can render its objects to STL. In your case, I
guess, you will add a net class to connect those tree objects formally into
a network to do functional simulation.
OpenSCAD or any other CAD-Programm could be used to provide the final
union() operation connecting some number of precompiled trees (neurons) into
a printable unit. I wouldn't advise to do the programming natively in
OpenSCAD.
Rudolf
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17524.html
come into play.
OpenSCAD.
Rudolf
