Dear Rudolf, thank you for this info - it may take me some time to
fully understand, I'll try.
A similar problem, doing a union() of a large number of cylinder and sphere
primitives is currently discussed here.
http://www.thingiverse.com/groups/openscad/topic:6515#comment-900694
CGAL rendering is not very efficient when (very) large numbers of shapes
come into play.
In that post you wrote "A single sweep() along a smoothed trajectory
will be faster than a union of cylinders and spheres describing the
same". Could you please explain further what you mean, in OpenSCAD
terms, by "single sweep() along a smoothed trajectory"? This sounds
useful. Certainly each of my branches can be modeled as a sequence of
nodes, where each node has an associated radius. Is there a way to
represent this directly in OpenSCAD? I.e. to specify a trajectory in
3D, and then extrude (ideally a circular cross-section, but a polygon
would work too) along this trajectory, with the extrusion radius
defined at each node?
Essentially this is what I tried to mimic using cylinder primitives
(and spheres at the nodes, to fill in the gaps between cylinder ends).
I've implemented some Matlab class to generically describe arteries with an
interpolation scheme. The output is a winding 'wire' in 3D with free radius
a each point in STL-format.
This part I seem to understand. Arteries are quite similar, in the
present context, to dendritic arbors - tapered cylinders with branch
points. Ultimately all I want is STL. In my own Matlab code I am able
to generate a reasonable 3D figure (by using the cylinder() function
and, after some manipulations, passing the results to the surf()
function). I've toyed with the idea of instead taking the cylinder()
output (basically the vertices at the bottom and top edge of the
cylinder) and using these to generate a tessellated surface in STL
syntax. As long as I use a fixed # of vertices for all cylinders,
connecting the top of one to the base of the next via triangles should
be quite doable.
In lack of an own union or furcation operator
capable to do the intersection triangulation we currently use OpenSCAD and
Blender to compose porperly placed wires into tree structures which we again
cut into puzzle pieces for 3D print.
This part I don't understand ;(
You might be interested for inspiration or even build on at least part of
the code (in a non-commercial way), e.g. to implement this 'little' details
on your own. Send me a PM to get in further touch.
Thank you!
I imagine some tree class, allowing for a (recursive) generic description of
path points with radii that can render its objects to STL. In your case, I
guess, you will add a net class to connect those tree objects formally into
a network to do functional simulation.
Such a class would be quite useful - seemingly to a variety of problem domains.
For functional simulations, the format we already use is quite
suitable (it's called SWC; a list of tuples, each tuple has <ID, type,
x, y, z, r, parent>) and widely used (see neuromorpho database if
curious).
My main goal is (a) virtual reality visualization of many neurons
together, and (b) 3D printing of individual neurons. For the latter,
there's a nice paper, but the code there is implemented within a
simulation environment (NEURON) and does not fit well with my current
pipeline.
McDougal, R. A. and G. M. Shepherd (2015). 3D-printer visualization of
neuron models. Frontiers in neuroinformatics 9.
OpenSCAD or any other CAD-Programm could be used to provide the final
union() operation connecting some number of precompiled trees (neurons) into
a printable unit. I wouldn't advise to do the programming natively in
OpenSCAD.
Rudolf
below:
http://forum.openscad.org/STL-without-render-tp17503p17524.html
To unsubscribe from STL without render?, click here.
NAML
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17526.html
This code is a good starting point and show case:
http://www.thingiverse.com/thing:547620/#files
to get an idea, how sweeps behave. The (implicit) union() is needed for
marriage of different sweep trajectories.
There is no language support for general extrusion along trajectories, and
there is no data structure support (or let's say only weak array support)
for things like trees and so on. But there are libraries like sweep() and
skin() going into this direction. Also see here:
http://www.thingiverse.com/thing:900137
an
radius
at each point in STL-format.
this is an example of the outcome:
http://forum.openscad.org/Non-Linear-Transformations-tp14539p14597.html
The class simply does some nspline calculation over a sequence of 4D vectors
(x, y, z, r) describing a skeleton line. Most of the code is for handling
STL-triangulation and output.
and
again
STL triagulation is easy and fast if you don't have to check for
self-intersection (SI). I.e. if the code can assume, no SI will happen, it
can skip all tests and calculations that would be needed to treat SI and
just knit some generic triangulation pattern in a straight forward manner.
Its helps to think about physical knitting to understand what is going on.
For the puzzle part: It might be interesting to print a structure in pieces,
e.g. to compose a construction kit or similar (which can also be used for
moulding). In your case, it might be advantegous to print the neurons and
the dendrits as destinct pieces and design a connector for piecing parts
together as puzzle.
A union of any non-SI shapes might be SI - and will be SI at defined
locations in the case of furcations and trees. So, if SI is only happening
at furcation points, the intersection can be calculated somehow in a fast
manner, to get a proper triangulation. Have a look, how the union of two
cylinders is mapped into STL (to get a first impression, you can use F10 and
Ctrl+1 which only partly triangulates).
This is the principle. OpenSCAD has this operator in form of union(). So,
one way is to import a bunch of branches (STLs) already correctly placed und
let OpenSCAD do the work dirty work in a general way.
In fact at CSG-level (F5) this is done only virtually by the graphics card.
And when it comes to STL output (F6) CGAL is used, which takes its time.
Knowing that all your branches will not SI, except at furcation points, you
can write your own specialized (and thus fast) union() that remeshes just
the furcation intersection part of the branches.
It depends on how often this is repeated. If you model just some two or
three examples, long CGAL rendering times for that what you have, might be
tolerable, as recoding consumes much more time.
For virtual visualization you might want to put in more effort. OpenSCAD has
some nice animation support on the CSG-level. Trygon used it to do some
amazing things.
http://forum.openscad.org/Product-Video-produced-with-OpenSCAD-td15783.html.
Much more of course is offered by Blender.
Rudolf
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17530.html
Simply replacing the unions with a cylinder by a hull of two spheres will
probably give a decent improvement in speed. Unioning a sphere with a
cylinder can be very slow.
an
radius
vectors
and
again
pieces,
together as puzzle.
and
und
has
amazing things.
Rudolf
Aha, I think I see what you mean:
What I'm doing now: cylinder from point A to point B, a sphere at
point B, another cylinder from point B to point C
What you suggest: spheres at points A, B and C; plus hull() of each
pair of spheres? But would I need to duplicate the sphere at point B,
since it's part of two hulls?
Did I understand that correctly? I'll try this.
I found another thread that discusses something similar. Interestingly
it starts with someone doing a hull() of two spheres, and hoping for a
faster solution.
http://forum.openscad.org/Rods-between-3D-points-td13104.html
In my case, I am able to generate the points framing a circle at each
end of the intended segment, call this pts_base and pts_top. So it
sounds like I could try:
pts = concat(pts_base, pts_top);
faces = faces(shape="rod", nside= len(pts_base), nseg=1);
polyhedron(points=pts, faces=faces("rod", nside=12));
However, this still needs some way to "fill the joint" at the
intersection of two such rods, and from what I've been reading in this
thread, it sounds like maybe it's precisely this problem (which I
"solved" by inserting a sphere at each joint) that is computationally
expensive?
On Thu, Jun 2, 2016 at 6:36 PM, nophead [via OpenSCAD]
with
an
radius
vectors
and
again
pieces,
together as puzzle.
and
und
card.
you
has
amazing things.
Rudolf
[hidden email]
[hidden email]
below:
http://forum.openscad.org/STL-without-render-tp17503p17531.html
NAML
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17532.html
Yes but duplicating a sphere takes no time at all because it is cached.
Hull is faster than union in later versions of OpenScad but you still need
to union the results so it won't be very fast but perhaps twice the current
speed at a guess.
faster solution.
expensive?
Unioning things that have lots of vertices is very expensive. Generating
polyhedra from points is very fast but you have to be able to fully
describe the shape mathematically. That is not easy where there is a
branch, so best case I think you will need a union per branch or a very
clever recursive function that makes one big polyhedron.
<[hidden email] http:///user/SendEmail.jtp?type=node&node=17532&i=0>
will
and
support)
and
with
an
radius
vectors
handling
OpenSCAD
and
we
again
it
and
manner.
on.
pieces,
for
and
parts
together as puzzle.
happening
fast
two
F10
and
So,
placed
und
card.
time.
you
just
be
OpenSCAD
has
amazing things.
Rudolf
[hidden email]
[hidden email]
below:
NAML
View this message in context: Re: STL without render?
at Nabble.com.
As pointed out above. Nophead's solution of "hull between spheres at junction
points" is the least effort for speedup. You can set the sphere resolution
low ($fn) for faster preview.
The route best suited to your specific problem is extruding a cross sectiin
along a 'wire' for which there is code linked above. You' d make many
'wires' and then skin them, finally union these together if you needed a
single solid object.
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17535.html
junction points" is the least effort for speedup. You can set the sphere
resolution low ($fn) for faster preview.
Thank you - preview is instantaneous (sub-second) for my current
solution (cylinders and spheres), but render takes 2.5 hours per
neuron (and I have many neurons to render). I will try the "hull
between spheres at junction points" and report back.
What I don't yet understand about this solution is how the "joint" or
"junctions" are handled: does the extrusion "turn the bend", so to
speak, or does this solution still require additional spheres (or ?)
at the points where the wire changes direction?
Many thanks!
below:
NAML
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17537.html
the problem is that a general union() will check each edge against each edge
of each other shape. This is a quadratic problem, if no optimization or
short cut scheme is employed. Double number of edges (shapes) four times
longer execution.
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17539.html
I did some very basic speed tests and even so the results were very
surprising.
A sphere with 250000 facets ($fn=500) takes virtually no time to render
(less than 1sec). But if you render the union of a few disjoint spheres the
time grows very fast:
total # total total #
facets time of spheres ($fn=20)
362 0s 1
3100 31s 10
31000 550s 100
The union of 10 coincident spheres (r=10, $fn=20) spent 800s!, that is much
more than 10 similar disjoint spheres.
What was a lot surprising for me was the time only one refined cylinder
spent to render.
# facets time
50000 7s
100000 29s
200000 129s
250000 212s
To confirm that using polyhedron is faster, I wrote the following code that
is able to generate a set (union) of disjoint "spheres" using only one call
of polyhedron:
n = 20; // $fn
m = n/2;
N = 2000; // number of spheres
radius = 10;
unitary_circle = [ for(i=[0:n]) [ cos(360i/n), sin(360i/n), 0 ] ];
// sphere
sphere_vertices = radius*[ for( j=[-m/2:m/2], p=unitary_circle )
cos(180j/m) * p + [0, 0, sin(180j/m)] ];
nvert = len(sphere_vertices);
// triangulated faces of the sphere
faces = concat(
[ for(i=[0:n-1])
[ 0, n+i+1, n+i+2 ] ] ,
[ for(j=[1:m-1], i=[0:n-1])
[ (n+1)j+i+1, (n+1)j+i, (n+1)(j+1)+i ] ] ,
[ (n+1)j+i+1, (n+1)(j+1)+i, (n+1)(j+1)+i+1 ] ] ,
[ for(i=[0:n-1])
[ (n+1)(m-1)+i, (n+1)(m+1)-1, (n+1)*(m-1)+i+1] ] ) ;
// vertices of the union of N spheres
unispheres = [ for(k=[1:N], p=sphere_vertices) p+[25*k,0,0] ];
// facets of the union of N spheres
unifaces = [ for(k=[1:N], f=faces) [for(i=f) i+nvert*(k-1) ] ];
polyhedron( points = unispheres, faces = unifaces);
sphere(10); // a regular sphere
As expected, the set of spheres generated by this code renders a lot faster
than the regular union of OpenSCAD spheres. And the time seems to grow
linearly:
timing of a set of sphere in one polyhedron
# facets time # spheres
40000 2s 100
400000 22s 1000
A neuron with just 1600 disjoint $fn=20 spheres will require a lot of time
to render. I don't believe that doing hulls between spheres and the
cylinders would result in a significant gain because those parts need to be
unioned and that is the bottleneck. To get a significant reduction in the
render time you will need to code the generation of vertices and facets to
be sent to polyhedron as the code above do. Doing that for a whole neuron is
a huge task.
The lesson here is: to do CSG operations with B-rep (the internal
representation CGAL uses) works only for small number of primitives. To deal
with a great number of primitives OpenSCAD needs to look for alternative
internal representations.
View this message in context: http://forum.openscad.org/STL-without-render-tp17503p17543.html
To deal with a great number of primitives OpenSCAD needs to look
for alternative internal representations.
Yes, this is all pretty much known, and the discussion about
alternatives is also not new. The Problem is that there's no
real alternative in sight.
The page collecting some info is:
https://github.com/openscad/openscad/wiki/Project%3A-Survey-of-CSG-algorithms
