John David
Sun, Mar 10, 2024 9:57 AM
I am working on rewriting/generalizing a little project which builds French
cleat toolholders, and have a number of questions. I have a couple of
variants of this using simple cubes, triangles, cylinders, but I am trying
to understand more advanced features of OpenSCAD.
For people that care about such things, French cleats normally come with a
45 or 30-degree angle, but can be set to any desired angle. The choice of
materials are often 3/4" plywood, 3/4" lumber (ie 1x*), 1/4" plywood...
Since the angle, thickness, width can all be defined up front, I would like
to set up some reasonable defaults, but allow the user to override them.
Q1: is there are way to access a nested (sub)module from outside its parent
scope?
I was hoping I could find a way to do something like:
module French_Cleat() {
module
define_solid_params(thickness=0.75,width=5.5/2,angle=45.0,chamfer=0.0625,saw_kerf=0.125,laseer_kerf=0.06)
{fc_angle=angle; ...}
function cleat_profile () =....; // uses fc_angle
and then be able to call it:
French_Cleat.define_solid_params(angle=30);
cp = French_Cleat.cleat_profile();
That did not work at all...
Q2: it looks like functions are compiled when I include/use a file, and not
when used. Is there a way around this.
Using the above code, I called:
cp30 = cleat_profile();
and OpenSCAD returned a profile which used the default 45, and not the
overwritten angle=30, because it appears that any global variables are set
at compile time. Is there a way to work around that?
Sorry for the very basic questions, but I am still learning the syntax and
semantics.
EBo --
scope?
module
semantics.
EBo --
Sun, Mar 10, 2024 12:00 PM
Others may have better answers, but I would have define_solid_params()
set global variables like sp_thickness, sp_width, etc.
French cleat toolholders, and have a number of questions. I have a
couple of variants of this using simple cubes, triangles, cylinders,
but I am trying to understand more advanced features of OpenSCAD.
with a 45 or 30-degree angle, but can be set to any desired angle.
The choice of materials are often 3/4" plywood, 3/4" lumber (ie 1x*),
1/4" plywood... Since the angle, thickness, width can all be defined
up front, I would like to set up some reasonable defaults, but allow
parent scope?
module
and not when used. Is there a way around this.
set at compile time. Is there a way to work around that?
and semantics.
EBo --
> parent scope?
> module
> and semantics.
> EBo --
Sun, Mar 10, 2024 12:49 PM
parent scope?
module
the overwritten angle=30, because it appears that any global
variables are set at compile time. Is there a way to work around that?
syntax and semantics.
EBo --
Yes. Put the user adjustable variables at the front, comment them for
use with the customizer
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Customizer
> Jon
>> parent scope?
>> module
>> EBo --
Sun, Mar 10, 2024 1:04 PM
I don't think he wants to use the customizer for these variable, since
they are all inter-related using the formulas in define_solid_params().
define_solid_params() set global variables like sp_thickness,
sp_width, etc.
1x*), 1/4" plywood... Since the angle, thickness, width can all be
defined up front, I would like to set up some reasonable defaults,
parent scope?
module
EBo --
>> sp_width, etc.
>> Jon
>>> parent scope?
>>> module
>>> EBo --
Sun, Mar 10, 2024 1:25 PM
Maybe. I was thinking more of ease of use for the end user - select
thickness, width, angle, chamfer kerf, etc. You'd already pointed out to
use global variables, since the more 'traditional linear program
structure?' is not how Openscad works.
sp_width, etc.
builds French cleat toolholders, and have a number of questions. I
have a couple of variants of this using simple cubes, triangles,
cylinders, but I am trying to understand more advanced features of
OpenSCAD.
its parent scope?
module
that?
EBo --
> Jon
>>> sp_width, etc.
>>> Jon
>>>> OpenSCAD.
>>>> its parent scope?
>>>> module
>>>> that?
>>>> EBo --
Sun, Mar 10, 2024 4:08 PM
parent scope?
No. OpenSCAD modules are black holes. No information comes out of them.
Also, OpenSCAD variables ... don't vary. Once set, they cannot be
changed. (You can create a new instance of a variable in a block, but
that's a new variable and the outer one is unchanged.)
module
Nope. Can't do anything like that, because there is absolutely no way
for a module to set a global variable.
No. (Though given the scoping rules, it doesn't matter when the file is
"compiled", or that it's compiled at all.)
Advice:
For a simple model where the user wants to set values, put the values
together at the top of the file, so that the user can set them using the
Customizer. See
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Customizer for
information on how to add comments to control the labels and other user
interface aspects.
For a subassembly where a program is going to set the values and control
them, the usual strategy is to have your subassembly's module take
parameters, and have the parameters have defaults.
Combining those two concepts:
cube1_size = 10;
cube2_size = 15;
ratio = 2;
twoCubes();
translate([30,0,0]) twoCubes(cube1_size, cube2_size);
translate([60,0,0]) twoCubes(cube1_size * ratio, cube2_size * ratio);
module twoCubes(c1=5, c2=7) {
cube(c1, center=true);
cube(c2);
Note that the file has default values (that the user can change with the
customizer) that control the middle pair of cubes, and the module has
its own defaults that control the first pair.
The usual variable scoping is lexical: you can look at the layout of
the program to see what variables are visible at any given point. Just
walk up the enclosing blocks until you get to the first variable with
that name.
You can use $ variables to pass information into modules or
functions. They are still immutable, but are dynamically scoped. They
are passed down through calls, no matter how the program is laid out.
Walk up the call stack until you find the first variable with that name.
$ variables don't lend themselves to module-level defaults, though you
can do it using is_undef().
You can write a variation on the example above as:
$cube1_size = 10;
$cube2_size = 15;
twoCubes();
translate([30,0,0]) {
$cube1_size = 20;
$cube2_size = 30;
twoCubes();
module twoCubes() {
cube($cube1_size, center=true);
cube($cube2_size);
... but mostly I wouldn't recommend it.
Related notes:
* In any given block, all assignments are processed before all
module invocations. Don't expect to be able to call a module,
then set a $ variable, then call it again. Both calls will get
the value from the assignment.
* With respect to the model, it almost doesn't matter what order
modules get called in. (Exceptions: echo(), rands(), and some
cases involving transparency and coloring that are probably best
viewed as weaknesses in the previewer.)
* The customizer will suck up all constant assignments, until it
hits the first module definition. If you want to have a global
variable that the user *shouldn't* customize, put in a dummy
"module stop();" after the customizable variables.
> parent scope?
> module
Advice:
For a simple model where the *user* wants to set values, put the values
Customizer. See
interface aspects.
cube1_size = 10;
cube2_size = 15;
ratio = 2;
twoCubes();
cube(c2);
that name.
You *can* use $ variables to pass information into modules or
$cube1_size = 10;
$cube2_size = 15;
twoCubes();
$cube1_size = 20;
$cube2_size = 30;
twoCubes();
module twoCubes() {
cube($cube2_size);
Related notes:
John David
Mon, Mar 11, 2024 1:00 AM
OK. It is starting to take shape. What I did was to build a named
parameter list that looks like:
[["cleat","type",type],
["cleat","thickness",thickness],
["cleat","width",width],
["cleat","chamfer",chamfer],
["cleat","kerf",kerf],
["cleat","angle",angle],
["cleat","profile",_fc_cleat_profile
(width,thickness,chamfer,angle,kerf)]];
and then pass these parameters through to other functions. This is only a
small example, but is starting to feel about right:
include <BOSL2/trigonometry.scad>
function
French_Cleat_params(type="solid",thickness=0.75,width=5.5/2,chamfer=0.125,kerf=0.125,angle=45.0)
function _fc_cleat_profile
(cleat_width,cleat_thickness,cleat_chamfer,cleat_angle,kerf) =
let(
c = cleat_thickness,
b = adj_ang_to_hyp(c,cleat_angle),
a = adj_ang_to_opp(c,cleat_angle),
a2 = adj_ang_to_opp(c-cleat_chamfer,cleat_angle),
c2 = c-cleat_chamfer
) [[0.0,0.0], [-c,0.0], [-c,a2],[-c2,a2]]; // FIXME: adjust for kerfs
function fc_param(params,catigory,var) =
let(
cat =
search(catigory,params,num_returns_per_match=0,index_col_num=0),
vals = [for(i=cat) for(j=i) params[j]],
scat = search(var,vals,num_returns_per_match=1,index_col_num=1),
val = [for(z=scat) for(k=z) vals[k]],
itm = val[0][2],
echo(".....",itm)
) itm;
// generate a set of parameters for the French Cleats (with user modified
angle).
cp = French_Cleat_params(angle=30);
// grab the French Cleat Parameters (as modified by user), and display
pc = fc_param(cp,"cleat","profile");
echo(" pc = ",pc);
color("yellow") linear_extrude(.25) polygon(pc);
I will clean this up as I start using it, but I think I am starting to
figure out OpenSCAD's syntax and semantics - the variables being static
after defined threw me for a loop).
I am confused about the warnings that are being generated by the search.
Anyone have suggestions on how to fix those?
EBo --
On Sun, Mar 10, 2024 at 12:08 PM Jordan Brown openscad@jordan.maileater.net
parent scope?
module
Nope. Can't do anything like that, because there is absolutely no way for
Advice:
Customizer. See
interface aspects.
cube1_size = 10;
cube2_size = 15;
ratio = 2;
twoCubes();
cube(c2);
customizer) that control the middle pair of cubes, and the module has its
The usual variable scoping is lexical: you can look at the layout of the
program to see what variables are visible at any given point. Just walk up
the enclosing blocks until you get to the first variable with that name.
You can use $ variables to pass information into modules or functions.
They are still immutable, but are dynamically scoped. They are passed down
through calls, no matter how the program is laid out. Walk up the call
$ variables don't lend themselves to module-level defaults, though you can
$cube1_size = 10;
$cube2_size = 15;
twoCubes();
$cube1_size = 20;
$cube2_size = 30;
twoCubes();
module twoCubes() {
cube($cube2_size);
Related notes:
- In any given block, all assignments are processed before all module
invocations. Don't expect to be able to call a module, then set a $
variable, then call it again. Both calls will get the value from the
assignment.
- With respect to the model, it almost doesn't matter what order
modules get called in. (Exceptions: echo(), rands(), and some cases
involving transparency and coloring that are probably best viewed as
- The customizer will suck up all constant assignments, until it hits
the first module definition. If you want to have a global variable that
the user *shouldn't* customize, put in a dummy "module stop();" after the
function
let(
let(
cat =
itm = val[0][2],
echo(".....",itm)
) itm;
angle).
echo(" pc = ",pc);
EBo --
On Sun, Mar 10, 2024 at 12:08 PM Jordan Brown <openscad@jordan.maileater.net>
> parent scope?
> module
> Advice:
> Customizer. See
> interface aspects.
> cube1_size = 10;
> cube2_size = 15;
> ratio = 2;
> twoCubes();
> cube(c2);
> You *can* use $ variables to pass information into modules or functions.
> $cube1_size = 10;
> $cube2_size = 15;
> twoCubes();
> $cube1_size = 20;
> $cube2_size = 30;
> twoCubes();
> module twoCubes() {
> cube($cube2_size);
> Related notes:
> assignment.
John David
Mon, Mar 11, 2024 1:45 AM
also with regards to manipulating named parameters, I remember reading
about something similar another project was using. Is there a pre-built
library for this functionality? I might have not found it yet, and should
scrap my use that instead.
EBo --
function
let(
let(
cat =
itm = val[0][2],
echo(".....",itm)
) itm;
angle).
echo(" pc = ",pc);
EBo --
parent scope?
module
Advice:
Customizer. See
interface aspects.
cube1_size = 10;
cube2_size = 15;
ratio = 2;
twoCubes();
cube(c2);
$cube1_size = 10;
$cube2_size = 15;
twoCubes();
$cube1_size = 20;
$cube2_size = 30;
twoCubes();
module twoCubes() {
cube($cube2_size);
Related notes:
assignment.
EBo --
> include <BOSL2/std.scad>
> function
> let(
> let(
> cat =
> itm = val[0][2],
> echo(".....",itm)
> ) itm;
> angle).
> echo(" pc = ",pc);
> EBo --
>> parent scope?
>> module
>> Advice:
>> Customizer. See
>> interface aspects.
>> cube1_size = 10;
>> cube2_size = 15;
>> ratio = 2;
>> twoCubes();
>> cube(c2);
>> $cube1_size = 10;
>> $cube2_size = 15;
>> twoCubes();
>> $cube1_size = 20;
>> $cube2_size = 30;
>> twoCubes();
>> module twoCubes() {
>> cube($cube2_size);
>> Related notes:
>> assignment.
JG
Jonathan Gilbert
Mon, Mar 11, 2024 1:47 AM
EBo --
a small example, but is starting to feel about right:
function
let(
let(
cat =
itm = val[0][2],
echo(".....",itm)
) itm;
angle).
echo(" pc = ",pc);
EBo --
parent scope?
module
Advice:
Customizer. See
interface aspects.
cube1_size = 10;
cube2_size = 15;
ratio = 2;
twoCubes();
cube(c2);
walk up the enclosing blocks until you get to the first variable with that
name.
functions. They are still immutable, but are dynamically scoped. They are
passed down through calls, no matter how the program is laid out. Walk up
$cube1_size = 10;
$cube2_size = 15;
twoCubes();
$cube1_size = 20;
$cube2_size = 30;
twoCubes();
module twoCubes() {
cube($cube2_size);
Related notes:
module invocations. Don't expect to be able to call a module, then set a $
assignment.
hits the first module definition. If you want to have a global variable
that the user *shouldn't* customize, put in a dummy "module stop();" after
https://github.com/jon-gilbert/openscad_objects is perhaps what you're
thinking of?
On Sun, Mar 10, 2024 at 6:46 PM John David via Discuss <
> EBo --
>> function
>> let(
>> let(
>> cat =
>> itm = val[0][2],
>> echo(".....",itm)
>> ) itm;
>> angle).
>> echo(" pc = ",pc);
>> EBo --
>>> parent scope?
>>> module
>>> Advice:
>>> Customizer. See
>>> interface aspects.
>>> cube1_size = 10;
>>> cube2_size = 15;
>>> ratio = 2;
>>> twoCubes();
>>> cube(c2);
>>> name.
>>> $cube1_size = 10;
>>> $cube2_size = 15;
>>> twoCubes();
>>> $cube1_size = 20;
>>> $cube2_size = 30;
>>> twoCubes();
>>> module twoCubes() {
>>> cube($cube2_size);
>>> Related notes:
>>> assignment.
- Jon Gilbert
jong@jong.org / jgilbertsjc@gmail.com
John David
Mon, Mar 11, 2024 2:13 AM
Thank you, Jon, for that pointer. It looks interesting. It gave me some
ideas on where to look inside BOSL2 as well -- where I found hashmap.
I will look at both of them, but I like some of the functionality with the
hashmap (specifically del and additems). I'll give that a try.
EBo --
On Sun, Mar 10, 2024 at 9:48 PM Jonathan Gilbert via Discuss <
EBo --
function
let(
let(
cat =
itm = val[0][2],
echo(".....",itm)
) itm;
modified angle).
echo(" pc = ",pc);
search. Anyone have suggestions on how to fix those?
EBo --
parent scope?
them.
module
is "compiled", or that it's compiled at all.)
Advice:
Customizer. See
interface aspects.
control them, the usual strategy is to have your subassembly's module take
cube1_size = 10;
cube2_size = 15;
ratio = 2;
twoCubes();
cube(c2);
the customizer) that control the middle pair of cubes, and the module has
name.
$cube1_size = 10;
$cube2_size = 15;
twoCubes();
$cube1_size = 20;
$cube2_size = 30;
twoCubes();
module twoCubes() {
cube($cube2_size);
Related notes:
assignment.
EBo --
> thinking of?
>> EBo --
>>> function
>>> let(
>>> let(
>>> cat =
>>> itm = val[0][2],
>>> echo(".....",itm)
>>> ) itm;
>>> modified angle).
>>> echo(" pc = ",pc);
>>> EBo --
>>>> parent scope?
>>>> them.
>>>> module
>>>> Advice:
>>>> Customizer. See
>>>> interface aspects.
>>>> cube1_size = 10;
>>>> cube2_size = 15;
>>>> ratio = 2;
>>>> twoCubes();
>>>> cube(c2);
>>>> name.
>>>> $cube1_size = 10;
>>>> $cube2_size = 15;
>>>> twoCubes();
>>>> $cube1_size = 20;
>>>> $cube2_size = 30;
>>>> twoCubes();
>>>> module twoCubes() {
>>>> cube($cube2_size);
>>>> Related notes:
>>>> assignment.
> - Jon Gilbert
