Save folder is not remembered (Issue #6277)
Michael Marx (spintel)
Mon, Oct 13, 2025 1:57 PM
Jon raised an issue https://github.com/openscad/openscad/issues/6277
Expected behavior
Once I tell OpenSCAD where I want to save files, it would be nice if OpenSCAD helped me, by
remembering the location, rather than forcing me to specify that location repeatedly
I suggested
I suspect others will not like such behaviour, I for example have a working directory that I want
to stay at, and wouldn't want it to change if I happened to save something elsewhere. I set the
directory in a shortcut (on the Desktop) which starts OpenSCAD.exe.
Jon rejoined
As I said in my comment, this has been discussed at length in the past, and no single option has
made everyone happy. But the current behavior is not as it was in the past. Hence my "bug" report.
I would welcome two behaviors (or more?!?) controlled by a Preference. It should be possible to
make almost everyone happier.
Dare I suggest that we hash this out on the main list?
'But the current behavior is not as it was in the past. Hence my "bug" report.'
I am reporting this as a bug because the current program behavior differs from the program behavior
in the past.
However, Jon was not particularly clear about what the past behaviour was, and with which version.
This needs clarification.
So, open for hashing out on the Mailing-list!
(Of note is, do we really need yet another option, when Operating System solutions exist to tell
OpenSCAD where you want to have the working directory)
...GO...
(p.s. Yet another 'religious' discussion, there are well fortified positions on all three sides,
keep discussion civil)
Jon raised an issue https://github.com/openscad/openscad/issues/6277 Expected behavior Once I tell OpenSCAD where I want to save files, it would be nice if OpenSCAD helped me, by remembering the location, rather than forcing me to specify that location repeatedly I suggested I suspect others will not like such behaviour, I for example have a working directory that I want to stay at, and wouldn't want it to change if I happened to save something elsewhere. I set the directory in a shortcut (on the Desktop) which starts OpenSCAD.exe. Jon rejoined As I said in my comment, this has been discussed at length in the past, and no single option has made everyone happy. But the current behavior is not as it was in the past. Hence my "bug" report. I would welcome two behaviors (or more?!?) controlled by a Preference. It should be possible to make almost everyone happier. Dare I suggest that we hash this out on the main list? 'But the current behavior is not as it was in the past. Hence my "bug" report.' I am reporting this as a bug because the current program behavior differs from the program behavior in the past. However, Jon was not particularly clear about what the past behaviour was, and with which version. This needs clarification. So, open for hashing out on the Mailing-list! (Of note is, do we really need yet another option, when Operating System solutions exist to tell OpenSCAD where you want to have the working directory) ...GO... (p.s. Yet another 'religious' discussion, there are well fortified positions on all three sides, keep discussion civil)
Mon, Oct 13, 2025 2:48 PM
Perhaps the best way to think about this would be
  1. Jon made a specific proposal
  2. if that proposal does not work for you, make a different specific
    proposal
After we have 2 or 3 or 4 proposals, we try to define modes for this,
and then possible preferences.  Once your preference is set on your
system, then everyone will be happy.
https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_openscad_openscad_issues_6277&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=khz4DJzc5O81zH49Cj7OHiIKHt7BfsICOCx6zGt-cS-hgwDu7IKNzE2ajP-buGUl&s=LA8hG4bZLFz7oTTYJ-K36P5fOei3ykHa24RH1xErjQ8&e=
Expected behavior
I suggested
Jon rejoined
report.'
working directory)
...GO...
Perhaps the best way to think about this would be 1) Jon made a specific proposal 2) if that proposal does not work for you, make a different specific proposal After we have 2 or 3 or 4 proposals, we try to define modes for this, and then possible preferences.  Once your preference is set on your system, then everyone will be happy. Jon On 10/13/2025 9:57 AM, Michael Marx (spintel) via Discuss wrote: > > Jon raised an issue https://github.com/openscad/openscad/issues/6277 > <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_openscad_openscad_issues_6277&d=DwMFAg&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=khz4DJzc5O81zH49Cj7OHiIKHt7BfsICOCx6zGt-cS-hgwDu7IKNzE2ajP-buGUl&s=LA8hG4bZLFz7oTTYJ-K36P5fOei3ykHa24RH1xErjQ8&e=> > > **Expected behavior** > Once I tell OpenSCAD where I want to save files, it would be nice if > OpenSCAD helped me, by remembering the location, rather than forcing > me to specify that location repeatedly > > I suggested > > I suspect others will not like such behaviour, I for example have a > working directory that I want to stay at, and wouldn't want it to > change if I happened to save something elsewhere. I set the directory > in a shortcut (on the Desktop) which starts OpenSCAD.exe. > > Jon rejoined > > As I said in my comment, this has been discussed at length in the > past, and no single option has made everyone happy. But the current > behavior is not as it was in the past. Hence my "bug" report. > > I would welcome two behaviors (or more?!?) controlled by a Preference. > It should be possible to make almost everyone happier. > > Dare I suggest that we hash this out on the main list? > > 'But the current behavior is not as it was in the past. Hence my "bug" > report.' > > I am reporting this as a bug because the current program behavior > differs from the program behavior in the past. > > However, Jon was not particularly clear about what the past behaviour > was, and with which version. > This needs clarification. > > So, open for hashing out on the Mailing-list! > (Of note is, do we really need yet another option, when Operating > System solutions exist to tell OpenSCAD where you want to have the > working directory) > > ...GO... > > (p.s. Yet another 'religious' discussion, there are well fortified > positions on all three sides, keep discussion civil) > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG antivirus software. www.avg.com
JJ
Jeffrey Jay Hayes
Mon, Oct 13, 2025 2:54 PM
I would like to have a tab or page in preferences where i have control over where my own files are, where libraries are, and so on
personal start points - list of folders that i create manually. The folders on the list can be ordered and one marked as the current place for new files to be saved
a list of paths in the environment : exported files .. platform specific folders included
with a checkbox to show which location is the current folder for saving new files
[  ]  $HOME /Users/vulcan/3D-designs
[ x ] $XPC_folder /mnt/Spare/scad-designs
[  ]  $SCAD_DEFAULT_FOLDER (do we have this?)
list of folders where libraries might be - one from the app’s installation directory, another for an optional nightly
with a checkbox to select which ones should be used
[  ]  $HOME /Users/vulcan/scad-libs
[  ]  SCAD Nightly libraries
[  ]  SCAD libraries
I will mock up a popup or preferences page to show all this
Jeff
On Oct 13, 2025, at 3:57 PM, Michael Marx (spintel) via Discuss discuss@lists.openscad.org wrote:
Expected behavior
I would like to have a tab or page in preferences where i have control over where my own files are, where libraries are, and so on personal start points - list of folders that i create manually. The folders on the list can be ordered and one marked as the current place for new files to be saved a list of paths in the environment : exported files .. platform specific folders included with a checkbox to show which location is the current folder for saving new files [ ] $HOME /Users/vulcan/3D-designs [ x ] $XPC_folder /mnt/Spare/scad-designs [ ] $SCAD_DEFAULT_FOLDER (do we have this?) list of folders where libraries might be - one from the app’s installation directory, another for an optional nightly with a checkbox to select which ones should be used [ ] $HOME /Users/vulcan/scad-libs [ ] SCAD Nightly libraries [ ] SCAD libraries I will mock up a popup or preferences page to show all this Jeff > On Oct 13, 2025, at 3:57 PM, Michael Marx (spintel) via Discuss <discuss@lists.openscad.org> wrote: > > Jon raised an issue https://github.com/openscad/openscad/issues/6277 > Expected behavior > Once I tell OpenSCAD where I want to save files, it would be nice if OpenSCAD helped me, by remembering the location, rather than forcing me to specify that location repeatedly
Mon, Oct 13, 2025 10:41 PM
Please resist playing with library location look-up, some people have complex setups.
It needs a clear understanding of the various library settings. Search Help/Library_Info for 'path'.
The other consideration, is how the 'current' path relates when you have multiple tabs.
Do you really want paths for other tabs affected by a save you do in one tab?
As I mentioned, the breadth of the preferences has exploded, one can have too many.
I'm still in the No change camp.
Jon, you still have not explained "But the current behavior is not as it was in the past.".
What past version, and how is the behaviour different?
From: Jeffrey Jay Hayes via Discuss [mailto:discuss@lists.openscad.org]
Sent: Tuesday, October 14, 2025 1:54 AM
To: OpenSCAD Discussion List
Cc: Jeffrey Jay Hayes
Subject: [OpenSCAD] Re: Save folder is not remembered (Issue #6277)
[  ]  SCAD libraries
Jeff
Jon raised an issue  https://github.com/openscad/openscad/issues/6277 https://github.com/openscad/openscad/issues/6277
Expected behavior
Please resist playing with library location look-up, some people have complex setups. It needs a clear understanding of the various library settings. Search Help/Library_Info for 'path'. The other consideration, is how the 'current' path relates when you have multiple tabs. Do you really want paths for other tabs affected by a save you do in one tab? As I mentioned, the breadth of the preferences has exploded, one can have too many. I'm still in the No change camp. ----- Jon, you still have not explained "But the current behavior is not as it was in the past.". What past version, and how is the behaviour different? _____ From: Jeffrey Jay Hayes via Discuss [mailto:discuss@lists.openscad.org] Sent: Tuesday, October 14, 2025 1:54 AM To: OpenSCAD Discussion List Cc: Jeffrey Jay Hayes Subject: [OpenSCAD] Re: Save folder is not remembered (Issue #6277) I would like to have a tab or page in preferences where i have control over where my own files are, where libraries are, and so on personal start points - list of folders that i create manually. The folders on the list can be ordered and one marked as the current place for new files to be saved a list of paths in the environment : exported files .. platform specific folders included with a checkbox to show which location is the current folder for saving new files [ ] $HOME /Users/vulcan/3D-designs [ x ] $XPC_folder /mnt/Spare/scad-designs [ ] $SCAD_DEFAULT_FOLDER (do we have this?) list of folders where libraries might be - one from the app’s installation directory, another for an optional nightly with a checkbox to select which ones should be used [ ] $HOME /Users/vulcan/scad-libs [ ] SCAD Nightly libraries [ ] SCAD libraries I will mock up a popup or preferences page to show all this Jeff On Oct 13, 2025, at 3:57 PM, Michael Marx (spintel) via Discuss <discuss@lists.openscad.org> wrote: Jon raised an issue <https://github.com/openscad/openscad/issues/6277> https://github.com/openscad/openscad/issues/6277 Expected behavior Once I tell OpenSCAD where I want to save files, it would be nice if OpenSCAD helped me, by remembering the location, rather than forcing me to specify that location repeatedly
Mon, Oct 13, 2025 11:01 PM
In the past, once I opened a file or saved a file, the appropriate
folder was remembered until I terminated OpenSCAD. Since I never re-boot
my computer, this means that it worked fine for weeks at a time.
I just tried it one more time, and I find that it is working fine: it
remembers both the open file folder and the STL folder.
I am now puzzled as to how I imagined that there was a problem. I know
it bit me repeatedly over the last few weeks.
I will try to reproduce.
At this point, my "bug report" may well be an error on my part.
complex setups.
have multiple tabs.
one tab?
have too many.
*From:*Jeffrey Jay Hayes via Discuss [mailto:discuss@lists.openscad.org]
saving new files
[   ]  SCAD libraries
Jeff
Jon raised an issuehttps://github.com/openscad/openscad/issues/6277
https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_openscad_openscad_issues_6277&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=IXVmo7y5QTgkk0CP8o5ffKadqf2ptCBrxaEe1LNH9sh2w0F-bu3G5YnQohqavqNX&s=pF1FYoof9Ys9lLgr_LZY9lCHKY4X2Rc1rhF-I0zljnM&e=
Expected behavior
In the past, once I opened a file or saved a file, the appropriate folder was remembered until I terminated OpenSCAD. Since I never re-boot my computer, this means that it worked fine for weeks at a time. I just tried it one more time, and I find that it is working fine: it remembers both the open file folder and the STL folder. I am now puzzled as to how I imagined that there was a problem. I know it bit me repeatedly over the last few weeks. I will try to reproduce. At this point, my "bug report" may well be an error on my part. Jon On 10/13/2025 6:41 PM, Michael Marx (spintel) via Discuss wrote: > > Please resist playing with library location look-up, some people have > complex setups. > It needs a clear understanding of the various library settings. Search > Help/Library_Info for 'path'. > > The other consideration, is how the 'current' path relates when you > have multiple tabs. > Do you really want paths for other tabs affected by a save you do in > one tab? > > As I mentioned, the breadth of the preferences has exploded, one can > have too many. > > I'm still in the No change camp. > > ----- > > Jon, you still have not explained "But the current behavior is not as > it was in the past.". > What past version, and how is the behaviour different? > > ------------------------------------------------------------------------ > > *From:*Jeffrey Jay Hayes via Discuss [mailto:discuss@lists.openscad.org] > *Sent:* Tuesday, October 14, 2025 1:54 AM > *To:* OpenSCAD Discussion List > *Cc:* Jeffrey Jay Hayes > *Subject:* [OpenSCAD] Re: Save folder is not remembered (Issue #6277) > > I would like to have a tab or page in preferences where i have control > over where my own files are, where libraries are, and so on > > personal start points - list of folders that i create manually. The > folders on the list can be ordered and one marked as the current place > for new files to be saved > > a list of paths in the environment : exported files .. platform > specific folders included > > with a checkbox to show which location is the current folder for > saving new files > > [   ]  $HOME /Users/vulcan/3D-designs > > [ x ] $XPC_folder /mnt/Spare/scad-designs > > [   ]  $SCAD_DEFAULT_FOLDER (do we have this?) > > list of folders where libraries might be - one from the app’s > installation directory, another for an optional nightly > > with a checkbox to select which ones should be used > > [   ]  $HOME /Users/vulcan/scad-libs > > [   ]  SCAD Nightly libraries > > [   ]  SCAD libraries > > I will mock up a popup or preferences page to show all this > > Jeff > > > > On Oct 13, 2025, at 3:57 PM, Michael Marx (spintel) via Discuss > <discuss@lists.openscad.org> wrote: > > Jon raised an issuehttps://github.com/openscad/openscad/issues/6277 > <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_openscad_openscad_issues_6277&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=IXVmo7y5QTgkk0CP8o5ffKadqf2ptCBrxaEe1LNH9sh2w0F-bu3G5YnQohqavqNX&s=pF1FYoof9Ys9lLgr_LZY9lCHKY4X2Rc1rhF-I0zljnM&e=> > > **Expected behavior** > Once I tell OpenSCAD where I want to save files, it would be nice if > OpenSCAD helped me, by remembering the location, rather than forcing > me to specify that location repeatedly > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG antivirus software. www.avg.com
K
Ken
Tue, Oct 14, 2025 12:10 AM
Not sure if it is related or not, but recently the windows 64 bit nightly builds are no longer saving the window positions I set.
When I updated to 2025.09.20 nightly build, I set the editor, console & viewport windows to exactly where I wanted them and the sizes I wanted across my 3 monitors & then shut down the program. When I brought it up again, it had forgotten the settings and had all three windows jammed together on one monitor.
I eventually found a work-around is to install version 2012-01, then run that & set the window positions. Then I shut that version down & run 2025.09.20, and it then "remembers" where 2012-01put the editor & console- but not the viewport- it always puts the viewport on monitor 1 instead of 3 - not my preferred option, but I can live with that .
After that little work-around, the nightly build will now remember my window positions.
I also just checked by installing 2025.10.13 nightly build and it also picked up the my preferred window positions straight away.
Oh, and it also remembers the last folder used when opening or saving a file..
[   ]  SCAD libraries
Jeff
Jon raised an issuehttps://github.com/openscad/openscad/issues/6277 https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_openscad_openscad_issues_6277&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=IXVmo7y5QTgkk0CP8o5ffKadqf2ptCBrxaEe1LNH9sh2w0F-bu3G5YnQohqavqNX&s=pF1FYoof9Ys9lLgr_LZY9lCHKY4X2Rc1rhF-I0zljnM&e=
Expected behavior
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Not sure if it is related or not, but recently the windows 64 bit nightly builds are no longer saving the window positions I set. When I updated to 2025.09.20 nightly build, I set the editor, console & viewport windows to exactly where I wanted them and the sizes I wanted across my 3 monitors & then shut down the program. When I brought it up again, it had forgotten the settings and had all three windows jammed together on one monitor. I eventually found a work-around is to install version 2012-01, then run that & set the window positions. Then I shut that version down & run 2025.09.20, and it then "remembers" where 2012-01put the editor & console- but not the viewport- it always puts the viewport on monitor 1 instead of 3 - not my preferred option, but I can live with that . After that little work-around, the nightly build will now remember my window positions. I also just checked by installing 2025.10.13 nightly build and it also picked up the my preferred window positions straight away. Oh, and it also remembers the last folder used when opening or saving a file.. On 2025-10-14 10:01, Jon Bondy via Discuss wrote: > > In the past, once I opened a file or saved a file, the appropriate folder was remembered until I terminated OpenSCAD. Since I never re-boot my computer, this means that it worked fine for weeks at a time. > > I just tried it one more time, and I find that it is working fine: it remembers both the open file folder and the STL folder. > > I am now puzzled as to how I imagined that there was a problem.  I know it bit me repeatedly over the last few weeks. > > I will try to reproduce. > > At this point, my "bug report" may well be an error on my part. > > Jon > > > On 10/13/2025 6:41 PM, Michael Marx (spintel) via Discuss wrote: >> >> Please resist playing with library location look-up, some people have complex setups. >> It needs a clear understanding of the various library settings. Search Help/Library_Info for 'path'. >> >> The other consideration, is how the 'current' path relates when you have multiple tabs. >> Do you really want paths for other tabs affected by a save you do in one tab? >> >> As I mentioned, the breadth of the preferences has exploded, one can have too many. >> >> I'm still in the No change camp. >> >> ----- >> >> Jon, you still have not explained "But the current behavior is not as it was in the past.". >> What past version, and how is the behaviour different? >> >> ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ >> >> *From:*Jeffrey Jay Hayes via Discuss [mailto:discuss@lists.openscad.org] >> *Sent:* Tuesday, October 14, 2025 1:54 AM >> *To:* OpenSCAD Discussion List >> *Cc:* Jeffrey Jay Hayes >> *Subject:* [OpenSCAD] Re: Save folder is not remembered (Issue #6277) >> >> I would like to have a tab or page in preferences where i have control over where my own files are, where libraries are, and so on >> >> personal start points - list of folders that i create manually. The folders on the list can be ordered and one marked as the current place for new files to be saved >> >> a list of paths in the environment : exported files .. platform specific folders included >> >> with a checkbox to show which location is the current folder for saving new files >> >> [   ]  $HOME /Users/vulcan/3D-designs >> >> [ x ] $XPC_folder /mnt/Spare/scad-designs >> >> [   ]  $SCAD_DEFAULT_FOLDER (do we have this?) >> >> list of folders where libraries might be - one from the app’s installation directory, another for an optional nightly >> >> with a checkbox to select which ones should be used >> >> [   ]  $HOME /Users/vulcan/scad-libs >> >> [   ]  SCAD Nightly libraries >> >> [   ]  SCAD libraries >> >> I will mock up a popup or preferences page to show all this >> >> Jeff >> >> >> >> On Oct 13, 2025, at 3:57 PM, Michael Marx (spintel) via Discuss <discuss@lists.openscad.org> wrote: >> >> Jon raised an issuehttps://github.com/openscad/openscad/issues/6277 <https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_openscad_openscad_issues_6277&d=DwMFaQ&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=AsrE-c7ZR7B2Kyr3qgfvvppkCEBVsNmwEMndcrRSuOI&m=IXVmo7y5QTgkk0CP8o5ffKadqf2ptCBrxaEe1LNH9sh2w0F-bu3G5YnQohqavqNX&s=pF1FYoof9Ys9lLgr_LZY9lCHKY4X2Rc1rhF-I0zljnM&e=> >> >> **Expected behavior** >> Once I tell OpenSCAD where I want to save files, it would be nice if OpenSCAD helped me, by remembering the location, rather than forcing me to specify that location repeatedly >> >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email todiscuss-leave@lists.openscad.org > > <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> Virus-free.www.avg.com <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient> > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org -- Cheers, Ken bats059@gmail.com https://vk7krj.com https://vk7krj.com/running.html ---------------------------------------- A baby can be defined as an ego with a noise at one end and a smell at the other. Your job as parents is to teach them to control all three. My job as a grandad is to tell you how you are doing it all wrong!
Tue, Oct 14, 2025 6:58 AM
That remembering where you saved something only happens when you
successfully save a file. So if you navigate to the destination
directory, remember you need to change one more thing, hit cancel,
change that thing, hit save again, you're back to where you started.
** KVK: 27239233    **
**  'a' for accelleration.
On Mon, Oct 13, 2025 at 07:01:16PM -0400, Jon Bondy via Discuss wrote: > In the past, once I opened a file or saved a file, the appropriate folder > was remembered until I terminated OpenSCAD. Since I never re-boot my > computer, this means that it worked fine for weeks at a time. > > I just tried it one more time, and I find that it is working fine: it > remembers both the open file folder and the STL folder. > > I am now puzzled as to how I imagined that there was a problem. I know it > bit me repeatedly over the last few weeks. That remembering where you saved something only happens when you successfully save a file. So if you navigate to the destination directory, remember you need to change one more thing, hit cancel, change that thing, hit save again, you're back to where you started. Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Verl. Spiegelmakerstraat 37 2645 LZ Delfgauw, The Netherlands. ** KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a** is going up. -- Chris Hadfield about flying up the space shuttle. ** 'a' for accelleration.
JJ
Jeffrey Jay Hayes
Tue, Oct 14, 2025 10:59 AM
On Oct 14, 2025, at 12:41 AM, Michael Marx (spintel) via Discuss discuss@lists.openscad.org wrote:
i don’t intend to “play with” anything. My proposal is to bring the mysteries of where OpenSCAD looks for stuff into the light .. an information page in Preferences will do that.
I have three places where I want to store .scad files so i would like to “register” them as a list of Known Places (in preferences ? maybe) and i think i can make that list appear in the Save dialog box as a list of favourite places.
Then it would make sense to put “the folder last saved to” to the top of that list of favourites .. and maybe “folder of last save” should be kept separately for each type of file we Export .. that would be nice eh?
no change needed here .. each Editor Tab is an instance of the Scintilla editor and as such remembers the folder its content was loaded from, which doing Save As can change but that Save A Copy will not change. I am not proposing to change this existing, built-in functionality.
Or possibly just the right amount. One of Pet Peeves on my list of Things Done Badly By Most Apps is them NOT showing where references (libraries) are looked for and another is them NOT showing how they are using environmental variables to form file paths for those reference locations.
I would like to improve that for OpenSCAD
> On Oct 14, 2025, at 12:41 AM, Michael Marx (spintel) via Discuss <discuss@lists.openscad.org> wrote: > > Please resist playing with library location look-up, some people have complex setups. > It needs a clear understanding of the various library settings. Search Help/Library_Info for 'path'. i don’t intend to “play with” anything. My proposal is to bring the mysteries of where OpenSCAD looks for stuff into the light .. an information page in Preferences will do that. I have three places where I want to store .scad files so i would like to “register” them as a list of Known Places (in preferences ? maybe) and i think i can make that list appear in the Save dialog box as a list of favourite places. Then it would make sense to put “the folder last saved to” to the top of that list of favourites .. and maybe “folder of last save” should be kept separately for each type of file we Export .. that would be nice eh? > The other consideration, is how the 'current' path relates when you have multiple tabs. no change needed here .. each Editor Tab is an instance of the Scintilla editor and as such remembers the folder its content was loaded from, which doing Save As can change but that Save A Copy will not change. I am not proposing to change this existing, built-in functionality. > As I mentioned, the breadth of the preferences has exploded, one can have too many. Or possibly just the right amount. One of Pet Peeves on my list of Things Done Badly By Most Apps is them NOT showing where references (libraries) are looked for and another is them NOT showing how they are using environmental variables to form file paths for those reference locations. I would like to improve that for OpenSCAD > > I'm still in the No change camp. > ----- > Jon, you still have not explained "But the current behavior is not as it was in the past.". > What past version, and how is the behaviour different? >
Tue, Oct 14, 2025 4:09 PM
The library path is not all that prominent, but it's in Help/Library
Info.  The per-user library path is directly accessible via File/Show
Library Folder.
In Windows, the Open dialog already has a system-wide favorite-places
mechanism.
On 10/14/2025 3:59 AM, Jeffrey Jay Hayes via Discuss wrote: > i don’t intend to “play with” anything. My proposal is to bring the > mysteries of where OpenSCAD looks for stuff into the light .. an > information page in Preferences will do that. The library path is not all that prominent, but it's in Help/Library Info.  The per-user library path is directly accessible via File/Show Library Folder. > I have three places where I want to store .scad files so i would like > to “register” them as a list of Known Places (in preferences ? maybe) > and i think i can make that list appear in the Save dialog box as a > list of favourite places. In Windows, the Open dialog already has a system-wide favorite-places mechanism.
Tue, Oct 14, 2025 5:53 PM
I could not find this mechanism, Jordan.
mechanism.
I could not find this mechanism, Jordan. On 10/14/2025 12:09 PM, Jordan Brown via Discuss wrote: > > In Windows, the Open dialog already has a system-wide favorite-places > mechanism. > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG antivirus software. www.avg.com
