2020.RC-12 Wish lists and feature requests
lar3ry
Mon, Dec 7, 2020 10:33 PM
Just a few things that I noticed in the first few minutes.
Love the tabs.
However, I'd like to see...
  1. A way to bring up a new tab
    (a) without opening a file. (oops... never mind! Discovered the mouse
    wheel click and menu Open File)
    (b) by dragging/dropping a .scad file (2019.05 opens a new window when I
    do that)
  2. When you switch to another tab, change the preview/render pane, if not to
    what was in it on the tab you switched to, at least either clear it or make
    the background a different colour.
  3. Same thing for when a tab is closed, but additionally, when the sole
    remaining tab is closed, I think the editor pane should not be hidden, but
    only cleared.
One thing missing that I use a lot... importing an STL file (I use
drag/drop), or is there a way to do that?
Looking good so far. Nice job, folks.
Just a few things that I noticed in the first few minutes. Love the tabs. However, I'd like to see... 1. A way to bring up a new tab (a) without opening a file. (oops... never mind! Discovered the mouse wheel click and menu Open File) (b) by dragging/dropping a .scad file (2019.05 opens a new window when I do that) 2. When you switch to another tab, change the preview/render pane, if not to what was in it on the tab you switched to, at least either clear it or make the background a different colour. 3. Same thing for when a tab is closed, but additionally, when the sole remaining tab is closed, I think the editor pane should not be hidden, but only cleared. One thing missing that I use a lot... importing an STL file (I use drag/drop), or is there a way to do that? Looking good so far. Nice job, folks. -- Sent from: http://forum.openscad.org/
W
Whosawhatsis
Mon, Dec 7, 2020 11:00 PM
I also haven't been able to find any way, when opening a file, to determine
whether it will be opened in a new tab or a new window. This wouldn't be
such a big deal if it was possible to move documents into/out of window
tabs, but that doesn't seem to be possible either. This may be part of this
elusive middle-click menu, but I can't access it using the trackpad on my
MacBook...
It would also be nice to see some process separation between windows, so
that it's possible to have more than one preview/render operation running
at a time (especially considering that they are single-threaded, and thus
won't make use of multiple processor cores). I sometimes generate complex
files where these take a while, and it would be nice to be able to work on
another design in another window while I'm waiting for it (without
resorting to launching a second instance from the terminal).
I haven't checked these on the release candidate, since there isn't one
available for Mac yet, but I'm running a recent snapshot release, so I
assume these problems still exist.
Love the tabs.
    do that)
    to
    only cleared.
I also haven't been able to find any way, when opening a file, to determine whether it will be opened in a new tab or a new window. This wouldn't be such a big deal if it was possible to move documents into/out of window tabs, but that doesn't seem to be possible either. This may be part of this elusive middle-click menu, but I can't access it using the trackpad on my MacBook... It would also be nice to see some process separation between windows, so that it's possible to have more than one preview/render operation running at a time (especially considering that they are single-threaded, and thus won't make use of multiple processor cores). I sometimes generate complex files where these take a while, and it would be nice to be able to work on another design in another window while I'm waiting for it (without resorting to launching a second instance from the terminal). I haven't checked these on the release candidate, since there isn't one available for Mac yet, but I'm running a recent snapshot release, so I assume these problems still exist. On December 7, 2020 at 14:33:47, lar3ry (lar3ry@sasktel.net) wrote: Just a few things that I noticed in the first few minutes. Love the tabs. However, I'd like to see... 1. A way to bring up a new tab (a) without opening a file. (oops... never mind! Discovered the mouse wheel click and menu Open File) (b) by dragging/dropping a .scad file (2019.05 opens a new window when I do that) 2. When you switch to another tab, change the preview/render pane, if not to what was in it on the tab you switched to, at least either clear it or make the background a different colour. 3. Same thing for when a tab is closed, but additionally, when the sole remaining tab is closed, I think the editor pane should not be hidden, but only cleared. One thing missing that I use a lot... importing an STL file (I use drag/drop), or is there a way to do that? Looking good so far. Nice job, folks. -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Dec 7, 2020 11:03 PM
I open separate windows if I want them to run independently and make use of
more cores. I use tabs if I want multiple views to share cache because they
are parts of the same project.
Love the tabs.
    do that)
    to
    make
    only cleared.
I open separate windows if I want them to run independently and make use of more cores. I use tabs if I want multiple views to share cache because they are parts of the same project. On Mon, 7 Dec 2020 at 23:00, Whosawhatsis <whosawhatsis@gmail.com> wrote: > I also haven't been able to find any way, when opening a file, to > determine whether it will be opened in a new tab or a new window. This > wouldn't be such a big deal if it was possible to move documents into/out > of window tabs, but that doesn't seem to be possible either. This may be > part of this elusive middle-click menu, but I can't access it using the > trackpad on my MacBook... > > It would also be nice to see some process separation between windows, so > that it's possible to have more than one preview/render operation running > at a time (especially considering that they are single-threaded, and thus > won't make use of multiple processor cores). I sometimes generate complex > files where these take a while, and it would be nice to be able to work on > another design in another window while I'm waiting for it (without > resorting to launching a second instance from the terminal). > > I haven't checked these on the release candidate, since there isn't one > available for Mac yet, but I'm running a recent snapshot release, so I > assume these problems still exist. > > On December 7, 2020 at 14:33:47, lar3ry (lar3ry@sasktel.net) wrote: > > Just a few things that I noticed in the first few minutes. > > Love the tabs. > However, I'd like to see... > 1. A way to bring up a new tab > (a) without opening a file. (oops... never mind! Discovered the mouse > wheel click and menu Open File) > (b) by dragging/dropping a .scad file (2019.05 opens a new window when I > do that) > 2. When you switch to another tab, change the preview/render pane, if not > to > what was in it on the tab you switched to, at least either clear it or > make > the background a different colour. > 3. Same thing for when a tab is closed, but additionally, when the sole > remaining tab is closed, I think the editor pane should not be hidden, but > only cleared. > > One thing missing that I use a lot... importing an STL file (I use > drag/drop), or is there a way to do that? > > Looking good so far. Nice job, folks. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
W
Whosawhatsis
Mon, Dec 7, 2020 11:05 PM
Sounds like it works differently on Windows. The Mac version treats all
windows as one process.
Love the tabs.
    do that)
    to
    make
    only cleared.
Sounds like it works differently on Windows. The Mac version treats all windows as one process. On December 7, 2020 at 15:04:33, nop head (nop.head@gmail.com) wrote: I open separate windows if I want them to run independently and make use of more cores. I use tabs if I want multiple views to share cache because they are parts of the same project. On Mon, 7 Dec 2020 at 23:00, Whosawhatsis <whosawhatsis@gmail.com> wrote: > I also haven't been able to find any way, when opening a file, to > determine whether it will be opened in a new tab or a new window. This > wouldn't be such a big deal if it was possible to move documents into/out > of window tabs, but that doesn't seem to be possible either. This may be > part of this elusive middle-click menu, but I can't access it using the > trackpad on my MacBook... > > It would also be nice to see some process separation between windows, so > that it's possible to have more than one preview/render operation running > at a time (especially considering that they are single-threaded, and thus > won't make use of multiple processor cores). I sometimes generate complex > files where these take a while, and it would be nice to be able to work on > another design in another window while I'm waiting for it (without > resorting to launching a second instance from the terminal). > > I haven't checked these on the release candidate, since there isn't one > available for Mac yet, but I'm running a recent snapshot release, so I > assume these problems still exist. > > On December 7, 2020 at 14:33:47, lar3ry (lar3ry@sasktel.net) wrote: > > Just a few things that I noticed in the first few minutes. > > Love the tabs. > However, I'd like to see... > 1. A way to bring up a new tab > (a) without opening a file. (oops... never mind! Discovered the mouse > wheel click and menu Open File) > (b) by dragging/dropping a .scad file (2019.05 opens a new window when I > do that) > 2. When you switch to another tab, change the preview/render pane, if not > to > what was in it on the tab you switched to, at least either clear it or > make > the background a different colour. > 3. Same thing for when a tab is closed, but additionally, when the sole > remaining tab is closed, I think the editor pane should not be hidden, but > only cleared. > > One thing missing that I use a lot... importing an STL file (I use > drag/drop), or is there a way to do that? > > Looking good so far. Nice job, folks. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Dec 7, 2020 11:22 PM
I don't have a current build installed, but I assume that it's pretty
much the same as it was last December...
If you open a new window using File/New Window, that new window belongs
to the same process.
If you open a new instance of OpenSCAD by hitting it in the start menu
again, it's a new process.
You can tell the difference by looking at Task Manager.
On 12/7/2020 3:05 PM, Whosawhatsis wrote: > Sounds like it works differently on Windows. The Mac version treats > all windows as one process. > > On December 7, 2020 at 15:04:33, nop head (nop.head@gmail.com > <mailto:nop.head@gmail.com>) wrote: > >> I open separate windows if I want them to run independently and make >> use of more cores. I use tabs if I want multiple views to share >> cache because they are parts of the same project. I don't have a current build installed, but I assume that it's pretty much the same as it was last December... If you open a new window using File/New Window, that new window belongs to the same process. If you open a new instance of OpenSCAD by hitting it in the start menu again, it's a new process. You can tell the difference by looking at Task Manager.
W
Whosawhatsis
Mon, Dec 7, 2020 11:27 PM
Clicking on OpenSCAD anywhere in the GUI on a Mac will bring forward the
existing process, not open a new instance. Creating a second instance can
only be done from the terminal, as I mentioned above. Opening a second
instance in the terminal gives you a second icon in the dock, and a second
process visible in Activity Monitor (the Mac equivalent of the window task
manager).
On December 7, 2020 at 15:22:34, Jordan Brown (openscad@jordan.maileater.net)
the same process.
Clicking on OpenSCAD anywhere in the GUI on a Mac will bring forward the existing process, not open a new instance. Creating a second instance can only be done from the terminal, as I mentioned above. Opening a second instance in the terminal gives you a second icon in the dock, and a second process visible in Activity Monitor (the Mac equivalent of the window task manager). On December 7, 2020 at 15:22:34, Jordan Brown (openscad@jordan.maileater.net) wrote: On 12/7/2020 3:05 PM, Whosawhatsis wrote: Sounds like it works differently on Windows. The Mac version treats all windows as one process. On December 7, 2020 at 15:04:33, nop head (nop.head@gmail.com) wrote: I open separate windows if I want them to run independently and make use of more cores. I use tabs if I want multiple views to share cache because they are parts of the same project. I don't have a current build installed, but I assume that it's pretty much the same as it was last December... If you open a new window using File/New Window, that new window belongs to the same process. If you open a new instance of OpenSCAD by hitting it in the start menu again, it's a new process. You can tell the difference by looking at Task Manager.
Mon, Dec 7, 2020 11:40 PM
Seems a big omission from an OS that you can't run two instances of a
program from the GUI.
manager).
the same process.
Seems a big omission from an OS that you can't run two instances of a program from the GUI. On Mon, 7 Dec 2020 at 23:27, Whosawhatsis <whosawhatsis@gmail.com> wrote: > Clicking on OpenSCAD anywhere in the GUI on a Mac will bring forward the > existing process, not open a new instance. Creating a second instance can > only be done from the terminal, as I mentioned above. Opening a second > instance in the terminal gives you a second icon in the dock, and a second > process visible in Activity Monitor (the Mac equivalent of the window task > manager). > > On December 7, 2020 at 15:22:34, Jordan Brown ( > openscad@jordan.maileater.net) wrote: > > On 12/7/2020 3:05 PM, Whosawhatsis wrote: > > Sounds like it works differently on Windows. The Mac version treats all > windows as one process. > > On December 7, 2020 at 15:04:33, nop head (nop.head@gmail.com) wrote: > > I open separate windows if I want them to run independently and make use > of more cores. I use tabs if I want multiple views to share cache because > they are parts of the same project. > > > I don't have a current build installed, but I assume that it's pretty much > the same as it was last December... > > If you open a new window using File/New Window, that new window belongs to > the same process. > If you open a new instance of OpenSCAD by hitting it in the start menu > again, it's a new process. > > You can tell the difference by looking at Task Manager. > > >
W
Whosawhatsis
Mon, Dec 7, 2020 11:45 PM
The OS expects app developers to make their apps run properly in a single
instance, rather than forcing their users to spawn multiple instances, then
need to figure out which window(s) go with which instance. It's a much more
user-friendly approach when the app is written natively, but it can be
annoying when the devs are all using windows, and just compiling a mac
version that they never dogfood...
manager).
the same process.
The OS expects app developers to make their apps run properly in a single instance, rather than forcing their users to spawn multiple instances, then need to figure out which window(s) go with which instance. It's a much more user-friendly approach when the app is written natively, but it can be annoying when the devs are all using windows, and just compiling a mac version that they never dogfood... On December 7, 2020 at 15:40:36, nop head (nop.head@gmail.com) wrote: Seems a big omission from an OS that you can't run two instances of a program from the GUI. On Mon, 7 Dec 2020 at 23:27, Whosawhatsis <whosawhatsis@gmail.com> wrote: > Clicking on OpenSCAD anywhere in the GUI on a Mac will bring forward the > existing process, not open a new instance. Creating a second instance can > only be done from the terminal, as I mentioned above. Opening a second > instance in the terminal gives you a second icon in the dock, and a second > process visible in Activity Monitor (the Mac equivalent of the window task > manager). > > On December 7, 2020 at 15:22:34, Jordan Brown ( > openscad@jordan.maileater.net) wrote: > > On 12/7/2020 3:05 PM, Whosawhatsis wrote: > > Sounds like it works differently on Windows. The Mac version treats all > windows as one process. > > On December 7, 2020 at 15:04:33, nop head (nop.head@gmail.com) wrote: > > I open separate windows if I want them to run independently and make use > of more cores. I use tabs if I want multiple views to share cache because > they are parts of the same project. > > > I don't have a current build installed, but I assume that it's pretty much > the same as it was last December... > > If you open a new window using File/New Window, that new window belongs to > the same process. > If you open a new instance of OpenSCAD by hitting it in the start menu > again, it's a new process. > > You can tell the difference by looking at Task Manager. > > >
Mon, Dec 7, 2020 11:50 PM
determine
this
MacBook...
I hadn't played with this much. On 2020.11.30 (as RC2 is doing minkowski
ATM...), Win-7,
File/New-Window or File/Open-in-New-Window are separate windows in the same
process.
I expected it to be a new instance/process.
That shouldn't be too hard.
But are there cases where it is good to be in the same process?
Reuse cache is about the only thing I came up with.
What about shift-click those menu items uses a new process??
I would suggest changing this would be outside the point release.
Whosawhatsis wrote > I also haven't been able to find any way, when opening a file, to > determine > whether it will be opened in a new tab or a new window. This wouldn't be > such a big deal if it was possible to move documents into/out of window > tabs, but that doesn't seem to be possible either. This may be part of > this > elusive middle-click menu, but I can't access it using the trackpad on my > MacBook... > > It would also be nice to see some process separation between windows, so > that it's possible to have more than one preview/render operation running > at a time (especially considering that they are single-threaded, and thus > won't make use of multiple processor cores). I hadn't played with this much. On 2020.11.30 (as RC2 is doing minkowski ATM...), Win-7, File/New-Window or File/Open-in-New-Window are separate windows in the same process. I expected it to be a new instance/process. That shouldn't be too hard. But are there cases where it is good to be in the same process? Reuse cache is about the only thing I came up with. What about shift-click those menu items uses a new process?? I would suggest changing this would be outside the point release. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
Mon, Dec 7, 2020 11:58 PM
Along the same theme, right-click Tab could have Move-to-New-Window, which
performs equivalent to File/New-Window.
Along the same theme, right-click Tab could have Move-to-New-Window, which performs equivalent to File/New-Window. ----- OpenSCAD Admin - email* me if you need anything, or if I've done something stupid... * on the Forum, click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
