lost work
Gene Heskett
Fri, Aug 13, 2021 12:28 PM
Greetings;
I just had a crash after about 2 hours of work, rewriting a module that
was such a mess it should never have disturbed any spinning rust ever.
And I know I went thru the motions of saving what I had done quite a few
times, but when I re-open the file, with a new copy of the appimage, its
what I started with 2+ hours ago. Nothing had been saved. This is most
frustrating. And I don't care to have to re-invent a whole set of wheels
but must.
Its likely too late now, but is there any way to restart OpenSCAD and
have it recover from the /tmp stuff it stores when last told to preview?
This whole fiasco started because rotate_extrude() was refusing the
output of anything to the right of it in the comand line, a union
between a ball sphere and a vertical bar thru the middle of the ball, to
be used to insert the balls into the races, intended to be rotated into
a ball bearing race. And that used to cut a further track as the 3rd
argument of a difference.
This now makes 2 different linux boxes that have been plagued by having
to back out of a directory and re-enter it in order to see the latest
save. cura, mc and openscad are all doing it. ext4 file systems, 2
debian installs, stretch on this box and buster on the box I was working
on. I am beginning to think my mounts in /etc/fstab are duff, but if I
want to see a new save, I have to force a re-read of the directory. So I
don't think this loss of data is an OpenSCAD problem but a linux
problem. The rotate_extrude is working at another location in this same
file.
Can anyone comment?
Thanks all.
Cheers, Gene Heskett
-Ed Howdershelt (Author)
Greetings; I just had a crash after about 2 hours of work, rewriting a module that was such a mess it should never have disturbed any spinning rust ever. And I know I went thru the motions of saving what I had done quite a few times, but when I re-open the file, with a new copy of the appimage, its what I started with 2+ hours ago. Nothing had been saved. This is most frustrating. And I don't care to have to re-invent a whole set of wheels but must. Its likely too late now, but is there any way to restart OpenSCAD and have it recover from the /tmp stuff it stores when last told to preview? This whole fiasco started because rotate_extrude() was refusing the output of anything to the right of it in the comand line, a union between a ball sphere and a vertical bar thru the middle of the ball, to be used to insert the balls into the races, intended to be rotated into a ball bearing race. And that used to cut a further track as the 3rd argument of a difference. This now makes 2 different linux boxes that have been plagued by having to back out of a directory and re-enter it in order to see the latest save. cura, mc and openscad are all doing it. ext4 file systems, 2 debian installs, stretch on this box and buster on the box I was working on. I am beginning to think my mounts in /etc/fstab are duff, but if I want to see a new save, I have to force a re-read of the directory. So I don't think this loss of data is an OpenSCAD problem but a linux problem. The rotate_extrude is working at another location in this same file. Can anyone comment? Thanks all. Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Gene Heskett
Fri, Aug 13, 2021 2:23 PM
On Friday 13 August 2021 08:28:45 Gene Heskett wrote:
Greetings;
preview?
Can anyone comment?
done it again, lost an hours work, can't even take a screenshot to save
my work. I can't type a rotate or rotate_extrude and hit preview. froze
up tight. mouse moves normal but no curser. What am I going to have to
do to not lose my work like this? Do a pulldown to "save-as" for every
line I type?
Thanks all.
On Friday 13 August 2021 08:28:45 Gene Heskett wrote: > Greetings; > > I just had a crash after about 2 hours of work, rewriting a module > that was such a mess it should never have disturbed any spinning rust > ever. And I know I went thru the motions of saving what I had done > quite a few times, but when I re-open the file, with a new copy of the > appimage, its what I started with 2+ hours ago. Nothing had been > saved. This is most frustrating. And I don't care to have to re-invent > a whole set of wheels but must. > > Its likely too late now, but is there any way to restart OpenSCAD and > have it recover from the /tmp stuff it stores when last told to > preview? > > This whole fiasco started because rotate_extrude() was refusing the > output of anything to the right of it in the comand line, a union > between a ball sphere and a vertical bar thru the middle of the ball, > to be used to insert the balls into the races, intended to be rotated > into a ball bearing race. And that used to cut a further track as the > 3rd argument of a difference. > > This now makes 2 different linux boxes that have been plagued by > having to back out of a directory and re-enter it in order to see the > latest save. cura, mc and openscad are all doing it. ext4 file > systems, 2 debian installs, stretch on this box and buster on the box > I was working on. I am beginning to think my mounts in /etc/fstab are > duff, but if I want to see a new save, I have to force a re-read of > the directory. So I don't think this loss of data is an OpenSCAD > problem but a linux problem. The rotate_extrude is working at another > location in this same file. > > Can anyone comment? > done it again, lost an hours work, can't even take a screenshot to save my work. I can't type a rotate or rotate_extrude and hit preview. froze up tight. mouse moves normal but no curser. What am I going to have to do to not lose my work like this? Do a pulldown to "save-as" for every line I type? > Thanks all. > > Cheers, Gene Heskett Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Fri, Aug 13, 2021 2:35 PM
When I do a preview I see
Saved backup file:
C:/Users/ChrisP/Documents/OpenSCAD/backups/potbox-backup-lzLPeAGl.scad
So if OpenSCAD were to crash I would open that file to get any unsaved
changes.
On Fri, 13 Aug 2021 at 13:28, Gene Heskett gheskett@shentel.net wrote:
Greetings;
but must.
file.
Can anyone comment?
Thanks all.
When I do a preview I see Parsing design (AST generation)... Saved backup file: C:/Users/ChrisP/Documents/OpenSCAD/backups/potbox-backup-lzLPeAGl.scad So if OpenSCAD were to crash I would open that file to get any unsaved changes. On Fri, 13 Aug 2021 at 13:28, Gene Heskett <gheskett@shentel.net> wrote: > Greetings; > > I just had a crash after about 2 hours of work, rewriting a module that > was such a mess it should never have disturbed any spinning rust ever. > And I know I went thru the motions of saving what I had done quite a few > times, but when I re-open the file, with a new copy of the appimage, its > what I started with 2+ hours ago. Nothing had been saved. This is most > frustrating. And I don't care to have to re-invent a whole set of wheels > but must. > > Its likely too late now, but is there any way to restart OpenSCAD and > have it recover from the /tmp stuff it stores when last told to preview? > > This whole fiasco started because rotate_extrude() was refusing the > output of anything to the right of it in the comand line, a union > between a ball sphere and a vertical bar thru the middle of the ball, to > be used to insert the balls into the races, intended to be rotated into > a ball bearing race. And that used to cut a further track as the 3rd > argument of a difference. > > This now makes 2 different linux boxes that have been plagued by having > to back out of a directory and re-enter it in order to see the latest > save. cura, mc and openscad are all doing it. ext4 file systems, 2 > debian installs, stretch on this box and buster on the box I was working > on. I am beginning to think my mounts in /etc/fstab are duff, but if I > want to see a new save, I have to force a re-read of the directory. So I > don't think this loss of data is an OpenSCAD problem but a linux > problem. The rotate_extrude is working at another location in this same > file. > > Can anyone comment? > > Thanks all. > > Cheers, Gene Heskett > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > Genes Web page <http://geneslinuxbox.net:6309/gene> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
BL
Bryan Lee
Fri, Aug 13, 2021 2:58 PM
Hey Gene!
General Linux stuff:  you can use this command to find any files in your
home driectory (~) or /tmp that were modified in the last 60 minutes:
find ~ /tmp -mmin -60
If you have a different mount point, you can add that between the "find"
and the "-mmin".  Modify Time is "less than", indicated by the "-", 60
minutes old.
Where are you saving your file?  Somewhere in your home directory?
Somewhere else on the local disk?  Somewhere on a remotely mounted volume:
NFS, SSHFS, etc?
Thus Gene Heskett hast written on Fri, Aug 13, 2021 at 08:28:45AM -0400, and, according to prophecy, it shall come to pass that:
Hey Gene! General Linux stuff: you can use this command to find any files in your home driectory (~) or /tmp that were modified in the last 60 minutes: find ~ /tmp -mmin -60 If you have a different mount point, you can add that between the "find" and the "-mmin". Modify Time is "less than", indicated by the "-", 60 minutes old. Where are you saving your file? Somewhere in your home directory? Somewhere else on the local disk? Somewhere on a remotely mounted volume: NFS, SSHFS, etc? Thus Gene Heskett hast written on Fri, Aug 13, 2021 at 08:28:45AM -0400, and, according to prophecy, it shall come to pass that: > Its likely too late now, but is there any way to restart OpenSCAD and > have it recover from the /tmp stuff it stores when last told to preview?
Gene Heskett
Fri, Aug 13, 2021 6:07 PM
On Friday 13 August 2021 10:58:05 Bryan Lee wrote:
Hey Gene!
minutes:
Chuckle, but Bryan, I've been an mc user since my first red hat 5.0
install in 1998. I skipped the winders thing, learning just enough to
keep the first pc's we bought for the office help at WDTV where I was
the Chief for the last 19 years of my working life, coming up from
os9 on a color computer and amigados on a full blown amiga to red hat.
Old habits die hard. No winders allowed on the premises. But 6 linux
boxes run 24/7.
Today my back is demanding a decent chair, so I am logged into that
buster box from this stretch machine running the newest 07252021
openscad appimage on that machine and I'm wearing out the mouse doing
a save as every 2 or 3 characters. And I have arrived at something
that works as desired for a preview. Takes 2-3 seconds to show it
exactly like I want it to print on a Prusa mk3S.
But it doesn't render as anything but the first 2 of 4 items in a
difference scope. No advisories of any kind, my echo's look good,
but a F6 does not appear to get past the for loop that rotates the
last, effectively the third argument for the difference(). It says
the render done in just a fraction of a second. But it renders only
the first two lines of the differences scope.
Here is the .scad:
module armbearing()
// my feeble attempt at generating a ball bearing using bb's.
// NOW MODed for smaller drive, in ~/Dlds/3dp.stf/smaller-harmonic-drive
// armature is eccentric, 37.60mm min to 41.66mm max
// adjust india till it fits the armature when distorted by it.
// was 40.3 but in PETG fit is tighter
fg=.45; // some fudge for printeers over extrusion
vg=.20; //height of layer
india=38.385+fg; // in mm's of ID, inner should rotate with
// armature w/o walking
outdia=52.14-fg; // outer diameter, same as belt inner
height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of these
// everything below is generated center=true
// which means we're dealing in radius
ctr_ht=(height * .50000); // 1/2 height,mults are faster
inrad=india*.50000;  // rad of inner diameter
outrad=outdia*.5000;  // rad of outer diameter
bbtrkd=(outdia+india).5; // to center it
bbtrkr=(outrad+inrad)
.5; // ditto the radius
echo(198, inrad,outrad,bbtrkr,bbtrkd);
//adjust bearing size till it fits
bb=4.35+.2; // crosman bb so when inner is preloaded its about right. Was 4.45,
// slightly tight.
bbgap=.40; // wide enough to make inserting bb's easier
// how many bb's?
racircum=(inrad+outrad).50PI;//length of bb track
echo(205, PI, racircum);
bbs=racircum/bb;
echo(207,bb,bbs);
$fn=360;
// draw it
cylinder(h=height,d=outdia);// big outer for a base to sub everything else from
translate([0,0,-.05])cylinder(h=height+.1,d=india);// subtract inner
for(fn=[0:2:359]) // now cut ball track and insertion slot
rotate(fn)
union()
translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// subtract bb
// subtract bb insertion slot
translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])square(height+1,true);
And two snapshots attached, one from the F5/preview, and one from the F6/render.
The first, preview is the desired result.
I see the last two translates and rotates could be moved to after the union()
on its line which might speed the render, but by how much?
Thanks for any clues as to why it doesn't render like it previews.
On Friday 13 August 2021 10:58:05 Bryan Lee wrote: > Hey Gene! > > General Linux stuff: you can use this command to find any files in > your home driectory (~) or /tmp that were modified in the last 60 > minutes: Chuckle, but Bryan, I've been an mc user since my first red hat 5.0 install in 1998. I skipped the winders thing, learning just enough to keep the first pc's we bought for the office help at WDTV where I was the Chief for the last 19 years of my working life, coming up from os9 on a color computer and amigados on a full blown amiga to red hat. Old habits die hard. No winders allowed on the premises. But 6 linux boxes run 24/7. > find ~ /tmp -mmin -60 > > If you have a different mount point, you can add that between the > "find" and the "-mmin". Modify Time is "less than", indicated by the > "-", 60 minutes old. > > > Where are you saving your file? Somewhere in your home directory? > Somewhere else on the local disk? Somewhere on a remotely mounted > volume: NFS, SSHFS, etc? > Today my back is demanding a decent chair, so I am logged into that buster box from this stretch machine running the newest 07252021 openscad appimage on that machine and I'm wearing out the mouse doing a save as every 2 or 3 characters. And I have arrived at something that works as desired for a preview. Takes 2-3 seconds to show it exactly like I want it to print on a Prusa mk3S. But it doesn't render as anything but the first 2 of 4 items in a difference scope. No advisories of any kind, my echo's look good, but a F6 does not appear to get past the for loop that rotates the last, effectively the third argument for the difference(). It says the render done in just a fraction of a second. But it renders only the first two lines of the differences scope. Here is the .scad: module armbearing() { // my feeble attempt at generating a ball bearing using bb's. // NOW MODed for smaller drive, in ~/Dlds/3dp.stf/smaller-harmonic-drive // armature is eccentric, 37.60mm min to 41.66mm max // adjust india till it fits the armature when distorted by it. // was 40.3 but in PETG fit is tighter fg=.45; // some fudge for printeers over extrusion vg=.20; //height of layer india=38.385+fg; // in mm's of ID, inner should rotate with // armature w/o walking outdia=52.14-fg; // outer diameter, same as belt inner height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of these // everything below is generated center=true // which means we're dealing in radius ctr_ht=(height * .50000); // 1/2 height,mults are faster inrad=india*.50000; // rad of inner diameter outrad=outdia*.5000; // rad of outer diameter bbtrkd=(outdia+india)*.5; // to center it bbtrkr=(outrad+inrad)*.5; // ditto the radius echo(198, inrad,outrad,bbtrkr,bbtrkd); //adjust bearing size till it fits bb=4.35+.2; // crosman bb so when inner is preloaded its about right. Was 4.45, // slightly tight. bbgap=.40; // wide enough to make inserting bb's easier // how many bb's? racircum=(inrad+outrad)*.50*PI;//length of bb track echo(205, PI, racircum); bbs=racircum/bb; echo(207,bb,bbs); $fn=360; // draw it difference() { cylinder(h=height,d=outdia);// big outer for a base to sub everything else from translate([0,0,-.05])cylinder(h=height+.1,d=india);// subtract inner for(fn=[0:2:359]) // now cut ball track and insertion slot { rotate(fn) { union() { translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// subtract bb // subtract bb insertion slot translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])square(height+1,true); } } } } }; And two snapshots attached, one from the F5/preview, and one from the F6/render. The first, preview is the desired result. I see the last two translates and rotates could be moved to after the union() on its line which might speed the render, but by how much? Thanks for any clues as to why it doesn't render like it previews. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Michael Möller
Fri, Aug 13, 2021 6:26 PM
You're using 2D shapes circle/square ? they fake render in F5, but without
a extrude they do not appear in 3D  / F6.
Hey Gene!
minutes:
boxes run 24/7.
Here is the .scad:
module armbearing()
Was 4.45,
// slightly tight.
// how many bb's?
bbs=racircum/bb;
echo(207,bb,bbs);
$fn=360;
// draw it
inner
rotate(fn)
union()
F6/render.
union()
You're using 2D shapes circle/square ? they fake render in F5, but without a extrude they do not appear in 3D / F6. On Fri, 13 Aug 2021 at 20:08, Gene Heskett <gheskett@shentel.net> wrote: > On Friday 13 August 2021 10:58:05 Bryan Lee wrote: > > > Hey Gene! > > > > General Linux stuff: you can use this command to find any files in > > your home driectory (~) or /tmp that were modified in the last 60 > > minutes: > > Chuckle, but Bryan, I've been an mc user since my first red hat 5.0 > install in 1998. I skipped the winders thing, learning just enough to > keep the first pc's we bought for the office help at WDTV where I was > the Chief for the last 19 years of my working life, coming up from > os9 on a color computer and amigados on a full blown amiga to red hat. > > Old habits die hard. No winders allowed on the premises. But 6 linux > boxes run 24/7. > > > find ~ /tmp -mmin -60 > > > > If you have a different mount point, you can add that between the > > "find" and the "-mmin". Modify Time is "less than", indicated by the > > "-", 60 minutes old. > > > > > > Where are you saving your file? Somewhere in your home directory? > > Somewhere else on the local disk? Somewhere on a remotely mounted > > volume: NFS, SSHFS, etc? > > > Today my back is demanding a decent chair, so I am logged into that > buster box from this stretch machine running the newest 07252021 > openscad appimage on that machine and I'm wearing out the mouse doing > a save as every 2 or 3 characters. And I have arrived at something > that works as desired for a preview. Takes 2-3 seconds to show it > exactly like I want it to print on a Prusa mk3S. > > But it doesn't render as anything but the first 2 of 4 items in a > difference scope. No advisories of any kind, my echo's look good, > but a F6 does not appear to get past the for loop that rotates the > last, effectively the third argument for the difference(). It says > the render done in just a fraction of a second. But it renders only > the first two lines of the differences scope. > > Here is the .scad: > module armbearing() > { > // my feeble attempt at generating a ball bearing using bb's. > // NOW MODed for smaller drive, in ~/Dlds/3dp.stf/smaller-harmonic-drive > // armature is eccentric, 37.60mm min to 41.66mm max > // adjust india till it fits the armature when distorted by it. > // was 40.3 but in PETG fit is tighter > fg=.45; // some fudge for printeers over extrusion > vg=.20; //height of layer > india=38.385+fg; // in mm's of ID, inner should rotate with > // armature w/o walking > outdia=52.14-fg; // outer diameter, same as belt inner > height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of these > // everything below is generated center=true > // which means we're dealing in radius > ctr_ht=(height * .50000); // 1/2 height,mults are faster > inrad=india*.50000; // rad of inner diameter > outrad=outdia*.5000; // rad of outer diameter > bbtrkd=(outdia+india)*.5; // to center it > bbtrkr=(outrad+inrad)*.5; // ditto the radius > echo(198, inrad,outrad,bbtrkr,bbtrkd); > //adjust bearing size till it fits > bb=4.35+.2; // crosman bb so when inner is preloaded its about right. > Was 4.45, > // slightly tight. > bbgap=.40; // wide enough to make inserting bb's easier > // how many bb's? > racircum=(inrad+outrad)*.50*PI;//length of bb track > echo(205, PI, racircum); > bbs=racircum/bb; > echo(207,bb,bbs); > $fn=360; > // draw it > difference() > { > cylinder(h=height,d=outdia);// big outer for a base to sub > everything else from > translate([0,0,-.05])cylinder(h=height+.1,d=india);// subtract > inner > for(fn=[0:2:359]) // now cut ball track and insertion slot > { > rotate(fn) > { > union() > { > > translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// subtract bb > // subtract bb insertion slot > > translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])square(height+1,true); > } > } > } > } > }; > > And two snapshots attached, one from the F5/preview, and one from the > F6/render. > The first, preview is the desired result. > I see the last two translates and rotates could be moved to after the > union() > on its line which might speed the render, but by how much? > > Thanks for any clues as to why it doesn't render like it previews. > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > Genes Web page <http://geneslinuxbox.net:6309/gene> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Gene Heskett
Fri, Aug 13, 2021 6:46 PM
Replacements that work? rotate_extrude() can find more ways to refuse or
crash than websters has words. Most common is a seeming missmatch in
variable signs when their is not, even the error message showing the
allowable range has the same sign. But its bitching about that or any
one of the others. And doing it without identifying the the errant var
that caused the error.
Hey Gene!
60 minutes:
red hat.
boxes run 24/7.
Here is the .scad:
module armbearing()
right. Was 4.45,
// slightly tight.
// how many bb's?
bbs=racircum/bb;
echo(207,bb,bbs);
$fn=360;
// draw it
subtract inner
rotate(fn)
union()
ight+1,true); }
the F6/render.
the union()
Genes Web page http://geneslinuxbox.net:6309/gene
On Friday 13 August 2021 14:26:20 Michael Möller wrote: > You're using 2D shapes circle/square ? they fake render in F5, but > without a extrude they do not appear in 3D / F6. > Replacements that work? rotate_extrude() can find more ways to refuse or crash than websters has words. Most common is a seeming missmatch in variable signs when their is not, even the error message showing the allowable range has the same sign. But its bitching about that or any one of the others. And doing it without identifying the the errant var that caused the error. > On Fri, 13 Aug 2021 at 20:08, Gene Heskett <gheskett@shentel.net> wrote: > > On Friday 13 August 2021 10:58:05 Bryan Lee wrote: > > > Hey Gene! > > > > > > General Linux stuff: you can use this command to find any files > > > in your home driectory (~) or /tmp that were modified in the last > > > 60 minutes: > > > > Chuckle, but Bryan, I've been an mc user since my first red hat 5.0 > > install in 1998. I skipped the winders thing, learning just enough > > to keep the first pc's we bought for the office help at WDTV where I > > was the Chief for the last 19 years of my working life, coming up > > from os9 on a color computer and amigados on a full blown amiga to > > red hat. > > > > Old habits die hard. No winders allowed on the premises. But 6 linux > > boxes run 24/7. > > > > > find ~ /tmp -mmin -60 > > > > > > If you have a different mount point, you can add that between the > > > "find" and the "-mmin". Modify Time is "less than", indicated by > > > the "-", 60 minutes old. > > > > > > > > > Where are you saving your file? Somewhere in your home directory? > > > Somewhere else on the local disk? Somewhere on a remotely mounted > > > volume: NFS, SSHFS, etc? > > > > Today my back is demanding a decent chair, so I am logged into that > > buster box from this stretch machine running the newest 07252021 > > openscad appimage on that machine and I'm wearing out the mouse > > doing a save as every 2 or 3 characters. And I have arrived at > > something that works as desired for a preview. Takes 2-3 seconds to > > show it exactly like I want it to print on a Prusa mk3S. > > > > But it doesn't render as anything but the first 2 of 4 items in a > > difference scope. No advisories of any kind, my echo's look good, > > but a F6 does not appear to get past the for loop that rotates the > > last, effectively the third argument for the difference(). It says > > the render done in just a fraction of a second. But it renders only > > the first two lines of the differences scope. > > > > Here is the .scad: > > module armbearing() > > { > > // my feeble attempt at generating a ball bearing using bb's. > > // NOW MODed for smaller drive, in > > ~/Dlds/3dp.stf/smaller-harmonic-drive // armature is eccentric, > > 37.60mm min to 41.66mm max > > // adjust india till it fits the armature when distorted by it. > > // was 40.3 but in PETG fit is tighter > > fg=.45; // some fudge for printeers over extrusion > > vg=.20; //height of layer > > india=38.385+fg; // in mm's of ID, inner should rotate with > > // armature w/o walking > > outdia=52.14-fg; // outer diameter, same as belt inner > > height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of > > these // everything below is generated center=true > > // which means we're dealing in radius > > ctr_ht=(height * .50000); // 1/2 height,mults are faster > > inrad=india*.50000; // rad of inner diameter > > outrad=outdia*.5000; // rad of outer diameter > > bbtrkd=(outdia+india)*.5; // to center it > > bbtrkr=(outrad+inrad)*.5; // ditto the radius > > echo(198, inrad,outrad,bbtrkr,bbtrkd); > > //adjust bearing size till it fits > > bb=4.35+.2; // crosman bb so when inner is preloaded its about > > right. Was 4.45, > > // slightly tight. > > bbgap=.40; // wide enough to make inserting bb's easier > > // how many bb's? > > racircum=(inrad+outrad)*.50*PI;//length of bb track > > echo(205, PI, racircum); > > bbs=racircum/bb; > > echo(207,bb,bbs); > > $fn=360; > > // draw it > > difference() > > { > > cylinder(h=height,d=outdia);// big outer for a base to sub > > everything else from > > translate([0,0,-.05])cylinder(h=height+.1,d=india);// > > subtract inner > > for(fn=[0:2:359]) // now cut ball track and insertion slot > > { > > rotate(fn) > > { > > union() > > { > > > > translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// subtract > > bb // subtract bb insertion slot > > > > translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])square(he > >ight+1,true); } > > } > > } > > } > > }; > > > > And two snapshots attached, one from the F5/preview, and one from > > the F6/render. > > The first, preview is the desired result. > > I see the last two translates and rotates could be moved to after > > the union() > > on its line which might speed the render, but by how much? > > > > Thanks for any clues as to why it doesn't render like it previews. > > -- > > "There are four boxes to be used in defense of liberty: > > soap, ballot, jury, and ammo. Please use in that order." > > -Ed Howdershelt (Author) > > If we desire respect for the law, we must first make the law > > respectable. - Louis D. Brandeis > > Genes Web page <http://geneslinuxbox.net:6309/gene> > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Fri, Aug 13, 2021 7:28 PM
Rotate_extrude doesn't like singularities in the centre. You can't have
negative X coordinates but you can have a shape that hits the X axis but it
must be more than a single point, i.e an edge.
Hey Gene!
60 minutes:
red hat.
boxes run 24/7.
Here is the .scad:
module armbearing()
right. Was 4.45,
// slightly tight.
// how many bb's?
bbs=racircum/bb;
echo(207,bb,bbs);
$fn=360;
// draw it
subtract inner
rotate(fn)
union()
ight+1,true); }
the F6/render.
the union()
Rotate_extrude doesn't like singularities in the centre. You can't have negative X coordinates but you can have a shape that hits the X axis but it must be more than a single point, i.e an edge. On Fri, 13 Aug 2021 at 19:46, Gene Heskett <gheskett@shentel.net> wrote: > On Friday 13 August 2021 14:26:20 Michael Möller wrote: > > > You're using 2D shapes circle/square ? they fake render in F5, but > > without a extrude they do not appear in 3D / F6. > > > Replacements that work? rotate_extrude() can find more ways to refuse or > crash than websters has words. Most common is a seeming missmatch in > variable signs when their is not, even the error message showing the > allowable range has the same sign. But its bitching about that or any > one of the others. And doing it without identifying the the errant var > that caused the error. > > > On Fri, 13 Aug 2021 at 20:08, Gene Heskett <gheskett@shentel.net> > wrote: > > > On Friday 13 August 2021 10:58:05 Bryan Lee wrote: > > > > Hey Gene! > > > > > > > > General Linux stuff: you can use this command to find any files > > > > in your home driectory (~) or /tmp that were modified in the last > > > > 60 minutes: > > > > > > Chuckle, but Bryan, I've been an mc user since my first red hat 5.0 > > > install in 1998. I skipped the winders thing, learning just enough > > > to keep the first pc's we bought for the office help at WDTV where I > > > was the Chief for the last 19 years of my working life, coming up > > > from os9 on a color computer and amigados on a full blown amiga to > > > red hat. > > > > > > Old habits die hard. No winders allowed on the premises. But 6 linux > > > boxes run 24/7. > > > > > > > find ~ /tmp -mmin -60 > > > > > > > > If you have a different mount point, you can add that between the > > > > "find" and the "-mmin". Modify Time is "less than", indicated by > > > > the "-", 60 minutes old. > > > > > > > > > > > > Where are you saving your file? Somewhere in your home directory? > > > > Somewhere else on the local disk? Somewhere on a remotely mounted > > > > volume: NFS, SSHFS, etc? > > > > > > Today my back is demanding a decent chair, so I am logged into that > > > buster box from this stretch machine running the newest 07252021 > > > openscad appimage on that machine and I'm wearing out the mouse > > > doing a save as every 2 or 3 characters. And I have arrived at > > > something that works as desired for a preview. Takes 2-3 seconds to > > > show it exactly like I want it to print on a Prusa mk3S. > > > > > > But it doesn't render as anything but the first 2 of 4 items in a > > > difference scope. No advisories of any kind, my echo's look good, > > > but a F6 does not appear to get past the for loop that rotates the > > > last, effectively the third argument for the difference(). It says > > > the render done in just a fraction of a second. But it renders only > > > the first two lines of the differences scope. > > > > > > Here is the .scad: > > > module armbearing() > > > { > > > // my feeble attempt at generating a ball bearing using bb's. > > > // NOW MODed for smaller drive, in > > > ~/Dlds/3dp.stf/smaller-harmonic-drive // armature is eccentric, > > > 37.60mm min to 41.66mm max > > > // adjust india till it fits the armature when distorted by it. > > > // was 40.3 but in PETG fit is tighter > > > fg=.45; // some fudge for printeers over extrusion > > > vg=.20; //height of layer > > > india=38.385+fg; // in mm's of ID, inner should rotate with > > > // armature w/o walking > > > outdia=52.14-fg; // outer diameter, same as belt inner > > > height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of > > > these // everything below is generated center=true > > > // which means we're dealing in radius > > > ctr_ht=(height * .50000); // 1/2 height,mults are faster > > > inrad=india*.50000; // rad of inner diameter > > > outrad=outdia*.5000; // rad of outer diameter > > > bbtrkd=(outdia+india)*.5; // to center it > > > bbtrkr=(outrad+inrad)*.5; // ditto the radius > > > echo(198, inrad,outrad,bbtrkr,bbtrkd); > > > //adjust bearing size till it fits > > > bb=4.35+.2; // crosman bb so when inner is preloaded its about > > > right. Was 4.45, > > > // slightly tight. > > > bbgap=.40; // wide enough to make inserting bb's easier > > > // how many bb's? > > > racircum=(inrad+outrad)*.50*PI;//length of bb track > > > echo(205, PI, racircum); > > > bbs=racircum/bb; > > > echo(207,bb,bbs); > > > $fn=360; > > > // draw it > > > difference() > > > { > > > cylinder(h=height,d=outdia);// big outer for a base to sub > > > everything else from > > > translate([0,0,-.05])cylinder(h=height+.1,d=india);// > > > subtract inner > > > for(fn=[0:2:359]) // now cut ball track and insertion slot > > > { > > > rotate(fn) > > > { > > > union() > > > { > > > > > > translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// subtract > > > bb // subtract bb insertion slot > > > > > > translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])square(he > > >ight+1,true); } > > > } > > > } > > > } > > > }; > > > > > > And two snapshots attached, one from the F5/preview, and one from > > > the F6/render. > > > The first, preview is the desired result. > > > I see the last two translates and rotates could be moved to after > > > the union() > > > on its line which might speed the render, but by how much? > > > > > > Thanks for any clues as to why it doesn't render like it previews. > > > -- > > > "There are four boxes to be used in defense of liberty: > > > soap, ballot, jury, and ammo. Please use in that order." > > > -Ed Howdershelt (Author) > > > If we desire respect for the law, we must first make the law > > > respectable. - Louis D. Brandeis > > > Genes Web page <http://geneslinuxbox.net:6309/gene> > > > _______________________________________________ > > > OpenSCAD mailing list > > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > Cheers, Gene Heskett > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > Genes Web page <http://geneslinuxbox.net:6309/gene> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Gene Heskett
Fri, Aug 13, 2021 8:45 PM
With the exception of the originating cylinder with an ending true, there
are offsets in the 30mm range applied long before it gets anywhere near
the rotate_extrude(). Using rotate and a for loop I now have something
that may work, except the blue text has said 999/1000 now for a good 30
minutes. It finally got done but did not report the elapsed time. I made
a couple changes that should have sped it up, but didn't.
Is there a give up and show what it has timer?
Hey Gene!
Prusa mk3S.
differences scope.
Here is the .scad:
module armbearing()
// slightly tight.
// how many bb's?
bbs=racircum/bb;
echo(207,bb,bbs);
$fn=360;
// draw it
subtract inner
slot {
rotate(fn)
union()
e(he ight+1,true); }
from the F6/render.
after the union()
previews. --
On Friday 13 August 2021 15:28:35 nop head wrote: > Rotate_extrude doesn't like singularities in the centre. You can't > have negative X coordinates but you can have a shape that hits the X > axis but it must be more than a single point, i.e an edge. With the exception of the originating cylinder with an ending true, there are offsets in the 30mm range applied long before it gets anywhere near the rotate_extrude(). Using rotate and a for loop I now have something that may work, except the blue text has said 999/1000 now for a good 30 minutes. It finally got done but did not report the elapsed time. I made a couple changes that should have sped it up, but didn't. Is there a give up and show what it has timer? > On Fri, 13 Aug 2021 at 19:46, Gene Heskett <gheskett@shentel.net> wrote: > > On Friday 13 August 2021 14:26:20 Michael Möller wrote: > > > You're using 2D shapes circle/square ? they fake render in F5, but > > > without a extrude they do not appear in 3D / F6. > > > > Replacements that work? rotate_extrude() can find more ways to > > refuse or crash than websters has words. Most common is a seeming > > missmatch in variable signs when their is not, even the error > > message showing the allowable range has the same sign. But its > > bitching about that or any one of the others. And doing it without > > identifying the the errant var that caused the error. > > > > > On Fri, 13 Aug 2021 at 20:08, Gene Heskett <gheskett@shentel.net> > > > > wrote: > > > > On Friday 13 August 2021 10:58:05 Bryan Lee wrote: > > > > > Hey Gene! > > > > > > > > > > General Linux stuff: you can use this command to find any > > > > > files in your home driectory (~) or /tmp that were modified in > > > > > the last 60 minutes: > > > > > > > > Chuckle, but Bryan, I've been an mc user since my first red hat > > > > 5.0 install in 1998. I skipped the winders thing, learning just > > > > enough to keep the first pc's we bought for the office help at > > > > WDTV where I was the Chief for the last 19 years of my working > > > > life, coming up from os9 on a color computer and amigados on a > > > > full blown amiga to red hat. > > > > > > > > Old habits die hard. No winders allowed on the premises. But 6 > > > > linux boxes run 24/7. > > > > > > > > > find ~ /tmp -mmin -60 > > > > > > > > > > If you have a different mount point, you can add that between > > > > > the "find" and the "-mmin". Modify Time is "less than", > > > > > indicated by the "-", 60 minutes old. > > > > > > > > > > > > > > > Where are you saving your file? Somewhere in your home > > > > > directory? Somewhere else on the local disk? Somewhere on a > > > > > remotely mounted volume: NFS, SSHFS, etc? > > > > > > > > Today my back is demanding a decent chair, so I am logged into > > > > that buster box from this stretch machine running the newest > > > > 07252021 openscad appimage on that machine and I'm wearing out > > > > the mouse doing a save as every 2 or 3 characters. And I have > > > > arrived at something that works as desired for a preview. Takes > > > > 2-3 seconds to show it exactly like I want it to print on a > > > > Prusa mk3S. > > > > > > > > But it doesn't render as anything but the first 2 of 4 items in > > > > a difference scope. No advisories of any kind, my echo's look > > > > good, but a F6 does not appear to get past the for loop that > > > > rotates the last, effectively the third argument for the > > > > difference(). It says the render done in just a fraction of a > > > > second. But it renders only the first two lines of the > > > > differences scope. > > > > > > > > Here is the .scad: > > > > module armbearing() > > > > { > > > > // my feeble attempt at generating a ball bearing using bb's. > > > > // NOW MODed for smaller drive, in > > > > ~/Dlds/3dp.stf/smaller-harmonic-drive // armature is eccentric, > > > > 37.60mm min to 41.66mm max > > > > // adjust india till it fits the armature when distorted by it. > > > > // was 40.3 but in PETG fit is tighter > > > > fg=.45; // some fudge for printeers over extrusion > > > > vg=.20; //height of layer > > > > india=38.385+fg; // in mm's of ID, inner should rotate with > > > > // armature w/o walking > > > > outdia=52.14-fg; // outer diameter, same as belt inner > > > > height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of > > > > these // everything below is generated center=true > > > > // which means we're dealing in radius > > > > ctr_ht=(height * .50000); // 1/2 height,mults are faster > > > > inrad=india*.50000; // rad of inner diameter > > > > outrad=outdia*.5000; // rad of outer diameter > > > > bbtrkd=(outdia+india)*.5; // to center it > > > > bbtrkr=(outrad+inrad)*.5; // ditto the radius > > > > echo(198, inrad,outrad,bbtrkr,bbtrkd); > > > > //adjust bearing size till it fits > > > > bb=4.35+.2; // crosman bb so when inner is preloaded its > > > > about right. Was 4.45, > > > > // slightly tight. > > > > bbgap=.40; // wide enough to make inserting bb's easier > > > > // how many bb's? > > > > racircum=(inrad+outrad)*.50*PI;//length of bb track > > > > echo(205, PI, racircum); > > > > bbs=racircum/bb; > > > > echo(207,bb,bbs); > > > > $fn=360; > > > > // draw it > > > > difference() > > > > { > > > > cylinder(h=height,d=outdia);// big outer for a base to > > > > sub everything else from > > > > translate([0,0,-.05])cylinder(h=height+.1,d=india);// > > > > subtract inner > > > > for(fn=[0:2:359]) // now cut ball track and insertion > > > > slot { > > > > rotate(fn) > > > > { > > > > union() > > > > { > > > > > > > > translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// > > > > subtract bb // subtract bb insertion slot > > > > > > > > translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])squar > > > >e(he ight+1,true); } > > > > } > > > > } > > > > } > > > > }; > > > > > > > > And two snapshots attached, one from the F5/preview, and one > > > > from the F6/render. > > > > The first, preview is the desired result. > > > > I see the last two translates and rotates could be moved to > > > > after the union() > > > > on its line which might speed the render, but by how much? > > > > > > > > Thanks for any clues as to why it doesn't render like it > > > > previews. -- > > > > "There are four boxes to be used in defense of liberty: > > > > soap, ballot, jury, and ammo. Please use in that order." > > > > -Ed Howdershelt (Author) > > > > If we desire respect for the law, we must first make the law > > > > respectable. - Louis D. Brandeis > > > > Genes Web page <http://geneslinuxbox.net:6309/gene> > > > > _______________________________________________ > > > > OpenSCAD mailing list > > > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > > Cheers, Gene Heskett > > -- > > "There are four boxes to be used in defense of liberty: > > soap, ballot, jury, and ammo. Please use in that order." > > -Ed Howdershelt (Author) > > If we desire respect for the law, we must first make the law > > respectable. - Louis D. Brandeis > > Genes Web page <http://geneslinuxbox.net:6309/gene> > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Michael Möller
Fri, Aug 13, 2021 8:51 PM
Gene: When you use a circle() as an object to do difference on a cylinder()
... you are subtracting a 2D object from a 3D object. "Does not Compute"
and crash bang. The preview does a nice thing "For Your Convinience" and
turns the circle into a 1mm cylinder. Thus the F5 looks good. The F6
however does things "By the book" and thus finds itself with conflicting
domain and hits a wall.
Do just a
circle(10);
and in F5 and F6 it shows the circle as a a cylinder or a"blue shadow",
respectively.
So, I've played with your code, and it will work (meaning F6 will render
the same as the F5 preview) if you change the circle to cylinder and square
to cube and give them - say - h=1 height. Rendering time isnt speedy,
admittedly.
Hey Gene!
60 minutes:
red hat.
boxes run 24/7.
Here is the .scad:
module armbearing()
right. Was 4.45,
// slightly tight.
// how many bb's?
bbs=racircum/bb;
echo(207,bb,bbs);
$fn=360;
// draw it
subtract inner
rotate(fn)
union()
ight+1,true); }
the F6/render.
the union()
Gene: When you use a circle() as an object to do difference on a cylinder() ... you are subtracting a 2D object from a 3D object. "Does not Compute" and crash bang. The preview does a nice thing "For Your Convinience" and turns the circle into a 1mm cylinder. Thus the F5 looks good. The F6 however does things "By the book" and thus finds itself with conflicting domain and hits a wall. Do just a circle(10); and in F5 and F6 it shows the circle as a a cylinder or a"blue shadow", respectively. So, I've played with your code, and it will work (meaning F6 will render the same as the F5 preview) if you change the circle to cylinder and square to cube and give them - say - h=1 height. Rendering time isnt speedy, admittedly. On Fri, 13 Aug 2021 at 21:30, nop head <nop.head@gmail.com> wrote: > Rotate_extrude doesn't like singularities in the centre. You can't have > negative X coordinates but you can have a shape that hits the X axis but it > must be more than a single point, i.e an edge. > > On Fri, 13 Aug 2021 at 19:46, Gene Heskett <gheskett@shentel.net> wrote: > >> On Friday 13 August 2021 14:26:20 Michael Möller wrote: >> >> > You're using 2D shapes circle/square ? they fake render in F5, but >> > without a extrude they do not appear in 3D / F6. >> > >> Replacements that work? rotate_extrude() can find more ways to refuse or >> crash than websters has words. Most common is a seeming missmatch in >> variable signs when their is not, even the error message showing the >> allowable range has the same sign. But its bitching about that or any >> one of the others. And doing it without identifying the the errant var >> that caused the error. >> >> > On Fri, 13 Aug 2021 at 20:08, Gene Heskett <gheskett@shentel.net> >> wrote: >> > > On Friday 13 August 2021 10:58:05 Bryan Lee wrote: >> > > > Hey Gene! >> > > > >> > > > General Linux stuff: you can use this command to find any files >> > > > in your home driectory (~) or /tmp that were modified in the last >> > > > 60 minutes: >> > > >> > > Chuckle, but Bryan, I've been an mc user since my first red hat 5.0 >> > > install in 1998. I skipped the winders thing, learning just enough >> > > to keep the first pc's we bought for the office help at WDTV where I >> > > was the Chief for the last 19 years of my working life, coming up >> > > from os9 on a color computer and amigados on a full blown amiga to >> > > red hat. >> > > >> > > Old habits die hard. No winders allowed on the premises. But 6 linux >> > > boxes run 24/7. >> > > >> > > > find ~ /tmp -mmin -60 >> > > > >> > > > If you have a different mount point, you can add that between the >> > > > "find" and the "-mmin". Modify Time is "less than", indicated by >> > > > the "-", 60 minutes old. >> > > > >> > > > >> > > > Where are you saving your file? Somewhere in your home directory? >> > > > Somewhere else on the local disk? Somewhere on a remotely mounted >> > > > volume: NFS, SSHFS, etc? >> > > >> > > Today my back is demanding a decent chair, so I am logged into that >> > > buster box from this stretch machine running the newest 07252021 >> > > openscad appimage on that machine and I'm wearing out the mouse >> > > doing a save as every 2 or 3 characters. And I have arrived at >> > > something that works as desired for a preview. Takes 2-3 seconds to >> > > show it exactly like I want it to print on a Prusa mk3S. >> > > >> > > But it doesn't render as anything but the first 2 of 4 items in a >> > > difference scope. No advisories of any kind, my echo's look good, >> > > but a F6 does not appear to get past the for loop that rotates the >> > > last, effectively the third argument for the difference(). It says >> > > the render done in just a fraction of a second. But it renders only >> > > the first two lines of the differences scope. >> > > >> > > Here is the .scad: >> > > module armbearing() >> > > { >> > > // my feeble attempt at generating a ball bearing using bb's. >> > > // NOW MODed for smaller drive, in >> > > ~/Dlds/3dp.stf/smaller-harmonic-drive // armature is eccentric, >> > > 37.60mm min to 41.66mm max >> > > // adjust india till it fits the armature when distorted by it. >> > > // was 40.3 but in PETG fit is tighter >> > > fg=.45; // some fudge for printeers over extrusion >> > > vg=.20; //height of layer >> > > india=38.385+fg; // in mm's of ID, inner should rotate with >> > > // armature w/o walking >> > > outdia=52.14-fg; // outer diameter, same as belt inner >> > > height=6-vg; // in mm's, armature is 11.5 mm wide uses 2 of >> > > these // everything below is generated center=true >> > > // which means we're dealing in radius >> > > ctr_ht=(height * .50000); // 1/2 height,mults are faster >> > > inrad=india*.50000; // rad of inner diameter >> > > outrad=outdia*.5000; // rad of outer diameter >> > > bbtrkd=(outdia+india)*.5; // to center it >> > > bbtrkr=(outrad+inrad)*.5; // ditto the radius >> > > echo(198, inrad,outrad,bbtrkr,bbtrkd); >> > > //adjust bearing size till it fits >> > > bb=4.35+.2; // crosman bb so when inner is preloaded its about >> > > right. Was 4.45, >> > > // slightly tight. >> > > bbgap=.40; // wide enough to make inserting bb's easier >> > > // how many bb's? >> > > racircum=(inrad+outrad)*.50*PI;//length of bb track >> > > echo(205, PI, racircum); >> > > bbs=racircum/bb; >> > > echo(207,bb,bbs); >> > > $fn=360; >> > > // draw it >> > > difference() >> > > { >> > > cylinder(h=height,d=outdia);// big outer for a base to sub >> > > everything else from >> > > translate([0,0,-.05])cylinder(h=height+.1,d=india);// >> > > subtract inner >> > > for(fn=[0:2:359]) // now cut ball track and insertion slot >> > > { >> > > rotate(fn) >> > > { >> > > union() >> > > { >> > > >> > > translate([bbtrkr,0,3])rotate([90,0,0])circle(d=bb,true);// subtract >> > > bb // subtract bb insertion slot >> > > >> > > translate([bbtrkr,0,3])rotate([90,0,0])scale([bbgap,1,1.1])square(he >> > >ight+1,true); } >> > > } >> > > } >> > > } >> > > }; >> > > >> > > And two snapshots attached, one from the F5/preview, and one from >> > > the F6/render. >> > > The first, preview is the desired result. >> > > I see the last two translates and rotates could be moved to after >> > > the union() >> > > on its line which might speed the render, but by how much? >> > > >> > > Thanks for any clues as to why it doesn't render like it previews. >> > > -- >> > > "There are four boxes to be used in defense of liberty: >> > > soap, ballot, jury, and ammo. Please use in that order." >> > > -Ed Howdershelt (Author) >> > > If we desire respect for the law, we must first make the law >> > > respectable. - Louis D. Brandeis >> > > Genes Web page <http://geneslinuxbox.net:6309/gene> >> > > _______________________________________________ >> > > OpenSCAD mailing list >> > > To unsubscribe send an email to discuss-leave@lists.openscad.org >> >> >> Cheers, Gene Heskett >> -- >> "There are four boxes to be used in defense of liberty: >> soap, ballot, jury, and ammo. Please use in that order." >> -Ed Howdershelt (Author) >> If we desire respect for the law, we must first make the law respectable. >> - Louis D. Brandeis >> Genes Web page <http://geneslinuxbox.net:6309/gene> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
