PC
Patrick Callahan
Tue, Nov 23, 2021 10:16 PM
The big thing that's missing is the ability to construct an object from an
OpenSCAD program. I believe that the expectation is that that will look
something like
o = {
a = 5;
b = 6;
Then there should probably be some other stuff like union, difference and
intersection. Maybe some kind of "object comprehension" that would let you
construct an object in the same sort of way that a list comprehension lets
you construct lists.
Just having the ability to create the object, pass it to a module or
function, and reference the contents by o.a or o.b would be a big win. It
would reduce the need to create constructor and access functions for every
aspect of a feature.
How can I help?
-Pat
Note that this reply is bottom-posted.
If using Gmail's web app, click the three dots immediately after hitting
reply, place cursor at bottom. Easy!
> something like
> o = {
> a = 5;
> b = 6;
How can I help?
-Pat
Wed, Nov 24, 2021 5:30 PM
On 23.11.21 23:16, Patrick Callahan wrote:
Discussion about objects is here:
https://github.com/openscad/openscad/pull/3087
https://github.com/openscad/openscad/issues/3088
This is based on the OpenSCAD2 proposal Doug made some
time ago. The topic is a bit dormant, but as Jordan
wrote, the some internal parts of the objects are now
already present in the dev snapshots and used by the
text/fontmetrics calls.
Also note that other parts of the OpenSCAD2 proposal
are already released, like the function literals.
In my view, it's not meant as big bang change, like
the python2 -> python3 process. Instead it's a guide
for improvement.
> How can I help?
for improvement.
PC
Patrick Callahan
Wed, Nov 24, 2021 6:30 PM
for improvement.
> > How can I help?
> for improvement.
> ciao,
> Torsten.
PC
Patrick Callahan
Wed, Nov 24, 2021 7:08 PM
Ok Read all that.
I understand some of the software language engineering issues raised and
that parts of the OpenScad2 proposal are moving forward even if OpenSCAD2
as a whole is not.
What do function literals allow me to do that I could not do without them?
I can see what they are but can't see beyond that.
For what hat are they suitable? I'm not clear on how to think about coding
with them.
for improvement.
Yup. There's a lot of discussion of various points on the proposal
itself, issue threads, and pull requests, and I'm reading more before
commenting further. Expect questions though.
> > How can I help?
> <snip>
Ok Read all that.
as a whole is not.
with them.
> for improvement.
Wed, Nov 24, 2021 7:13 PM
Function literals allow you to store function references in valuables and
pass them as parameters. So for example you could have a quicksort routine
and pass a function to do the comparison.
On Wed, 24 Nov 2021 at 19:09, Patrick Callahan pat.callahan1@gmail.com
Ok Read all that.
as a whole is not.
coding with them.
for improvement.
On Wed, 24 Nov 2021 at 19:09, Patrick Callahan <pat.callahan1@gmail.com>
>> > How can I help?
>> <snip>
> Ok Read all that.
> as a whole is not.
> coding with them.
>> for improvement.
Wed, Nov 24, 2021 7:59 PM
think about coding with them.
Passing functions to other functions or modules allows
for quite powerful library style functions, e.g. fold()
that give the caller influence of calculation details.
fold = function(i, v, f, off = 0) len(v) > off ? fold(f(i, v[off]), v, f, off + 1) : i;
v = [1, 2, 7, 4, -5];
f_add = function(x, y) x + y;
f_mul = function(x, y) x * y;
f_min = function(x, y) is_undef(x) ? y : min(x, y);
f_max = function(x, y) is_undef(x) ? y : max(x, y);
echo(add = fold(0, v, f_add)); // ECHO: add = 9
echo(mul = fold(1, v, f_mul)); // ECHO: mul = -280
echo(min = fold(undef, v, f_min)) // ECHO: -5
echo(max = fold(undef, v, f_max)) // ECHO: 7
More examples: https://github.com/thehans/funcutils
PC
Patrick Callahan
Thu, Nov 25, 2021 1:52 AM
I've looked through https://github.com/thehans/funcutils.
Now, after looking through the documentation and function definitions in a
few of the modules, I wonder how the utility functions defined in the
funcutils library help when one uses them in an OpenSCAD program.
I know this question exhibits my lack of background in functional
programming.
-Pat
I wonder when functional programming will start to click for me.
off + 1) : i;
programming.
-Pat
> off + 1) : i;
> ciao,
> Torsten.
FH
Father Horton
Thu, Nov 25, 2021 4:01 AM
It took several tries for it to click. XSLT is the first functional
language I encountered and it took me forever to get it. It didn’t help
that one of the free books I looked at on Amazon did its level best to use
it as an imperative language.
On Wed, Nov 24, 2021 at 7:52 PM Patrick Callahan pat.callahan1@gmail.com
programming.
-Pat
off + 1) : i;
On Wed, Nov 24, 2021 at 7:52 PM Patrick Callahan <pat.callahan1@gmail.com>
> programming.
> -Pat
>> off + 1) : i;
>> ciao,
>> Torsten.
PC
Patrick Callahan
Fri, Nov 26, 2021 12:38 PM
My code looks as imperative as possible. That For statement is my
downfall, even if it is used in a functional way.
It's been said that OpenScad is a functional language. Is it?
Can you do this?
Array(10).fill("functional programming is not a religion")
.map((msg) => {
console.log(msg);
return msg;
Sorry about the impure thoughts Father Horton, see you next Saturday...
On Thu, Nov 25, 2021 at 2:17 AM Father Horton fatherhorton@gmail.com
a few of the modules, I wonder how the utility functions defined in the
programming.
-Pat
f, off + 1) : i;
Can you do this?
.map((msg) => {
console.log(msg);
return msg;
On Thu, Nov 25, 2021 at 2:17 AM Father Horton <fatherhorton@gmail.com>
>> programming.
>> -Pat
>>> f, off + 1) : i;
>>> ciao,
>>> Torsten.
Fri, Nov 26, 2021 1:32 PM
On 26.11.21 13:38, Patrick Callahan wrote:
Sure, but why?
array = [ for (msg = [ for ([0:9]) "blah" ]) echo(msg) msg ];
> Can you do this?
Sure, but why?
