Hey Everyone,
Has anyone looked into using libigl as a (partial) CGAL replacement for 3D
boolean op's and mesh manipulations?
http://libigl.github.io/libigl/
https://github.com/libigl/libigl
http://www.alecjacobson.com/weblog/?tag=libigl
Looks to be quite powerful!
Andrew.
View this message in context: http://forum.openscad.org/libigl-anyone-poked-at-it-for-CGAL-partial-replacement-tp14769.html
This appears to use CGAL and Cork to implement boolean operations.
https://github.com/gilbo/cork
They mention that Cork is available as an alternative: it is faster, but
not always robust.
On 26 November 2015 at 15:38, clothbot andrew@plumb.org wrote:
Hey Everyone,
Andrew.
Cork is an unfinished project (still in the research phase) with 1
contributor; development stopped 3 years ago.
When libigl uses CGAL, it uses infinite precision rationals, just like
OpenSCAD.
not always robust.
Hey Everyone,
Andrew.
Ah, so it does:
https://github.com/libigl/libigl/blob/master/tutorial/609_Boolean/main.cpp https://github.com/libigl/libigl/blob/master/tutorial/609_Boolean/main.cpp
https://github.com/libigl/libigl/blob/master/include/igl/copyleft/boolean/mesh_boolean.cpp https://github.com/libigl/libigl/blob/master/include/igl/copyleft/boolean/mesh_boolean.cpp
On the plus side, looks like the meshes going into the operations and coming out are Eigen data constructs, so it may be easier to parallelize the operations and faster non-CSG mesh transforms (translate, rotate, etc.).
Something to play with…
Andrew.
https://github.com/gilbo/cork https://github.com/gilbo/cork
They mention that Cork is available as an alternative: it is faster, but not always robust.
On 26 November 2015 at 15:38, clothbot <andrew@plumb.org mailto:andrew@plumb.org> wrote:
Hey Everyone,
http://libigl.github.io/libigl/ http://libigl.github.io/libigl/
https://github.com/libigl/libigl https://github.com/libigl/libigl
http://www.alecjacobson.com/weblog/?tag=libigl http://www.alecjacobson.com/weblog/?tag=libigl
Andrew.
View this message in context: http://forum.openscad.org/libigl-anyone-poked-at-it-for-CGAL-partial-replacement-tp14769.html http://forum.openscad.org/libigl-anyone-poked-at-it-for-CGAL-partial-replacement-tp14769.html
"The future is already here. It's just not very evenly distributed" -- William Gibson
Yes, but the "Eigen data constructs" (I don't understand this yet) use
floating point representation, and the conversion from CGAL to native
representation can result in an invalid mesh. This is mentioned in the
tutorial. Therefore, I don't see how we can use this: it's not robust.
What I think we want is a robust CSG geometry engine that works with
floating point meshes. This is extremely difficult to program correctly,
because you have to repair damage to the mesh caused by transformations,
deal with floating point instability, and so on, and there are a lot of
tricky edge cases. I'd be looking for a well-exercised engine with about 20
years worth of development and maintenance, and definitely not a
single-person project with only a year or two of work done.
On 26 November 2015 at 17:43, Andrew Plumb andrew@plumb.org wrote:
Ah, so it does:
Andrew.
not always robust.
Hey Everyone,
Andrew.
Sent from the OpenSCAD mailing list archive at Nabble.com
http://nabble.com.
William Gibson
This may not be what you are looking for but its worth considering.
It is a voxel based csg tree system with mesh import and export. You create
shapes as voxel grids and then it can perform csg operations on them, it
uses a sparse storage mechanism so its effectivly only storing the surface
voxels amd thier relationships.
Ah, so it does:
Andrew.
not always robust.
Hey Everyone,
3D
Andrew.
http://nabble.com.
William Gibson
Ooooh! Very interesting!
http://www.openvdb.org/download/ http://www.openvdb.org/download/
https://github.com/dreamworksanimation/openvdb https://github.com/dreamworksanimation/openvdb
Even has python hooks: https://github.com/dreamworksanimation/openvdb/tree/master/openvdb/python https://github.com/dreamworksanimation/openvdb/tree/master/openvdb/python
Definitely going to be exploring that for a bit!
Andrew.
On Nov 26, 2015, at 10:16 PM, Tim Hawkins tim.thawkins@gmail.com wrote:
http://www.openvdb.org http://www.openvdb.org/
It is a voxel based csg tree system with mesh import and export. You create shapes as voxel grids and then it can perform csg operations on them, it uses a sparse storage mechanism so its effectivly only storing the surface voxels amd thier relationships.
On Fri, Nov 27, 2015, 07:40 doug moen <doug@moens.org mailto:doug@moens.org> wrote:
Yes, but the "Eigen data constructs" (I don't understand this yet) use floating point representation, and the conversion from CGAL to native representation can result in an invalid mesh. This is mentioned in the tutorial. Therefore, I don't see how we can use this: it's not robust.
What I think we want is a robust CSG geometry engine that works with floating point meshes. This is extremely difficult to program correctly, because you have to repair damage to the mesh caused by transformations, deal with floating point instability, and so on, and there are a lot of tricky edge cases. I'd be looking for a well-exercised engine with about 20 years worth of development and maintenance, and definitely not a single-person project with only a year or two of work done.
On 26 November 2015 at 17:43, Andrew Plumb <andrew@plumb.org mailto:andrew@plumb.org> wrote:
Ah, so it does:
Andrew.
On Nov 26, 2015, at 3:51 PM, doug moen <doug@moens.org mailto:doug@moens.org> wrote:
Hey Everyone,
Andrew.
Sent from the OpenSCAD mailing list archive at Nabble.com http://nabble.com/.
Me: http://clothbot.com/wiki/ http://clothbot.com/wiki/
It looks interesting.
It does have CSG operations. While reading about voxel based systems, I
found a claim that CSG is slow on voxel systems, compared to mesh systems,
and I found a forum post complaining about the speed of CSG operations in
OpenVDB. So this might not solve our speed problems with CGAL.
I didn't find any operations for convex hull or minkowski sum. It's not
obvious how you implement these without converting to a mesh first, which I
bet is slow.
It is described as a visual effects library, and the home page demos
effects like clouds, fog, dust clouds, particle based fluid simulations. If
this is the focus, then I'm not sure it will be efficient for our use
cases. We could try it and do some performance measurements.
I wonder what kind of 3D modelling operations are enabled by a voxel
engine, stuff that's difficult with our current mesh engine?
Ah, so it does:
Andrew.
not always robust.
Hey Everyone,
3D
Andrew.
http://nabble.com.
William Gibson
It does claim to be multithreaded, which i can belive as voxel operations
are easy to partition, i dont claim to have any expertice in this, my
graphics abilities are limited to 2d, i used to write postscript
rasterisation engines, which render down to a trapezoid list which is easy
to slice and hand out to different threads for operations like colour
correction and halftoning.
Given it does work on a different set of principles there will be
operations that are missing or sub optimimal, like wise there will be
aspects that are faster and open up new capabilities, its just a case of
determining what the tradeoffs are.
bet is slow.
Ah, so it does:
Andrew.
Hey Everyone,
for 3D
Andrew.
http://nabble.com.
William Gibson
Also you need to decide if the license is acceptable, it uses the Mozia
Public License, which is a mashup of the BSD License and the GPL V2
License.
bet is slow.
Ah, so it does:
Andrew.
Hey Everyone,
for 3D
Andrew.
http://nabble.com.
William Gibson
